[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-365-gb74322912
Sat Sep 9 00:37:47 PDT 2023
the project "PostGIS".
       via  b74322912e5321e6df5bcbe0457cb40e8117bbdd (commit)
       via  4eeb3732e6eaa1e33862281c8d870a42b51c03e7 (commit)
       via  bc8c2e589d60172b76f5ce436361ba4b4eca9f82 (commit)
       via  edd468ef5d5a6b0894b8554b20491f2e12630542 (commit)
      from  565d8bce2da937c30261db762a7704636ffb683d (commit)
revisions in full, below.
commit b74322912e5321e6df5bcbe0457cb40e8117bbdd
Author: Zuochenwei <zuochenwei5 at gmail.com>
Date:   Fri Sep 8 08:27:52 2023 +0000
    Translated using Weblate (Chinese (Simplified))
    Currently translated at 100.0% (79 of 79 strings)
    Translation: postgis/reference_lrs.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_lrsxml/zh_Hans/
diff --git a/doc/po/zh_Hans/reference_lrs.xml.po b/doc/po/zh_Hans/reference_lrs.xml.po
index 645edeb58..d0ab87959 100644
--- a/doc/po/zh_Hans/reference_lrs.xml.po
+++ b/doc/po/zh_Hans/reference_lrs.xml.po
@@ -6,7 +6,7 @@ msgstr ""
 "Project-Id-Version: build-pg 13\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2023-07-29 10:57+0000\n"
-"PO-Revision-Date: 2023-09-08 07:58+0000\n"
+"PO-Revision-Date: 2023-09-09 07:37+0000\n"
 "Last-Translator: Zuochenwei <zuochenwei5 at gmail.com>\n"
 "Language-Team: Chinese (Simplified) <https://weblate.osgeo.org/projects/"
 "postgis/reference_lrsxml/zh_Hans/>\n"
@@ -478,13 +478,13 @@ msgstr "仅对具有 M 分量的线性几何使用此函数"
 msgid ""
 "The semantic is specified by the <emphasis>ISO/IEC 13249-3 SQL/MM Spatial</"
 "emphasis> standard."
-msgstr ""
+msgstr "语义由 <emphasis>ISO/IEC 13249-3 SQL/MM 空间</emphasis>标准指定。"
 #. Tag: para
 #: reference_lrs.xml:413
 #, no-c-format
 msgid "Availability: 1.1.0 by old name ST_Locate_Along_Measure."
-msgstr ""
+msgstr "可用性:1.1.0(旧名称 ST_Locate_Along_Measure)。"
 #. Tag: para
 #: reference_lrs.xml:414
@@ -492,13 +492,13 @@ msgstr ""
 msgid ""
 "Changed: 2.0.0 in prior versions this used to be called "
 "ST_Locate_Along_Measure."
-msgstr ""
+msgstr "更改:2.0.0 在之前的版本中,这曾经被称为 ST_Locate_Along_Measure。"
 #. Tag: para
 #: reference_lrs.xml:417
 #, no-c-format
 msgid "&sqlmm_compliant; SQL-MM IEC 13249-3: 5.1.13"
-msgstr ""
+msgstr "&sqlmm_compliant; SQL-MM IEC 13249-3: 5.1.13"
 #. Tag: para
 #: reference_lrs.xml:429
@@ -507,12 +507,14 @@ msgid ""
 ", <xref linkend=\"ST_LocateBetweenElevations\"/>, <xref "
 "linkend=\"ST_InterpolatePoint\"/>"
 msgstr ""
+", <xref linkend=\"ST_LocateBetweenElevations\"/>, <xref linkend="
+"\"ST_InterpolatePoint\"/>"
 #. Tag: refpurpose
 #: reference_lrs.xml:437
 #, no-c-format
 msgid "Returns the portions of a geometry that match a measure range."
-msgstr ""
+msgstr "返回与测量范围匹配的几何图形部分。"
 #. Tag: funcprototype
 #: reference_lrs.xml:442
@@ -532,7 +534,8 @@ msgstr ""
 msgid ""
 "Return a geometry (collection) with the portions of the input measured "
 "geometry that match the specified measure range (inclusively)."
