[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-516-gca33aa7cb
Wed Sep 13 04:43:27 PDT 2023
the project "PostGIS".
       via  ca33aa7cbce3b25eb7fdaa42b93b9e5a280525f9 (commit)
      from  d0b1200c304f0014e1f94ab368330b77bfeaec08 (commit)
revisions in full, below.
commit ca33aa7cbce3b25eb7fdaa42b93b9e5a280525f9
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Sep 13 13:43:06 2023 +0200
    Revert drop of entities
diff --git a/doc/po/templates/reference_input.xml.pot b/doc/po/templates/reference_input.xml.pot
index 449e3c48f..2a541f759 100644
--- a/doc/po/templates/reference_input.xml.pot
+++ b/doc/po/templates/reference_input.xml.pot
@@ -6,7 +6,7 @@ msgid ""
 msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
-"POT-Creation-Date: 2023-09-12 22:08+0000\n"
+"POT-Creation-Date: 2023-09-13 11:41+0000\n"
 "PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
 "Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
 "Language-Team: LANGUAGE <kde-i18n-doc at kde.org>\n"
diff --git a/doc/po/templates/reference_measure.xml.pot b/doc/po/templates/reference_measure.xml.pot
index b229528c0..8d83afc65 100644
--- a/doc/po/templates/reference_measure.xml.pot
+++ b/doc/po/templates/reference_measure.xml.pot
 msgstr ""
+"POT-Creation-Date: 2023-09-13 11:40+0000\n"
@@ -1055,7 +1055,9 @@ msgstr ""
 #: reference_measure.xml:926
 #, no-c-format
 msgid ""
-"SPHEROID[<NAME>,<SEMI-MAJOR AXIS>,<INVERSE FLATTENING>]"
+"<![CDATA[[\n"
+"SPHEROID[<NAME>,<SEMI-MAJOR AXIS>,<INVERSE FLATTENING>]\n"
 msgstr ""
 #. Tag: para
diff --git a/doc/reference_input.xml b/doc/reference_input.xml
index 913845202..9c626d44f 100644
--- a/doc/reference_input.xml
+++ b/doc/reference_input.xml
@@ -44,7 +44,7 @@
 			postgis-specific approach.</para>
 			</note>
-			 <para>[[[sfs_compliant]]] s3.2.6.2</para>
+			 <para>&sfs_compliant; s3.2.6.2</para>
 			 <para>Performed by the GEOS module.</para>
 			 <para role="availability" conformance="1.1.0">Availability: 1.1.0</para>
 		  </refsection>
@@ -95,7 +95,7 @@
 					approach.</para>
 				</note>
 			</refsection>
@@ -211,8 +211,8 @@ SELECT ST_AsEWKT(ST_GeogFromText('SRID=4267;POINT(-77.0092 38.889588)'));
 			</para>
 		</note>
-		<para>[[[sqlmm_compliant]]]</para>
+		<para>&sqlmm_compliant;</para>
 	  </refsection>
@@ -255,10 +255,10 @@ SELECT ST_AsEWKT(ST_GeogFromText('SRID=4267;POINT(-77.0092 38.889588)'));
 			identifier</para>
 		</note>
 		<para role="enhanced" conformance="2.0.0">Enhanced: 2.0.0 support for Polyhedral surfaces and TIN was introduced.</para>
-		<para>[[[Z_support]]]</para>
-		<para>[[[curve_support]]]</para>
-		<para>[[[P_support]]]</para>
-		<para>[[[T_support]]]</para>
+		<para>&Z_support;</para>
+		<para>&curve_support;</para>
+		<para>&P_support;</para>
+		<para>&T_support;</para>
 	  </refsection>
 	  <refsection>
@@ -489,8 +489,8 @@ SELECT ST_GeomFromEWKT('POLYHEDRALSURFACE(
 		  </refsynopsisdiv>
 		  <refsection>
 			<title>Description</title>
