[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-600-gf21036ff2
Wed Sep 20 00:36:37 PDT 2023
the project "PostGIS".
       via  f21036ff23bfa555a04a78483d6160d180b510a1 (commit)
      from  ff129279933b3772883cbd67e33cf77b63d9cee2 (commit)
revisions in full, below.
commit f21036ff23bfa555a04a78483d6160d180b510a1
Author: Weblate <noreply at weblate.org>
Date:   Wed Sep 20 07:33:50 2023 +0000
    Update translation files
    Updated by "Update PO files to match POT (msgmerge)" hook in Weblate.
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/
diff --git a/doc/po/de/postgis-manual.po b/doc/po/de/postgis-manual.po
index 9a4f162f1..6601a356e 100644
--- a/doc/po/de/postgis-manual.po
+++ b/doc/po/de/postgis-manual.po
@@ -5,7 +5,7 @@ msgid ""
 msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
-"POT-Creation-Date: 2023-09-18 22:57+0000\n"
+"POT-Creation-Date: 2023-09-20 07:32+0000\n"
 "PO-Revision-Date: 2023-09-14 17:40+0000\n"
 "Last-Translator: Automatically generated\n"
 "Language-Team: none\n"
@@ -7581,11 +7581,6 @@ msgstr ""
 "müssen. Die Kommentare werden auch als Teil der Installation \"CREATE "
 "EXTENSION\" angelegt."
-#. Tag: command
-#, no-c-format
-msgid "make comments"
-msgstr "make comments"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -7615,11 +7610,6 @@ msgstr ""
 "postgis.us/study_guides\">PostGIS / PostgreSQL Study Guides</link> als HTML "
 "oder PDF heruntergeladen werden"
-#. Tag: command
-#, no-c-format
-msgid "make cheatsheets"
-msgstr "make cheatsheets"
 #. Tag: title
 #, no-c-format
 msgid "Building PostGIS Extensions and Deploying them"
@@ -7840,11 +7830,6 @@ msgstr "Softwaretest"
 msgid "If you wish to test the PostGIS build, run"
 msgstr "Wenn Sie die Kompilation von PostGIS überprüfen wollen:"
-#. Tag: command
-#, no-c-format
-msgid "make check"
-msgstr "make check"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -7945,11 +7930,6 @@ msgstr "Installation"
 msgid "To install PostGIS, type"
 msgstr "Um PostGIS zu installieren geben Sie bitte folgendes ein"
-#. Tag: command
-#, no-c-format
-msgid "make install"
-msgstr "make install"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -8000,11 +7980,6 @@ msgstr ""
 "<filename>raster_comments.sql</filename> anzulegen, können Sie die SQL-"
 "Dateien folgendermaßen installieren:"
-#. Tag: command
-#, no-c-format
-msgid "make comments-install"
-msgstr "make comments-install"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -40562,11 +40537,6 @@ msgid "Clone the PostGIS' git repository. On Unix, type:"
 msgstr ""
 "Eine Kopie des PostGIS Subversion Trunks auschecken. Eingabe unter Unix:"
-#. Tag: command
-#, no-c-format
-msgid "git clone https://git.osgeo.org/gitea/postgis/postgis.git"
-msgstr ""
 #. Tag: para
 #, fuzzy, no-c-format
 msgid "This will be stored in the directory postgis"
@@ -40581,11 +40551,6 @@ msgstr ""
 "Erledigen Sie die Änderungen an der Dokumentation mit Ihrem "
 "Lieblingstexteditor. Auf Unix, tippen Sie (zum Beispiel):"
-#. Tag: command
-#, fuzzy, no-c-format
-msgid "vim doc/postgis.xml"
-msgstr "vim trunk/doc/postgis.xml"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -40606,11 +40571,6 @@ msgstr ""
 "Erzeugung einer Patchdatei, welche die Unterschiede zur Master-Kopie der "
 "Dokumentation enthält. Unter Unix tippen Sie bitte:"
-#. Tag: command
-msgid "git diff doc/postgis.xml > doc.patch"
-msgstr "svn diff trunk/doc/postgis.xml > doc.patch"
 #. Tag: para
 #, no-c-format
 msgid "Attach the patch to a new issue in bug tracker."