-msgstr ""
+msgstr "返回一个几何图形(集合),其中包含与指定测量范围(包含)匹配的输入测量几何图"
+"形部分。"
 #. Tag: para
 #: reference_lrs.xml:459
@@ -541,19 +544,20 @@ msgid ""
 "If the <varname>offset</varname> is provided, the result is offset to the "
 "left or right of the input line by the specified distance. A positive offset "
 "will be to the left, and a negative one to the right."
-msgstr ""
+msgstr "如果提供了<varname>偏移量</varname>,则结果将向输入行的左侧或右侧偏移指定的距"
+"离。 正偏移量将向左偏移,负偏移量将向右偏移。"
 #. Tag: para
 #: reference_lrs.xml:463 reference_lrs.xml:526
 #, no-c-format
 msgid "Clipping a non-convex POLYGON may produce invalid geometry."
-msgstr ""
+msgstr "裁剪非凸多边形可能会产生无效的几何图形。"
 #. Tag: para
 #: reference_lrs.xml:467
 #, no-c-format
 msgid "Availability: 1.1.0 by old name ST_Locate_Between_Measures."
-msgstr ""
+msgstr "可用性:1.1.0(旧名称 ST_Locate_Between_Measures)。"
 #. Tag: para
 #: reference_lrs.xml:468
@@ -561,13 +565,13 @@ msgstr ""
 msgid ""
 "Changed: 2.0.0 - in prior versions this used to be called "
 "ST_Locate_Between_Measures."
-msgstr ""
+msgstr "更改:2.0.0 - 在之前的版本中,这曾经被称为 ST_Locate_Between_Measures。"
 #. Tag: para
 #: reference_lrs.xml:469 reference_lrs.xml:529
 #, no-c-format
 msgid "Enhanced: 3.0.0 - added support for POLYGON, TIN, TRIANGLE."
-msgstr ""
+msgstr "增强:3.0.0 - 添加了对多边形、TIN、三角形的支持。"
 #. Tag: para
 #: reference_lrs.xml:472
@@ -580,19 +584,19 @@ msgstr "&sqlmm_compliant; SQL-MM IEC 13249-3: 5.1"
 #, no-c-format
 msgid ""
 "A LineString with the section between measures 2 and 8, offset to the left"
-msgstr ""
+msgstr "一个 LineString,其部分位于小节 2 和小节 8 之间,向左偏移"
 #. Tag: para
 #: reference_lrs.xml:496
 #, no-c-format
 msgid ", <xref linkend=\"ST_LocateBetweenElevations\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"ST_LocateBetweenElevations\"/>"
 #. Tag: refpurpose
 #: reference_lrs.xml:504
 #, no-c-format
 msgid "Returns the portions of a geometry that lie in an elevation (Z) range."
-msgstr ""
+msgstr "返回位于高程 (Z) 范围内的几何图形部分。"
 #: reference_lrs.xml:510
@@ -611,7 +615,7 @@ msgstr ""
 msgid ""
 "Returns a geometry (collection) with the portions of a geometry that lie in "
 "an elevation (Z) range."
-msgstr ""
+msgstr "返回一个几何图形(集合),其中包含位于高程 (Z) 范围内的几何图形部分。"
 #. Tag: para
 #: reference_lrs.xml:528
@@ -623,13 +627,13 @@ msgstr "可用性:1.4.0"
 #: reference_lrs.xml:543
 #, no-c-format
 msgid ", <xref linkend=\"ST_LocateBetween\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"ST_LocateBetween\"/>"
 #. Tag: refpurpose
 #: reference_lrs.xml:552
 #, no-c-format
 msgid "Returns the interpolated measure of a geometry closest to a point."
-msgstr ""
+msgstr "返回最接近点的几何图形的插值测量值。"
 #: reference_lrs.xml:557
@@ -647,7 +651,7 @@ msgstr ""
 msgid ""
 "Returns an interpolated measure value of a linear measured geometry at the "
 "location closest to the given point."
