[postgis-tickets] [PostGIS] #5529: Tools build still requires too much
PostGIS trac at osgeo.org
Sun Sep 10 01:12:42 PDT 2023
 Reporter:  robe                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  medium                 |  Milestone:  PostGIS 3.4.1
Component:  build/upgrade/install  |    Version:  3.4.x
 Keywords:                         |
 I was trying to do this on a system that does not have geos dev or proj
 dev installed.
 ./configure --without-pgconfig
 and I can't tells me I need those.
 I installed geosdevl and tried to get away without proj dev
 ./configure --without-pgconfig --without-projdir
 and get
 configure: error: the --with-projdir directory "no" cannot be found
 shp2pgsql doesn't require geos or proj, so we should allow building
 without those if user choose --without-pgconfig
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5529>
