[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-495-gf7456520b
Tue Sep 12 23:31:03 PDT 2023
the project "PostGIS".
       via  f7456520b17374a8db5f6c3e350c753ce3299472 (commit)
       via  825f3703bd4bf35f8f12956d9eeac122739c0649 (commit)
       via  d6980d908c2d42c9d801e21fe26b407b8ffd0d43 (commit)
      from  0674db0e8f6aa1a7622a7609722041210c61c9f8 (commit)
revisions in full, below.
commit f7456520b17374a8db5f6c3e350c753ce3299472
Author: Zuochenwei <zuochenwei5 at gmail.com>
Date:   Wed Sep 13 06:29:27 2023 +0000
    Translated using Weblate (Chinese (Simplified))
    Currently translated at 100.0% (157 of 157 strings)
    Translation: postgis/using_raster_dataman.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/using_raster_datamanxml/zh_Hans/
diff --git a/doc/po/zh_Hans/using_raster_dataman.xml.po b/doc/po/zh_Hans/using_raster_dataman.xml.po
index dbd62ff76..cae77e061 100644
--- a/doc/po/zh_Hans/using_raster_dataman.xml.po
+++ b/doc/po/zh_Hans/using_raster_dataman.xml.po
@@ -9,7 +9,7 @@ msgstr ""
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2023-09-12 22:08+0000\n"
 "PO-Revision-Date: 2023-09-13 06:31+0000\n"
-"Last-Translator: Sandro Santilli <strk at kbt.io>\n"
+"Last-Translator: Zuochenwei <zuochenwei5 at gmail.com>\n"
 "Language-Team: Chinese (Simplified) <https://weblate.osgeo.org/projects/"
 "postgis/using_raster_datamanxml/zh_Hans/>\n"
 "Language: zh_Hans\n"
@@ -1421,12 +1421,14 @@ msgid ""
 "directory for each record. Requires you have plpython installed. Should work "
 "fine with both plpythonu and plpython3u."
 msgstr ""
+"这是一个 plpython 存储函数,它在服务器目录中为每条记录创建一个文件。 "
+"需要你安装了 plpython。 应该可以与 plpythonu 和 plpython3u 一起正常工作。"
 #. Tag: title
 #: using_raster_dataman.xml:568
 #, no-c-format
 msgid "Outputting Rasters with PSQL"
-msgstr ""
+msgstr "使用 PSQL 输出栅格"
 #. Tag: para
 #: using_raster_dataman.xml:569
@@ -1437,6 +1439,9 @@ msgid ""
 "legacy large object support. To use first launch your psql commandline "
 "connected to your database."
 msgstr ""
+"遗憾的是,PSQL 没有易于使用的内置功能来输出二进制文件。 这是一个有点依赖于 "
+"PostgreSQL 遗留的大对象支持的 hack。 要使用,首先启动连接到数据库的 psql "
+"命令行。"
 #. Tag: para
 #: using_raster_dataman.xml:571
@@ -1444,4 +1449,4 @@ msgstr ""
 msgid ""
 "Unlike the python approach, this approach creates the file on your local "
 "computer."
-msgstr ""
+msgstr "与 python 方法不同,此方法在本地计算机上创建文件。"
commit 825f3703bd4bf35f8f12956d9eeac122739c0649
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Sep 13 06:30:29 2023 +0000
index d2b65741f..dbd62ff76 100644
@@ -2,13 +2,14 @@
 # Automatically generated, 2023.
 # Zuochenwei <zuochenwei5 at gmail.com>, 2023.
+# Sandro Santilli <strk at kbt.io>, 2023.
 msgid ""
 msgstr ""
 "Project-Id-Version: build-pg 13\n"
-"PO-Revision-Date: 2023-09-13 05:59+0000\n"
-"Last-Translator: Zuochenwei <zuochenwei5 at gmail.com>\n"
+"PO-Revision-Date: 2023-09-13 06:31+0000\n"
+"Last-Translator: Sandro Santilli <strk at kbt.io>\n"
@@ -296,7 +297,7 @@ msgstr "栅格处理:用于操作输入栅格数据集的可选参数"
 #: using_raster_dataman.xml:152
 #, no-c-format
 msgid "-s <SRID>"
-msgstr "-s <SRID>"
+msgstr "-s <SRID>"
 #. Tag: para
 #: using_raster_dataman.xml:154
commit d6980d908c2d42c9d801e21fe26b407b8ffd0d43
Date:   Wed Sep 13 05:59:26 2023 +0000
    Translated using Weblate (Japanese)
    Translate-URL: https://weblate.osgeo.org/projects/postgis/using_raster_datamanxml/ja/
diff --git a/doc/po/ja/using_raster_dataman.xml.po b/doc/po/ja/using_raster_dataman.xml.po
index 695103bf1..1e038e146 100644
--- a/doc/po/ja/using_raster_dataman.xml.po
+++ b/doc/po/ja/using_raster_dataman.xml.po
@@ -3,13 +3,14 @@
 # Translators:
 # TERAMOTO Ikuhiro <yellow at affrc.go.jp>, 2016
 # Teramoto Ikuhiro <yellow at affrc.go.jp>, 2022, 2023.
 msgid ""
 msgstr ""
 "Project-Id-Version: PostGIS\n"
-"Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
 "Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
 "using_raster_datamanxml/ja/>\n"
 "Language: ja\n"
Summary of changes:
 doc/po/ja/using_raster_dataman.xml.po      |  5 +++--
 doc/po/zh_Hans/using_raster_dataman.xml.po | 14 ++++++++++----
 2 files changed, 13 insertions(+), 6 deletions(-)
hooks/post-receive
