[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-401-gb96c561ee
Mon Sep 11 12:40:01 PDT 2023
the project "PostGIS".
       via  b96c561eeae1a306af4eec63540f29853f15bb46 (commit)
       via  e06397bc0ac14067257fda938a996eac6cc74acd (commit)
       via  e26fe35aed35bbf719ab5ae8a3e0e857dd574d6a (commit)
      from  421474b270878e8b44df825340244232679fc350 (commit)
revisions in full, below.
commit b96c561eeae1a306af4eec63540f29853f15bb46
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Sep 11 19:34:20 2023 +0000
    Translated xsl-config using Weblate (Italian)
    Currently translated at 79.1% (19 of 24 strings)
    Translation: postgis/xsl-config
    Translate-URL: https://weblate.osgeo.org/projects/postgis/xsl-config/it/
diff --git a/doc/po/it_IT/xsl-config.xml.po b/doc/po/it_IT/xsl-config.xml.po
index 4b8db12d7..58f38be80 100644
--- a/doc/po/it_IT/xsl-config.xml.po
+++ b/doc/po/it_IT/xsl-config.xml.po
@@ -1,19 +1,19 @@
 # Regina Obe <regina at arrival3d.com>, 2023.
+# Sandro Santilli <strk at kbt.io>, 2023.
 msgid ""
 msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2023-08-03 01:03+0000\n"
-"PO-Revision-Date: 2023-08-28 12:08+0000\n"
-"Last-Translator: Regina Obe <regina at arrival3d.com>\n"
-"Language-Team: Italian <https://weblate.osgeo.org/projects/postgis/xsl-"
-"config/it/>\n"
+"PO-Revision-Date: 2023-09-11 19:39+0000\n"
+"Last-Translator: Sandro Santilli <strk at kbt.io>\n"
+"Language-Team: Italian <https://weblate.osgeo.org/projects/postgis/xsl-config/it/>\n"
 "Language: it_IT\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
 "Plural-Forms: nplurals=2; plural=n != 1;\n"
-"X-Generator: Weblate 4.16.4\n"
+"X-Generator: Weblate 5.0\n"
 #. Tag: title
 #: xsl-config.xml:41
@@ -26,7 +26,7 @@ msgstr "Funzioni PostGIS aggiunto o migliorate nella versione %"
 #, no-c-format
 msgid ""
 "The functions given below are PostGIS functions that were added or enhanced."
-msgstr ""
+msgstr "Le seguenti funzioni PostGIS sono quelle aggiunte o migliorate."
 #. Tag: para
 #: xsl-config.xml:53
commit e06397bc0ac14067257fda938a996eac6cc74acd
Date:   Mon Sep 11 19:36:03 2023 +0000
    Translated using Weblate (Italian)
    Currently translated at 21.0% (47 of 223 strings)
    Translation: postgis/introduction.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/introductionxml/it/
diff --git a/doc/po/it_IT/introduction.xml.po b/doc/po/it_IT/introduction.xml.po
index e3a822e8f..95f49417a 100644
--- a/doc/po/it_IT/introduction.xml.po
+++ b/doc/po/it_IT/introduction.xml.po
@@ -13,7 +13,7 @@ msgstr ""
 "Project-Id-Version: PostGIS\n"
 "POT-Creation-Date: 2023-08-12 00:40+0000\n"
-"PO-Revision-Date: 2023-09-09 07:37+0000\n"
 "Language-Team: Italian <https://weblate.osgeo.org/projects/postgis/"
 "introductionxml/it/>\n"
@@ -138,7 +138,7 @@ msgstr ""
 #: introduction.xml:47
 #, no-c-format
 msgid "Darafei Praliaskouski"
-msgstr ""
+msgstr "Darafei Praliaskouski"
 #. Tag: para
 #: introduction.xml:49
@@ -147,6 +147,9 @@ msgid ""
 "Index improvements, bug fixing and geometry/geography function improvements, "
 "SFCGAL, raster, GitHub curation, and bot maintenance."
 msgstr ""
+"Miglioramento degli indici, correzione di malfunzionamenti e migliorie nelle "
+"funzioni a supporto di geometrie/geografie, SFCGAL, raster, cura di GitHub e "
+"mantenimento bot."
 #. Tag: term
 #: introduction.xml:54
commit e26fe35aed35bbf719ab5ae8a3e0e857dd574d6a
Date:   Mon Sep 11 19:28:10 2023 +0000
    Translated using Weblate (German)
    Currently translated at 45.2% (113 of 250 strings)
    Translation: postgis/reference_accessor.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_accessorxml/de/
diff --git a/doc/po/de/reference_accessor.xml.po b/doc/po/de/reference_accessor.xml.po
index b92eaa96f..d0382f1ef 100644
--- a/doc/po/de/reference_accessor.xml.po
+++ b/doc/po/de/reference_accessor.xml.po
@@ -7,8 +7,8 @@ msgstr ""
 "POT-Creation-Date: 2023-09-11 19:02+0000\n"
-"PO-Revision-Date: 2023-01-09 04:42+0000\n"
 "Language-Team: German <https://weblate.osgeo.org/projects/postgis/"
 "reference_accessorxml/de/>\n"
 "Language: de\n"
@@ -16,7 +16,7 @@ msgstr ""
-"X-Generator: Weblate 4.15\n"
 #. Tag: title
 #: reference_accessor.xml:4
@@ -1393,6 +1393,9 @@ msgid ""
 "SQL-MM defines the result of <code>ST_IsRing(NULL)</code> to be 0, while "
 "PostGIS returns <varname>NULL</varname>."
 msgstr ""
+"SQL-MM gibt vor, daß das Ergebnis von<code>ST_IsRing(NULL)</code> der Wert 0 "
+"sein soll, während PostGIS den Wert\n"
+"<varname>NULL</varname> zurückgibt."
 #. Tag: para
 #: reference_accessor.xml:1293
Summary of changes:
 doc/po/de/reference_accessor.xml.po |  9 ++++++---
 doc/po/it_IT/introduction.xml.po    |  7 +++++--
 doc/po/it_IT/xsl-config.xml.po      | 12 ++++++------
 3 files changed, 17 insertions(+), 11 deletions(-)
hooks/post-receive
