[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-309-gd3f7885d8
Wed Sep 6 08:04:13 PDT 2023
the project "PostGIS".
       via  d3f7885d82baf21bf7041ce4b1c58f07beba55cd (commit)
      from  46762f988e7e45f5fc04a6df527bf687a85ec8b1 (commit)
revisions in full, below.
commit d3f7885d82baf21bf7041ce4b1c58f07beba55cd
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Sep 6 17:00:55 2023 +0200
    Add a `check-lint` Makefile target
    Allows running lint tests in isolation from the rest.
    This is because linting does not depend on PostgreSQL version
    so we could avoid running it for all versions in CI
    [CI skip]
diff --git a/GNUmakefile.in b/GNUmakefile.in
index e6ba14332..38aaf1221 100644
--- a/GNUmakefile.in
+++ b/GNUmakefile.in
@@ -65,12 +65,16 @@ clean-local:
 # TODO: drop 'test' target..
 test: check
-check: check-no-trailing-blanks check-unit docs-check check-news check-tests-enabled check-lang-enabled
+check: check-unit docs-check check-lint
 ifeq (@LIBLWGEOM_ONLY@,no)
 check: check-regress
 endif
+# The "lint" tests do not depend on specific code configurations
+# but solely on the source code state
+check-lint: check-no-trailing-blanks check-news check-tests-enabled check-lang-enabled
 staged-install: all
 	$(MAKE) -C regress staged-install
Summary of changes:
 GNUmakefile.in | 6 +++++-
 1 file changed, 5 insertions(+), 1 deletion(-)
hooks/post-receive
