[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-556-g65dbb2b9c
Thu Sep 14 16:39:30 PDT 2023
the project "PostGIS".
       via  65dbb2b9c24c477a28015a1903ed62ef4e19b621 (commit)
      from  936ce3efcec8c2e6351c0acd1ec4e9c5622f74c3 (commit)
revisions in full, below.
commit 65dbb2b9c24c477a28015a1903ed62ef4e19b621
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Sep 15 01:38:53 2023 +0200
    Replace expr with posix case
    Hopefully fixes macos build,
    ref https://cirrus-ci.com/task/6421549176061952
diff --git a/configure.ac b/configure.ac
index fab4f2b20..99ce20667 100644
--- a/configure.ac
+++ b/configure.ac
@@ -295,23 +295,28 @@ if test "x$XSLBASE" = "x"; then
 		/usr/share/xsl/docbook-xsl
 	for p in ${SEARCHPATH}; do
-    if expr "${p}" : / >/dev/null; then
-      AC_MSG_CHECKING([for html/docbook.xsl in directory $p...])
-      if test -r "${p}"/html/docbook.xsl; then
-        XSLBASE_AUTO="${p}"
-        AC_MSG_RESULT([found])
-        break
-      fi
-      AC_MSG_RESULT([not found])
-    elif test "x$XMLCATALOG" != "x"; then
-      AC_MSG_CHECKING([for html/docbook.xsl in URI $p...])
-      if $XMLCATALOG '' "${p}/html/docbook.xsl" >/dev/null; then
-        break
-      fi
-    fi
+    case "${p}" in
+        AC_MSG_CHECKING([for html/docbook.xsl in directory $p...])
+        if test -r "${p}"/html/docbook.xsl; then
+          XSLBASE_AUTO="${p}"
+          AC_MSG_RESULT([found])
+          break
+        fi
+        AC_MSG_RESULT([not found])
+        if test "x$XMLCATALOG" != "x"; then
+          AC_MSG_CHECKING([for html/docbook.xsl in URI $p...])
+          if $XMLCATALOG '' "${p}/html/docbook.xsl" >/dev/null; then
+            break
+          fi
+        fi
+    esac
 	done
 	dnl Check to see if the automatically searched paths above located a
Summary of changes:
 configure.ac | 39 ++++++++++++++++++++++-----------------
 1 file changed, 22 insertions(+), 17 deletions(-)
hooks/post-receive
