[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-547-g2a366e9b3
Thu Sep 14 13:13:02 PDT 2023
the project "PostGIS".
       via  2a366e9b3cabe0855d00e9b53509076203bf0d8a (commit)
       via  bdac1913f560d851b92a7f9c8de7e4e6b313733f (commit)
      from  43d23f4ce7d21b32fa06964b89bc249d63a33d14 (commit)
revisions in full, below.
commit 2a366e9b3cabe0855d00e9b53509076203bf0d8a
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Sep 14 22:12:30 2023 +0200
    Use the legacy URI for docbook.xsl
    References #5539
diff --git a/doc/Makefile.in b/doc/Makefile.in
index e6b3928aa..eaf8576f7 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -111,7 +111,10 @@ XSLTPROC_CHUNKED_HTML_OPTS = \
 	--stringparam img.src.path ../ \
 	--stringparam html.stylesheet ../style.css
-DOCBOOK_XSLBASE=http://cdn.docbook.org/release/xsl/current
+# FIXME: the official URI would be http://cdn.docbook.org/release/xsl/current/
+# but see https://trac.osgeo.org/postgis/ticket/5539
+#DOCBOOK_XSLBASE=http://cdn.docbook.org/release/xsl/current
+DOCBOOK_XSLBASE=http://docbook.sourceforge.net/release/xsl-ns
 HTML_DOCBOOK_XSL=$(DOCBOOK_XSLBASE)/html/docbook.xsl
 CHUNK_HTML_DOCBOOK_XSL=$(DOCBOOK_XSLBASE)/html/chunk.xsl
commit bdac1913f560d851b92a7f9c8de7e4e6b313733f
Date:   Thu Sep 14 22:11:15 2023 +0200
    Search for xmlcatalog at configure time
diff --git a/configure.ac b/configure.ac
index 1ecbc1a22..f4b0a34e9 100644
--- a/configure.ac
+++ b/configure.ac
@@ -205,6 +205,12 @@ if test "x$XSLTPROC" = "x"; then
   CAN_BUILD_COMMENTS=no
 fi
+AC_PATH_PROG([XMLCATALOG], [xmlcatalog], [])
+if test "x$XMLCATALOG" = "x"; then
+	AC_MSG_WARN([xmlcatalog is not installed so documentation cannot be built])
+	CAN_BUILD_COMMENTS=no
+fi
 AC_PATH_PROG([XML2POT], [xml2pot], [])
 if test "x$XML2POT" = "x"; then
 	AC_MSG_WARN([xml2pot is not installed so translations cannot be updated])
index b1b3c1b57..e6b3928aa 100644
@@ -588,9 +588,9 @@ check-cheatsheets: requirements_not_met_xmllint
 else
 check-xml: postgis-out.xml
 	# Fail early if cannot find required RelaxNG
-	xmlcatalog "" "http://docbook.org/xml/5.0/rng/docbook.rng"
+	$(XMLCATALOG) "" "http://docbook.org/xml/5.0/rng/docbook.rng"
 	# Fail early if cannot find required DTD
-	xmlcatalog "" "http://docbook.org/xml/5.0/dtd/docbook.dtd"
+	$(XMLCATALOG) "" "http://docbook.org/xml/5.0/dtd/docbook.dtd"
 	# TODO: --schematron http://docbook.org/xml/5.0/sch/docbook.sch
 	# See https://trac.osgeo.org/postgis/ticket/5532
 	$(XMLLINT) --noout --nonet \
Summary of changes:
 configure.ac    | 6 ++++++
 doc/Makefile.in | 9 ++++++---
 2 files changed, 12 insertions(+), 3 deletions(-)
hooks/post-receive
