[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-517-gb6583e983
Wed Sep 13 05:11:31 PDT 2023
the project "PostGIS".
       via  b6583e98323ffe1a8438b51f3a9c70205fdbcf6b (commit)
      from  ca33aa7cbce3b25eb7fdaa42b93b9e5a280525f9 (commit)
revisions in full, below.
commit b6583e98323ffe1a8438b51f3a9c70205fdbcf6b
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Sep 13 14:11:10 2023 +0200
    Rely on system's xmlcatalog to find docbook XSL
diff --git a/configure.ac b/configure.ac
index 8cf852e2b..4642485ea 100644
--- a/configure.ac
+++ b/configure.ac
@@ -255,71 +255,6 @@ if test "x$XMLLINT" = "x"; then
 	AC_MSG_WARN([xmllint is not installed so documentation cannot be checked])
 fi
-dnl
-dnl Allow the user to specify the location of the html/docbook.xsl stylesheet
-dnl
-AC_ARG_WITH([xsldir],
-	[AS_HELP_STRING([--with-xsldir=PATH], [specify the directory containing the docbook.xsl stylesheet])],
-	[XSLBASE="$withval"], [XSLBASE=""])
-XSLBASE_AUTO=""
-if test "x$XSLBASE" = "x"; then
-	dnl If the user did not specify a directory for the docbook
-	dnl stylesheet, choose the first directory
-	dnl that matches from the following list
-	SEARCHPATH="
-		/usr/share/sgml/docbook/xsl-stylesheets
-		/usr/share/xml/docbook/stylesheet/docbook-xsl-ns
-		/usr/share/xml/docbook/stylesheet/nwalsh
-		/usr/share/sgml/docbook/stylesheet/xsl/nwalsh
-		/opt/local/share/xsl/docbook-xsl
-		/usr/local/opt/docbook-xsl/docbook-xsl
-		/usr/local/share/xsl/docbook-xsl
-		/usr/share/xsl/docbook-xsl
-	for p in ${SEARCHPATH}; do
-		if test -r "${p}"/html/docbook.xsl; then
-			XSLBASE_AUTO="${p}"
-			break
-		fi
-	done
-	dnl Check to see if the automatically searched paths above located a
-	dnl valid Docbook stylesheet
-	if test "x$XSLBASE_AUTO" = "x"; then
-		AC_MSG_WARN([could not locate Docbook stylesheets required to build the documentation])
-	fi
-else
-	dnl The user specified an alternate directory so make sure everything
-	dnl looks sensible
-	if test ! -d "$XSLBASE"; then
-		AC_MSG_ERROR([the docbook stylesheet directory specified using --with-xsldir does not exist])
-	fi
-	if test ! -f "$XSLBASE/html/docbook.xsl"; then
-		AC_MSG_ERROR([the docbook stylesheet directory specified using --with-xsldir does not contain the html/docbook.xsl file])
-	fi
-fi
-dnl
-dnl If XSLBASE has been set then at this point we know it must be
-dnl valid and so we can just use it. If XSLBASE_AUTO has been set, and XSLBASE
-dnl is empty then a valid stylesheet was found in XSLBASE_AUTO so we
-dnl should use that. Otherwise just continue silently with a blank XSLBASE
-dnl variable which will trigger the error message in the documentation Makefile
-dnl
-	if test ! "x$XSLBASE_AUTO" = "x"; then
-		XSLBASE="$XSLBASE_AUTO"
-	fi
-fi
-AC_SUBST([XSLBASE])
 dnl ===========================================================================
 dnl Detect if pkg-config installed
@@ -1871,7 +1806,6 @@ fi
 AC_MSG_RESULT()
 AC_MSG_RESULT([ -------- Documentation Generation -------- ])
 AC_MSG_RESULT([  xsltproc:             ${XSLTPROC}])
-AC_MSG_RESULT([  xsl style sheets:     ${XSLBASE}])
 AC_MSG_RESULT([  dblatex:              ${DBLATEX}])
 AC_MSG_RESULT([  convert:              ${CONVERT}])
 AC_MSG_RESULT()
diff --git a/doc/Makefile.in b/doc/Makefile.in
index 77ad2e9f5..107567e2a 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -60,7 +60,6 @@ INSTALL=@INSTALL@
 INSTALL_DATA=@INSTALL_DATA@
 XSLTPROC=@XSLTPROC@
-XSLBASE=@XSLBASE@
 CAN_UPDATE_TRANSLATIONS=@CAN_UPDATE_TRANSLATIONS@
 XMLLINT=@XMLLINT@
 CAN_BUILD_COMMENTS=@CAN_BUILD_COMMENTS@
@@ -112,8 +111,9 @@ XSLTPROC_CHUNKED_HTML_OPTS = \
 	--stringparam img.src.path ../ \
 	--stringparam html.stylesheet ../style.css
-HTML_DOCBOOK_XSL=$(XSLBASE)/html/docbook.xsl
-CHUNK_HTML_DOCBOOK_XSL=$(XSLBASE)/html/chunk.xsl
+DOCBOOK_XSLBASE=http://cdn.docbook.org/release/xsl/current/
+HTML_DOCBOOK_XSL=$(DOCBOOK_XSLBASE)/html/docbook.xsl
+CHUNK_HTML_DOCBOOK_XSL=$(DOCBOOK_XSLBASE)/html/chunk.xsl
 # DBLatex's dblatex script for PDF generation from DocBook
 DBLATEX=@DBLATEX@
Summary of changes:
 configure.ac    | 66 ---------------------------------------------------------
 doc/Makefile.in |  6 +++---
 2 files changed, 3 insertions(+), 69 deletions(-)
hooks/post-receive
