[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-519-g9b4164749
Wed Sep 13 06:07:51 PDT 2023
the project "PostGIS".
       via  9b4164749c01a512cb709870cb1846c8d38277e5 (commit)
      from  899bd928a940f3ef3c3aca30228981d74275b35b (commit)
revisions in full, below.
commit 9b4164749c01a512cb709870cb1846c8d38277e5
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Sep 13 15:07:30 2023 +0200
    Use tag <option> for commandline options, and don't translate
diff --git a/doc/installation.xml b/doc/installation.xml
index 6e96cc783..1bb403b0c 100644
--- a/doc/installation.xml
+++ b/doc/installation.xml
@@ -339,7 +339,7 @@ sh autogen.sh
 	  <variablelist>
 		<varlistentry>
-		  <term>--with-library-minor-version</term>
+		  <term><option>--with-library-minor-version</option></term>
 		  <listitem>
 			<para>Starting with PostGIS 3.0, the library files generated by default will no longer have the minor version
 			as part of the file name.  This means all PostGIS 3 libs will end in <code>postgis-3</code>.
@@ -354,7 +354,7 @@ sh autogen.sh
 		<varlistentry>
-		  <term>--prefix=PREFIX</term>
+		  <term><option>--prefix=PREFIX</option></term>
 		  <listitem>
 			<para>
 			  This is the location the PostGIS loader executables and shared libs will be installed.
@@ -376,7 +376,7 @@ sh autogen.sh
 		</varlistentry>
 		<varlistentry>
-		  <term>--with-pgconfig=FILE</term>
+		  <term><option>--with-pgconfig=FILE</option></term>
 		  <listitem>
 			<para>
 			  PostgreSQL provides a utility called <command>pg_config</command>
@@ -390,7 +390,7 @@ sh autogen.sh
 		</varlistentry>
 		<varlistentry>
-		  <term>--with-gdalconfig=FILE</term>
+		  <term><option>--with-gdalconfig=FILE</option></term>
 		  <listitem>
 			<para>
 			  GDAL, a required library, provides functionality needed for raster support
@@ -404,7 +404,7 @@ sh autogen.sh
 		</varlistentry>
 		<varlistentry>
-		  <term>--with-geosconfig=FILE</term>
+		  <term><option>--with-geosconfig=FILE</option></term>
 		  <listitem>
 			<para>
 			  GEOS, a required geometry library, provides a utility called
@@ -418,7 +418,7 @@ sh autogen.sh
 		</varlistentry>
 		<varlistentry>
-		  <term>--with-xml2config=FILE</term>
+		  <term><option>--with-xml2config=FILE</option></term>
 		  <listitem>
 			<para>
 			  LibXML is the library required for doing GeomFromKML/GML processes.
@@ -436,7 +436,7 @@ sh autogen.sh
 		<varlistentry>
-		  <term>--with-projdir=DIR</term>
+		  <term><option>--with-projdir=DIR</option></term>
 		  <listitem>
 			<para>
 			  Proj is a reprojection library required by PostGIS. Use this
@@ -448,7 +448,7 @@ sh autogen.sh
 		</varlistentry>
 		<varlistentry>
-		  <term>--with-libiconv=DIR</term>
+		  <term><option>--with-libiconv=DIR</option></term>
 		  <listitem>
 			<para>
 			  Directory where iconv is installed.
@@ -457,7 +457,7 @@ sh autogen.sh
 		</varlistentry>
 		<varlistentry>
-		  <term>--with-jsondir=DIR</term>
+		  <term><option>--with-jsondir=DIR</option></term>
 		  <listitem>
 			<para>
 			  <link xlink:href="http://oss.metaparadigm.com/json-c/">JSON-C</link> is an MIT-licensed JSON library required by PostGIS ST_GeomFromJSON support. Use this
@@ -469,7 +469,7 @@ sh autogen.sh
 		</varlistentry>
 		<varlistentry>
-		  <term>--with-pcredir=DIR</term>
+		  <term><option>--with-pcredir=DIR</option></term>
 		  <listitem>
 			<para>
 			  <link xlink:href="http://www.pcre.org/">PCRE</link> is an BSD-licensed Perl Compatible Regular Expression library required by address_standardizer extension. Use this
@@ -481,7 +481,7 @@ sh autogen.sh
 		</varlistentry>
 		<varlistentry>
-		  <term>--with-gui</term>
+		  <term><option>--with-gui</option></term>
 		  <listitem>
 			<para>
 			  Compile the data import GUI (requires GTK+2.0).  This will create shp2pgsql-gui graphical interface
@@ -490,7 +490,7 @@ sh autogen.sh
 		  </listitem>
 		</varlistentry>
 		<varlistentry>
-		  <term>--without-raster</term>
+		  <term><option>--without-raster</option></term>
 		  <listitem>
 			<para>
 			  Compile without raster support.
