[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-602-g063401d10
Wed Sep 20 00:54:22 PDT 2023
the project "PostGIS".
       via  063401d10376a3642e7ae7afd7489d8dd03ad73d (commit)
      from  d9c6b9edefaf4cd2f1a391cdd85daa8a95ce626f (commit)
revisions in full, below.
commit 063401d10376a3642e7ae7afd7489d8dd03ad73d
Author: Weblate <noreply at weblate.org>
Date:   Wed Sep 20 07:52:57 2023 +0000
    Update translation files
    Updated by "Update PO files to match POT (msgmerge)" hook in Weblate.
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/
diff --git a/doc/po/de/postgis-manual.po b/doc/po/de/postgis-manual.po
index 6601a356e..d7313de4d 100644
--- a/doc/po/de/postgis-manual.po
+++ b/doc/po/de/postgis-manual.po
@@ -5,7 +5,7 @@ msgid ""
 msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
-"POT-Creation-Date: 2023-09-20 07:32+0000\n"
+"POT-Creation-Date: 2023-09-20 07:42+0000\n"
 "PO-Revision-Date: 2023-09-14 17:40+0000\n"
 "Last-Translator: Automatically generated\n"
 "Language-Team: none\n"
@@ -26499,8 +26499,9 @@ msgstr ""
 #, no-c-format
 msgid ""
 "Returns a <varname>POINT</varname> which is guaranteed to lie in the "
-"interior of a surface (POLYGON, MULTIPOLYGON, and CURVED POLYGON). In "
-"PostGIS this function also works on line and point geometries."
+"interior of a surface (<varname>POLYGON</varname>, <varname>MULTIPOLYGON</"
+"varname>, and <varname>CURVEPOLYGON</varname>). In PostGIS this function "
+"also works on line and point geometries."
 msgstr ""
 #. Tag: para
diff --git a/doc/po/es/postgis-manual.po b/doc/po/es/postgis-manual.po
index e930a00e3..3508c46ee 100644
--- a/doc/po/es/postgis-manual.po
+++ b/doc/po/es/postgis-manual.po
 msgstr ""
 "PO-Revision-Date: 2023-09-14 23:56+0000\n"
 "Last-Translator: Sandro Santilli <strk at kbt.io>\n"
 "Language-Team: Spanish <https://weblate.osgeo.org/projects/postgis/postgis-"
@@ -24363,8 +24363,9 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
diff --git a/doc/po/fr/postgis-manual.po b/doc/po/fr/postgis-manual.po
index 40601a6c7..df8ef0990 100644
--- a/doc/po/fr/postgis-manual.po
+++ b/doc/po/fr/postgis-manual.po
 msgstr ""
 "PO-Revision-Date: 2023-09-14 20:23+0000\n"
 "Language-Team: French <https://weblate.osgeo.org/projects/postgis/postgis-"
@@ -28849,13 +28849,10 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
-"Renvoie un <varname>POINT</varname> dont il est garanti qu'il se trouve à "
-"l'intérieur d'une surface (POLYGON, MULTIPOLYGON et CURVED POLYGON). Dans "
-"PostGIS, cette fonction fonctionne également pour les géométries de lignes "
-"et de points."
 #. Tag: para
 #, no-c-format
@@ -50314,6 +50311,17 @@ msgstr ""
 msgid "Supports geography"
 msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ "Returns a <varname>POINT</varname> which is guaranteed to lie in the "
+#~ "interior of a surface (POLYGON, MULTIPOLYGON, and CURVED POLYGON). In "
+#~ "PostGIS this function also works on line and point geometries."
+#~ msgstr ""
+#~ "Renvoie un <varname>POINT</varname> dont il est garanti qu'il se trouve à "
+#~ "l'intérieur d'une surface (POLYGON, MULTIPOLYGON et CURVED POLYGON). Dans "
+#~ "PostGIS, cette fonction fonctionne également pour les géométries de "
+#~ "lignes et de points."
 #, no-c-format
 #~ msgid "make comments"
 #~ msgstr "make comments"
diff --git a/doc/po/it_IT/postgis-manual.po b/doc/po/it_IT/postgis-manual.po
index fc8c8f421..45c02a667 100644
--- a/doc/po/it_IT/postgis-manual.po
+++ b/doc/po/it_IT/postgis-manual.po
 msgstr ""
 "PO-Revision-Date: 2023-09-19 06:23+0000\n"
 "Language-Team: Italian <https://weblate.osgeo.org/projects/postgis/postgis-"
@@ -24455,12 +24455,10 @@ msgstr "Calcola un punto che si trova in un poligono o su una geometria."
 #, no-c-format
 msgid ""
 msgstr ""
-"Restituisce un <varname>POINT</varname> che è garantito essere all'interno "
-"di una superficie (POLYGON, MULTIPOLYGON e CURVED POLYGON). In PostGIS "
-"questa funzione funziona anche su geometrie di linee e punti."
 #. Tag: para
 #, no-c-format
@@ -41168,6 +41166,16 @@ msgstr "Supporta il 2.5/3D"
 msgstr "Supporta il tipo geography"
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#~ "Restituisce un <varname>POINT</varname> che è garantito essere "
+#~ "all'interno di una superficie (POLYGON, MULTIPOLYGON e CURVED POLYGON). "
+#~ "In PostGIS questa funzione funziona anche su geometrie di linee e punti."
