[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-367-gcd356b07a
Sun Sep 10 23:56:36 PDT 2023
the project "PostGIS".
       via  cd356b07aac34c6b19e72980eab8ba5ccb39d774 (commit)
      from  904b079d74e5f5147b860d92bb8bbf95c4b592e3 (commit)
revisions in full, below.
commit cd356b07aac34c6b19e72980eab8ba5ccb39d774
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Sep 11 08:56:15 2023 +0200
    We're not using math2ml anymore, so stop looking for it
diff --git a/configure.ac b/configure.ac
index 96a1d50fa..de25dd878 100644
--- a/configure.ac
+++ b/configure.ac
@@ -319,27 +319,6 @@ fi
 AC_SUBST([XSLBASE])
-dnl
-dnl Let's see if we can find mathml2.dtd
-dnl
-AC_ARG_WITH([mathmldtd],
-	[AS_HELP_STRING([--with-mathmldtd=PATH], [specify the dtd path for mathml2.dtd])],
-	[MATHML2_DTD="$withval"], [MATHML2_DTD=""])
-dnl TODO: get more paths to add here...
-if test "x$MATHML2_DTD" = "x"; then
-	MATHML2_DTD="http://www.w3.org/Math/DTD/mathml2/mathml2.dtd"
-	SEARCHPATH="
-			/usr/share/xml/schema/w3c/mathml/dtd
-	for p in ${SEARCHPATH}; do
-		if test -r "${p}"/mathml2.dtd; then
-			MATHML2_DTD="${p}/mathml2.dtd"
-			break
-		fi
-	done
-fi
-AC_SUBST([MATHML2_DTD])
 dnl ===========================================================================
 dnl Detect if pkg-config installed
@@ -1894,7 +1873,6 @@ AC_MSG_RESULT([  xsltproc:             ${XSLTPROC}])
 AC_MSG_RESULT([  xsl style sheets:     ${XSLBASE}])
 AC_MSG_RESULT([  dblatex:              ${DBLATEX}])
 AC_MSG_RESULT([  convert:              ${CONVERT}])
-AC_MSG_RESULT([  mathml2.dtd:          ${MATHML2_DTD}])
 AC_MSG_RESULT()
 if test "$POSTGIS_GEOS_VERSION" -lt 31200; then
Summary of changes:
 configure.ac | 22 ----------------------
 1 file changed, 22 deletions(-)
hooks/post-receive
