[postgis-tickets] [PostGIS] #5542: docbook5 | ../../doc/postgis_comments.sql: No such file or directory
PostGIS trac at osgeo.org
Sat Sep 16 18:39:12 PDT 2023
  Reporter:  ImreSamu               |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.5.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:  docbook5 docker-postgis
Comment (by ImreSamu):
 update:
 To resolve the issue, only the following two packages are needed:
 - docbook5-xml
 - libxml2-utils
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5542#comment:1>
