[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-603-g4aa6f56e3
Wed Sep 20 01:01:11 PDT 2023
the project "PostGIS".
       via  4aa6f56e30736a40e77fbce1844ca500e78e51a4 (commit)
      from  063401d10376a3642e7ae7afd7489d8dd03ad73d (commit)
revisions in full, below.
commit 4aa6f56e30736a40e77fbce1844ca500e78e51a4
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Sep 20 09:58:32 2023 +0200
    Have the pot file sorted by input filename (normalized)
    Also take the chance for sorting XML filenames in the Makefile too
diff --git a/doc/Makefile.in b/doc/Makefile.in
index 5ab84e16f..7c5496c3f 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -157,22 +157,23 @@ endif
 all: $(BUILD_TARGET)
 XML_SOURCES = \
-    extras_address_standardizer.xml \
+	administration.xml \
+	database_tuning.xml \
+	extras_address_standardizer.xml \
 	extras_historytable.xml \
 	extras_tigergeocoder.xml \
 	extras_topology.xml \
 	extras.xml \
 	installation.xml \
-	administration.xml \
-	database_tuning.xml \
 	introduction.xml \
 	performance_tips.xml \
-	postgis.xml \
 	postgis_special.xml \
+	postgis.xml \
 	reference_accessor.xml \
 	reference_bbox.xml \
 	reference_cluster.xml \
 	reference_constructor.xml \
+	reference_coverage.xml \
 	reference_editor.xml \
 	reference_exception.xml \
 	reference_guc.xml \
@@ -180,14 +181,13 @@ XML_SOURCES = \
 	reference_lrs.xml \
 	reference_management.xml \
 	reference_measure.xml \
-	reference_sfcgal.xml \
 	reference_operator.xml \
 	reference_output.xml \
 	reference_overlay.xml \
 	reference_processing.xml \
-	reference_coverage.xml \
 	reference_raster.xml \
 	reference_relationship.xml \
+	reference_sfcgal.xml \
 	reference_srs.xml \
 	reference_trajectory.xml \
 	reference_transaction.xml \
@@ -325,7 +325,7 @@ $(XML_SOURCE_POTS): %.xml.pot: %.xml po/strip_untranslatable.sh
 update-pot: $(XML_UNIFIED_POT)
 $(XML_UNIFIED_POT): $(XML_SOURCE_POTS)
-	@$(MSGCAT) --use-first --no-location -o $@.tmp $(XML_SOURCE_POTS)
+	@$(MSGCAT) --sort-by-file --use-first --no-location -o $@.tmp $(XML_SOURCE_POTS)
 	@if test -f $@; then \
     if test -n "$$($(MSGCOMM) --unique $@.tmp $@ | tail -1)"; then \
       $(MSGMERGE) -U $@ $@.tmp || exit 1; \
diff --git a/doc/po/templates/postgis-manual.pot b/doc/po/templates/postgis-manual.pot
index 24c841a6b..39cb649ea 100644
--- a/doc/po/templates/postgis-manual.pot
+++ b/doc/po/templates/postgis-manual.pot
@@ -10,11 +10,751 @@ msgstr ""
 "PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
 "Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
 "Language-Team: LANGUAGE <kde-i18n-doc at kde.org>\n"
-"Language: \n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
+#. Tag: chapter
+#, no-c-format
+msgid "&database_tuning;"
+msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "PostGIS Administration"
+msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Configuring raster support"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"If you enabled raster support you may want to read below how to properly "
+"configure it."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"As of PostGIS 2.1.3, out-of-db rasters and all raster drivers are disabled "
+"by default. In order to re-enable these, you need to set the following "
+"environment variables <varname>POSTGIS_GDAL_ENABLED_DRIVERS</varname> and "
+"<varname>POSTGIS_ENABLE_OUTDB_RASTERS</varname> in the server environment. "
+"For PostGIS 2.2, you can use the more cross-platform approach of setting the "
+"corresponding <xref linkend=\"PostGIS_GUC\"/>."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "If you want to enable offline raster:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Any other setting or no setting at all will disable out of db rasters."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"In order to enable all GDAL drivers available in your GDAL install, set this "
+"environment variable as follows"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"If you want to only enable specific drivers, set your environment variable "
+"as follows:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "If you are on windows, do not quote the driver list"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Setting environment variables varies depending on OS. For PostgreSQL "
+"installed on Ubuntu or Debian via apt-postgresql, the preferred way is to "
+"edit <filename>/etc/postgresql/<replaceable>10</replaceable>/"
+"<replaceable>main</replaceable>/environment</filename> where 10 refers to "
+"version of PostgreSQL and main refers to the cluster."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"On windows, if you are running as a service, you can set via System "
+"variables which for Windows 7 you can get to by right-clicking on Computer-"
+">Properties Advanced System Settings or in explorer navigating to "
+"<varname>Control Panel\\All Control Panel Items\\System</varname>. Then "
+"clicking <emphasis>Advanced System Settings ->Advanced->Environment "
+"Variables</emphasis> and adding new system variables."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"After you set the environment variables, you'll need to restart your "
+"PostgreSQL service for the changes to take effect."
+msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Creating spatial databases"
+msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Spatially enable database using EXTENSION"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"If you are using PostgreSQL 9.1+ and have compiled and installed the "
+"extensions/postgis modules, you can turn a database into a spatial one using "
+"the EXTENSION mechanism."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Core postgis extension includes geometry, geography, spatial_ref_sys and all "
+"the functions and comments. Raster and topology are packaged as a separate "
+"extension."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Run the following SQL snippet in the database you want to enable spatially:"
+msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Spatially enable database without using EXTENSION (discouraged)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"This is generally only needed if you cannot or don't want to get PostGIS "
+"installed in the PostgreSQL extension directory (for example during testing, "
+"development or in a restricted environment)."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Adding PostGIS objects and function definitions into your database is done "
+"by loading the various sql files located in <filename>[prefix]/share/"
+"contrib</filename> as specified during the build phase."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The core PostGIS objects (geometry and geography types, and their support "
+"functions) are in the <filename>postgis.sql</filename> script. Raster "
+"objects are in the <filename>rtpostgis.sql</filename> script. Topology "
+"objects are in the <filename>topology.sql</filename> script."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"For a complete set of EPSG coordinate system definition identifiers, you can "
+"also load the <filename>spatial_ref_sys.sql</filename> definitions file and "
+"populate the <varname>spatial_ref_sys</varname> table. This will permit you "
+"to perform ST_Transform() operations on geometries."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"If you wish to add comments to the PostGIS functions, you can find them in "
+"the <filename>postgis_comments.sql</filename> script. Comments can be viewed "
+"by simply typing <command>\\dd [function_name]</command> from a "
+"<command>psql</command> terminal window."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Run the following Shell commands in your terminal:"
+msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Upgrading spatial databases"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Upgrading existing spatial databases can be tricky as it requires "
+"replacement or introduction of new PostGIS object definitions."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Unfortunately not all definitions can be easily replaced in a live database, "
+"so sometimes your best bet is a dump/reload process."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"PostGIS provides a SOFT UPGRADE procedure for minor or bugfix releases, and "
+"a HARD UPGRADE procedure for major releases."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Before attempting to upgrade PostGIS, it is always worth to backup your "
+"data. If you use the -Fc flag to pg_dump you will always be able to restore "
+"the dump with a HARD UPGRADE."
+msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Soft upgrade"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"If you installed your database using extensions, you'll need to upgrade "
+"using the extension model as well. If you installed using the old sql script "
+"way, you are advised to switch your install to extensions because the script "
+"way is no longer supported."
+msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Soft Upgrade 9.1+ using extensions"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"If you originally installed PostGIS with extensions, then you need to "
+"upgrade using extensions as well. Doing a minor upgrade with extensions, is "
+"fairly painless."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"If you are running PostGIS 3 or above, then you should use the <xref "
+"linkend=\"PostGIS_Extensions_Upgrade\"/> function to upgrade to the latest "
+"version you have installed."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "If you are running PostGIS 2.5 or lower, then do the following:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"If you have multiple versions of PostGIS installed, and you don't want to "
+"upgrade to the latest, you can explicitly specify the version as follows:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "If you get an error notice something like:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Then you'll need to backup your database, create a fresh one as described in "
+"<xref linkend=\"create_new_db_extensions\"/> and then restore your backup on "
+"top of this new database."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "If you get a notice message like:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Then everything is already up to date and you can safely ignore it. "
+"<emphasis role=\"bold\">UNLESS</emphasis> you're attempting to upgrade from "
+"an development version to the next (which doesn't get a new version number); "
+"in that case you can append \"next\" to the version string, and next time "
+"you'll need to drop the \"next\" suffix again:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"If you installed PostGIS originally without a version specified, you can "
+"often skip the reinstallation of postgis extension before restoring since "
+"the backup just has <code>CREATE EXTENSION postgis</code> and thus picks up "
+"the newest latest version during restore."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"If you are upgrading PostGIS extension from a version prior to 3.0.0, you "
+"will have a new extension <emphasis>postgis_raster</emphasis> which you can "
+"safely drop, if you don't need raster support. You can drop as follows:"
+msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Soft Upgrade Pre 9.1+ or without extensions"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"This section applies only to those who installed PostGIS not using "
+"extensions. If you have extensions and try to upgrade with this approach "
+"you'll get messages like:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"NOTE: if you are moving from PostGIS 1.* to PostGIS 2.* or from PostGIS 2.* "
+"prior to r7409, you cannot use this procedure but would rather need to do a "
+"<link linkend=\"hard_upgrade\">HARD UPGRADE</link>."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"After compiling and installing (make install) you should find a set of "
+"<filename>*_upgrade.sql</filename> files in the installation folders. You "
+"can list them all with:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Load them all in turn, starting from <filename>postgis_upgrade.sql</"
+"filename>."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The same procedure applies to raster, topology and sfcgal extensions, with "
+"upgrade files named <filename>rtpostgis_upgrade.sql</filename>, "
+"<filename>topology_upgrade.sql</filename> and <filename>sfcgal_upgrade.sql</"
+"filename> respectively. If you need them:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "You are advised to switch to an extension based install by running"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"If you can't find the <filename>postgis_upgrade.sql</filename> specific for "
+"upgrading your version you are using a version too early for a soft upgrade "
+"and need to do a <link linkend=\"hard_upgrade\">HARD UPGRADE</link>."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The <xref linkend=\"PostGIS_Full_Version\"/> function should inform you "
+"about the need to run this kind of upgrade using a \"procs need upgrade\" "
+"message."
+msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Hard upgrade"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"By HARD UPGRADE we mean full dump/reload of postgis-enabled databases. You "
+"need a HARD UPGRADE when PostGIS objects' internal storage changes or when "
+"SOFT UPGRADE is not possible. The <link linkend=\"release_notes\">Release "
+"Notes</link> appendix reports for each version whether you need a dump/"
+"reload (HARD UPGRADE) to upgrade."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The dump/reload process is assisted by the postgis_restore script which "
+"takes care of skipping from the dump all definitions which belong to PostGIS "
+"(including old ones), allowing you to restore your schemas and data into a "
+"database with PostGIS installed without getting duplicate symbol errors or "
+"bringing forward deprecated objects."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Supplementary instructions for windows users are available at <link xlink:"
+"href=\"http://trac.osgeo.org/postgis/wiki/UsersWikiWinUpgrade\">Windows Hard "
+"upgrade</link>."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "The Procedure is as follows:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Create a \"custom-format\" dump of the database you want to upgrade (let's "
+"call it <varname>olddb</varname>) include binary blobs (-b) and verbose (-v) "
+"output. The user can be the owner of the db, need not be postgres super "
+"account."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Do a fresh install of PostGIS in a new database -- we'll refer to this "
+"database as <varname>newdb</varname>. Please refer to <xref "
+"linkend=\"create_new_db\"/> and <xref linkend=\"create_new_db_extensions\"/> "
+"for instructions on how to do this."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The spatial_ref_sys entries found in your dump will be restored, but they "
+"will not override existing ones in spatial_ref_sys. This is to ensure that "
+"fixes in the official set will be properly propagated to restored databases. "
+"If for any reason you really want your own overrides of standard entries "
+"just don't load the spatial_ref_sys.sql file when creating the new db."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"If your database is really old or you know you've been using long deprecated "
+"functions in your views and functions, you might need to load "
+"<filename>legacy.sql</filename> for all your functions and views etc. to "
+"properly come back. Only do this if _really_ needed. Consider upgrading your "
+"views and functions before dumping instead, if possible. The deprecated "
+"functions can be later removed by loading <filename>uninstall_legacy.sql</"
+"filename>."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Restore your backup into your fresh <varname>newdb</varname> database using "
+"postgis_restore. Unexpected errors, if any, will be printed to the standard "
+"error stream by psql. Keep a log of those."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Errors may arise in the following cases:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Some of your views or functions make use of deprecated PostGIS objects. In "
+"order to fix this you may try loading <filename>legacy.sql</filename> script "
+"prior to restore or you'll have to restore to a version of PostGIS which "
+"still contains those objects and try a migration again after porting your "
+"code. If the <filename>legacy.sql</filename> way works for you, don't forget "
+"to fix your code to stop using deprecated functions and drop them loading "
+"<filename>uninstall_legacy.sql</filename>."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Some custom records of spatial_ref_sys in dump file have an invalid SRID "
+"value. Valid SRID values are bigger than 0 and smaller than 999000. Values "
+"in the 999000.999999 range are reserved for internal use while values > "
+"999999 can't be used at all. All your custom records with invalid SRIDs will "
+"be retained, with those > 999999 moved into the reserved range, but the "
+"spatial_ref_sys table would lose a check constraint guarding for that "
+"invariant to hold and possibly also its primary key ( when multiple invalid "
+"SRIDS get converted to the same reserved SRID value )."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"In order to fix this you should copy your custom SRS to a SRID with a valid "
+"value (maybe in the 910000..910999 range), convert all your tables to the "
+"new srid (see <xref linkend=\"UpdateGeometrySRID\"/>), delete the invalid "
+"entry from spatial_ref_sys and re-construct the check(s) with:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"If you are upgrading an old database containing french <link xlink:"
+"href=\"https://en.wikipedia.org/wiki/Institut_g%C3%A9ographique_national\"> "
+"IGN </link> cartography, you will have probably SRIDs out of range and you "
+"will see, when importing your database, issues like this :"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"In this case, you can try following steps : first throw out completely the "
+"IGN from the sql which is resulting from postgis_restore. So, after having "
+"run :"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "run this command :"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Create then your newdb, activate the required Postgis extensions, and insert "
+"properly the french system IGN with : <link xlink:href=\"https://raw."
