[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-565-ga830a8833
Thu Sep 14 22:27:07 PDT 2023
the project "PostGIS".
       via  a830a8833ffccd18e53f8ae500a77c4c20783b60 (commit)
      from  3a4b92978a0abcc6683a7342a6efdfc7befd2967 (commit)
revisions in full, below.
commit a830a8833ffccd18e53f8ae500a77c4c20783b60
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Sep 15 01:25:20 2023 -0400
    FIX GARDEN TESTS
     1. Makefile, was generating postgis for raster
     2. Fix namespaces in xsl
     3. Prefix tables with 35 instead of 34
     Closes #5540 for PostGIS 3.5.0
diff --git a/doc/Makefile.in b/doc/Makefile.in
index 36519e36e..9a59bc361 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -604,7 +604,7 @@ else
 garden: postgis_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql raster_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql
 endif
-%_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql: xsl/postgis_gardentest.sql.xsl postgis-out.xml
+%_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql: xsl/%_gardentest.sql.xsl postgis-out.xml
 	$(XSLTPROC) -o $@ $(XSLTPROC_PATH_OPT) $^
 check: check-unit
diff --git a/doc/xsl/postgis_gardentest.sql.xsl b/doc/xsl/postgis_gardentest.sql.xsl
index 06a942649..bd1dcfb1c 100644
--- a/doc/xsl/postgis_gardentest.sql.xsl
+++ b/doc/xsl/postgis_gardentest.sql.xsl
@@ -1,5 +1,8 @@
-<xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform"  xmlns:pgis="http://www.postgis.org/pgis">
+<xsl:stylesheet version="1.0"
+	xmlns:xsl="http://www.w3.org/1999/XSL/Transform"
+	xmlns:db="http://docbook.org/ns/docbook" xmlns:pgis="http://postgis.net/pgis"
 	 Copyright 2008-2010, Regina Obe
@@ -8,7 +11,7 @@
 			using a garden variety of geometries.  Its intent is to flag major crashes.
 	<xsl:output method="text" />
-	<xsl:variable name='testversion'>3.4.0</xsl:variable>
+	<xsl:variable name='testversion'>3.5.0</xsl:variable>
 	<xsl:variable name='fnexclude14'>AddGeometryColumn DropGeometryColumn DropGeometryTable</xsl:variable>
 	<xsl:variable name='fnexclude'>AddGeometryColumn DropGeometryColumn DropGeometryTable</xsl:variable>
 	<!--This is just a place holder to state functions not supported or tested separately -->
@@ -33,7 +36,7 @@
 	<xsl:variable name='var_matrix'>'FF1FF0102'</xsl:variable>
 	<xsl:variable name='var_boolean'>false</xsl:variable>
 	<xsl:variable name='var_geom_name'>the_geom</xsl:variable>
-	<xsl:variable name='var_logtable'>postgis_garden_log34</xsl:variable>
+	<xsl:variable name='var_logtable'>postgis_garden_log35</xsl:variable>
 	<xsl:variable name='var_logupdatesql'>UPDATE <xsl:value-of select="$var_logtable" /> SET log_end = clock_timestamp()
 		FROM (SELECT logid FROM <xsl:value-of select="$var_logtable" /> ORDER BY logid DESC limit 1) As foo
 		WHERE <xsl:value-of select="$var_logtable" />.logid = foo.logid  AND <xsl:value-of select="$var_logtable" />.log_end IS NULL;</xsl:variable>
@@ -330,7 +333,7 @@ CREATE TABLE <xsl:value-of select="$var_logtable" />_output(logid integer PRIMAR
                 <xsl:apply-templates select="/db:book/db:chapter[@xml:id='reference']" />
         </xsl:template>
-	<xsl:template match='chapter'>
+	<xsl:template match='db:chapter'>
 <!--Start Test table creation, insert, analyze crash test, drop -->
 		<xsl:for-each select="document('')//pgis:gardens/pgis:gset[not(contains(@createtable,'false'))]">
 			<xsl:variable name='log_label'>table Test <xsl:value-of select="@GeometryType" /></xsl:variable>
@@ -468,7 +471,7 @@ SELECT '<xsl:value-of select="$log_label" /> Geography: End Testing';
 <!--End Test table creation, insert, drop  -->
