[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-566-g698c0cd04
Fri Sep 15 04:23:41 PDT 2023
the project "PostGIS".
       via  698c0cd04e8f28b01c874ac138be3d5048199e2b (commit)
      from  a830a8833ffccd18e53f8ae500a77c4c20783b60 (commit)
revisions in full, below.
commit 698c0cd04e8f28b01c874ac138be3d5048199e2b
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Sep 15 10:02:23 2023 +0000
    Translated PostGIS Manual using Weblate (Italian)
    Currently translated at 21.4% (1239 of 5771 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/it/
diff --git a/doc/po/it_IT/postgis-manual.po b/doc/po/it_IT/postgis-manual.po
index ec04cd19f..8f407e31a 100644
--- a/doc/po/it_IT/postgis-manual.po
+++ b/doc/po/it_IT/postgis-manual.po
@@ -6,10 +6,10 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2023-09-14 17:40+0000\n"
-"PO-Revision-Date: 2023-09-14 23:56+0000\n"
+"PO-Revision-Date: 2023-09-15 11:23+0000\n"
 "Last-Translator: Sandro Santilli <strk at kbt.io>\n"
-"Language-Team: Italian <https://weblate.osgeo.org/projects/postgis/postgis-"
-"manual/it/>\n"
+"Language-Team: Italian <https://weblate.osgeo.org/projects/postgis/"
+"postgis-manual/it/>\n"
 "Language: it_IT\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
@@ -109,7 +109,7 @@ msgstr ""
 #. Tag: term
 #, no-c-format
 msgid "Country code"
-msgstr ""
+msgstr "Codice paese"
 #. Tag: para
 #, no-c-format
@@ -121,7 +121,7 @@ msgstr ""
 #. Tag: term
 #, no-c-format
 msgid "Postcode/zipcode"
-msgstr ""
+msgstr "Codice postale"
 #. Tag: para
 #, no-c-format
@@ -130,11 +130,14 @@ msgid ""
 "are currently in the parseaddress-api.c and are relatively simple to make "
 "changes to if needed."
 msgstr ""
+"Questi vengono riconosciuti usando espressioni regolari compatibili con "
+"Perl. Queste regex sono attualmente contenute in parseaddress-api.c e sono "
+"relativamente semplici da modificare se necessario."
 #. Tag: term
 #, no-c-format
 msgid "State/province"
-msgstr ""
+msgstr "Stato/provincia"
 #. Tag: para
 #, no-c-format
@@ -143,11 +146,14 @@ msgid ""
 "are currently in the parseaddress-api.c but could get moved into includes in "
 "the future for easier maintenance."
 msgstr ""
+"Perl. Queste regex sono attualmente nel file parseaddress-api.c, ma in "
+"futuro potrebbero essere spostate in includes per facilitare la manutenzione."
 #. Tag: title
 #, no-c-format
 msgid "Address Standardizer Types"
-msgstr ""
+msgstr "Tipi di standardizzatori di indirizzi"
 #. Tag: para
 #, no-c-format
@@ -167,6 +173,8 @@ msgid ""
 "A composite type that consists of the elements of an address. This is the "
 "return type for <varname>standardize_address</varname> function."
 msgstr ""
+"Un tipo composito che consiste negli elementi di un indirizzo. È il tipo di "
+"ritorno della funzione <varname>standardize_address</varname>."
 #. Tag: title
 #, no-c-format
@@ -181,6 +189,11 @@ msgid ""
 "for elements are borrowed from <link xlink:href=\"http://www.pagcgeo.org/"
 "docs/html/pagc-12.html#ss12.1\">PAGC Postal Attributes</link>."
 msgstr ""
+"Un tipo composito che consiste in elementi di un indirizzo. È il tipo di "
+"ritorno della funzione <xref linkend=\"standardize_address\"/>. Alcune "
+"descrizioni degli elementi sono prese in prestito da <link xlink:href=\"http"
+"://www.pagcgeo.org/docs/html/pagc-12.html#ss12.1\">PAGC Postal "
+"Attributes</link>."
 #. Tag: para
 #, no-c-format
@@ -188,11 +201,13 @@ msgid ""
 "The token numbers denote the output reference number in the <xref linkend="
 "\"rulestab\"/>."
 msgstr ""
+"I numeri dei token indicano il numero di riferimento dell'uscita di <xref "
+"linkend=\"rulestab\"/>."
 #. Tag: para
 #, no-c-format
 msgid "&address_standardizer_required;"
-msgstr ""
+msgstr "&address_standardizer_required;"
 #. Tag: term
 #, no-c-format
Summary of changes:
 doc/po/it_IT/postgis-manual.po | 31 +++++++++++++++++++++++--------
 1 file changed, 23 insertions(+), 8 deletions(-)
hooks/post-receive