+"githubusercontent.com/Remi-C/IGN_spatial_ref_for_PostGIS/master/"
+"Put_IGN_SRS_into_Postgis.sql\"> this script </link> After these operations, "
+"import your data :"
+msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Performance Tuning"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Tuning for PostGIS performance is much like tuning for any PostgreSQL "
+"workload. The only additional consideration is that geometries and rasters "
+"are usually large, so memory-related optimizations generally have more of an "
+"impact on PostGIS than other types of PostgreSQL queries."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"For general details about optimizing PostgreSQL, refer to <link xlink:"
+"href=\"https://wiki.postgresql.org/wiki/"
+"Tuning_Your_PostgreSQL_Server\">Tuning your PostgreSQL Server</link>."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"For PostgreSQL 9.4+ configuration can be set at the server level without "
+"touching <code>postgresql.conf</code> or <code>postgresql.auto.conf</code> "
+"by using the <code>ALTER SYSTEM</code> command."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"In addition to the Postgres settings, PostGIS has some custom settings which "
+"are listed in <xref linkend=\"PostGIS_GUC\"/>."
+msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Startup"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "These settings are configured in <code>postgresql.conf</code>:"
+msgstr ""
+#. Tag: link
+#, no-c-format
+msgid "constraint_exclusion"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Default: partition"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"This is generally used for table partitioning. The default for this is set "
+"to \"partition\" which is ideal for PostgreSQL 8.4 and above since it will "
+"force the planner to only analyze tables for constraint consideration if "
+"they are in an inherited hierarchy and not pay the planner penalty otherwise."
+msgstr ""
+#. Tag: link
+#, no-c-format
+msgid "shared_buffers"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Default: ~128MB in PostgreSQL 9.6"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Set to about 25% to 40% of available RAM. On windows you may not be able to "
+"set as high."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://www.postgresql.org/docs/current/static/runtime-"
+"config-resource.html#GUC-MAX-WORKER-PROCESSES\">max_worker_processes</link> "
+"This setting is only available for PostgreSQL 9.4+. For PostgreSQL 9.6+ this "
+"setting has additional importance in that it controls the max number of "
+"processes you can have for parallel queries."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Default: 8"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Sets the maximum number of background processes that the system can support. "
+"This parameter can only be set at server start."
+msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Runtime"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"http://www.postgresql.org/docs/current/static/runtime-"
+"config-resource.html#GUC-WORK-MEM\">work_mem</link> - sets the size of "
+"memory used for sort operations and complex queries"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Default: 1-4MB"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Adjust up for large dbs, complex queries, lots of RAM"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Adjust down for many concurrent users or low RAM."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "If you have lots of RAM and few developers:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"config-resource.html#GUC-MAINTENANCE-WORK-MEM\">maintenance_work_mem</link> "
+"- the memory size used for VACUUM, CREATE INDEX, etc."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Default: 16-64MB"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Generally too low - ties up I/O, locks objects while swapping memory"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Recommend 32MB to 1GB on production servers w/lots of RAM, but depends on "
+"the # of concurrent users. If you have lots of RAM and few developers:"
+msgstr ""
+#. Tag: link
+#, no-c-format
+msgid "max_parallel_workers_per_gather"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"This setting is only available for PostgreSQL 9.6+ and will only affect "
+"PostGIS 2.3+, since only PostGIS 2.3+ supports parallel queries. If set to "
+"higher than 0, then some queries such as those involving relation functions "
+"like <code>ST_Intersects</code> can use multiple processes and can run more "
+"than twice as fast when doing so. If you have a lot of processors to spare, "
+"you should change the value of this to as many processors as you have. Also "
+"make sure to bump up <code>max_worker_processes</code> to at least as high "
+"as this number."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Default: 0"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Sets the maximum number of workers that can be started by a single "
+"<varname>Gather</varname> node. Parallel workers are taken from the pool of "
+"processes established by <varname>max_worker_processes</varname>. Note that "
+"the requested number of workers may not actually be available at run time. "
+"If this occurs, the plan will run with fewer workers than expected, which "
+"may be inefficient. Setting this value to 0, which is the default, disables "
+"parallel query execution."
+msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "PostGIS Extras"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"This chapter documents features found in the extras folder of the PostGIS "
+"source tarballs and source repository. These are not always packaged with "
+"PostGIS binary releases, but are usually PL/pgSQL based or standard shell "
+"scripts that can be run as is."
+msgstr ""
+#. Tag: chapter
+#, no-c-format
+msgid "&extras_address_standardizer; &extras_tigergeocoder;"
+msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Address Standardizer"
@@ -5328,25 +6068,6 @@ msgid ""
 "topology (say a spatially-simplified version of the starting topology)."
 msgstr ""
-#. Tag: title
-#, no-c-format
-msgid "PostGIS Extras"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"This chapter documents features found in the extras folder of the PostGIS "
-"source tarballs and source repository. These are not always packaged with "
-"PostGIS binary releases, but are usually PL/pgSQL based or standard shell "
-"scripts that can be run as is."
-msgstr ""
-#. Tag: chapter
-#, no-c-format
-msgid "&extras_address_standardizer; &extras_tigergeocoder;"
-msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "PostGIS Installation"
@@ -6472,15 +7193,15 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"For each state you want to load data for, generate a state script <xref "
-"linkend=\"Loader_Generate_Script\"/>."
+"DO NOT Generate the state script until you have already loaded the nation "
+"data, because the state script utilizes county list loaded by nation script."
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"DO NOT Generate the state script until you have already loaded the nation "
-"data, because the state script utilizes county list loaded by nation script."
+"For each state you want to load data for, generate a state script <xref "
+"linkend=\"Loader_Generate_Script\"/>."
 msgstr ""
 #. Tag: para
@@ -6742,728 +7463,6 @@ msgid ""
 "varname> variables have been set correctly."
 msgstr ""
-#. Tag: title
-#, no-c-format
-msgid "PostGIS Administration"
-msgstr ""
-#. Tag: chapter
-#, no-c-format
-msgid "&database_tuning;"
-msgstr ""
-#. Tag: title
-#, no-c-format
-msgid "Configuring raster support"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"If you enabled raster support you may want to read below how to properly "
-"configure it."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"As of PostGIS 2.1.3, out-of-db rasters and all raster drivers are disabled "
-"by default. In order to re-enable these, you need to set the following "
-"environment variables <varname>POSTGIS_GDAL_ENABLED_DRIVERS</varname> and "
-"<varname>POSTGIS_ENABLE_OUTDB_RASTERS</varname> in the server environment. "
-"For PostGIS 2.2, you can use the more cross-platform approach of setting the "
-"corresponding <xref linkend=\"PostGIS_GUC\"/>."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "If you want to enable offline raster:"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Any other setting or no setting at all will disable out of db rasters."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"In order to enable all GDAL drivers available in your GDAL install, set this "
-"environment variable as follows"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"If you want to only enable specific drivers, set your environment variable "
-"as follows:"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "If you are on windows, do not quote the driver list"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Setting environment variables varies depending on OS. For PostgreSQL "
-"installed on Ubuntu or Debian via apt-postgresql, the preferred way is to "
-"edit <filename>/etc/postgresql/<replaceable>10</replaceable>/"
-"<replaceable>main</replaceable>/environment</filename> where 10 refers to "
-"version of PostgreSQL and main refers to the cluster."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"On windows, if you are running as a service, you can set via System "
-"variables which for Windows 7 you can get to by right-clicking on Computer-"
-">Properties Advanced System Settings or in explorer navigating to "
-"<varname>Control Panel\\All Control Panel Items\\System</varname>. Then "
-"clicking <emphasis>Advanced System Settings ->Advanced->Environment "
-"Variables</emphasis> and adding new system variables."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"After you set the environment variables, you'll need to restart your "
-"PostgreSQL service for the changes to take effect."