-			<para>[[[sfs_compliant]]]</para>
-			<para>[[[sqlmm_compliant]]] SQL-MM 3: 5.1.40</para>
+			<para>&sfs_compliant;</para>
+			<para>&sqlmm_compliant; SQL-MM 3: 5.1.40</para>
 		  </refsection>
 		  <refsection>
 			<title>See Also</title>
@@ -530,9 +530,9 @@ SELECT ST_GeomFromEWKT('POLYHEDRALSURFACE(
 				</para>
 			</note>
-			<para>[[[sfs_compliant]]] s3.2.6.2 - option SRID is from the conformance suite.</para>
+			<para>&sfs_compliant; s3.2.6.2 - option SRID is from the conformance suite.</para>
             <note><para>While not OGC-compliant, <xref linkend="ST_MakePoint"/> is faster than ST_GeomFromText and ST_PointFromText. It is also easier to use for numeric coordinate values. <xref linkend="ST_Point"/> is another option similar in speed to <xref linkend="ST_MakePoint"/> and is OGC-compliant, but doesn't support anything but 2D points.</para></note>
 			<warning><para role="changed" conformance="2.0.0">Changed: 2.0.0 In prior versions of PostGIS ST_GeomFromText('GEOMETRYCOLLECTION(EMPTY)') was allowed.  This is now illegal in PostGIS 2.0.0 to better conform with SQL/MM standards. This should now be
 			    written as ST_GeomFromText('GEOMETRYCOLLECTION EMPTY')</para></warning>
@@ -625,8 +625,8 @@ SELECT ST_GeomFromText('CIRCULARSTRING(220268 150415,220227 150505,220227 150406
 		</note>
-		<para>[[[sqlmm_compliant]]] SQL-MM 3: 7.2.8</para>
+		<para>&sqlmm_compliant; SQL-MM 3: 7.2.8</para>
 	  </refsection>
@@ -689,8 +689,8 @@ aline                            | null_return
 			</para>
 		</note>
-		<para>[[[sqlmm_compliant]]]SQL-MM 3: 9.4.4</para>
+		<para>&sqlmm_compliant;SQL-MM 3: 9.4.4</para>
 	  </refsection>
@@ -750,8 +750,8 @@ aline                            | null_return
 			</para>
 		</note>
-		<para>[[[sfs_compliant]]] 3.2.6.2</para>
-		<para>[[[sqlmm_compliant]]] SQL-MM 3: 9.2.4</para>
+		<para>&sfs_compliant; 3.2.6.2</para>
+		<para>&sqlmm_compliant; SQL-MM 3: 9.2.4</para>
 	  </refsection>
@@ -812,8 +812,8 @@ SELECT ST_MPointFromText('MULTIPOINT((-70.9590 42.1180),(-70.9611 42.1223))', 43
 			</para>
 		</note>
-		<para>[[[sqlmm_compliant]]] SQL-MM 3: 9.6.4</para>
+		<para>&sqlmm_compliant; SQL-MM 3: 9.6.4</para>
 	  </refsection>
@@ -875,8 +875,8 @@ SELECt ST_MPolyFromText('MULTIPOLYGON(((-70.916 42.1002,-70.9468 42.0946,-70.976
 					It is slower than ST_GeomFromText since it adds an additional validation step.  If you are building points from long lat coordinates and care more about performance and accuracy than OGC compliance, use <xref linkend="ST_MakePoint"/> or OGC compliant alias <xref linkend="ST_Point"/>.   </para>
 			</note>
-			<para>[[[sqlmm_compliant]]] SQL-MM 3: 6.1.8</para>
+			<para>&sqlmm_compliant; SQL-MM 3: 6.1.8</para>
 		  </refsection>
 		  <refsection>
@@ -926,8 +926,8 @@ SELECT ST_PointFromText('POINT(-71.064544 42.28787)', 4326);
 		<note><para>If you are absolutely sure all your WKT geometries are polygons, don't use this function.
