[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-361-g565d8bce2
Sat Sep 9 00:07:59 PDT 2023
the project "PostGIS".
       via  565d8bce2da937c30261db762a7704636ffb683d (commit)
       via  07458345aa77aa850f03df2b57eb9e142a4da24c (commit)
      from  57cb19bc551a07b6e2c0e3ad3c0f729931049e02 (commit)
revisions in full, below.
commit 565d8bce2da937c30261db762a7704636ffb683d
Author: Regina Obe <lr at pcorp.us>
Date:   Sat Sep 9 03:07:51 2023 -0400
    Add another example for ST_GeneratePoints using ST_DumpPoints
diff --git a/doc/reference_processing.xml b/doc/reference_processing.xml
index f6040a5e4..b0630b1b3 100644
--- a/doc/reference_processing.xml
+++ b/doc/reference_processing.xml
@@ -1270,7 +1270,7 @@ result
       <refnamediv>
         <refname>ST_GeneratePoints</refname>
-        <refpurpose>Generates random points contained in a Polygon or MultiPolygon.</refpurpose>
+        <refpurpose>Generates a multipoint of random points contained in a Polygon or MultiPolygon.</refpurpose>
       </refnamediv>
       <refsynopsisdiv>
@@ -1300,7 +1300,7 @@ result
         <title>Description</title>
         <para>
-            ST_GeneratePoints generates a given number of pseudo-random points
+            ST_GeneratePoints generates a multipoint consisting of a given number of pseudo-random points
             which lie within the input area.
             The optional <varname>seed</varname> is used to regenerate a deterministic sequence of points,
             and must be greater than zero.
@@ -1318,7 +1318,7 @@ result
                           <imageobject>
                             <imagedata fileref="images/st_generatepoints01.png" />
                           </imageobject>
-                          <caption><para>Generated 12 Points overlaid on top of original polygon using a random seed value 1996</para></caption>
+                          <caption><para>Generated a multipoint consisting of 12 Points overlaid on top of original polygon using a random seed value 1996</para></caption>
                         </mediaobject>
                       </informalfigure>
                         <programlisting>SELECT ST_GeneratePoints(geom, 12, 1996)
@@ -1329,6 +1329,13 @@ FROM (
         10, 'endcap=round join=round') AS geom
 ) AS s;</programlisting>
             </para>
+<para>Given a table of polygons s, return 12 individual points per polygon. Results will be different each time you run.</para>
+<programlisting>SELECT s.id, dp.path[1] AS pt_id, dp.geom
+FROM s, ST_DumpPoints(ST_GeneratePoints(s.geom,12)) AS dp;</programlisting>
+        </refsection>
+        <refsection>
+          <title>See Also</title>
+          <para><xref linkend="ST_DumpPoints"/></para>
         </refsection>
     </refentry>
commit 07458345aa77aa850f03df2b57eb9e142a4da24c
Date:   Sat Sep 9 02:57:09 2023 -0400
    Cleanup of winnie's scripts
diff --git a/ci/winnie/regress_postgis.sh b/ci/winnie/regress_postgis.sh
index 9906d5659..6da211b7f 100644
--- a/ci/winnie/regress_postgis.sh
+++ b/ci/winnie/regress_postgis.sh
@@ -9,9 +9,6 @@ echo PATH AFTER: $PATH
 export PGWINVER=${PG_VER}edb
 export WORKSPACE=`pwd`
-export PGPATH=${PROJECTS}/postgresql/rel/pg${PG_VER}w${OS_BUILD}${GCC_TYPE}
-export PGPATHEDB=${PROJECTS}/postgresql/rel/pg${PG_VER}w${OS_BUILD}${GCC_TYPE}edb
 export POSTGIS_VER=${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
 export POSTGIS_MICRO_VER=${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}
@@ -64,8 +61,7 @@ if [ -n "$PCRE_VER" ]; then
 fi
-if [$INCLUDE_MINOR_LIB == "1"]; then
+if [[ "${INCLUDE_MINOR_LIB}" == "1" ]] ; then
 #CPPFLAGS="-I${PGPATH}/include -I${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include" \
