[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-599-gff1292799
Wed Sep 20 00:33:35 PDT 2023
the project "PostGIS".
       via  ff129279933b3772883cbd67e33cf77b63d9cee2 (commit)
      from  7c11c30e0599ddb611526b934c4f9bc3c130d3cc (commit)
revisions in full, below.
commit ff129279933b3772883cbd67e33cf77b63d9cee2
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Sep 20 09:32:48 2023 +0200
    Do not inlude <command> tags in translation
diff --git a/doc/po/strip_untranslatable.sh b/doc/po/strip_untranslatable.sh
index c673429b2..d90a8b6ef 100755
--- a/doc/po/strip_untranslatable.sh
+++ b/doc/po/strip_untranslatable.sh
@@ -15,5 +15,6 @@ sed -e '/^#\. Tag: programlisting$/,/^$/d' \
     -e '/^#\. Tag: option$/,/^$/d' \
     -e '/^#\. Tag: varname$/,/^$/d' \
     -e '/^#\. Tag: code$/,/^$/d' \
+    -e '/^#\. Tag: command$/,/^$/d' \
     -i $1
diff --git a/doc/po/templates/postgis-manual.pot b/doc/po/templates/postgis-manual.pot
index 09554b4d7..2691253e5 100644
--- a/doc/po/templates/postgis-manual.pot
+++ b/doc/po/templates/postgis-manual.pot
@@ -6,10 +6,11 @@ msgid ""
 msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
-"POT-Creation-Date: 2023-09-18 22:57+0000\n"
+"POT-Creation-Date: 2023-09-20 07:32+0000\n"
 "PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
 "Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
 "Language-Team: LANGUAGE <kde-i18n-doc at kde.org>\n"
+"Language: \n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
@@ -5927,11 +5928,6 @@ msgid ""
 "Comments are also included as part of the CREATE EXTENSION install."
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgid "make comments"
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -5951,11 +5947,6 @@ msgid ""
 "Guides</link>"
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgid "make cheatsheets"
-msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Building PostGIS Extensions and Deploying them"
@@ -6115,11 +6106,6 @@ msgstr ""
 msgid "If you wish to test the PostGIS build, run"
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgid "make check"
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -6197,11 +6183,6 @@ msgstr ""
 msgid "To install PostGIS, type"
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgid "make install"
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -6239,11 +6220,6 @@ msgid ""
 "running"
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgid "make comments-install"
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -33886,11 +33862,6 @@ msgstr ""
 msgid "Clone the PostGIS' git repository. On Unix, type:"
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgid "git clone https://git.osgeo.org/gitea/postgis/postgis.git"
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid "This will be stored in the directory postgis"
@@ -33903,11 +33874,6 @@ msgid ""
 "Unix, type (for example):"
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgid "vim doc/postgis.xml"
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -33923,11 +33889,6 @@ msgid ""
 "documentation. On Unix, type:"
 msgstr ""
-#. Tag: command
-#, no-c-format
-msgid "git diff doc/postgis.xml > doc.patch"
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid "Attach the patch to a new issue in bug tracker."
Summary of changes:
 doc/po/strip_untranslatable.sh      |  1 +
 doc/po/templates/postgis-manual.pot | 43 ++-----------------------------------
 2 files changed, 3 insertions(+), 41 deletions(-)
hooks/post-receive