 					It is slower than ST_GeomFromText since it adds an additional validation step. </para></note>
-		<para>[[[sqlmm_compliant]]] SQL-MM 3: 8.3.6</para>
+		<para>&sqlmm_compliant; SQL-MM 3: 8.3.6</para>
 	  </refsection>
 	  <refsection>
@@ -971,7 +971,7 @@ t
 		  </refsynopsisdiv>
 		  <refsection>
-			<para>[[[sqlmm_compliant]]] SQL-MM 3: 5.1.34</para>
+			<para>&sqlmm_compliant; SQL-MM 3: 5.1.34</para>
 		  </refsection>
 		  <refsection>
@@ -1011,7 +1011,7 @@ t
 		<para>If SRID is not specified, it defaults to 4326 (WGS 84 long lat).</para>
 	  </refsection>
@@ -1059,10 +1059,10 @@ ST_GeogFromWKB(E'\\001\\002\\000\\000\\000\\002\\000\\000\\000\\037\\205\\353Q\\
 			identifier</para>
 		</note>
 	  </refsection>
 	  <refsection>
@@ -1122,9 +1122,9 @@ SELECT ST_GeomFromEWKB('\001\002\000\000 \255\020\000\000\003\000\000\000\344J=\
 		SQL. This is an alternate name for ST_WKBToSQL.</para>
 		<para>If SRID is not specified, it defaults to 0 (Unknown).</para>
-		<para>[[[sfs_compliant]]] s3.2.7.2 - the optional SRID is from the conformance suite</para>
-		<para>[[[sqlmm_compliant]]] SQL-MM 3: 5.1.41</para>
+		<para>&sfs_compliant; s3.2.7.2 - the optional SRID is from the conformance suite</para>
+		<para>&sqlmm_compliant; SQL-MM 3: 5.1.41</para>
 	  </refsection>
@@ -1209,8 +1209,8 @@ SELECT
 		</note>
-		<para>[[[sqlmm_compliant]]] SQL-MM 3: 7.2.9</para>
+		<para>&sqlmm_compliant; SQL-MM 3: 7.2.9</para>
 	  </refsection>
@@ -1280,8 +1280,8 @@ aline                            | null_return
 		  <varname>LINESTRING</varname>.</para>
 		</note>
 	  </refsection>
 	  <refsection>
@@ -1341,10 +1341,10 @@ aline                            | null_return
 		<para>If an SRID is not specified, it defaults to 0.  <varname>NULL</varname> is
 		returned if the input <varname>bytea</varname> does not represent a
 		<varname>POINT</varname> geometry.</para>
-		<para>[[[sfs_compliant]]] s3.2.7.2</para>
-		<para>[[[sqlmm_compliant]]] SQL-MM 3: 6.1.9</para>
+		<para>&sfs_compliant; s3.2.7.2</para>
+		<para>&sqlmm_compliant; SQL-MM 3: 6.1.9</para>
 	  </refsection>
 	  <refsection>
@@ -1396,7 +1396,7 @@ SELECT
 		  </refsynopsisdiv>
 		  <refsection>
-			<para>[[[sqlmm_compliant]]] SQL-MM 3: 5.1.36</para>
+			<para>&sqlmm_compliant; SQL-MM 3: 5.1.36</para>
 		  </refsection>
 		  <refsection>
@@ -1567,9 +1567,9 @@ SELECT ST_AsText(ST_GeomFromGeoHash('9qqj7nmxncgyy4d0dbxqz0', 10));
 		<para role="availability" conformance="1.5">Availability: 1.5, requires libxml2 1.6+</para>
 		<para role="enhanced" conformance="2.0.0">Enhanced: 2.0.0 default srid optional parameter added.</para>
 		<para>GML allow mixed dimensions (2D and 3D inside the same MultiGeometry for instance). As PostGIS geometries don't, ST_GeomFromGML convert the whole geometry to 2D if a missing Z dimension is found once.</para>
 		<para>GML support mixed SRS inside the same MultiGeometry. As PostGIS geometries don't, ST_GeomFromGML, in this case, reproject all subgeometries to the SRS root node. If no srsName attribute available for the GML root node, the function throw an error.</para>
@@ -1707,7 +1707,7 @@ SELECT ST_AsEWKT(ST_GeomFromGML('
 		<para role="availability" conformance="2.0.0">Availability: 2.0.0 requires - JSON-C >= 0.9</para>
 		<note><para>If you do not have JSON-C enabled, support you will get an error notice instead of seeing an output.
 			To enable JSON-C, run configure --with-jsondir=/path/to/json-c.  See <xref linkend="installation_configuration"/> for details.</para></note>
 	  </refsection>
 	 <refsection>
@@ -1763,7 +1763,7 @@ LINESTRING(1 2,4 5,7 8)
 		</para>
 		<para role="availability" conformance="1.5">Availability: 1.5, requires libxml2 2.6+</para>
 		<note>
 			<para>ST_GeomFromKML function not support SQL/MM curves geometries.</para>
 		</note>
@@ -1862,7 +1862,7 @@ LINESTRING(-113.98 39.198,-113.981 39.195)
 		</refsynopsisdiv>
 		  <refsection>
-			<para>[[[sqlmm_compliant]]] SQL-MM 3: 5.1.50 (except for curves support).</para>
+			<para>&sqlmm_compliant; SQL-MM 3: 5.1.50 (except for curves support).</para>
Summary of changes:
 doc/po/templates/reference_input.xml.pot   |  2 +-
 doc/po/templates/reference_measure.xml.pot |  6 +-
 doc/reference_input.xml                    | 98 +++++++++++++++---------------
 3 files changed, 54 insertions(+), 52 deletions(-)
hooks/post-receive