-msgstr ""
-#. Tag: title
-#, no-c-format
-msgid "Creating spatial databases"
-msgstr ""
-#. Tag: title
-#, no-c-format
-msgid "Spatially enable database using EXTENSION"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"If you are using PostgreSQL 9.1+ and have compiled and installed the "
-"extensions/postgis modules, you can turn a database into a spatial one using "
-"the EXTENSION mechanism."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Core postgis extension includes geometry, geography, spatial_ref_sys and all "
-"the functions and comments. Raster and topology are packaged as a separate "
-"extension."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Run the following SQL snippet in the database you want to enable spatially:"
-msgstr ""
-#. Tag: title
-#, no-c-format
-msgid "Spatially enable database without using EXTENSION (discouraged)"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"This is generally only needed if you cannot or don't want to get PostGIS "
-"installed in the PostgreSQL extension directory (for example during testing, "
-"development or in a restricted environment)."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Adding PostGIS objects and function definitions into your database is done "
-"by loading the various sql files located in <filename>[prefix]/share/"
-"contrib</filename> as specified during the build phase."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"The core PostGIS objects (geometry and geography types, and their support "
-"functions) are in the <filename>postgis.sql</filename> script. Raster "
-"objects are in the <filename>rtpostgis.sql</filename> script. Topology "
-"objects are in the <filename>topology.sql</filename> script."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"For a complete set of EPSG coordinate system definition identifiers, you can "
-"also load the <filename>spatial_ref_sys.sql</filename> definitions file and "
-"populate the <varname>spatial_ref_sys</varname> table. This will permit you "
-"to perform ST_Transform() operations on geometries."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"If you wish to add comments to the PostGIS functions, you can find them in "
-"the <filename>postgis_comments.sql</filename> script. Comments can be viewed "
-"by simply typing <command>\\dd [function_name]</command> from a "
-"<command>psql</command> terminal window."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Run the following Shell commands in your terminal:"
-msgstr ""
-#. Tag: title
-#, no-c-format
-msgid "Upgrading spatial databases"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Upgrading existing spatial databases can be tricky as it requires "
-"replacement or introduction of new PostGIS object definitions."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Unfortunately not all definitions can be easily replaced in a live database, "
-"so sometimes your best bet is a dump/reload process."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"PostGIS provides a SOFT UPGRADE procedure for minor or bugfix releases, and "
-"a HARD UPGRADE procedure for major releases."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Before attempting to upgrade PostGIS, it is always worth to backup your "
-"data. If you use the -Fc flag to pg_dump you will always be able to restore "
-"the dump with a HARD UPGRADE."
-msgstr ""
-#. Tag: title
-#, no-c-format
-msgid "Soft upgrade"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"If you installed your database using extensions, you'll need to upgrade "
-"using the extension model as well. If you installed using the old sql script "
-"way, you are advised to switch your install to extensions because the script "
-"way is no longer supported."
-msgstr ""
-#. Tag: title
-#, no-c-format
-msgid "Soft Upgrade 9.1+ using extensions"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"If you originally installed PostGIS with extensions, then you need to "
-"upgrade using extensions as well. Doing a minor upgrade with extensions, is "
-"fairly painless."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"If you are running PostGIS 3 or above, then you should use the <xref "
-"linkend=\"PostGIS_Extensions_Upgrade\"/> function to upgrade to the latest "
-"version you have installed."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "If you are running PostGIS 2.5 or lower, then do the following:"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"If you have multiple versions of PostGIS installed, and you don't want to "
-"upgrade to the latest, you can explicitly specify the version as follows:"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "If you get an error notice something like:"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Then you'll need to backup your database, create a fresh one as described in "
-"<xref linkend=\"create_new_db_extensions\"/> and then restore your backup on "
-"top of this new database."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "If you get a notice message like:"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Then everything is already up to date and you can safely ignore it. "
-"<emphasis role=\"bold\">UNLESS</emphasis> you're attempting to upgrade from "
-"an development version to the next (which doesn't get a new version number); "
-"in that case you can append \"next\" to the version string, and next time "
-"you'll need to drop the \"next\" suffix again:"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"If you installed PostGIS originally without a version specified, you can "
-"often skip the reinstallation of postgis extension before restoring since "
-"the backup just has <code>CREATE EXTENSION postgis</code> and thus picks up "
-"the newest latest version during restore."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"If you are upgrading PostGIS extension from a version prior to 3.0.0, you "
-"will have a new extension <emphasis>postgis_raster</emphasis> which you can "
-"safely drop, if you don't need raster support. You can drop as follows:"
-msgstr ""
-#. Tag: title
-#, no-c-format
-msgid "Soft Upgrade Pre 9.1+ or without extensions"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"This section applies only to those who installed PostGIS not using "
-"extensions. If you have extensions and try to upgrade with this approach "
-"you'll get messages like:"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"NOTE: if you are moving from PostGIS 1.* to PostGIS 2.* or from PostGIS 2.* "
-"prior to r7409, you cannot use this procedure but would rather need to do a "
-"<link linkend=\"hard_upgrade\">HARD UPGRADE</link>."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"After compiling and installing (make install) you should find a set of "
-"<filename>*_upgrade.sql</filename> files in the installation folders. You "
-"can list them all with:"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Load them all in turn, starting from <filename>postgis_upgrade.sql</"
-"filename>."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"The same procedure applies to raster, topology and sfcgal extensions, with "
-"upgrade files named <filename>rtpostgis_upgrade.sql</filename>, "
-"<filename>topology_upgrade.sql</filename> and <filename>sfcgal_upgrade.sql</"
-"filename> respectively. If you need them:"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "You are advised to switch to an extension based install by running"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"If you can't find the <filename>postgis_upgrade.sql</filename> specific for "
-"upgrading your version you are using a version too early for a soft upgrade "
-"and need to do a <link linkend=\"hard_upgrade\">HARD UPGRADE</link>."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"The <xref linkend=\"PostGIS_Full_Version\"/> function should inform you "
-"about the need to run this kind of upgrade using a \"procs need upgrade\" "
-"message."