@@ -45784,6 +45744,34 @@ msgstr ""
 msgid "Supports geography"
 msgstr ""
+#, no-c-format
+#~ msgid "make comments"
+#~ msgstr "make comments"
+#, no-c-format
+#~ msgid "make cheatsheets"
+#~ msgstr "make cheatsheets"
+#, no-c-format
+#~ msgid "make check"
+#~ msgstr "make check"
+#, no-c-format
+#~ msgid "make install"
+#~ msgstr "make install"
+#, no-c-format
+#~ msgid "make comments-install"
+#~ msgstr "make comments-install"
+#, fuzzy, no-c-format
+#~ msgid "vim doc/postgis.xml"
+#~ msgstr "vim trunk/doc/postgis.xml"
+#~ msgid "git diff doc/postgis.xml > doc.patch"
+#~ msgstr "svn diff trunk/doc/postgis.xml > doc.patch"
 #, no-c-format
 #~ msgid "building"
 #~ msgstr "building"
diff --git a/doc/po/es/postgis-manual.po b/doc/po/es/postgis-manual.po
index 521a1cdb8..e930a00e3 100644
--- a/doc/po/es/postgis-manual.po
+++ b/doc/po/es/postgis-manual.po
 msgstr ""
 "PO-Revision-Date: 2023-09-14 23:56+0000\n"
 "Last-Translator: Sandro Santilli <strk at kbt.io>\n"
 "Language-Team: Spanish <https://weblate.osgeo.org/projects/postgis/postgis-"
@@ -6839,11 +6839,6 @@ msgid ""
 "Comments are also included as part of the CREATE EXTENSION install."
 msgstr ""
-#. Tag: command
-#, no-c-format
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -6873,11 +6868,6 @@ msgstr ""
 "href=\"http://www.postgis.us/study_guides\"> Guias de Estudio PostGIS / "
 "PostgreSQL</link>"
-#. Tag: command
-#, no-c-format
 #. Tag: title
 #, no-c-format
@@ -7090,11 +7080,6 @@ msgstr "Tests"
 msgstr "Si quieres hacer un test en la compilación de PostGIS, ejecuta"
-#. Tag: command
-#, no-c-format
-msgid "make check"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -7186,11 +7171,6 @@ msgstr "Instalación"
 msgstr "Para instalar PostGIS entre"
-#. Tag: command
-#, no-c-format
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -7241,11 +7221,6 @@ msgstr ""
 "<filename>raster_comments.sql</filename>, instala los ficheros sql "
 "ejecutando:"
-#. Tag: command
-#, no-c-format
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -36100,11 +36075,6 @@ msgid "Clone the PostGIS' git repository. On Unix, type:"
 msgstr ""
 "Consiga una copia de la rama de PostGIS en Subversion. En Unix, teclee:"
-#. Tag: command
-#, no-c-format
-msgstr ""
 #. Tag: para
@@ -36119,11 +36089,6 @@ msgstr ""
 "Haga los cambios a la documentación con su editor favorito. En Unix, teclee "
 "(por ejemplo):"
-#. Tag: command
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -36144,11 +36109,6 @@ msgstr ""
 "Haga un fichero para solucionarlo que contenga las diferencias desde la "
 "copia maestra de la documentación. En Unix, teclee:"
-#. Tag: command
 #. Tag: para
 #, no-c-format
@@ -41220,6 +41180,34 @@ msgstr ""
 msgstr ""
+#, no-c-format
+#, no-c-format
+#, no-c-format
+#, no-c-format
+#, no-c-format
 #, no-c-format
 #~ msgid "building"
 #~ msgstr "construyendo"
diff --git a/doc/po/fr/postgis-manual.po b/doc/po/fr/postgis-manual.po
index 2a4fe7d6c..40601a6c7 100644
--- a/doc/po/fr/postgis-manual.po
+++ b/doc/po/fr/postgis-manual.po
 msgstr ""
 "PO-Revision-Date: 2023-09-14 20:23+0000\n"
 "Language-Team: French <https://weblate.osgeo.org/projects/postgis/postgis-"
@@ -7924,11 +7924,6 @@ msgstr ""
 "commande si vous installez depuis l'archive tar. Les commentaires sont aussi "
 "inclus par l'installation via CREATE EXTENSION."