-msgstr ""
+msgstr "返回最接近给定点的位置处的线性测量几何图形的插值测量值。"
 #. Tag: para
 #: reference_lrs.xml:574
@@ -661,12 +665,13 @@ msgstr "可用性: 2.0.0"
 msgid ""
 ", <xref linkend=\"ST_LocateAlong\"/>, <xref linkend=\"ST_LocateBetween\"/>"
 msgstr ""
+", <xref linkend=\"ST_LocateAlong\"/>, <xref linkend=\"ST_LocateBetween\"/>"
 #. Tag: refpurpose
 #: reference_lrs.xml:598
 #, no-c-format
 msgid "Interpolates measures along a linear geometry."
-msgstr ""
+msgstr "沿线性几何形状插值测量值。"
 #: reference_lrs.xml:603
@@ -688,6 +693,10 @@ msgid ""
 "added. If the geometry has a measure dimension, it is over-written with new "
 "values. Only LINESTRINGS and MULTILINESTRINGS are supported."
 msgstr ""
+"返回派生几何图形,其测量值在起点和终点之间线性插值。 "
+"如果几何图形没有测量尺寸,则添加一个。 "
+"如果几何图形具有测量尺寸,则会用新值覆盖它。 仅支持 LINESTRINGS 和 "
+"MULTILINESTRINGS。"
 #. Tag: para
 #: reference_lrs.xml:618
commit 4eeb3732e6eaa1e33862281c8d870a42b51c03e7
Date:   Fri Sep 8 08:43:59 2023 +0000
    Currently translated at 100.0% (22 of 22 strings)
    Translation: postgis/reference_trajectory.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_trajectoryxml/zh_Hans/
diff --git a/doc/po/zh_Hans/reference_trajectory.xml.po b/doc/po/zh_Hans/reference_trajectory.xml.po
index fe81f3ece..13220d7c2 100644
--- a/doc/po/zh_Hans/reference_trajectory.xml.po
+++ b/doc/po/zh_Hans/reference_trajectory.xml.po
 "POT-Creation-Date: 2023-07-18 20:22+0000\n"
-"PO-Revision-Date: 2023-09-05 05:07+0000\n"
 "postgis/reference_trajectoryxml/zh_Hans/>\n"
@@ -15,7 +15,7 @@ msgstr ""
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
 "Plural-Forms: nplurals=1; plural=0;\n"
-"X-Generator: Weblate 4.16.4\n"
+"X-Generator: Weblate 5.0\n"
 #. Tag: para
 #: reference_trajectory.xml:5
@@ -25,19 +25,20 @@ msgid ""
 "geometry with increasing measures (M value) on each coordinate. Spatio-"
 "temporal data can be modeled by using relative times (such as the epoch) as "
 "the measure values."
-msgstr ""
+msgstr "这些函数支持处理轨迹。 轨迹是每个坐标上具有递增度量(M 值)的线性几何。 "
+"时空数据可以使用相对时间(例如历元)作为度量值来建模。"
 #. Tag: title
 #: reference_trajectory.xml:12
 #, no-c-format
 msgid "Trajectory Functions"
-msgstr ""
+msgstr "轨迹函数"
 #. Tag: refpurpose
 #: reference_trajectory.xml:18
 #, no-c-format
 msgid "Tests if the geometry is a valid trajectory."
-msgstr ""
+msgstr "测试几何图形是否为有效轨迹。"
 #: reference_trajectory.xml:23
@@ -62,6 +63,8 @@ msgid ""
 "represented as a <varname>LINESTRING</varname> with measures (M values). The "
 "measure values must increase from each vertex to the next."
 msgstr ""
+"测试几何体是否编码有效的轨迹。 有效轨迹表示为带有度量(M 值)的<varname> "
+"LINESTRING</varname>。 测量值必须从每个顶点到下一个顶点增加。"
 #. Tag: para
 #: reference_trajectory.xml:38
@@ -69,7 +72,8 @@ msgstr ""
 msgid ""
 "Valid trajectories are expected as input to spatio-temporal functions like "
 "<xref linkend=\"ST_ClosestPointOfApproach\"/>"
-msgstr ""
+msgstr "预计有效轨迹作为时空函数(如 <xref linkend=\"ST_ClosestPointOfApproach\""
+"/>)的输入"
 #. Tag: para
 #: reference_trajectory.xml:42 reference_trajectory.xml:97
@@ -103,7 +107,7 @@ msgstr "相关信息"
 #: reference_trajectory.xml:64
 #, no-c-format
 msgid "Returns a measure at the closest point of approach of two trajectories."