-msgstr ""
-#. Tag: title
-#, no-c-format
-msgid "Hard upgrade"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"By HARD UPGRADE we mean full dump/reload of postgis-enabled databases. You "
-"need a HARD UPGRADE when PostGIS objects' internal storage changes or when "
-"SOFT UPGRADE is not possible. The <link linkend=\"release_notes\">Release "
-"Notes</link> appendix reports for each version whether you need a dump/"
-"reload (HARD UPGRADE) to upgrade."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"The dump/reload process is assisted by the postgis_restore script which "
-"takes care of skipping from the dump all definitions which belong to PostGIS "
-"(including old ones), allowing you to restore your schemas and data into a "
-"database with PostGIS installed without getting duplicate symbol errors or "
-"bringing forward deprecated objects."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Supplementary instructions for windows users are available at <link xlink:"
-"href=\"http://trac.osgeo.org/postgis/wiki/UsersWikiWinUpgrade\">Windows Hard "
-"upgrade</link>."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "The Procedure is as follows:"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Create a \"custom-format\" dump of the database you want to upgrade (let's "
-"call it <varname>olddb</varname>) include binary blobs (-b) and verbose (-v) "
-"output. The user can be the owner of the db, need not be postgres super "
-"account."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Do a fresh install of PostGIS in a new database -- we'll refer to this "
-"database as <varname>newdb</varname>. Please refer to <xref "
-"linkend=\"create_new_db\"/> and <xref linkend=\"create_new_db_extensions\"/> "
-"for instructions on how to do this."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"The spatial_ref_sys entries found in your dump will be restored, but they "
-"will not override existing ones in spatial_ref_sys. This is to ensure that "
-"fixes in the official set will be properly propagated to restored databases. "
-"If for any reason you really want your own overrides of standard entries "
-"just don't load the spatial_ref_sys.sql file when creating the new db."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"If your database is really old or you know you've been using long deprecated "
-"functions in your views and functions, you might need to load "
-"<filename>legacy.sql</filename> for all your functions and views etc. to "
-"properly come back. Only do this if _really_ needed. Consider upgrading your "
-"views and functions before dumping instead, if possible. The deprecated "
-"functions can be later removed by loading <filename>uninstall_legacy.sql</"
-"filename>."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Restore your backup into your fresh <varname>newdb</varname> database using "
-"postgis_restore. Unexpected errors, if any, will be printed to the standard "
-"error stream by psql. Keep a log of those."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Errors may arise in the following cases:"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Some of your views or functions make use of deprecated PostGIS objects. In "
-"order to fix this you may try loading <filename>legacy.sql</filename> script "
-"prior to restore or you'll have to restore to a version of PostGIS which "
-"still contains those objects and try a migration again after porting your "
-"code. If the <filename>legacy.sql</filename> way works for you, don't forget "
-"to fix your code to stop using deprecated functions and drop them loading "
-"<filename>uninstall_legacy.sql</filename>."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Some custom records of spatial_ref_sys in dump file have an invalid SRID "
-"value. Valid SRID values are bigger than 0 and smaller than 999000. Values "
-"in the 999000.999999 range are reserved for internal use while values > "
-"999999 can't be used at all. All your custom records with invalid SRIDs will "
-"be retained, with those > 999999 moved into the reserved range, but the "
-"spatial_ref_sys table would lose a check constraint guarding for that "
-"invariant to hold and possibly also its primary key ( when multiple invalid "
-"SRIDS get converted to the same reserved SRID value )."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"In order to fix this you should copy your custom SRS to a SRID with a valid "
-"value (maybe in the 910000..910999 range), convert all your tables to the "
-"new srid (see <xref linkend=\"UpdateGeometrySRID\"/>), delete the invalid "
-"entry from spatial_ref_sys and re-construct the check(s) with:"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"If you are upgrading an old database containing french <link xlink:"
-"href=\"https://en.wikipedia.org/wiki/Institut_g%C3%A9ographique_national\"> "
-"IGN </link> cartography, you will have probably SRIDs out of range and you "
-"will see, when importing your database, issues like this :"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"In this case, you can try following steps : first throw out completely the "
-"IGN from the sql which is resulting from postgis_restore. So, after having "
-"run :"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "run this command :"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Create then your newdb, activate the required Postgis extensions, and insert "
-"properly the french system IGN with : <link xlink:href=\"https://raw."
-"githubusercontent.com/Remi-C/IGN_spatial_ref_for_PostGIS/master/"
-"Put_IGN_SRS_into_Postgis.sql\"> this script </link> After these operations, "
-"import your data :"
-msgstr ""
-#. Tag: title
-#, no-c-format
-msgid "Performance Tuning"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Tuning for PostGIS performance is much like tuning for any PostgreSQL "
-"workload. The only additional consideration is that geometries and rasters "
-"are usually large, so memory-related optimizations generally have more of an "
-"impact on PostGIS than other types of PostgreSQL queries."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"For general details about optimizing PostgreSQL, refer to <link xlink:"
-"href=\"https://wiki.postgresql.org/wiki/"
-"Tuning_Your_PostgreSQL_Server\">Tuning your PostgreSQL Server</link>."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"For PostgreSQL 9.4+ configuration can be set at the server level without "
-"touching <code>postgresql.conf</code> or <code>postgresql.auto.conf</code> "
-"by using the <code>ALTER SYSTEM</code> command."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"In addition to the Postgres settings, PostGIS has some custom settings which "
-"are listed in <xref linkend=\"PostGIS_GUC\"/>."
-msgstr ""
-#. Tag: title
-#, no-c-format
-msgid "Startup"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "These settings are configured in <code>postgresql.conf</code>:"
-msgstr ""
-#. Tag: link
-#, no-c-format
-msgid "constraint_exclusion"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Default: partition"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"This is generally used for table partitioning. The default for this is set "
-"to \"partition\" which is ideal for PostgreSQL 8.4 and above since it will "
-"force the planner to only analyze tables for constraint consideration if "
-"they are in an inherited hierarchy and not pay the planner penalty otherwise."
-msgstr ""
-#. Tag: link
-#, no-c-format
-msgid "shared_buffers"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Default: ~128MB in PostgreSQL 9.6"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Set to about 25% to 40% of available RAM. On windows you may not be able to "
-"set as high."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<link xlink:href=\"https://www.postgresql.org/docs/current/static/runtime-"
-"config-resource.html#GUC-MAX-WORKER-PROCESSES\">max_worker_processes</link> "
-"This setting is only available for PostgreSQL 9.4+. For PostgreSQL 9.6+ this "
-"setting has additional importance in that it controls the max number of "
-"processes you can have for parallel queries."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Default: 8"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Sets the maximum number of background processes that the system can support. "
-"This parameter can only be set at server start."