-#. Tag: command
-#, no-c-format
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -7957,11 +7952,6 @@ msgstr ""
 "partir de <link xlink:href=\"http://www.postgis.us/study_guides\">PostGIS / "
 "PostgreSQL Study Guides</link>"
-#. Tag: command
-#, no-c-format
 #. Tag: title
 #, no-c-format
@@ -8195,11 +8185,6 @@ msgstr "Tests"
 msgstr "Si vous désirez tester la compilation de PostGIS, lancez"
-#. Tag: command
-#, no-c-format
-msgid "make check"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -8303,11 +8288,6 @@ msgstr "Installation"
 msgstr "Pour installer PostGIS, entrez"
-#. Tag: command
-#, no-c-format
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -8357,11 +8337,6 @@ msgstr ""
 "générer les fichiers <filename>postgis_comments.sql</filename>, "
 "<filename>raster_comments.sql</filename>, installer le fichier sql en lançant"
-#. Tag: command
-#, no-c-format
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -43949,11 +43924,6 @@ msgstr ""
 msgstr "Clonez le dépôt git de PostGIS. Sous Unix, tapez :"
-#. Tag: command
-#, no-c-format
-msgstr "git clone https://git.osgeo.org/gitea/postgis/postgis.git"
 #. Tag: para
 #, no-c-format
@@ -43968,11 +43938,6 @@ msgstr ""
 "Faites vos changements sur la documentation avec votre éditeur de texte "
 "favori. Sur Unix, tapez (pour exemple) :"
-#. Tag: command
-#, no-c-format
-msgstr "vim doc/postgis.xml"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -43993,11 +43958,6 @@ msgstr ""
 "Faites un correctif contenant les différences avec une copie de la "
 "documentation principale. Sur Unix, tapez :"
-#. Tag: command
-#, no-c-format
-msgstr "git diff doc/postgis.xml > doc.patch"
 #. Tag: para
 #, no-c-format
@@ -50354,6 +50314,38 @@ msgstr ""
 msgstr ""
+#, no-c-format
+#, no-c-format
+#, no-c-format
+#, no-c-format
+#, no-c-format
+#, no-c-format
+#~ msgid "git clone https://git.osgeo.org/gitea/postgis/postgis.git"
+#~ msgstr "git clone https://git.osgeo.org/gitea/postgis/postgis.git"
+#, no-c-format
+#~ msgstr "vim doc/postgis.xml"
+#, no-c-format
+#~ msgstr "git diff doc/postgis.xml > doc.patch"
 #, no-c-format
 #~ msgid "building"
diff --git a/doc/po/it_IT/postgis-manual.po b/doc/po/it_IT/postgis-manual.po
index 837153b3f..fc8c8f421 100644
--- a/doc/po/it_IT/postgis-manual.po
+++ b/doc/po/it_IT/postgis-manual.po
@@ -5,11 +5,11 @@ msgid ""
 msgstr ""
 "PO-Revision-Date: 2023-09-19 06:23+0000\n"
-"Language-Team: Italian <https://weblate.osgeo.org/projects/postgis/"
-"postgis-manual/it/>\n"
+"Language-Team: Italian <https://weblate.osgeo.org/projects/postgis/postgis-"
+"manual/it/>\n"
 "Language: it_IT\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
@@ -302,8 +302,8 @@ msgstr "è un testo (numero di token <code>10</code>): Esempio Boston."
 msgid ""
 "is text (token number <code>11</code>): Example <code>MASSACHUSETTS</code>"
 msgstr ""
-"è un testo (numero di token <code>11</code>): Esempio "
-"<code>MASSACHUSETTS</code>"
+"è un testo (numero di token <code>11</code>): Esempio <code>MASSACHUSETTS</"
+"code>"
 #. Tag: para
 #, no-c-format
@@ -405,9 +405,9 @@ msgid ""
 "pagcgeo.org/docs/html/pagc-12.html#--r-rec--\">PAGC Address Standardizer "
 "Rule records</link>."
 msgstr ""
-"campo di testo che indica la regola. I dettagli si trovano in <link "
-"xlink:href=\"http://www.pagcgeo.org/docs/html/pagc-12.html#--r-rec--\""
-">Regole di normalizzazione degli indirizzi del PAGC</link>."
+"campo di testo che indica la regola. I dettagli si trovano in <link xlink:"
+"href=\"http://www.pagcgeo.org/docs/html/pagc-12.html#--r-rec--\">Regole di "
+"normalizzazione degli indirizzi del PAGC</link>."
