[postgis-tickets] [PostGIS] #5542: docbook5 | ../../doc/postgis_comments.sql: No such file or directory
PostGIS trac at osgeo.org
Sat Sep 16 18:47:04 PDT 2023
  Reporter:  ImreSamu               |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.5.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:  docbook5 docker-postgis
Description changed by ImreSamu:
Old description:
> The recent updates to the master version of PostGIS related to 'docbook5'
> caused a building problem in the Docker PostGIS master images.  (
> {{{postgis/postgis:15-master}}} )
> An error message showed up, saying a certain file couldn't be found.
> cat: ../../doc/postgis_comments.sql: No such file or directory
> Ideally, there should've been a warning about missing components, or no
> error at all.
> The issue was resolved by including the following building components:
> - docbook-xml
> - docbook5-xml
> - libxml2-utils
> patch/workaround:  https://github.com/postgis/docker-
> postgis/pull/359/commits/b1591edf1351ea3141934d3996253e84686afcc0
> original log:
> #17 173.8       | /usr/bin/perl ../../utils/create_extension_unpackage.pl
> postgis >> sql/raster_unpackage.sql
> #17 173.8 /usr/bin/perl ../../utils/create_upgrade.pl
> sql/postgis_for_extension.sql > sql/postgis_upgrade_for_extension.sql.in
> #17 173.8 sed -ne '/UNPACKAGE_CODE/{s///; :a' -e 'n;p;ba' -e '}' \
> #17 173.8       ./unpackage_raster_if_needed.sql  >>
> #17 173.8 printf '\\echo Use "CREATE EXTENSION postgis" to load this
> file. \\quit\n' > sql/postgis--3.5.0dev.sql
> #17 173.8 cat sql/postgis_for_extension.sql
> ../../doc/postgis_comments.sql sql/spatial_ref_sys_config_dump.sql
> sql/spatial_ref_sys.sql >> sql/postgis--3.5.0dev.sql
> #17 173.8 cat: ../../doc/postgis_comments.sql: No such file or directory
> #17 173.8 make[2]: *** [Makefile:95: sql/postgis--3.5.0dev.sql] Error 1
> #17 173.8 make[2]: *** Deleting file 'sql/postgis--3.5.0dev.sql'
> #17 173.8 make[2]: *** Waiting for unfinished jobs....
> #17 173.8 make[2]: Leaving directory
> '/usr/src/postgis/extensions/postgis'
> #17 173.9 make[1]: Leaving directory '/usr/src/postgis/extensions'
> #17 173.9 make[1]: *** [Makefile:29: all] Error 1
> #17 173.9 make: *** [GNUmakefile:25: all] Error 1
New description:
 error at all.
 - ~~docbook-xml~~ ( correction ! )
 - docbook5-xml
 - libxml2-utils
 original log:
 #17 173.8 printf '\\echo Use "CREATE EXTENSION postgis" to load this file.
 #17 173.8 cat sql/postgis_for_extension.sql ../../doc/postgis_comments.sql
 sql/spatial_ref_sys_config_dump.sql sql/spatial_ref_sys.sql >> sql/postgis
 --3.5.0dev.sql
 #17 173.8 make[2]: Leaving directory '/usr/src/postgis/extensions/postgis'
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5542#comment:2>
