[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-562-g1e71cf1c0
Thu Sep 14 19:13:50 PDT 2023
the project "PostGIS".
       via  1e71cf1c0abab47163c85f60d87c6826b2ac2525 (commit)
       via  dfdc9c4f6f9e05f9b43222b1e2f1d0c51919a0cf (commit)
       via  e7a349cd7eea5db9bf3094028074655de9c3d51d (commit)
      from  506e27a69dace92684a7a44b6e965d3cdfcecc2b (commit)
revisions in full, below.
commit 1e71cf1c0abab47163c85f60d87c6826b2ac2525
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Sep 15 04:12:08 2023 +0200
    Try XSL base uri https://cdn.docbook.org/release/xsl/current too
    Might be needed for MacOS:
    https://github.com/Homebrew/homebrew-core/blob/b90647c158fb3a37fce5417b2348190ef77259a3/Formula/d/docbook-xsl.rb#L88
    See how existing uris and directories did not help:
    https://cirrus-ci.com/task/4704652273385472?logs=test#L1022
diff --git a/configure.ac b/configure.ac
index 36f954ef8..0fd6d5d6b 100644
--- a/configure.ac
+++ b/configure.ac
@@ -288,6 +288,7 @@ if test "x$XSLBASE" = "x"; then
 	dnl that matches from the following list
 	SEARCHPATH="
 		http://cdn.docbook.org/release/xsl/current
+		https://cdn.docbook.org/release/xsl/current
 		http://docbook.sourceforge.net/release/xsl-ns/current
 		/usr/share/sgml/docbook/xsl-stylesheets
 		/usr/share/xml/docbook/stylesheet/docbook-xsl-ns
commit dfdc9c4f6f9e05f9b43222b1e2f1d0c51919a0cf
Date:   Fri Sep 15 04:08:38 2023 +0200
    Do not override .po files if no messages changed in template file
    References #5455
index 99ce20667..36f954ef8 100644
--- a/configure.ac
+++ b/configure.ac
@@ -226,6 +226,11 @@ if test "x$MSGCAT" = "x"; then
 	AC_MSG_WARN([msgcat is not installed so translation templates cannot be updated])
 fi
+AC_PATH_PROG([MSGCOMM], [msgcomm], [])
+if test "x$MSGCOMM" = "x"; then
+	AC_MSG_WARN([msgcomm is not installed so translations cannot be updated])
+fi
 AC_PATH_PROG([MSGATTRIB], [msgattrib], [])
 if test "x$MSGATTRIB" = "x"; then
 	AC_MSG_WARN([msgattrib is not installed so translations cannot be updated])
diff --git a/doc/Makefile.in b/doc/Makefile.in
index 2d1a9f21a..aaf3e4e53 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -7,7 +7,7 @@
 # PostGIS documentation build Makefile
-# Copyright 2003-2022 Sandro Santilli <strk at kbt.io>
+# Copyright 2003-2023 Sandro Santilli <strk at kbt.io>
 # Copyright 2004-2012 Paul Ramsey <pramsey at cleverelephant.ca>
 # Copyright 2009-2022 Regina Obe <lr at pcorp.us>
 # Copyright 2008-2010 Mark Cave-Ayland
@@ -121,6 +121,7 @@ DBLATEX=@DBLATEX@
 # Gettext for translated documentation
 MSGCAT=@MSGCAT@
+MSGCOMM=@MSGCOMM@
 MSGMERGE=@MSGMERGE@
 MSGINIT=@MSGINIT@
 MSGATTRIB=@MSGATTRIB@
@@ -256,13 +257,33 @@ GENERATED_CHEATSHEET_FILES = $(patsubst \
 VPATH = $(srcdir)
+ifeq ($(MSGMERGE),)
+$(PO_FILES): requirements_not_met_msgmerge
+endif
+ifeq ($(MSGATTRIB),)
+$(PO_FILES): requirements_not_met_msgattrib
+endif
+ifeq ($(MSGCOMM),)
+$(PO_FILES): requirements_not_met_msgcomm
+endif
+ifeq ($(MSGCAT),)
+$(XML_UNIFIED_POT): requirements_not_met_msgcat
+endif
+ifeq ($(MSGINIT),)
+$(PO_FILES): requirements_not_met_msginit
+endif
 ifeq ($(XML2POT),)
 $(XML_SOURCE_POTS): requirements_not_met_xml2pot
-else
+endif
 $(XML_SOURCE_POTS): %.xml.pot: %.xml
 	$(XML2POT) $< > $@
 	$(abs_srcdir)/po/strip_untranslatable.sh $@
-endif
 # Update translation template
 update-pot: $(XML_UNIFIED_POT)
@@ -286,20 +307,23 @@ $(XML_UNIFIED_POT): $(XML_SOURCE_POTS)
 # Creates or updates translation files
 update-po: $(PO_FILES)