-msgstr ""
-#. Tag: title
-#, no-c-format
-msgid "Runtime"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<link xlink:href=\"http://www.postgresql.org/docs/current/static/runtime-"
-"config-resource.html#GUC-WORK-MEM\">work_mem</link> - sets the size of "
-"memory used for sort operations and complex queries"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Default: 1-4MB"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Adjust up for large dbs, complex queries, lots of RAM"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Adjust down for many concurrent users or low RAM."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "If you have lots of RAM and few developers:"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"config-resource.html#GUC-MAINTENANCE-WORK-MEM\">maintenance_work_mem</link> "
-"- the memory size used for VACUUM, CREATE INDEX, etc."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Default: 16-64MB"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Generally too low - ties up I/O, locks objects while swapping memory"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Recommend 32MB to 1GB on production servers w/lots of RAM, but depends on "
-"the # of concurrent users. If you have lots of RAM and few developers:"
-msgstr ""
-#. Tag: link
-#, no-c-format
-msgid "max_parallel_workers_per_gather"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"This setting is only available for PostgreSQL 9.6+ and will only affect "
-"PostGIS 2.3+, since only PostGIS 2.3+ supports parallel queries. If set to "
-"higher than 0, then some queries such as those involving relation functions "
-"like <code>ST_Intersects</code> can use multiple processes and can run more "
-"than twice as fast when doing so. If you have a lot of processors to spare, "
-"you should change the value of this to as many processors as you have. Also "
-"make sure to bump up <code>max_worker_processes</code> to at least as high "
-"as this number."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Default: 0"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Sets the maximum number of workers that can be started by a single "
-"<varname>Gather</varname> node. Parallel workers are taken from the pool of "
-"processes established by <varname>max_worker_processes</varname>. Note that "
-"the requested number of workers may not actually be available at run time. "
-"If this occurs, the plan will run with fewer workers than expected, which "
-"may be inefficient. Setting this value to 0, which is the default, disables "
-"parallel query execution."
-msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Introduction"
@@ -8929,6 +8928,11 @@ msgstr ""
 msgid "PostGIS Aggregate Functions"
 msgstr ""
+#. Tag: section
+#, no-c-format
+msgid "&list_aggregates;"
+msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -8937,16 +8941,16 @@ msgid ""
 "<code>average</code>."
 msgstr ""
-#. Tag: section
-#, no-c-format
-msgid "&list_aggregates;"
-msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "PostGIS Window Functions"
 msgstr ""
+#. Tag: section
+#, no-c-format
+msgid "&list_window_functions;"
+msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -8956,16 +8960,16 @@ msgid ""
 "code> clause."
 msgstr ""
-#. Tag: section
-#, no-c-format
-msgid "&list_window_functions;"
-msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "PostGIS SQL-MM Compliant Functions"
 msgstr ""
+#. Tag: section
+#, no-c-format
+msgid "&list_sqlmm_functions;"
+msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -8973,11 +8977,6 @@ msgid ""
 "standard"
 msgstr ""
-#. Tag: section
-#, no-c-format
-msgid "&list_sqlmm_functions;"
-msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "PostGIS Geography Support Functions"
@@ -9030,6 +9029,11 @@ msgstr ""
 msgid "PostGIS Geometry / Geography / Raster Dump Functions"
 msgstr ""
+#. Tag: section
+#, no-c-format
+msgid "&list_dump_functions;"
+msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -9038,11 +9042,6 @@ msgid ""
 "link> or <link linkend=\"geomval\">geomval</link> data type object."
 msgstr ""
-#. Tag: section
-#, no-c-format
-msgid "&list_dump_functions;"
-msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "PostGIS Box Functions"
@@ -9067,6 +9066,11 @@ msgstr ""
 msgid "PostGIS Functions that support 3D"
 msgstr ""
+#. Tag: section
+#, no-c-format
+msgid "&list_3d_functions;"
+msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -9074,16 +9078,16 @@ msgid ""
 "Index."
 msgstr ""
-#. Tag: section
-#, no-c-format
-msgid "&list_3d_functions;"
-msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "PostGIS Curved Geometry Support Functions"
 msgstr ""
+#. Tag: section
+#, no-c-format
+msgid "&list_curved_geometry_functions;"
+msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -9091,16 +9095,16 @@ msgid ""
 "CURVEPOLYGON, and other curved geometry types"
 msgstr ""
-#. Tag: section
-#, no-c-format
-msgid "&list_curved_geometry_functions;"
-msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "PostGIS Polyhedral Surface Support Functions"
 msgstr ""
+#. Tag: section
+#, no-c-format
+msgid "&list_polyhedral_geometry_functions;"
+msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -9108,11 +9112,6 @@ msgid ""
 "POLYHEDRALSURFACE, POLYHEDRALSURFACEM geometries"
 msgstr ""
-#. Tag: section
-#, no-c-format
-msgid "&list_polyhedral_geometry_functions;"
-msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "PostGIS Function Support Matrix"
@@ -9240,14 +9239,52 @@ msgstr ""
 msgid "&table_body_function_support_matrix;"
 msgstr ""
+#. Tag: section
+#, no-c-format
+msgid "&list_new_functions;"
+msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "New, Enhanced or changed PostGIS Functions"
 msgstr ""
-#. Tag: section
+#. Tag: title
 #, no-c-format
-msgid "&list_new_functions;"
+msgid "PostGIS Reference"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The functions given below are the ones which a user of PostGIS is likely to "
+"need. There are other functions which are required support functions to the "
+"PostGIS objects which are not of use to a general user."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"PostGIS has begun a transition from the existing naming convention to an SQL-"
+"MM-centric convention. As a result, most of the functions that you know and "
+"love have been renamed using the standard spatial type (ST) prefix. Previous "
+"functions are still available, though are not listed in this document where "
+"updated functions are equivalent. The non ST_ functions not listed in this "
+"documentation are deprecated and will be removed in a future release so STOP "
+"USING THEM."
+msgstr ""
+#. Tag: chapter
+#, no-c-format
+msgid ""
+"&reference_type; &reference_management; &reference_constructor; "
+"&reference_accessor; &reference_editor; &reference_validation; "
+"&reference_srs; &reference_input; &reference_output; &reference_operator; "
+"&reference_relationship; &reference_measure; &reference_overlay; "
+"&reference_processing; &reference_coverage; &reference_transformation; "
+"&reference_cluster; &reference_bbox; &reference_lrs; &reference_trajectory; "
+"&reference_sfcgal; &reference_transaction; &reference_version; "
+"&reference_guc; &reference_troubleshooting;"
 msgstr ""
 #. Tag: title
@@ -12494,6 +12531,186 @@ msgstr ""
 msgid ", <xref linkend=\"ST_Scale\"/>, <xref linkend=\"ST_Translate\"/>"
 msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Coverages"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"These functions operate on sets of polygonal geometry that form \"implicit "
+"coverages\". To form a valid coverage polygons must not overlap, and the "
+"vertices of adjacent edges must match exactly. Coverages are fast to "
+"process, and can be operated on with window functions, which retain the "
+"coverage topology inside the window partition while altering the edges."