 #. Tag: para
 #, no-c-format
@@ -461,9 +461,9 @@ msgid ""
 "as follows:"
 msgstr ""
 "Ogni regola inizia con una serie di token di input seguiti da un terminatore "
-"<code>-1</code>. I token di input validi estratti da <link xlink:href=\"http"
-"://www.pagcgeo.org/docs/html/pagc-12.html#ss12.2\">PAGC Input Tokens</link> "
-"sono i seguenti:"
+"<code>-1</code>. I token di input validi estratti da <link xlink:href="
+"\"http://www.pagcgeo.org/docs/html/pagc-12.html#ss12.2\">PAGC Input Tokens</"
+"link> sono i seguenti:"
 #. Tag: emphasis
 #, no-c-format
@@ -563,8 +563,8 @@ msgid ""
 "emphasis>."
 msgstr ""
 "(24). Parole e abbreviazioni utilizzate per indicare edifici o complessi di "
-"edifici, di solito come suffisso. Ad esempio: <emphasis>Centro "
-"commerciale</emphasis>."
+"edifici, di solito come suffisso. Ad esempio: <emphasis>Centro commerciale</"
+"emphasis>."
 #. Tag: para
 #, no-c-format
@@ -572,8 +572,8 @@ msgid ""
 "(22). Words used to denote directions, for example <emphasis>North</"
 "emphasis>."
 msgstr ""
-"(22). Parole usate per indicare le direzioni, ad esempio "
-"<emphasis>Nord</emphasis>."
+"(22). Parole usate per indicare le direzioni, ad esempio <emphasis>Nord</"
+"emphasis>."
 #. Tag: para
 #, no-c-format
@@ -587,8 +587,8 @@ msgid ""
 "the <emphasis>Interstate</emphasis> in <emphasis>Interstate 5</emphasis>"
 msgstr ""
 "(6). Parole e abbreviazioni utilizzate per indicare autostrade e strade. Ad "
-"esempio: la <emphasis>Interstate</emphasis> in <emphasis>Interstate "
-"5</emphasis>"
+"esempio: la <emphasis>Interstate</emphasis> in <emphasis>Interstate 5</"
+"emphasis>"
 #. Tag: para
 #, no-c-format
@@ -6516,11 +6516,6 @@ msgstr ""
 "commenti se si installa dal tar. I commenti sono inclusi anche "
 "nell'installazione di CREATE EXTENSION."
-#. Tag: command
-#, no-c-format
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -6550,11 +6545,6 @@ msgstr ""
 "pagina <link xlink:href=\"http://www.postgis.us/study_guides\">PostGIS / "
-#. Tag: command
-#, no-c-format
 #. Tag: title
 #, no-c-format
@@ -6784,11 +6774,6 @@ msgstr "Test"
 msgstr "Se volete eseguire un test sul PostGIS compilato, eseguite"
-#. Tag: command
-#, no-c-format
-msgid "make check"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -6890,11 +6875,6 @@ msgstr "Installazione"
 msgstr "Per installare PostGIS, digitate"
-#. Tag: command
-#, no-c-format
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -6943,11 +6923,6 @@ msgstr ""
 "file <filename>postgis_comments.sql</filename> e <filename>raster_comments."
 "sql</filename>, installate i file SQL eseguendo"
-#. Tag: command
-#, no-c-format
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -36347,11 +36322,6 @@ msgstr ""
 msgstr "Ottieni un clone del repository git di PostGIS. In Unix, digita:"
-#. Tag: command
-#, no-c-format
 #. Tag: para
 #, no-c-format
@@ -36366,11 +36336,6 @@ msgstr ""
 "Apportare le modifiche alla documentazione con l'editor di testo preferito. "
 "In Unix, ad esempio, digitare:"
-#. Tag: command
-#, no-c-format
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -36391,11 +36356,6 @@ msgstr ""
 "Produrre una patch, cioè un file contenente le differenze rispetto alla "
 "copia master della documentazione. In Unix, digitare:"
-#. Tag: command
-#, no-c-format
 #. Tag: para
 #, no-c-format