-msgstr ""
+msgstr "返回两条轨迹最接近点处的测量值。"
 #: reference_trajectory.xml:71
@@ -120,7 +124,7 @@ msgstr ""
 msgid ""
 "Returns the smallest measure at which points interpolated along the given "
 "trajectories are at the smallest distance."
-msgstr ""
+msgstr "返回沿给定轨迹插值的点距离最小的最小测量值。"
 #. Tag: para
 #: reference_trajectory.xml:86 reference_trajectory.xml:142
@@ -130,6 +134,8 @@ msgid ""
 "linkend=\"ST_IsValidTrajectory\"/>. Null is returned if the trajectories do "
 "not overlap in their M ranges."
 msgstr ""
+"输入必须是经 <xref linkend=\"ST_IsValidTrajectory\"/> 检查的有效轨迹。 "
+"如果轨迹在其 M 范围内不重叠,则返回 Null。"
 #. Tag: para
 #: reference_trajectory.xml:92
@@ -137,7 +143,7 @@ msgstr ""
 msgid ""
 "See <xref linkend=\"ST_LocateAlong\"/> for getting the actual points at the "
 "given measure."
-msgstr ""
+msgstr "请参阅 <xref linkend=\"ST_LocateAlong\"/>以获取给定测量处的实际点。"
 #. Tag: para
 #: reference_trajectory.xml:108
@@ -146,6 +152,8 @@ msgid ""
 ", <xref linkend=\"ST_DistanceCPA\"/>, <xref linkend=\"ST_LocateAlong\"/>, "
 "<xref linkend=\"ST_AddMeasure\"/>"
 msgstr ""
+", <xref linkend=\"ST_DistanceCPA\"/>, <xref linkend=\"ST_LocateAlong\"/>, "
+"<xref linkend=\"ST_AddMeasure\"/>"
 #. Tag: refpurpose
 #: reference_trajectory.xml:121
@@ -153,7 +161,7 @@ msgstr ""
 msgid ""
 "Returns the distance between the closest point of approach of two "
 "trajectories."
-msgstr ""
+msgstr "返回两条轨迹的最近接近点之间的距离。"
 #: reference_trajectory.xml:128
@@ -169,7 +177,7 @@ msgstr ""
 #, no-c-format
 msgid ""
 "Returns the minimum distance two moving objects have ever been each other."
-msgstr ""
+msgstr "返回两个移动对象彼此之间的最小距离。"
 #. Tag: para
 #: reference_trajectory.xml:160
@@ -178,6 +186,8 @@ msgid ""
 ", <xref linkend=\"ST_ClosestPointOfApproach\"/>, <xref "
 "linkend=\"ST_AddMeasure\"/>, <xref linkend=\"geometry_distance_cpa\"/>"
 msgstr ""
+", <xref linkend=\"ST_ClosestPointOfApproach\"/>, <xref linkend="
+"\"ST_AddMeasure\"/>, <xref linkend=\"geometry_distance_cpa\"/>"
 #. Tag: refpurpose
 #: reference_trajectory.xml:173
@@ -185,7 +195,7 @@ msgstr ""
 msgid ""
 "Tests if the closest point of approach of two trajectories is within the "
 "specified distance."
-msgstr ""
+msgstr "测试两条轨迹的最近接近点是否在指定距离内。"
 #: reference_trajectory.xml:181
@@ -203,7 +213,7 @@ msgstr ""
 msgid ""
 "Tests whether two moving objects have ever been closer than the specified "
 "distance."
