[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-402-g8e99b5042
Mon Sep 11 14:54:17 PDT 2023
the project "PostGIS".
       via  8e99b50428af40c6118f19a6d501b9ce4a22780d (commit)
      from  b96c561eeae1a306af4eec63540f29853f15bb46 (commit)
revisions in full, below.
commit 8e99b50428af40c6118f19a6d501b9ce4a22780d
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Jul 14 18:12:18 2023 +0200
    Don't use border attribute in informaltable
    Fails validation with relaxng
diff --git a/doc/using_postgis_dataman.xml b/doc/using_postgis_dataman.xml
index 61350ba3f..1e824f3f3 100644
--- a/doc/using_postgis_dataman.xml
+++ b/doc/using_postgis_dataman.xml
@@ -908,7 +908,7 @@ SELECT ST_Distance('LINESTRING(-122.33 47.606, 0.0 51.5)'::geometry, 'POINT(-21.
       If the endpoints of a simple LineString are identical it is called <emphasis>closed</emphasis>
       and referred to as a Linear Ring.</para>
-	  <informaltable border="0" frame="none">
+	  <informaltable frame="none">
 		<tgroup cols="1">
 		  <tbody>
 			<row>
@@ -976,7 +976,7 @@ SELECT ST_Distance('LINESTRING(-122.33 47.606, 0.0 51.5)'::geometry, 'POINT(-21.
 	  any two elements occurs at points that are on the
 	  boundaries of both elements.  </para>
 		<tgroup cols="1">
 		  <tbody>
 			<row>
@@ -1085,7 +1085,7 @@ SELECT
         </para></listitem>
         </orderedlist>
 		<tgroup cols="1">
 		  <tbody>
 			<row>
@@ -1183,7 +1183,7 @@ SELECT
         </para></listitem>
         </orderedlist>
 		<tgroup cols="1">
 		  <tbody>
 			<row>
diff --git a/doc/using_postgis_query.xml b/doc/using_postgis_query.xml
index 59f7561d0..51bb7560a 100644
--- a/doc/using_postgis_query.xml
+++ b/doc/using_postgis_query.xml
@@ -152,7 +152,7 @@
          <para>Visually, for two overlapping polygonal geometries, this looks like:</para>
-          <informaltable frame="none" border="0">
             <tgroup cols="2">
               <colspec colwidth="80pt" />
@@ -324,7 +324,7 @@ FROM city JOIN state ON ST_Intersects(city.geom, state.geom);
         are insufficient to  provide a desired spatial filter condition.
         </para>
           <tgroup cols="1">
             <tbody>
               <row>
@@ -353,7 +353,7 @@ FROM city JOIN state ON ST_Intersects(city.geom, state.geom);
           </tgroup>
         </informaltable>
           <tgroup cols="1">
             <tbody>
               <row>
Summary of changes:
 doc/using_postgis_dataman.xml | 8 ++++----
 doc/using_postgis_query.xml   | 6 +++---
 2 files changed, 7 insertions(+), 7 deletions(-)
hooks/post-receive