@@ -41208,6 +41168,38 @@ msgstr "Supporta il 2.5/3D"
 msgstr "Supporta il tipo geography"
+#, no-c-format
+#, no-c-format
+#, no-c-format
+#, no-c-format
+#, no-c-format
+#, no-c-format
+#, no-c-format
+#, no-c-format
 #, no-c-format
 #~ msgid "building"
 #~ msgstr "compilare"
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index c8f5c501a..0bc9362c3 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
 msgstr ""
 "PO-Revision-Date: 2023-09-20 04:23+0000\n"
 "Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
-"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
-"postgis-manual/ja/>\n"
+"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
+"manual/ja/>\n"
 "Language: ja\n"
@@ -7559,11 +7559,6 @@ msgstr ""
 "メントを作成する必要はありません。コメントはCREATE EXTENSIONによるインストー"
 "ルの一部として取り込まれます。"
-#. Tag: command
-#, no-c-format
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -7591,11 +7586,6 @@ msgstr ""
 "HTMLとPDFのビルド済みのものは<link xlink:href=\"http://www.postgis.us/"
 "study_guides\">PostGIS / PostgreSQL Study Guides</link>にあります。"
-#. Tag: command
-#, no-c-format
 #. Tag: title
 #, no-c-format
@@ -7818,11 +7808,6 @@ msgstr "テスト"
 msgstr "PostGISのテストを行うには、次のコマンドを実行します。"
-#. Tag: command
-#, no-c-format
-msgid "make check"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -7921,11 +7906,6 @@ msgstr "インストール"
 msgstr "PostGISをインストールするには、次のコマンドを実行します。"
-#. Tag: command
-#, no-c-format
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -7974,11 +7954,6 @@ msgstr ""
 "sql</filename>, <filename>raster_comments.sql</filename>を生成していた場合"
 "は、次のコマンドを実行すると、これらのSQLファイルがインストールされます。"
-#. Tag: command
-#, no-c-format
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -14234,11 +14209,10 @@ msgid ""
 "\">Kontur Population Data</link> that do not span more than 3000 km from "
 "their center:"
 msgstr ""
-"例: 3次元クラスタリングと重み付けを使った、事前集計した地球規模の人口データセ"
-"ットのクラスタリング。<link xlink:href=\"https://data.humdata.org/dataset/"
-"kontur-population-dataset\">Kontur Population "
-"Data</link>に基づいて、中心から3000km以下となる、少なくとも 20 "
-"の地域が識別されます:"
+"例: 3次元クラスタリングと重み付けを使った、事前集計した地球規模の人口データ"
+"セットのクラスタリング。<link xlink:href=\"https://data.humdata.org/dataset/"
+"kontur-population-dataset\">Kontur Population Data</link>に基づいて、中心から"
+"3000km以下となる、少なくとも 20 の地域が識別されます:"
 #. Tag: para
 #, no-c-format
@@ -19795,23 +19769,24 @@ msgid ""
 "Insert geometries into roads table with a SRID set already using <link "
 "linkend=\"ST_GeomFromEWKT\">EWKT format</link>:"
 msgstr ""
-"ジオメトリを、<link linkend=\"ST_GeomFromEWKT\""
-">EWKT書式</link>を使って、SRIDを持つ道路テーブルに挿入します:"
+"ジオメトリを、<link linkend=\"ST_GeomFromEWKT\">EWKT書式</link>を使って、SRID"
+"を持つ道路テーブルに挿入します:"
 #. Tag: para
 #, no-c-format
 msgid ""
 "This will change the srid of the roads table to 4326 from whatever it was "
 "before:"
-msgstr "これにより道路テーブルが、以前がどんなSRIDであっても、4326に変更されます:"
+msgstr ""
+"これにより道路テーブルが、以前がどんなSRIDであっても、4326に変更されます:"
 #. Tag: para
 #, no-c-format
 msgid "The prior example is equivalent to this DDL statement:"
 msgstr ""
-"上述の例と、次のDDL手続き (訳注: DDLはData Definition "
-"Languageの略で、データ構造の操作を行う言語を指し、この場合は CREATE "
-"TABLEやALTER TABLE等が該当します)とは同じです:"
+"上述の例と、次のDDL手続き (訳注: DDLはData Definition Languageの略で、データ"
+"構造の操作を行う言語を指し、この場合は CREATE TABLEやALTER TABLE等が該当しま"
+"す)とは同じです:"
 #. Tag: para
 #, no-c-format
@@ -20457,7 +20432,8 @@ msgstr ""
 #, no-c-format
 msgid ""
