[postgis-tickets] [PostGIS] #5542: docbook5 | ../../doc/postgis_comments.sql: No such file or directory
PostGIS trac at osgeo.org
Sat Sep 16 15:41:50 PDT 2023
 Reporter:  ImreSamu                 |      Owner:  strk
     Type:  defect                   |     Status:  new
 Priority:  medium                   |  Milestone:  PostGIS 3.5.0
Component:  build/upgrade/install    |    Version:  master
 Keywords:  docbook5 docker-postgis  |
 The recent updates to the master version of PostGIS related to 'docbook5'
 caused a building problem in the Docker PostGIS master images.  (
 {{{postgis/postgis:15-master}}} )
 An error message showed up, saying a certain file couldn't be found.
 cat: ../../doc/postgis_comments.sql: No such file or directory
 Ideally, there should've been a warning about missing components, or no
 error at all.
 The issue was resolved by including the following building components:
 - docbook-xml
 - docbook5-xml
 - libxml2-utils
 patch/workaround:  https://github.com/postgis/docker-
 postgis/pull/359/commits/b1591edf1351ea3141934d3996253e84686afcc0
 original log:
 #17 173.8       | /usr/bin/perl ../../utils/create_extension_unpackage.pl
 postgis >> sql/raster_unpackage.sql
 #17 173.8 /usr/bin/perl ../../utils/create_upgrade.pl
 sql/postgis_for_extension.sql > sql/postgis_upgrade_for_extension.sql.in
 #17 173.8 sed -ne '/UNPACKAGE_CODE/{s///; :a' -e 'n;p;ba' -e '}' \
 #17 173.8       ./unpackage_raster_if_needed.sql  >>
 #17 173.8 printf '\\echo Use "CREATE EXTENSION postgis" to load this file.
 \\quit\n' > sql/postgis--3.5.0dev.sql
 #17 173.8 cat sql/postgis_for_extension.sql ../../doc/postgis_comments.sql
 sql/spatial_ref_sys_config_dump.sql sql/spatial_ref_sys.sql >> sql/postgis
 --3.5.0dev.sql
 #17 173.8 cat: ../../doc/postgis_comments.sql: No such file or directory
 #17 173.8 make[2]: *** [Makefile:95: sql/postgis--3.5.0dev.sql] Error 1
 #17 173.8 make[2]: *** Deleting file 'sql/postgis--3.5.0dev.sql'
 #17 173.8 make[2]: *** Waiting for unfinished jobs....
 #17 173.8 make[2]: Leaving directory '/usr/src/postgis/extensions/postgis'
 #17 173.9 make[1]: Leaving directory '/usr/src/postgis/extensions'
 #17 173.9 make[1]: *** [Makefile:29: all] Error 1
 #17 173.9 make: *** [GNUmakefile:25: all] Error 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5542>
