[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-308-g46762f988
Wed Sep 6 04:01:09 PDT 2023
the project "PostGIS".
       via  46762f988e7e45f5fc04a6df527bf687a85ec8b1 (commit)
      from  d2e470e0be11d3a58296680dbf9a301dcfaca383 (commit)
revisions in full, below.
commit 46762f988e7e45f5fc04a6df527bf687a85ec8b1
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Sep 6 12:26:10 2023 +0200
    [woodie] Reduce code duplication for docs workflow
diff --git a/.woodpecker/docs-localized.yml.in b/.woodpecker/docs-localized.yml.in
index 2f3665785..48cbc8ba5 100644
--- a/.woodpecker/docs-localized.yml.in
+++ b/.woodpecker/docs-localized.yml.in
@@ -6,6 +6,7 @@
     when:
       path:
         include:
+          - <<: *common_doc_paths
           # Localized assets
           - "doc/po/@LANG@/Makefile.in"
           - "doc/po/@LANG@/*.po"
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index ca48078a2..8b8dfd0ac 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -1,32 +1,22 @@
 variables:
   - &test_image 'docker.osgeo.org/postgis/build-test:trisquel3'
+  - common_doc_paths: &common_doc_paths
+      # related config files
+      - ".woodpecker/docs.yml"
+      # Makefiles
+      - "doc/Makefile.in"
+      - "doc/html/images/Makefile.in"
+      # XML sources
+      - "doc/*.xml"
+      # Internationalization Makefiles
+      - "doc/po/Makefile.local"
   - &when_path
       include:
-        # Common docs path
-        # related config files
-        - ".woodpecker/docs.yml"
-        # Makefiles
-        - "doc/Makefile.in"
-        - "doc/html/images/Makefile.in"
-        # XML sources
-        - "doc/*.xml"
-        # Internationalization Makefiles
-        - "doc/po/Makefile.local"
-        # END OF COMMON PATHS
   - &when_path_full
       include:
-        # Makefiles
-        # XML sources
-        - "doc/*.xml"
-        # Localized assets
+        # Any localized assets
         - "doc/po/*/Makefile.in"
         - "doc/po/*/*.po"
@@ -94,21 +84,11 @@ steps:
     when:
       path:
         include:
           # Localized assets
           - "doc/po/ja/Makefile.in"
           - "doc/po/ja/*.po"
           - "utils/check_localized_cheatsheets.sh"
-          # Makefiles
-          # XML sources
-          - "doc/*.xml"
   check-xml-de:
     image: *test_image
     commands:
@@ -117,21 +97,11 @@ steps:
     when:
       path:
         include:
           # Localized assets
           - "doc/po/de/Makefile.in"
           - "doc/po/de/*.po"
-          # Makefiles
-          # XML sources
-          - "doc/*.xml"
   check-xml-fr:
     image: *test_image
     commands:
@@ -140,21 +110,11 @@ steps:
     when:
       path:
         include:
           # Localized assets
           - "doc/po/fr/Makefile.in"
           - "doc/po/fr/*.po"
-          # Makefiles
-          # XML sources
-          - "doc/*.xml"
 ### TARGET html
   html-ja:
     image: *test_image
@@ -164,21 +124,11 @@ steps:
     when:
       path:
         include:
           # Localized assets
           - "doc/po/ja/*.po"
-          # Makefiles
-          # XML sources
-          - "doc/*.xml"
   html-de:
     image: *test_image
     commands:
@@ -187,21 +137,11 @@ steps:
     when:
       path:
         include:
           # Localized assets
           - "doc/po/de/*.po"
-          # Makefiles
-          # XML sources
-          - "doc/*.xml"
   html-fr:
     image: *test_image
     commands:
@@ -210,21 +150,11 @@ steps:
     when:
       path:
         include:
           # Localized assets
