[postgis-tickets] [PostGIS] #5529: Tools build still requires too much
PostGIS trac at osgeo.org
Sun Sep 10 01:21:25 PDT 2023
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.1
 Component:  build/upgrade/install  |    Version:  3.4.x
Resolution:                         |   Keywords:
Comment (by robe):
 Okay possible maybe nothing can be done with proj or geos since we are
 pulling in liblwgeom, but I shouldn't have to explicitly says --without-
 protobuf
 I ended up with this cause all I needed was shp2pgsl
 apt install automake autoconf libtool libgeos-dev libproj-dev
 ./configure --without-pgconfig --without-protobuf --without-raster
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5529#comment:1>