 <!--Start test on operators  -->
-	<xsl:for-each select="db:sect1[contains(@xml:id,'Operator') and not(contains($fnexclude,db:funcdef/db:function))]/db:refentry">
+	<xsl:for-each select="db:section[contains(@xml:id,'Operator') and not(contains($fnexclude,db:funcdef/db:function))]/db:refentry">
 		<xsl:sort select="@id"/>
 		<xsl:for-each select="db:refsynopsisdiv/db:funcsynopsis/db:funcprototype">
 			<xsl:variable name='fnname'><xsl:value-of select="db:funcdef/db:function"/></xsl:variable>
@@ -521,7 +524,7 @@ SELECT '<xsl:value-of select="$log_label" /> Geography: End Testing';
 	</xsl:for-each>
 <!--End test on operators -->
 <!-- Start regular function checks excluding operators -->
-		<xsl:for-each select="db:sect1[not(contains(@xml:id,'Operator'))]//db:refentry">
+		<xsl:for-each select="db:section[not(contains(@xml:id,'Operator'))]//db:refentry">
diff --git a/doc/xsl/raster_gardentest.sql.xsl b/doc/xsl/raster_gardentest.sql.xsl
index 275532314..1565dc041 100644
--- a/doc/xsl/raster_gardentest.sql.xsl
+++ b/doc/xsl/raster_gardentest.sql.xsl
@@ -1,6 +1,8 @@
 	 Copyright 2010, Regina Obe
 	 License: BSD-3-Clause
@@ -8,7 +10,7 @@
 			using a garden variety of rasters.  Its intent is to flag major crashes.
 	<xsl:variable name='fnexclude'>AddRasterColumn AddRasterConstraints DropRasterConstraints DropRasterColumn DropRasterTable</xsl:variable>
 	<!--This is just a place holder to state functions not supported in 1.3 or tested separately -->
@@ -31,7 +33,7 @@
 	<xsl:variable name='var_rastercolumn'>'rast'</xsl:variable>
 	<xsl:variable name='var_rastertable'>'pgis_rgarden_1bb'</xsl:variable>
-	<xsl:variable name='var_logtable'>raster_garden_log34</xsl:variable>
+	<xsl:variable name='var_logtable'>raster_garden_log35</xsl:variable>
 	<xsl:variable name='var_pixeltypes'>{8BUI,1BB}</xsl:variable>
 	<xsl:variable name='var_pixelvalues'>{255,0}</xsl:variable>
 	<xsl:variable name='var_algorithm'>'Lanczos'</xsl:variable>
@@ -131,9 +133,10 @@ DROP TABLE IF EXISTS <xsl:value-of select="$var_logtable" />;
 CREATE TABLE <xsl:value-of select="$var_logtable" />(logid serial PRIMARY KEY, log_label text, spatial_class text DEFAULT 'raster', func text, g1 text, g2 text, log_start timestamp, log_end timestamp, log_sql text);
 DROP TABLE IF EXISTS <xsl:value-of select="$var_logtable" />_output;
 CREATE TABLE <xsl:value-of select="$var_logtable" />_output(logid integer PRIMARY KEY, log_output xml);
-            <xsl:apply-templates select="/db:book/db:chapter[@xml:id='RT_reference']" />
+						<xsl:apply-templates select="/db:book/db:chapter[@xml:id='RT_reference']" />
+            <xsl:apply-templates select="/db:book/db:chapter[@xml:id='RT_reference']/db:section[contains(@xml:id, 'Type')]" />
         </xsl:template>
 <!-- define a table we call pgis_rgarden_mega that will contain a raster column with a band for all types of pixels we support -->
 DROP TABLE IF EXISTS pgis_rgarden_mega;
 CREATE TABLE pgis_rgarden_mega(rid serial PRIMARY KEY, rast raster);
@@ -189,7 +192,7 @@ COMMIT;
-	<xsl:for-each select="db:sect1[contains(@xml:id,'RT_Operator')]//db:refentry">
+	<xsl:for-each select="db:section[contains(@xml:id,'RT_Operator')]/db:refentry">
@@ -239,7 +242,7 @@ COMMIT;
-		<xsl:for-each select="db:sect1[not(contains(@xml:id,'Operator'))]/db:refentry">
+		<xsl:for-each select="db:section[not(contains(@xml:id,'Operator'))]/db:refentry">
Summary of changes:
 doc/Makefile.in                    |  2 +-
 doc/xsl/postgis_gardentest.sql.xsl | 15 +++++++++------
 doc/xsl/raster_gardentest.sql.xsl  | 19 +++++++++++--------
 3 files changed, 21 insertions(+), 15 deletions(-)
hooks/post-receive