 "Changed: 2.2.0 In prior versions this used to be called ST_Distance_Sphere"
-msgstr "Changed: 2.2.0 前の版ではこの関数はST_Distance_Sphereと呼ばれていました"
+msgstr ""
+"Changed: 2.2.0 前の版ではこの関数はST_Distance_Sphereと呼ばれていました"
 #. Tag: para
 #, no-c-format
@@ -20496,7 +20472,8 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid "Changed: 2.2.0 In prior versions this was called ST_Distance_Spheroid"
+msgstr ""
 #. Tag: para
 #, no-c-format
@@ -20699,8 +20676,8 @@ msgid ""
 msgstr ""
 "Changed: 2.0.0 大幅な変更 -- 以前の版ではジオグラフィのPOLYGONやMULTIPOLYGON"
 "への適用によってPOLYGONやMULTIPOLYGONの周囲長を返しました。2.0.0版ではジオメ"
-"トリの挙動に従うため0を返すように変更しました。ポリゴンの周囲長を求める場合は"
-"、ST_Perimeterを使います"
+"トリの挙動に従うため0を返すように変更しました。ポリゴンの周囲長を求める場合"
+"は、ST_Perimeterを使います"
 #. Tag: para
 #, no-c-format
@@ -42132,11 +42109,6 @@ msgstr ""
 msgstr "PostGISのgitリポジトリを複製します。UNIXでは次のように入力します。"
-#. Tag: command
-#, no-c-format
 #. Tag: para
 #, no-c-format
@@ -42151,11 +42123,6 @@ msgstr ""
 "お使いのテキストエディタで文書に変更を加えます。Unixでは、たとえば次のように"
 "します。"
-#. Tag: command
-#, no-c-format
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -42175,11 +42142,6 @@ msgstr ""
 "文書のマスタコピーからパッチファイルを作成します。Unixでは次のように入力しま"
 "す。"
-#. Tag: command
-#, no-c-format
 #. Tag: para
 #, no-c-format
@@ -47193,15 +47155,16 @@ msgid ""
 "projection from an existing one using <xref linkend=\"RT_ST_Transform\"/>"
 msgstr ""
 "既存テーブルから新しいラスタテーブルを生成するための多数の選択肢があります。"
-"たとえば、<xref linkend=\"RT_ST_Transform\""
-"/>を使って、既存テーブルから異なる投影法のラスタテーブルを生成します"
+"たとえば、<xref linkend=\"RT_ST_Transform\"/>を使って、既存テーブルから異なる"
+"投影法のラスタテーブルを生成します"
 #. Tag: para
 #, no-c-format
 msgid ""
 "Once you are done populating your table initially, you'll want to create a "
 "spatial index on the raster column with something like:"
-msgstr "はじめにテーブルにデータを入れたら、ラスタカラムに空間インデクスを生成したく"
+msgstr ""
+"はじめにテーブルにデータを入れたら、ラスタカラムに空間インデクスを生成したく"
 "なるでしょう:"
 #. Tag: para
@@ -47228,7 +47191,8 @@ msgstr ""
 #, no-c-format
 msgid ""
 "Apply raster constraints using <xref linkend=\"RT_AddRasterConstraints\"/>"
-msgstr "<xref linkend=\"RT_AddRasterConstraints\"/>を用いてラスタ制約を適用します"
+msgstr ""
+"<xref linkend=\"RT_AddRasterConstraints\"/>を用いてラスタ制約を適用します"
 #. Tag: title
 #, no-c-format
@@ -48106,6 +48070,38 @@ msgstr "2.5次元/3次元対応"
 msgstr "ジオグラフィ対応"
+#, no-c-format
+#, no-c-format
+#, no-c-format
+#, no-c-format
+#, no-c-format
+#, no-c-format
+#, no-c-format
+#, no-c-format
 #, no-c-format
 #~ msgid "building"
diff --git a/doc/po/ko_KR/postgis-manual.po b/doc/po/ko_KR/postgis-manual.po
index 9c4f4b462..263c90f25 100644
--- a/doc/po/ko_KR/postgis-manual.po
+++ b/doc/po/ko_KR/postgis-manual.po
 msgstr ""
@@ -7151,11 +7151,6 @@ msgid ""
 msgstr ""
-#. Tag: command
-#, no-c-format
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -7184,11 +7179,6 @@ msgstr ""
 "postgis.us/study_guides\">PostGIS / PostgreSQL Study Guides</link> 에서 다운"
 "로드받을 수 있습니다."
-#. Tag: command
-#, no-c-format
 #. Tag: title
 #, no-c-format
@@ -7398,11 +7388,6 @@ msgstr "테스트"
 msgstr "만약 PostGIS 빌드를 테스트하고 싶다면, 실행하십시오."
-#. Tag: command
-#, no-c-format
-msgid "make check"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -7498,11 +7483,6 @@ msgstr "설치"
 msgstr "PostGIS 설치를 위해서 다음을 입력하십시오."
-#. Tag: command
-#, no-c-format
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -7550,11 +7530,6 @@ msgstr ""
 "comments</command> 명령어를 실행한 적이 있으시다면, 다음을 실행해 sql 파일을 "
 "설치하십시오."
