[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-553-g34ee46ef1
Thu Sep 14 14:10:55 PDT 2023
the project "PostGIS".
       via  34ee46ef1532ab53b090fc7f6d73ac0d73703923 (commit)
      from  0041dedc12d7cfcaf5d0bdfb1d0e37b20a218cfc (commit)
revisions in full, below.
commit 34ee46ef1532ab53b090fc7f6d73ac0d73703923
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Sep 14 23:10:33 2023 +0200
    Encode new requirement on xmlcatalog
diff --git a/doc/Makefile.in b/doc/Makefile.in
index 18a224282..27c615289 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -330,6 +330,8 @@ postgis-out.xml: postgis.xml Makefile $(XML_INPUTS) Makefile
 ifeq ($(XMLLINT),)
 postgis-nospecial.xml: requirements_not_met_xmllint
 postgis-out.xml: requirements_not_met_xmllint
+check-xml: requirements_not_met_xmllint
+check-cheatsheets: requirements_not_met_xmllint
 endif
 chunked-html: $(html_builddir)/postgis$(DOCSUFFIX)/docbook.css
@@ -583,10 +585,10 @@ check-regress:
 check-unit: check-xml
-ifeq ($(XMLLINT),)
-check-xml: requirements_not_met_xmllint
-check-cheatsheets: requirements_not_met_xmllint
-else
+ifeq ($(XMLCATALOG),)
+check-xml: requirements_not_met_xmlcatalog
+endif
 check-xml: postgis-out.xml
 	# Fail early if cannot find required RelaxNG
 	$(XMLCATALOG) "" "http://docbook.org/xml/5.0/rng/docbook.rng"
@@ -599,15 +601,11 @@ check-xml: postgis-out.xml
 		--relaxng http://docbook.org/xml/5.0/rng/docbook.rng \
 check-cheatsheets: cheatsheets
 	for f in $(html_builddir)/*_cheatsheet-en.html; do \
 		$(abs_top_srcdir)/utils/check_localized_cheatsheets.sh $${f} en $(patsubst -%,%,$(DOCSUFFIX)) || exit 1; \
 	done
-endif
 requirements_not_met_xsltproc:
 	@echo
 	@echo "configure was unable to find 'xsltproc' which is required"
@@ -627,6 +625,15 @@ requirements_not_met_xmllint:
 	@echo
 	@false
+requirements_not_met_xmlcatalog:
+	@echo
+	@echo "configure was unable to find 'xmlcatalog' which is required"
+	@echo "to check the postgis documentation."
+	@echo "Install xmlcatalog and then re-run configure."
+	@echo
+	@false
 requirements_not_met_xslbase:
 	@echo
 	@echo "configure was unable to find the Docbook XSL stylesheet directory"
Summary of changes:
 doc/Makefile.in | 23 +++++++++++++++--------
 1 file changed, 15 insertions(+), 8 deletions(-)
hooks/post-receive
