[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-574-g644797a9e
Sun Sep 17 00:02:59 PDT 2023
the project "PostGIS".
       via  644797a9ea72e4db0c8768b96fe1affd97252baf (commit)
      from  2739e487f7db1d344afe9f106c9f897264370de0 (commit)
revisions in full, below.
commit 644797a9ea72e4db0c8768b96fe1affd97252baf
Author: Sandro Santilli <strk at kbt.io>
Date:   Sun Sep 17 08:59:49 2023 +0200
    Do not check documentation on `make check` if deps are not met
    References #5536 #5542
diff --git a/doc/Makefile.in b/doc/Makefile.in
index 9a59bc361..b5becf14e 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -149,6 +149,7 @@ ifeq ($(CAN_BUILD_EPUB),yes)
 BUILD_TARGET += epub
 endif
 # TODO: add "html" to the BUILD_TARGET if it can be built
 all: $(BUILD_TARGET)
@@ -257,6 +258,22 @@ GENERATED_CHEATSHEET_FILES = $(patsubst \
 VPATH = $(srcdir)
+CAN_CHECK_XML = yes
+ifeq ($(XMLLINT),)
+postgis-nospecial.xml: requirements_not_met_xmllint
+postgis-out.xml: requirements_not_met_xmllint
+check-cheatsheets: requirements_not_met_xmllint
+check-xml: requirements_not_met_xmllint
+CAN_CHECK_XML = no
+endif
+ifeq ($(XMLCATALOG),)
+check-xml: requirements_not_met_xmlcatalog
+CAN_CHECK_XML = no
+endif
 ifeq ($(MSGMERGE),)
 $(PO_FILES): requirements_not_met_msgmerge
 endif
@@ -282,6 +299,13 @@ ifeq ($(XML2POT),)
 $(XML_SOURCE_POTS): requirements_not_met_xml2pot
 endif
+CHECK_UNIT_TARGET =
+ifeq ($(CAN_CHECK_XML),yes)
+CHECK_UNIT_TARGET = check-xml
+endif
 $(XML_SOURCE_POTS): %.xml.pot: %.xml
 	$(XML2POT) $< > $@
 	$(abs_srcdir)/po/strip_untranslatable.sh $@
@@ -354,13 +378,6 @@ postgis-out.xml: postgis.xml Makefile $(XML_INPUTS) Makefile
 	$(PERL) -lpe "s'@@LAST_RELEASE_VERSION@@'${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}'g;s'@@POSTGIS_DOWNLOAD_URL@@'${POSTGIS_DOWNLOAD_URL}'g;" $< > $@.in
 	$(XMLLINT) $(XSLTPROC_PATH_OPT) --noent -o $@ $@.in
-ifeq ($(XMLLINT),)
-postgis-nospecial.xml: requirements_not_met_xmllint
-postgis-out.xml: requirements_not_met_xmllint
-check-xml: requirements_not_met_xmllint
-check-cheatsheets: requirements_not_met_xmllint
-endif
 chunked-html: $(html_builddir)/postgis$(DOCSUFFIX)/docbook.css
 $(html_builddir)/postgis$(DOCSUFFIX)/docbook.css: postgis-out.xml Makefile
 	$(XSLTPROC) $(XSLTPROC_COMMONOPTS) \
@@ -610,11 +627,7 @@ endif
 check: check-unit
 check-regress:
-check-unit: check-xml
-ifeq ($(XMLCATALOG),)
-check-xml: requirements_not_met_xmlcatalog
-endif
+check-unit: $(CHECK_UNIT_TARGET)
 check-xml: postgis-out.xml
 	# Fail early if cannot find required RelaxNG
Summary of changes:
 doc/Makefile.in | 37 +++++++++++++++++++++++++------------
 1 file changed, 25 insertions(+), 12 deletions(-)
hooks/post-receive