-#. Tag: command
-#, no-c-format
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -38471,11 +38446,6 @@ msgstr ""
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgstr ""
 #. Tag: para
 #, no-c-format
@@ -38488,11 +38458,6 @@ msgid ""
 "Unix, type (for example):"
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -38508,11 +38473,6 @@ msgid ""
 "documentation. On Unix, type:"
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgstr ""
 #. Tag: para
 #, no-c-format
@@ -43779,6 +43739,26 @@ msgstr ""
 msgstr ""
+#, no-c-format
+#, no-c-format
+#, no-c-format
+#, no-c-format
+#, no-c-format
 #, no-c-format
 #~ msgid "building"
diff --git a/doc/po/pl/postgis-manual.po b/doc/po/pl/postgis-manual.po
index 75b268303..beea64bfa 100644
--- a/doc/po/pl/postgis-manual.po
+++ b/doc/po/pl/postgis-manual.po
 msgstr ""
@@ -5954,11 +5954,6 @@ msgid ""
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -5978,11 +5973,6 @@ msgid ""
 "Guides</link>"
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgstr ""
 #. Tag: title
 #, no-c-format
@@ -6142,11 +6132,6 @@ msgstr ""
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgid "make check"
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -6224,11 +6209,6 @@ msgstr ""
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -6266,11 +6246,6 @@ msgid ""
 "running"
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -34035,11 +34010,6 @@ msgstr ""
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgstr ""
 #. Tag: para
 #, no-c-format
@@ -34052,11 +34022,6 @@ msgid ""
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -34072,11 +34037,6 @@ msgid ""
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgstr ""
 #. Tag: para
 #, no-c-format
diff --git a/doc/po/pt_BR/postgis-manual.po b/doc/po/pt_BR/postgis-manual.po
index 62693ef5c..cbe879a60 100644
--- a/doc/po/pt_BR/postgis-manual.po
+++ b/doc/po/pt_BR/postgis-manual.po
 msgstr ""
@@ -7225,11 +7225,6 @@ msgid ""
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgstr "fazer comentários"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -7259,11 +7254,6 @@ msgstr ""
 "xlink:href=\"http://www.postgis.us/study_guides\">PostGIS / PostgreSQL Study "
 "Guides</link>"
-#. Tag: command
-#, no-c-format
-msgstr "faça anotações"
 #. Tag: title
 #, no-c-format
@@ -7485,11 +7475,6 @@ msgstr "Testando"
 msgstr "Se desejar testar o PostGIS, rode"
-#. Tag: command
-#, no-c-format
-msgid "make check"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -7588,11 +7573,6 @@ msgstr "Instalação"
 msgstr "Para instalar o PostGIS, digite"
-#. Tag: command
-#, no-c-format
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -7643,11 +7623,6 @@ msgstr ""
 "<filename>raster_comments.sql</filename>, instale o arquivo sql para "
 "executar "
-#. Tag: command
-#, no-c-format
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -38888,11 +38863,6 @@ msgstr ""
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgstr ""
 #. Tag: para
 #, no-c-format
@@ -38905,11 +38875,6 @@ msgid ""
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -38925,11 +38890,6 @@ msgid ""
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgstr ""
 #. Tag: para
 #, no-c-format
@@ -44173,6 +44133,26 @@ msgstr ""
 msgstr ""
+#, no-c-format
+#~ msgstr "fazer comentários"
+#, no-c-format
+#~ msgstr "faça anotações"
+#, no-c-format
+#, no-c-format
+#, no-c-format
 #, no-c-format
 #~ msgid "building"
 #~ msgstr "construindo"
diff --git a/doc/po/ro/postgis-manual.po b/doc/po/ro/postgis-manual.po
index b044f1c52..006d5c462 100644
--- a/doc/po/ro/postgis-manual.po
+++ b/doc/po/ro/postgis-manual.po
 msgstr ""
@@ -5925,11 +5925,6 @@ msgid ""
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -5949,11 +5944,6 @@ msgid ""
 "Guides</link>"
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgstr ""
 #. Tag: title
 #, no-c-format
@@ -6113,11 +6103,6 @@ msgstr ""
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgid "make check"
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -6195,11 +6180,6 @@ msgstr ""
