[postgis-tickets] [PostGIS] #5532: Improve validation of PostGIS Manual docbook (was: Validate postgis manual using XSD and RELAXNG schemas)
PostGIS trac at osgeo.org
Tue Sep 12 15:47:27 PDT 2023
  Reporter:  strk           |      Owner:  strk
      Type:  defect         |     Status:  assigned
  Priority:  medium         |  Milestone:  PostGIS 3.5.0
 Component:  documentation  |    Version:  master
Resolution:                 |   Keywords:
Changes (by strk):
 * summary:  Validate postgis manual using XSD and RELAXNG schemas =>
Old description:
> In addition (or instead of) using the DTD,
> xmllint supports these switches:
>  --schema http://docbook.org/xml/5.0/xsd/docbook.xsd
>  --relaxng http://docbook.org/xml/5.0/rng/docbook.rng
> In both cases the URIs are looked up in xml catalogs, and we could use
> the `xmlcatalog` tool to verify local versions exist at configure time,
> this is what I have in my system:
> $ xmlcatalog "" 'http://docbook.org/xml/5.0/xsd/docbook.xsd'
> file:///usr/share/xml/docbook/schema/xsd/5.0/docbook.xsd
> $ xmlcatalog "" 'http://docbook.org/xml/5.0/rng/docbook.rng'
> file:///usr/share/xml/docbook/schema/rng/5.0/docbook.rng
New description:
 In addition (or instead of) using the DTD, we could use XMLSchema, RelaxNG
 and maybe Schematron. xmllint supports these switches:
 In both cases the URIs are looked up in xml catalogs, and we could use the
 `xmlcatalog` tool to verify local versions exist at configure time, this
 I also seem to have a Schematron file, but when I try to use it I get an
 error:
 $ xmllint --noout --nonet --schematron
 /usr/share/xml/docbook/schema/schematron/5.0/docbook.sch postgis-out.xml
 /usr/share/xml/docbook/schema/schematron/5.0/docbook.sch:6: element rule:
 Schemas parser error : Failed to compile context expression
 db:firstterm[@linkend]
 /usr/share/xml/docbook/schema/schematron/5.0/docbook.sch:16: element rule:
 db:glossterm[@linkend]
 /usr/share/xml/docbook/schema/schematron/5.0/docbook.sch:26: element rule:
 db:glosssee[@otherterm]
 /usr/share/xml/docbook/schema/schematron/5.0/docbook.sch:31: element rule:
 db:glossseealso[@otherterm]
 Schematron schema /usr/share/xml/docbook/schema/schematron/5.0/docbook.sch
 failed to compile
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5532#comment:1>