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"Window function that finds locations where polygons fail to form a valid "
+"coverage."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"A window function which checks if the polygons in the window partition form "
+"a valid polygonal coverage. It returns linear indicators showing the "
+"location of invalid edges (if any) in each polygon."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"A set of valid polygons is a valid coverage if the following conditions hold:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<emphasis role=\"bold\">Non-overlapping</emphasis> - polygons do not overlap "
+"(their interiors do not intersect)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<emphasis role=\"bold\">Edge-Matched</emphasis> - vertices along shared "
+"edges are identical"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"As a window function a value is returned for every input polygon. For "
+"polygons which violate one or more of the validity conditions the return "
+"value is a MULTILINESTRING containing the problematic edges. Coverage-valid "
+"polygons return the value NULL. Non-polygonal or empty geometries also "
+"produce NULL values."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The conditions allow a valid coverage to contain holes (gaps between "
+"polygons), as long as the surrounding polygons are edge-matched. However, "
+"very narrow gaps are often undesirable. If the <parameter>tolerance</"
+"parameter> parameter is specified with a non-zero distance, edges forming "
+"narrower gaps will also be returned as invalid."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The polygons being checked for coverage validity must also be valid "
+"geometries. This can be checked with <xref linkend=\"ST_IsValid\"/>."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Requires GEOS >= 3.12.0"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Invalid edges caused by overlap and non-matching vertices"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+", <xref linkend=\"ST_CoverageUnion\"/>, <xref "
+"linkend=\"ST_CoverageSimplify\"/>"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Window function that simplifies the edges of a polygonal coverage."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"A window function which simplifies the edges of polygons in a polygonal "
+"coverage. The simplification preserves the coverage topology. This means the "
+"simplified output polygons are consisent along shared edges, and still form "
+"a valid coverage."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The simplification uses a variant of the <link xlink:href=\"https://en."
+"wikipedia.org/wiki/Visvalingam%E2%80%93Whyatt_algorithm\">Visvalingam–Whyatt "
+"algorithm</link>. The <parameter>tolerance</parameter> parameter has units "
+"of distance, and is roughly equal to the square root of triangular areas to "
+"be simplified."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"To simplify only the \"internal\" edges of the coverage (those that are "
+"shared by two polygons) set the <parameter>simplifyBoundary</parameter> "
+"parameter to false."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"If the input is not a valid coverage there may be unexpected artifacts in "
+"the output (such as boundary intersections, or separated boundaries which "
+"appeared to be shared). Use <xref linkend=\"ST_CoverageInvalidEdges\"/> to "
+"determine if a coverage is valid."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Input coverage"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Simplified coverage"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"Computes the union of a set of polygons forming a coverage by removing "
+"shared edges."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"An aggregate function which unions a set of polygons forming a polygonal "
+"coverage. The result is a polygonal geometry covering the same area as the "
+"coverage. This function produces the same result as <xref "
+"linkend=\"ST_Union\"/>, but uses the coverage structure to compute the union "
+"much faster."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"the output (such as unmerged or overlapping polygons). Use <xref "
+"linkend=\"ST_CoverageInvalidEdges\"/> to determine if a coverage is valid."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Availability: 3.4.0 - requires GEOS >= 3.8.0"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Union result"
+msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Geometry Editors"
@@ -17254,619 +17471,6 @@ msgid ""
 "<xref linkend=\"ST_ShortestLine\"/>, <xref linkend=\"ST_3DMaxDistance\"/>"
 msgstr ""
-#. Tag: title
-#, no-c-format
-msgid "SFCGAL Functions"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"SFCGAL is a C++ wrapper library around CGAL that provides advanced 2D and 3D "
-"spatial functions. For robustness, geometry coordinates have an exact "
-"rational number representation."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Installation instructions for the library can be found on the SFCGAL home "
-"page (<link xlink:href=\"http://www.sfcgal.org\">http://www.sfcgal.org</"
-"link>). To enable the functions use <code>create extension postgis_sfcgal</"
-"code>."
-msgstr ""
-#. Tag: refpurpose
-#, no-c-format
-msgid "<refpurpose>Returns the version of SFCGAL in use</refpurpose>"
-msgstr ""
-#. Tag: funcdef
-#, no-c-format
-msgid "text <function>postgis_sfcgal_version</function>"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "<para>Returns the version of SFCGAL in use</para>"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "&sfcgal_required;"
-msgstr ""
-#. Tag: refpurpose
-#, no-c-format
-msgid ""
-"<refpurpose>Returns the full version of SFCGAL in use including CGAL and "
-"Boost versions</refpurpose>"
-msgstr ""
-#. Tag: funcdef
-#, no-c-format
-msgid "text <function>postgis_sfcgal_full_version</function>"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<para>Returns the full version of SFCGAL in use including CGAL and Boost "
-"versions</para>"
-msgstr ""
-#. Tag: refpurpose
-#, no-c-format
-msgid "Computes area of 3D surface geometries. Will return 0 for solids."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "&sqlmm_compliant; SQL-MM IEC 13249-3: 8.1, 10.5"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Note: By default a PolyhedralSurface built from WKT is a surface geometry, "
-"not solid. It therefore has surface area. Once converted to a solid, no area."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-", <xref linkend=\"ST_MakeSolid\"/>, <xref linkend=\"ST_IsSolid\"/>, <xref "
-"linkend=\"ST_Area\"/>"
-msgstr ""
-#. Tag: refpurpose
-#, no-c-format
-msgid "Computes the 3D convex hull of a geometry."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Original geometry overlaid with 3D convex hull"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ", <xref linkend=\"ST_AsX3D\"/>"
-msgstr ""
-#. Tag: refpurpose
-#, no-c-format
-msgid "Perform 3D intersection"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Return a geometry that is the shared portion between geom1 and geom2."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"3D images were generated using PostGIS <xref linkend=\"ST_AsX3D\"/> and "
-"rendering in HTML using <link xlink:href=\"http://www.x3dom.org\">X3Dom HTML "
-"Javascript rendering library</link>."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Original 3D geometries overlaid. geom2 is shown semi-transparent"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Intersection of geom1 and geom2"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "3D linestrings and polygons"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Cube (closed Polyhedral Surface) and Polygon Z"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Intersection of 2 solids that result in volumetric intersection is also a "
-"solid (ST_Dimension returns 3)"
-msgstr ""
-#. Tag: refpurpose
-#, no-c-format
-msgid "Perform 3D difference"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Returns that part of geom1 that is not part of geom2."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Original 3D geometries overlaid. geom2 is the part that will be removed."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "What's left after removing geom2"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-", <xref linkend=\"ST_AsX3D\"/>, <xref linkend=\"ST_3DIntersection\"/> <xref "
-"linkend=\"ST_3DUnion\"/>"
-msgstr ""
-#. Tag: refpurpose
-#, no-c-format
-msgid "Perform 3D union."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Availability: 3.3.0 aggregate variant was added"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<emphasis role=\"bold\">Aggregate variant:</emphasis> returns a geometry "
-"that is the 3D union of a rowset of geometries. The ST_3DUnion() function is "
-"an \"aggregate\" function in the terminology of PostgreSQL. That means that "
-"it operates on rows of data, in the same way the SUM() and AVG() functions "
-"do and like most aggregates, it also ignores NULL geometries."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Original 3D geometries overlaid. geom2 is the one with transparency."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Union of geom1 and geom2"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"linkend=\"ST_3DDifference\"/>"
-msgstr ""
-#. Tag: refpurpose
-#, no-c-format
-msgid "Computes an Alpha-shape enclosing a geometry"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Computes the <link xlink:href=\"https://en.wikipedia.org/wiki/"
-"Alpha_shape\">Alpha-Shape</link> of the points in a geometry. An alpha-shape "
-"is a (usually) concave polygonal geometry which contains all the vertices of "
-"the input, and whose vertices are a subset of the input vertices. An alpha-"
-"shape provides a closer fit to the shape of the input than the shape "
-"produced by the <link linkend=\"ST_ConvexHull\">convex hull</link>."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"The \"closeness of fit\" is controlled by the <varname>alpha</varname> "
-"parameter, which can have values from 0 to infinity. Smaller alpha values "
-"produce more concave results. Alpha values greater than some data-dependent "
-"value produce the convex hull of the input."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Following the CGAL implementation, the alpha value is the <emphasis>square</"
-"emphasis> of the radius of the disc used in the Alpha-Shape algorithm to "
-"\"erode\" the Delaunay Triangulation of the input points. See <link xlink:"
-"href=\"https://doc.cgal.org/latest/Alpha_shapes_2/index."