 #, no-c-format
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index 0bc9362c3..d3ca26950 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
 msgstr ""
 "PO-Revision-Date: 2023-09-20 04:23+0000\n"
 "Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
 "Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
@@ -27543,12 +27543,10 @@ msgstr "ポリゴン内またはジオメトリ上にあるのが保証された
 #, no-c-format
 msgid ""
 msgstr ""
-"サーフェス (POLYGON、MULTIPOLYGON、CURVED POLYGON)内部にあることが保証された"
-"<varname>POINT</varname>を返します。PostGISでは、この関数はラインジオメトリと"
-"ポイントジオメトリ上でも動作します。"
 #. Tag: para
 #, no-c-format
@@ -48070,6 +48068,16 @@ msgstr "2.5次元/3次元対応"
 msgstr "ジオグラフィ対応"
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#~ "サーフェス (POLYGON、MULTIPOLYGON、CURVED POLYGON)内部にあることが保証され"
+#~ "た<varname>POINT</varname>を返します。PostGISでは、この関数はラインジオメ"
+#~ "トリとポイントジオメトリ上でも動作します。"
 #, no-c-format
diff --git a/doc/po/ko_KR/postgis-manual.po b/doc/po/ko_KR/postgis-manual.po
index 263c90f25..90a70ae46 100644
--- a/doc/po/ko_KR/postgis-manual.po
+++ b/doc/po/ko_KR/postgis-manual.po
 msgstr ""
@@ -25144,8 +25144,9 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
diff --git a/doc/po/pl/postgis-manual.po b/doc/po/pl/postgis-manual.po
index beea64bfa..6254b16cb 100644
--- a/doc/po/pl/postgis-manual.po
+++ b/doc/po/pl/postgis-manual.po
 msgstr ""
@@ -22409,8 +22409,9 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
diff --git a/doc/po/pt_BR/postgis-manual.po b/doc/po/pt_BR/postgis-manual.po
index cbe879a60..e8b7f240f 100644
--- a/doc/po/pt_BR/postgis-manual.po
+++ b/doc/po/pt_BR/postgis-manual.po
 msgstr ""
@@ -25388,8 +25388,9 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
diff --git a/doc/po/ro/postgis-manual.po b/doc/po/ro/postgis-manual.po
index 006d5c462..c4eade9bc 100644
--- a/doc/po/ro/postgis-manual.po
+++ b/doc/po/ro/postgis-manual.po
 msgstr ""
@@ -22246,8 +22246,9 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
diff --git a/doc/po/ru/postgis-manual.po b/doc/po/ru/postgis-manual.po
index ba2da6147..56dad815b 100644
--- a/doc/po/ru/postgis-manual.po
+++ b/doc/po/ru/postgis-manual.po
 msgstr ""
@@ -22263,8 +22263,9 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
diff --git a/doc/po/zh_Hans/postgis-manual.po b/doc/po/zh_Hans/postgis-manual.po
index 36bcbd60c..3e1cd3ef5 100644
--- a/doc/po/zh_Hans/postgis-manual.po
+++ b/doc/po/zh_Hans/postgis-manual.po
 msgstr ""
 "PO-Revision-Date: 2023-09-15 02:23+0000\n"
 "Last-Translator: Zuochenwei <zuochenwei5 at gmail.com>\n"
 "Language-Team: Chinese (Simplified) <https://weblate.osgeo.org/projects/"
@@ -25401,11 +25401,10 @@ msgstr "计算保证位于多边形或几何体上的点。"
 #, no-c-format
 msgid ""
 msgstr ""
-"返回保证位于曲面内部的<varname>点</varname>(POLYGON、MULTIPOLYGON 和 CURVED "
-"POLYGON)。 在 PostGIS 中,此函数也适用于线和点几何图形。"
 #. Tag: para
 #, no-c-format
@@ -43767,6 +43766,15 @@ msgstr ""
 msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#~ "返回保证位于曲面内部的<varname>点</varname>(POLYGON、MULTIPOLYGON 和 "
+#~ "CURVED POLYGON)。 在 PostGIS 中,此函数也适用于线和点几何图形。"
 #, no-c-format
 #~ msgstr "发表评论"
Summary of changes:
 doc/po/de/postgis-manual.po      |  7 ++++---
 doc/po/es/postgis-manual.po      |  7 ++++---
 doc/po/fr/postgis-manual.po      | 22 +++++++++++++++-------
 doc/po/it_IT/postgis-manual.po   | 20 ++++++++++++++------
 doc/po/ja/postgis-manual.po      | 20 ++++++++++++++------
 doc/po/ko_KR/postgis-manual.po   |  7 ++++---
 doc/po/pl/postgis-manual.po      |  7 ++++---
 doc/po/pt_BR/postgis-manual.po   |  7 ++++---
 doc/po/ro/postgis-manual.po      |  7 ++++---
 doc/po/ru/postgis-manual.po      |  7 ++++---
 doc/po/zh_Hans/postgis-manual.po | 18 +++++++++++++-----
 11 files changed, 84 insertions(+), 45 deletions(-)
hooks/post-receive