-ifeq ($(MSGMERGE),)
-$(PO_FILES): requirements_not_met_msgmerge
-endif
 $(PO_FILES): $(XML_UNIFIED_POT)
 	@mkdir -p `dirname $@`
 	@lang=`basename $$(dirname $@)`; \
 	if test -f $@; then \
-		echo "Updating po file for language $$lang..." ; \
-		$(MSGMERGE) --no-fuzzy-matching --update $@ $(XML_UNIFIED_POT) && \
-		$(MSGATTRIB) --no-obsolete -o $@ $@ || exit 1; \
+		$(MSGMERGE) --no-fuzzy-matching -q -o $@.tmp $@ $(XML_UNIFIED_POT) || exit 1; \
+		$(MSGATTRIB) --no-obsolete -o $@.tmp $@.tmp || exit 1; \
+		if test -n "$$($(MSGCOMM) --unique $@.tmp $@ | tail -1)"; then \
+			mv $@.tmp $@; \
+			echo "$@ updated"; \
+		else \
+			echo "$@ unchanged"; \
+			touch $@; \
+			rm -f $@.tmp; \
+		fi; \
 	else \
-		echo "Creating po file for language $$lang..." ; \
 		$(MSGINIT) -i $(XML_UNIFIED_POT) -o $@ -l $$lang --no-translator || exit 1; \
+		echo "$@ created"; \
 	fi;
 ifeq ($(XSLTPROC),)
@@ -651,11 +675,17 @@ requirements_not_met_xslbase:
 	@echo "  http://postgis.net/documentation"
 	@echo
+requirements_not_met_msginit: requirements_not_met_gettext
+requirements_not_met_msgattrib: requirements_not_met_gettext
+requirements_not_met_msgcat: requirements_not_met_gettext
+requirements_not_met_msgcomm: requirements_not_met_gettext
+requirements_not_met_msgmerge: requirements_not_met_gettext
 requirements_not_met_gettext:
 	@echo
-	@echo "configure was unable to find both gettext's 'msgmerge' utility program."
+	@echo "configure was unable to find gettext utility programs."
 	@echo "To update the translation templates, install gettext and then re-run configure."
 	@echo
+	@false
 requirements_not_met_xml2pot:
 	@echo
commit e7a349cd7eea5db9bf3094028074655de9c3d51d
Date:   Fri Sep 15 02:36:28 2023 +0200
    Allow parallel po update
index 27c615289..2d1a9f21a 100644
@@ -236,6 +236,12 @@ XML_SOURCE_POTS = $(XML_SOURCES:%.xml=%.xml.pot)
 XML_UNIFIED_POT = $(srcdir)/po/templates/postgis-manual.pot
+PO_FILES = $(patsubst \
+	$(srcdir)/po/%/postgis-manual.po, \
+	$(translations) \
 GENERATED_COMMENT_FILES = $(patsubst \
 	$(srcdir)/xsl/%.xsl, \
@@ -278,24 +284,24 @@ $(XML_UNIFIED_POT): $(XML_SOURCE_POTS)
 	@if test -e $@.tmp; then mv $@.tmp $@; fi
+update-po: $(PO_FILES)
 ifeq ($(MSGMERGE),)
-update-po: requirements_not_met_msgmerge
-else
-update-po: $(XML_UNIFIED_POT)
-	@for lang in $(translations); do \
-    mkdir -p $(srcdir)/po/$$lang; \
-		po=$(srcdir)/po/$$lang/`basename $(XML_UNIFIED_POT) .pot`.po; \
-		if test -f $$po; then \
-			$(MSGMERGE) --no-fuzzy-matching --update $$po $(XML_UNIFIED_POT) && \
-			$(MSGATTRIB) --no-obsolete -o $$po $$po || exit 1; \
-		else \
-			$(MSGINIT) -i $(XML_UNIFIED_POT) -o $$po -l $$lang --no-translator || exit 1; \
-		fi; \
-  done
 endif
+$(PO_FILES): $(XML_UNIFIED_POT)
+	@mkdir -p `dirname $@`
+	@lang=`basename $$(dirname $@)`; \
+	if test -f $@; then \
+		echo "Updating po file for language $$lang..." ; \
+		$(MSGMERGE) --no-fuzzy-matching --update $@ $(XML_UNIFIED_POT) && \
+		$(MSGATTRIB) --no-obsolete -o $@ $@ || exit 1; \
+	else \
+		echo "Creating po file for language $$lang..." ; \
+		$(MSGINIT) -i $(XML_UNIFIED_POT) -o $@ -l $$lang --no-translator || exit 1; \
+	fi;
 ifeq ($(XSLTPROC),)
 $(XSL_GENERATED_SOURCES): requirements_not_met_xsltproc
 else
Summary of changes:
 configure.ac    |  6 +++++
 doc/Makefile.in | 74 ++++++++++++++++++++++++++++++++++++++++++---------------
 2 files changed, 61 insertions(+), 19 deletions(-)
hooks/post-receive
