[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-563-gf9f2002cc
Thu Sep 14 19:19:42 PDT 2023
the project "PostGIS".
       via  f9f2002cc64e07bfec8070e4b5774ee07472a7ff (commit)
      from  1e71cf1c0abab47163c85f60d87c6826b2ac2525 (commit)
revisions in full, below.
commit f9f2002cc64e07bfec8070e4b5774ee07472a7ff
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Sep 15 04:19:01 2023 +0200
    Do not override .pot file if no messages changed in XML files
    Closes #5455
diff --git a/doc/Makefile.in b/doc/Makefile.in
index aaf3e4e53..36519e36e 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -267,6 +267,7 @@ endif
 ifeq ($(MSGCOMM),)
 $(PO_FILES): requirements_not_met_msgcomm
+$(XML_UNIFIED_POT): requirements_not_met_msgcomm
 endif
 ifeq ($(MSGCAT),)
@@ -289,13 +290,9 @@ $(XML_SOURCE_POTS): %.xml.pot: %.xml
 update-pot: $(XML_UNIFIED_POT)
 $(XML_UNIFIED_POT): $(XML_SOURCE_POTS)
-	$(MSGCAT) --use-first --no-location -o $@.tmp $(XML_SOURCE_POTS)
+	@$(MSGCAT) --use-first --no-location -o $@.tmp $(XML_SOURCE_POTS)
 	@if test -f $@; then \
-    changed=`diff $@.tmp $@ \
-			| grep -v '^[<>] "POT-Creation-Date:' \
-			| grep -v '^[<>] "Report-Msgid-Bugs-To:' \
-			| wc -l`; \
-    if expr $${changed} \> 3 >/dev/null; then \
+    if test -n "$$($(MSGCOMM) --unique $@.tmp $@ | tail -1)"; then \
       echo "$@ updated"; \
     else \
       echo "$@ unchanged"; \
Summary of changes:
 doc/Makefile.in | 9 +++------
 1 file changed, 3 insertions(+), 6 deletions(-)
hooks/post-receive