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -6237,11 +6217,6 @@ msgid ""
 "running"
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -33872,11 +33847,6 @@ msgstr ""
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgstr ""
 #. Tag: para
 #, no-c-format
@@ -33889,11 +33859,6 @@ msgid ""
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -33909,11 +33874,6 @@ msgid ""
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgstr ""
 #. Tag: para
 #, no-c-format
diff --git a/doc/po/ru/postgis-manual.po b/doc/po/ru/postgis-manual.po
index bd44b7fe7..ba2da6147 100644
--- a/doc/po/ru/postgis-manual.po
+++ b/doc/po/ru/postgis-manual.po
 msgstr ""
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 "Guides</link>"
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgid "make check"
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 "running"
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -33889,11 +33864,6 @@ msgstr ""
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgstr ""
 #. Tag: para
 #, no-c-format
@@ -33906,11 +33876,6 @@ msgid ""
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -33926,11 +33891,6 @@ msgid ""
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgstr ""
 #. Tag: para
 #, no-c-format
diff --git a/doc/po/zh_Hans/postgis-manual.po b/doc/po/zh_Hans/postgis-manual.po
index 989beb94e..36bcbd60c 100644
--- a/doc/po/zh_Hans/postgis-manual.po
+++ b/doc/po/zh_Hans/postgis-manual.po
 msgstr ""
 "PO-Revision-Date: 2023-09-15 02:23+0000\n"
 "Last-Translator: Zuochenwei <zuochenwei5 at gmail.com>\n"
 "Language-Team: Chinese (Simplified) <https://weblate.osgeo.org/projects/"
@@ -6538,11 +6538,6 @@ msgstr ""
 "的 tar.gz 中,因此如果从 tar 包中安装,则无需进行注释。 注释包含在 CREATE "
 "EXTENSION 安装中。"
-#. Tag: command
-#, no-c-format
-msgstr "发表评论"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -6569,11 +6564,6 @@ msgstr ""
 "预构建的HTML和PDF版本可以在<link xlink:href=\"http://www.postgis.us/"
 "study_guides\">PostGIS / PostgreSQL学习指南</link>中找到"
-#. Tag: command
-#, no-c-format
-msgstr "制作备忘单"
 #. Tag: title
 #, no-c-format
@@ -6771,11 +6761,6 @@ msgstr "测试"
 msgstr "要测试 PostGIS,请运行以下命令"
-#. Tag: command
-#, no-c-format
-msgid "make check"
-msgstr "进行检查"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -6868,11 +6853,6 @@ msgstr "安装"
 msgstr "要安装 PostGIS,请运行以下命令"
-#. Tag: command
-#, no-c-format
-msgstr "进行安装"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -6917,11 +6897,6 @@ msgstr ""
 "件:<filename>postgis_comments.sql</filename>,<filename>raster_comments.sql</"
 "filename>"
-#. Tag: command
-#, no-c-format
-msgstr "评论脚本-安装"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -38207,11 +38182,6 @@ msgstr ""
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgstr ""
 #. Tag: para
 #, no-c-format
@@ -38224,11 +38194,6 @@ msgid ""
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -38244,11 +38209,6 @@ msgid ""
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgstr ""
 #. Tag: para
 #, no-c-format
@@ -43807,6 +43767,26 @@ msgstr ""
 msgstr ""
+#, no-c-format
+#~ msgstr "发表评论"
+#, no-c-format
+#~ msgstr "制作备忘单"
+#, no-c-format
+#~ msgstr "进行检查"
+#, no-c-format
+#~ msgstr "进行安装"
+#, no-c-format
+#~ msgstr "评论脚本-安装"
 #, no-c-format
 #~ msgid "name"
 #~ msgstr "Name"
Summary of changes:
 doc/po/de/postgis-manual.po      |  70 ++++++++++-------------
 doc/po/es/postgis-manual.po      |  70 ++++++++++-------------
 doc/po/fr/postgis-manual.po      |  74 +++++++++++-------------
 doc/po/it_IT/postgis-manual.po   | 106 ++++++++++++++++------------------
 doc/po/ja/postgis-manual.po      | 120 +++++++++++++++++++--------------------
 doc/po/ko_KR/postgis-manual.po   |  62 +++++++-------------
 doc/po/pl/postgis-manual.po      |  42 +-------------
 doc/po/pt_BR/postgis-manual.po   |  62 +++++++-------------
 doc/po/ro/postgis-manual.po      |  42 +-------------
 doc/po/ru/postgis-manual.po      |  42 +-------------
 doc/po/zh_Hans/postgis-manual.po |  62 +++++++-------------
 11 files changed, 264 insertions(+), 488 deletions(-)
hooks/post-receive