           - "doc/po/fr/*.po"
-          # Makefiles
-          # XML sources
-          - "doc/*.xml"
 ### TARGET cheatsheets
   cheatsheets-ja:
     image: *test_image
@@ -234,21 +164,11 @@ steps:
     when:
       path:
         include:
           # Localized assets
           - "doc/po/ja/*.po"
-          # Makefiles
-          # XML sources
-          - "doc/*.xml"
   cheatsheets-de:
     image: *test_image
     commands:
@@ -257,21 +177,11 @@ steps:
     when:
       path:
         include:
           # Localized assets
           - "doc/po/de/*.po"
-          # Makefiles
-          # XML sources
-          - "doc/*.xml"
   cheatsheets-fr:
     image: *test_image
     commands:
@@ -280,21 +190,11 @@ steps:
     when:
       path:
         include:
           # Localized assets
           - "doc/po/fr/*.po"
-          # Makefiles
-          # XML sources
-          - "doc/*.xml"
 ### TARGET check-cheatsheets
   check-cheatsheets-ja:
     image: *test_image
@@ -304,21 +204,11 @@ steps:
     when:
       path:
         include:
           # Localized assets
           - "doc/po/ja/*.po"
-          # Makefiles
-          # XML sources
-          - "doc/*.xml"
   check-cheatsheets-de:
     image: *test_image
     commands:
@@ -327,21 +217,11 @@ steps:
     when:
       path:
         include:
           # Localized assets
           - "doc/po/de/*.po"
-          # Makefiles
-          # XML sources
-          - "doc/*.xml"
   check-cheatsheets-fr:
     image: *test_image
     commands:
@@ -350,21 +230,11 @@ steps:
     when:
       path:
         include:
           # Localized assets
           - "doc/po/fr/*.po"
-          # Makefiles
-          # XML sources
-          - "doc/*.xml"
 ### TARGET pdf
   pdf-ja:
     image: *test_image
@@ -374,21 +244,11 @@ steps:
     when:
       path:
         include:
           # Localized assets
           - "doc/po/ja/*.po"
-          # Makefiles
-          # XML sources
-          - "doc/*.xml"
   pdf-de:
     image: *test_image
     commands:
@@ -397,21 +257,11 @@ steps:
     when:
       path:
         include:
           # Localized assets
           - "doc/po/de/*.po"
-          # Makefiles
-          # XML sources
-          - "doc/*.xml"
   pdf-fr:
     image: *test_image
     commands:
@@ -420,18 +270,8 @@ steps:
     when:
       path:
         include:
           # Localized assets
           - "doc/po/fr/*.po"
-          # Makefiles
-          # XML sources
-          - "doc/*.xml"
diff --git a/.woodpecker/update-docs-localized.sh b/.woodpecker/update-docs-localized.sh
index 991b4ec31..131fbe067 100755
--- a/.woodpecker/update-docs-localized.sh
+++ b/.woodpecker/update-docs-localized.sh
@@ -9,10 +9,6 @@ TARGETS="check-xml html cheatsheets check-cheatsheets pdf"
 cat docs.yml | sed '/DO NOT EDIT/q' > docs.yml.new
-cat docs.yml.new |
-  sed '/# Common docs path/,/# END OF COMMON/!d;/# END OF COMMON/q' |
-  sed 's/^/  /' > docs.yml.common_paths
 exec >> docs.yml.new
 for target in ${TARGETS}
 do
@@ -21,10 +17,7 @@ do
   do
     group=localized-${target}
     sed "s/@LANG@/${lang}/;s/@TARGET@/${target}/;s/@GROUP@/${group}/" docs-localized.yml.in
-    # Add common docs paths
-    cat docs.yml.common_paths
   done
 done
 mv -b docs.yml.new docs.yml
-rm docs.yml.common_paths
Summary of changes:
 .woodpecker/docs-localized.yml.in    |   1 +
 .woodpecker/docs.yml                 | 216 +++++------------------------------
 .woodpecker/update-docs-localized.sh |   7 --
 3 files changed, 29 insertions(+), 195 deletions(-)
hooks/post-receive