-msgstr ""
+msgstr "测试两个移动物体是否曾经比指定距离更近。"
 #. Tag: para
 #: reference_trajectory.xml:196
@@ -213,6 +223,8 @@ msgid ""
 "linkend=\"ST_IsValidTrajectory\"/>. False is returned if the trajectories do "
 msgstr ""
+"如果轨迹在其 M 范围内不重叠,则返回 False。"
 #. Tag: para
 #: reference_trajectory.xml:215
@@ -221,3 +233,5 @@ msgid ""
 "linkend=\"ST_DistanceCPA\"/>, <xref linkend=\"geometry_distance_cpa\"/>"
 msgstr ""
+"\"ST_DistanceCPA\"/>, <xref linkend=\"geometry_distance_cpa\"/>"
commit bc8c2e589d60172b76f5ce436361ba4b4eca9f82
Date:   Fri Sep 8 08:50:46 2023 +0000
    Currently translated at 29.4% (33 of 112 strings)
    Translation: postgis/reference_sfcgal.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_sfcgalxml/zh_Hans/
diff --git a/doc/po/zh_Hans/reference_sfcgal.xml.po b/doc/po/zh_Hans/reference_sfcgal.xml.po
index 27f4604f7..372147448 100644
--- a/doc/po/zh_Hans/reference_sfcgal.xml.po
+++ b/doc/po/zh_Hans/reference_sfcgal.xml.po
@@ -7,7 +7,7 @@ msgstr ""
 "postgis/reference_sfcgalxml/zh_Hans/>\n"
@@ -25,7 +25,8 @@ msgid ""
 "SFCGAL is a C++ wrapper library around CGAL that provides advanced 2D and 3D "
 "spatial functions. For robustness, geometry coordinates have an exact "
 "rational number representation."
-msgstr ""
+msgstr "SFCGAL是CGAL的C++封装库,提供高级的二维和三维空间函数。为了确保稳健性,几何坐"
+"标具有精确的有理数表示。"
 #. Tag: para
 #: reference_sfcgal.xml:9
@@ -35,24 +36,27 @@ msgid ""
 "page (<ulink url=\"http://www.sfcgal.org\">http://www.sfcgal.org</ulink>). "
 "To enable the functions use <code>create extension postgis_sfcgal</code>."
 msgstr ""
+"该库的安装说明可以在 SFCGAL 主页 (<ulink url=\"http://www.sfcgal.org\""
+">http://www.sfcgal.org</ulink>) 上找到。 要启用这些功能,请使用<code>create "
+"extension postgis_sfcgal</code>。"
 #. Tag: title
 #: reference_sfcgal.xml:16
 #, no-c-format
 msgid "SFCGAL Functions"
-msgstr ""
+msgstr "SFCGAL 函数"
 #. Tag: refpurpose
 #: reference_sfcgal.xml:21
 #, no-c-format
 msgid "<refpurpose>Returns the version of SFCGAL in use</refpurpose>"
-msgstr ""
+msgstr "<refpurpose>返回正在使用的 SFCGAL 版本</refpurpose>"
 #. Tag: funcdef
 #: reference_sfcgal.xml:27
 #, no-c-format
 msgid "text <function>postgis_sfcgal_version</function>"
-msgstr ""
+msgstr "文本 <function>postgis_sfcgal_version</function>描述"
 #. Tag: title
 #: reference_sfcgal.xml:34 reference_sfcgal.xml:69 reference_sfcgal.xml:104
@@ -71,7 +75,7 @@ msgstr "描述"
 #: reference_sfcgal.xml:36
 #, no-c-format
 msgid "<para>Returns the version of SFCGAL in use</para>"
-msgstr ""
+msgstr "<para>返回正在使用的 SFCGAL 版本</para>"
 #. Tag: para
 #: reference_sfcgal.xml:38 reference_sfcgal.xml:106 reference_sfcgal.xml:195
@@ -93,7 +97,7 @@ msgstr "可用性:2.1.0"
 #: reference_sfcgal.xml:1255
 #, no-c-format
 msgid "&sfcgal_required;"
-msgstr ""
+msgstr "&sfcgal_required;"
 #. Tag: para