@@ -498,7 +498,7 @@ sh autogen.sh
 		  </listitem>
 		</varlistentry>
 		<varlistentry>
-		  <term>--without-topology</term>
+		  <term><option>--without-topology</option></term>
 		  <listitem>
 			<para>
 			  Disable topology support. There is no corresponding library
@@ -507,7 +507,7 @@ sh autogen.sh
 		  </listitem>
 		</varlistentry>
 		<varlistentry>
-		  <term>--with-gettext=no</term>
+		  <term><option>--with-gettext=no</option></term>
 		  <listitem>
 			<para>
 			  By default PostGIS will try to detect gettext support and compile with it, however if you run into incompatibility issues that
@@ -518,7 +518,7 @@ sh autogen.sh
 		  </listitem>
 		</varlistentry>
 		<varlistentry>
-		  <term>--with-sfcgal=PATH</term>
+		  <term><option>--with-sfcgal=PATH</option></term>
 		  <listitem>
 			<para>
 			  By default PostGIS will not install with sfcgal support without this switch.
@@ -527,7 +527,7 @@ sh autogen.sh
 		  </listitem>
 		</varlistentry>
 		<varlistentry>
-		  <term>--without-phony-revision</term>
+		  <term><option>--without-phony-revision</option></term>
 		  <listitem>
 			<para>
 			  Disable updating postgis_revision.h to match current HEAD of the git repository.
diff --git a/doc/po/strip_untranslatable.sh b/doc/po/strip_untranslatable.sh
index cb6740dc6..bfee44878 100755
--- a/doc/po/strip_untranslatable.sh
+++ b/doc/po/strip_untranslatable.sh
@@ -11,5 +11,6 @@ sed -e '/^#\. Tag: programlisting$/,/^$/d' \
     -e '/^#\. Tag: funcsynopsis$/,/^$/d' \
     -e '/^#\. Tag: refname$/,/^$/d' \
     -e '/^#\. Tag: funcprototype$/,/^$/d' \
+    -e '/^#\. Tag: option$/,/^$/d' \
     -i $1
diff --git a/doc/po/templates/installation.xml.pot b/doc/po/templates/installation.xml.pot
index 1f1542993..0c306ed12 100644
--- a/doc/po/templates/installation.xml.pot
+++ b/doc/po/templates/installation.xml.pot
@@ -6,7 +6,7 @@ msgid ""
 msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
-"POT-Creation-Date: 2023-09-12 22:08+0000\n"
+"POT-Creation-Date: 2023-09-13 13:07+0000\n"
 "PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
 "Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
 "Language-Team: LANGUAGE <kde-i18n-doc at kde.org>\n"
@@ -437,12 +437,6 @@ msgid ""
 "command> parameters."
 msgstr ""
-#. Tag: term
-#: installation.xml:333
-#, no-c-format
-msgid "--with-library-minor-version"
-msgstr ""
 #. Tag: para
 #: installation.xml:335
 #, no-c-format
@@ -456,12 +450,6 @@ msgid ""
 "configure statement."
 msgstr ""
-#. Tag: term
-#: installation.xml:348
-#, no-c-format
-msgid "--prefix=PREFIX"
-msgstr ""
 #. Tag: para
 #: installation.xml:350
 #, no-c-format
@@ -481,12 +469,6 @@ msgid ""
 "link> to track this bug."
 msgstr ""
-#. Tag: term
-#: installation.xml:370
-#, no-c-format
-msgid "--with-pgconfig=FILE"
-msgstr ""
 #. Tag: para
 #: installation.xml:372
 #, no-c-format
@@ -498,12 +480,6 @@ msgid ""
 "build against."
