[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-573-g2739e487f
Sat Sep 16 23:36:35 PDT 2023
the project "PostGIS".
       via  2739e487f7db1d344afe9f106c9f897264370de0 (commit)
      from  ea76f5eabe77a5bd494ca8d8022316a2d15d462a (commit)
revisions in full, below.
commit 2739e487f7db1d344afe9f106c9f897264370de0
Author: Sandro Santilli <strk at kbt.io>
Date:   Sun Sep 17 08:35:07 2023 +0200
    Disable extensions if comments cannot be built due to missing xmllint
    References #5542
diff --git a/configure.ac b/configure.ac
index 0fd6d5d6b..7f82a6cc8 100644
--- a/configure.ac
+++ b/configure.ac
@@ -211,6 +211,15 @@ if test "x$XMLCATALOG" = "x"; then
 	CAN_BUILD_COMMENTS=no
 fi
+AC_PATH_PROG([XMLLINT], [xmllint], [])
+if test "x$XMLLINT" = "x"; then
+	dnl AC_MSG_WARN([xmllint is not installed so documentation cannot be checked])
+	AC_MSG_WARN([xmlcatalog is not installed so documentation cannot be built])
+	CAN_BUILD_COMMENTS=no
+fi
 AC_PATH_PROG([XML2POT], [xml2pot], [])
 if test "x$XML2POT" = "x"; then
 	AC_MSG_WARN([xml2pot is not installed so translations cannot be updated])
@@ -266,12 +275,6 @@ if test "x$DBTOEPUB" = "x"; then
 fi
 AC_SUBST(CAN_BUILD_EPUB)
-AC_PATH_PROG([XMLLINT], [xmllint], [])
-if test "x$XMLLINT" = "x"; then
-	AC_MSG_WARN([xmllint is not installed so documentation cannot be checked])
-fi
 dnl
 dnl Allow the user to specify the location of the html/docbook.xsl stylesheet
 dnl
@@ -1749,9 +1752,9 @@ dnl ===========================================================================
 EXTENSIONS=""
 if test "x$PG_CONFIG" != "xno"; then
   if test \
-          "x$XSLTPROC" != "x" -o \
           -e doc/postgis_comments.sql -a \
-          -e doc/raster_comments.sql;
+          -e doc/raster_comments.sql -o \
+          "$CAN_BUILD_COMMENTS" = "yes"
   then
       AC_MSG_RESULT([enabling PostgreSQL extension support...])
       EXTENSIONS=extensions
Summary of changes:
 configure.ac | 19 +++++++++++--------
 1 file changed, 11 insertions(+), 8 deletions(-)
hooks/post-receive