 #: reference_sfcgal.xml:40 reference_sfcgal.xml:75 reference_sfcgal.xml:109
@@ -145,13 +149,14 @@ msgstr "相关信息"
 msgid ""
 "<refpurpose>Returns the full version of SFCGAL in use including CGAL and "
 "Boost versions</refpurpose>"
-msgstr ""
+msgstr "<refpurpose>返回正在使用的 SFCGAL 的完整版本,包括 CGAL 和 Boost "
+"版本</refpurpose>"
 #. Tag: funcdef
 #: reference_sfcgal.xml:62
 #, no-c-format
 msgid "text <function>postgis_sfcgal_full_version</function>"
-msgstr ""
+msgstr "文本<function>postgis_sfcgal_full_version</function>"
 #. Tag: para
 #: reference_sfcgal.xml:71
@@ -159,7 +164,7 @@ msgstr ""
 msgid ""
 "<para>Returns the full version of SFCGAL in use including CGAL and Boost "
 "versions</para>"
-msgstr ""
+msgstr "<para>返回正在使用的 SFCGAL 的完整版本,包括 CGAL 和 Boost 版本</para>"
 #. Tag: para
 #: reference_sfcgal.xml:73 reference_sfcgal.xml:145
@@ -171,7 +176,7 @@ msgstr "可用性: 3.3.0"
 #: reference_sfcgal.xml:91
 #, no-c-format
 msgid "Computes area of 3D surface geometries. Will return 0 for solids."
-msgstr ""
+msgstr "计算 3D 表面几何形状的面积。 对于固体将返回 0。"
 #: reference_sfcgal.xml:96
@@ -185,7 +190,7 @@ msgstr ""
 #: reference_sfcgal.xml:108
 #, no-c-format
 msgid "&sqlmm_compliant; SQL-MM IEC 13249-3: 8.1, 10.5"
-msgstr ""
+msgstr "&sqlmm_compliant; SQL-MM IEC 13249-3: 8.1, 10.5"
 #. Tag: title
 #: reference_sfcgal.xml:114 reference_sfcgal.xml:153 reference_sfcgal.xml:204
@@ -204,6 +209,8 @@ msgid ""
 "Note: By default a PolyhedralSurface built from WKT is a surface geometry, "
 "not solid. It therefore has surface area. Once converted to a solid, no area."
 msgstr ""
+"注意:默认情况下,从 WKT 构建的 PolyhedralSurface 是曲面几何体,而不是实体。 "
+"因此它具有表面积。 一旦转换为实体,就没有面积了。"
 #. Tag: para
 #: reference_sfcgal.xml:122
@@ -212,12 +219,14 @@ msgid ""
 ", <xref linkend=\"ST_MakeSolid\"/>, <xref linkend=\"ST_IsSolid\"/>, <xref "
 "linkend=\"ST_Area\"/>"
 msgstr ""
+", <xref linkend=\"ST_MakeSolid\"/>, <xref linkend=\"ST_IsSolid\"/>, <xref "
+"linkend=\"ST_Area\"/>"
 #. Tag: refpurpose
 #: reference_sfcgal.xml:130
 #, no-c-format
 msgid "Computes the 3D convex hull of a geometry."
-msgstr ""
+msgstr "计算几何体的 3D 凸包。"
 #: reference_sfcgal.xml:135
@@ -231,19 +240,19 @@ msgstr ""
 #: reference_sfcgal.xml:164
 #, no-c-format
 msgid "Original geometry overlaid with 3D convex hull"
-msgstr ""
+msgstr "原始几何体覆盖 3D 凸包"
 #. Tag: para
 #: reference_sfcgal.xml:171
 #, no-c-format
 msgid ", <xref linkend=\"ST_AsX3D\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"ST_AsX3D\"/>"
 #. Tag: refpurpose
 #: reference_sfcgal.xml:179
 #, no-c-format
 msgid "Perform 3D intersection"
-msgstr ""
+msgstr "执行 3D 相交"
 #: reference_sfcgal.xml:184
@@ -258,7 +267,7 @@ msgstr ""
 #: reference_sfcgal.xml:194
 #, no-c-format
 msgid "Return a geometry that is the shared portion between geom1 and geom2."
