[postgis-tickets] [PostGIS] #5532: Validate postgis manual using XSD and RELAXNG schemas
PostGIS trac at osgeo.org
Tue Sep 12 15:42:20 PDT 2023
 Reporter:  strk           |      Owner:  strk
     Type:  defect         |     Status:  assigned
 Priority:  medium         |  Milestone:  PostGIS 3.5.0
Component:  documentation  |    Version:  master
 Keywords:                 |
 In addition (or instead of) using the DTD,
 xmllint supports these switches:
  --schema http://docbook.org/xml/5.0/xsd/docbook.xsd
  --relaxng http://docbook.org/xml/5.0/rng/docbook.rng
 In both cases the URIs are looked up in xml catalogs, and we could use the
 `xmlcatalog` tool to verify local versions exist at configure time, this
 is what I have in my system:
 $ xmlcatalog "" 'http://docbook.org/xml/5.0/xsd/docbook.xsd'
 file:///usr/share/xml/docbook/schema/xsd/5.0/docbook.xsd
 $ xmlcatalog "" 'http://docbook.org/xml/5.0/rng/docbook.rng'
 file:///usr/share/xml/docbook/schema/rng/5.0/docbook.rng
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5532>