 msgstr ""
-#. Tag: term
-#: installation.xml:384
-#, no-c-format
-msgid "--with-gdalconfig=FILE"
-msgstr ""
 #. Tag: para
 #: installation.xml:386
 #, no-c-format
@@ -515,12 +491,6 @@ msgid ""
 "GDAL installation that PostGIS will build against."
 msgstr ""
-#. Tag: term
-#: installation.xml:398
-#, no-c-format
-msgid "--with-geosconfig=FILE"
-msgstr ""
 #. Tag: para
 #: installation.xml:400
 #, no-c-format
@@ -532,12 +502,6 @@ msgid ""
 "that PostGIS will build against."
 msgstr ""
-#. Tag: term
-#: installation.xml:412
-#, no-c-format
-msgid "--with-xml2config=FILE"
-msgstr ""
 #. Tag: para
 #: installation.xml:414
 #, no-c-format
@@ -551,12 +515,6 @@ msgid ""
 "specify a particular LibXML installation that PostGIS will build against."
 msgstr ""
-#. Tag: term
-#: installation.xml:430
-#, no-c-format
-msgid "--with-projdir=DIR"
-msgstr ""
 #. Tag: para
 #: installation.xml:432
 #, no-c-format
@@ -566,24 +524,12 @@ msgid ""
 "particular Proj installation directory that PostGIS will build against."
 msgstr ""
-#. Tag: term
-#: installation.xml:442
-#, no-c-format
-msgid "--with-libiconv=DIR"
-msgstr ""
 #. Tag: para
 #: installation.xml:444
 #, no-c-format
 msgid "Directory where iconv is installed."
 msgstr ""
-#. Tag: term
-#: installation.xml:451
-#, no-c-format
-msgid "--with-jsondir=DIR"
-msgstr ""
 #. Tag: para
 #: installation.xml:453
 #, no-c-format
@@ -595,12 +541,6 @@ msgid ""
 "will build against."
 msgstr ""
-#. Tag: term
-#: installation.xml:463
-#, no-c-format
-msgid "--with-pcredir=DIR"
-msgstr ""
 #. Tag: para
 #: installation.xml:465
 #, no-c-format
@@ -612,12 +552,6 @@ msgid ""
 "PostGIS will build against."
 msgstr ""
-#. Tag: term
-#: installation.xml:475
-#, no-c-format
-msgid "--with-gui"
-msgstr ""
 #. Tag: para
 #: installation.xml:477
 #, no-c-format
@@ -626,24 +560,12 @@ msgid ""
 "gui graphical interface to shp2pgsql."
 msgstr ""
-#. Tag: term
-#: installation.xml:484
-#, no-c-format
-msgid "--without-raster"
-msgstr ""
 #. Tag: para
 #: installation.xml:486
 #, no-c-format
 msgid "Compile without raster support."
 msgstr ""
-#. Tag: term
-#: installation.xml:492
-#, no-c-format
-msgid "--without-topology"
-msgstr ""
 #. Tag: para
 #: installation.xml:494
 #, no-c-format
@@ -652,12 +574,6 @@ msgid ""
 "needed for topology is in postgis-&last_release_version; library."
 msgstr ""
-#. Tag: term
-#: installation.xml:501
-#, no-c-format
-msgid "--with-gettext=no"
-msgstr ""
 #. Tag: para
 #: installation.xml:503
 #, no-c-format
@@ -672,12 +588,6 @@ msgid ""
 "yet documented and still experimental."
 msgstr ""
-#. Tag: term
-#: installation.xml:512
-#, no-c-format
-msgid "--with-sfcgal=PATH"
-msgstr ""
 #. Tag: para
 #: installation.xml:514
 #, no-c-format
@@ -687,12 +597,6 @@ msgid ""
 "alternate PATH to sfcgal-config."
 msgstr ""
-#. Tag: term
-#: installation.xml:521
-#, no-c-format
-msgid "--without-phony-revision"
-msgstr ""
 #. Tag: para
 #: installation.xml:523
 #, no-c-format
Summary of changes:
 doc/installation.xml                  | 32 ++++++------
 doc/po/strip_untranslatable.sh        |  1 +
 doc/po/templates/installation.xml.pot | 98 +----------------------------------
 3 files changed, 18 insertions(+), 113 deletions(-)
hooks/post-receive