 #CFLAGS="-Wall -fno-omit-frame-pointer"
@@ -73,7 +69,7 @@ if [$INCLUDE_MINOR_LIB == "1"]; then
 #LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib -L${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib" \
-LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${LZ4_PATH}/bin -L${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib -L${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib" \
+LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${LZ4_PATH}/lib -L${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib -L${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib" \
 ./configure \
   --host=${MINGHOST} --with-xml2config=${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin/xml2-config  \
   --with-pgconfig=${PGPATH}/bin/pg_config \
diff --git a/ci/winnie/winnie_common.sh b/ci/winnie/winnie_common.sh
index c01b9a1d5..ab62b4e5f 100644
--- a/ci/winnie/winnie_common.sh
+++ b/ci/winnie/winnie_common.sh
@@ -67,8 +67,10 @@ export BOOST_VER_WU=1_78_0
 export LZ4_PATH=${PROJECTS}/lz4/rel-lz4-${LZ4_VER}w${OS_BUILD}${GCC_TYPE}
+echo ${PATH}
-export PATH="${PROJECTS}/CGAL/rel-cgal-${CGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/boost/rel-${BOOST_VER_WU}w${OS_BUILD}${GCC_TYPE}/lib:${LZ4_PATH}/bin:${LZ4_PATH}/lib:${PATH}"
+PATH="/mingw64/bin:/usr/local/bin:/usr/bin:/bin:/c/Windows/System32:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl"
+export PATH="${PROJECTS}/CGAL/rel-cgal-${CGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/boost/rel-${BOOST_VER_WU}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
 #export GDAL_VER=2.4.0
 #export PROJ_VER=5.2.0
@@ -78,7 +80,7 @@ echo "LIBXML_VER $LIBXML_VER"
 echo "CGAL_VER $CGAL_VER"
 export PROJECTS=/projects
 export MINGPROJECTS=/projects
-export PATHOLD=$PATH
 if [ "$OS_BUILD" == "64" ] ; then
 	export MINGHOST=x86_64-w64-mingw32
@@ -111,9 +113,9 @@ export PGPATHEDB=${PROJECTS}/postgresql/rel/pg${PG_VER}w${OS_BUILD}${GCC_TYPE}ed
 export GDAL_DATA="${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/share/gdal"
-export PATH="${PATHOLD}:${PGPATH}/bin:${PGPATH}/lib"
+export PATH="${PGPATH}/bin:${PGPATH}/lib:${PATH}"
 export PATH="${PROJECTS}/xsltproc:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJ_PATH}/bin:${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
-export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJ_PATH}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:/mingw/${MINGHOST}/lib/pkgconfig"
+export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJ_PATH}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:/mingw/${MINGHOST}/lib/pkgconfig"
 export SHLIB_LINK="-static-libstdc++ -lstdc++ -Wl,-Bdynamic -lm"
@@ -122,15 +124,13 @@ CPPFLAGS="-I${PGPATH}/include -I${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}
 #add protobuf
 export PATH="${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
+export PATH="${PATH}:${PGPATH}/bin:${PGPATH}/lib"
 #add lz4
 export PATH="${LZ4_PATH}/bin:${LZ4_PATH}/lib:${PATH}"
-echo $PATH
-export PATH="${PROJECTS}/xsltproc:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
-export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${LZ4_PATH}/lib/pkgconfig"
 #add protobuf
@@ -139,5 +139,5 @@ export PATH="${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/bin
 echo "PATH AFTER: $PATH"
 if  [[ "${INCLUDE_MINOR_LIB}" == '' ]] ; then
-	export INCLUDE_MINOR_LIB=true
+	export INCLUDE_MINOR_LIB=1
 fi;
Summary of changes:
 ci/winnie/regress_postgis.sh |  8 ++------
 ci/winnie/winnie_common.sh   | 18 +++++++++---------
 doc/reference_processing.xml | 13 ++++++++++---
 3 files changed, 21 insertions(+), 18 deletions(-)
hooks/post-receive