-msgstr ""
+msgstr "返回作为 geom1 和 geom2 之间共享部分的几何图形。"
 #. Tag: para
 #: reference_sfcgal.xml:197 reference_sfcgal.xml:274 reference_sfcgal.xml:355
@@ -275,12 +284,14 @@ msgid ""
 "rendering in HTML using <ulink url=\"http://www.x3dom.org\">X3Dom HTML "
 "Javascript rendering library</ulink>."
 msgstr ""
+"3D 图像是使用 <xref linkend=\"ST_AsX3D\"/>生成的,并使用<ulink url=\"http"
+"://www.x3dom.org\"> X3Dom HTML Javascript 渲染库</ulink>以 HTML 形式渲染。"
 #. Tag: para
 #: reference_sfcgal.xml:217
 #, no-c-format
 msgid "Original 3D geometries overlaid. geom2 is shown semi-transparent"
-msgstr ""
+msgstr "原始 3D 几何图形叠加。 geom2 显示为半透明"
 #. Tag: para
 #: reference_sfcgal.xml:228
commit edd468ef5d5a6b0894b8554b20491f2e12630542
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Sep 8 17:00:46 2023 +0000
    Translated using Weblate (Italian)
    Currently translated at 20.1% (45 of 223 strings)
    Translation: postgis/introduction.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/introductionxml/it/
diff --git a/doc/po/it_IT/introduction.xml.po b/doc/po/it_IT/introduction.xml.po
index 38076d5de..e3a822e8f 100644
--- a/doc/po/it_IT/introduction.xml.po
+++ b/doc/po/it_IT/introduction.xml.po
@@ -4,8 +4,8 @@
 # pibinko <pibinko at gmail.com>, 2013
 # Sandro Santilli <strk.io>, 2014
-# Sandro Santilli <strk at kbt.io>, 2014
+# Sandro Santilli <strk at kbt.io>, 2014, 2023.
 # Stefano Costa <steko at iosa.it>, 2013
 # Regina Obe <regina at arrival3d.com>, 2023.
 msgid ""
@@ -13,8 +13,8 @@ msgstr ""
 "Project-Id-Version: PostGIS\n"
 "POT-Creation-Date: 2023-08-12 00:40+0000\n"
-"PO-Revision-Date: 2023-08-28 12:08+0000\n"
-"Last-Translator: Regina Obe <regina at arrival3d.com>\n"
+"Last-Translator: Sandro Santilli <strk at kbt.io>\n"
 "Language-Team: Italian <https://weblate.osgeo.org/projects/postgis/"
 "introductionxml/it/>\n"
 "Language: it_IT\n"
@@ -22,7 +22,7 @@ msgstr ""
 "Plural-Forms: nplurals=2; plural=n != 1;\n"
 #. Tag: title
 #: introduction.xml:3
@@ -68,6 +68,11 @@ msgid ""
 "(coverages, surfaces, networks), data source for desktop user interface "
 "tools for viewing and editing GIS data, and web-based access tools."
 msgstr ""
+"Il gruppo di sviluppo di PostGIS pianifica l e migliorie di necessarie a "
+"supportare meglio importanti funzionalita' GIS nelle aree degli standard "
+"spaziali OGC e SQL/MM, costrutti topologici avanzati (coperture, superfici, "
+"reti), sorgenti di dati per le interfacce utente da scrivania per "
+"visualizzare e modificare i dati GIS, e sistemi di accesso via web."
 #. Tag: title
 #: introduction.xml:21
@@ -96,7 +101,7 @@ msgstr ""
 #. Tag: term
 #: introduction.xml:31
-#, fuzzy, no-c-format
+#, no-c-format
 msgid "Raúl Marín Rodríguez"
 msgstr "Raúl Marín Rodríguez"
Summary of changes:
 doc/po/it_IT/introduction.xml.po           | 17 +++++++----
 doc/po/zh_Hans/reference_lrs.xml.po        | 49 ++++++++++++++++++------------
 doc/po/zh_Hans/reference_sfcgal.xml.po     | 47 +++++++++++++++++-----------
 doc/po/zh_Hans/reference_trajectory.xml.po | 40 ++++++++++++++++--------
 4 files changed, 96 insertions(+), 57 deletions(-)
hooks/post-receive