-"html#Chapter_2D_Alpha_Shapes\">CGAL Alpha-Shapes</link> for more "
-"information. This is different from the original definition of alpha-shapes, "
-"which defines alpha as the radius of the eroding disc."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"The computed shape does not contain holes unless the optional "
-"<varname>allow_holes</varname> argument is specified as true."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"This function effectively computes a concave hull of a geometry in a similar "
-"way to <xref linkend=\"ST_ConcaveHull\"/>, but uses CGAL and a different "
-"algorithm."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Availability: 3.3.0 - requires SFCGAL >= 1.4.1."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Alpha-shape of a MultiPoint (same example As <xref "
-"linkend=\"ST_OptimalAlphaShape\"/>)"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Alpha-shape of a MultiPoint, allowing holes (same example as <xref "
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"linkend=\"ST_ConcaveHull\"/>)"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ", <xref linkend=\"ST_OptimalAlphaShape\"/>"
-msgstr ""
-#. Tag: refpurpose
-#, no-c-format
-msgid "Compute the approximate medial axis of an areal geometry."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Return an approximate medial axis for the areal input based on its straight "
-"skeleton. Uses an SFCGAL specific API when built against a capable version "
-"(1.2.0+). Otherwise the function is just a wrapper around "
-"ST_StraightSkeleton (slower case)."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "A polygon and its approximate medial axis"
-msgstr ""
-#. Tag: refpurpose
-#, no-c-format
-msgid ""
-"Return a constrained Delaunay triangulation around the given input geometry."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Return a <link xlink:href=\"https://en.wikipedia.org/wiki/"
-"Constrained_Delaunay_triangulation\">Constrained Delaunay triangulation</"
-"link> around the vertices of the input geometry. Output is a TIN."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "ST_ConstrainedDelaunayTriangles of 2 polygons"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "of 2 polygons. Triangle edges cross polygon boundaries."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-", <xref linkend=\"ST_TriangulatePolygon\"/>, <xref linkend=\"ST_Tesselate\"/"
-">, <xref linkend=\"ST_ConcaveHull\"/>, <xref linkend=\"ST_Dump\"/>"
-msgstr ""
-#. Tag: refpurpose
-#, no-c-format
-msgid "Extrude a surface to a related volume"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Original octagon formed from buffering point"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Hexagon extruded 30 units along Z produces a PolyhedralSurfaceZ"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Original linestring"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "LineString Extruded along Z produces a PolyhedralSurfaceZ"
-msgstr ""
-#. Tag: refpurpose
-#, no-c-format
-msgid "Force LHR orientation"
-msgstr ""
-#. Tag: refpurpose
-#, no-c-format
-msgid "Check if a surface is or not planar"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Availability: 2.2.0: This was documented in 2.1.0 but got accidentally left "
-"out in 2.1 release."
-msgstr ""
-#. Tag: refpurpose
-#, no-c-format
-msgid "Test if the geometry is a solid. No validity check is performed."
-msgstr ""
-#. Tag: refpurpose
-#, no-c-format
-msgid ""
-"Cast the geometry into a solid. No check is performed. To obtain a valid "
-"solid, the input geometry must be a closed Polyhedral Surface or a closed "
-"TIN."
-msgstr ""
-#. Tag: refpurpose
-#, no-c-format
-msgid "Performs Minkowski sum"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"This function performs a 2D minkowski sum of a point, line or polygon with a "
-"polygon."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"A minkowski sum of two geometries A and B is the set of all points that are "
-"the sum of any point in A and B. Minkowski sums are often used in motion "
-"planning and computer-aided design. More details on <link xlink:"
-"href=\"https://en.wikipedia.org/wiki/Minkowski_addition\">Wikipedia "
-"Minkowski addition</link>."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"The first parameter can be any 2D geometry (point, linestring, polygon). If "
-"a 3D geometry is passed, it will be converted to 2D by forcing Z to 0, "
-"leading to possible cases of invalidity. The second parameter must be a 2D "
-"polygon."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Implementation utilizes <link xlink:href=\"http://doc.cgal.org/latest/"
-"Minkowski_sum_2/\">CGAL 2D Minkowskisum</link>."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Minkowski Sum of Linestring and circle polygon where Linestring cuts thru "
-"the circle"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Before Summing"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "After summing"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Minkowski Sum of a polygon and multipoint"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"After summing: polygon is duplicated and translated to position of points"
-msgstr ""
-#. Tag: refpurpose
-#, no-c-format
-msgid ""
-"Computes an Alpha-shape enclosing a geometry using an \"optimal\" alpha "
-"value."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Computes the \"optimal\" alpha-shape of the points in a geometry. The alpha-"
-"shape is computed using a value of α chosen so that:"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"the number of polygon elements is equal to or smaller than "
-"<varname>nb_components</varname> (which defaults to 1)"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "all input points are contained in the shape"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"The result will not contain holes unless the optional <varname>allow_holes</"
-"varname> argument is specified as true."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Optimal alpha-shape of a MultiPoint (same example as <xref "
-"linkend=\"ST_AlphaShape\"/>)"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Optimal alpha-shape of a MultiPoint, allowing holes (same example as <xref "
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ", <xref linkend=\"ST_AlphaShape\"/>"
-msgstr ""
-#. Tag: refpurpose
-#, no-c-format
-msgid "Determine surface orientation"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"The function only applies to polygons. It returns -1 if the polygon is "
-"counterclockwise oriented and 1 if the polygon is clockwise oriented."
-msgstr ""
-#. Tag: refpurpose
-#, no-c-format
-msgid "Compute a straight skeleton from a geometry"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Original polygon"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Straight Skeleton of polygon"
-msgstr ""
-#. Tag: refpurpose
-#, no-c-format
-msgid ""
-"Perform surface Tesselation of a polygon or polyhedralsurface and returns as "
-"a TIN or collection of TINS"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Takes as input a surface such a MULTI(POLYGON) or POLYHEDRALSURFACE and "
-"returns a TIN representation via the process of tessellation using triangles."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Original Cube"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "ST_AsText output:"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Tesselated Cube with triangles colored"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "ST_AsText output"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Tesselated Polygon"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ", <xref linkend=\"ST_DelaunayTriangles\"/>"
-msgstr ""
-#. Tag: refpurpose
-#, no-c-format
-msgid ""
-"Computes the volume of a 3D solid. If applied to surface (even closed) "
-"geometries will return 0."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "&sqlmm_compliant; SQL-MM IEC 13249-3: 9.1 (same as ST_3DVolume)"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"When closed surfaces are created with WKT, they are treated as areal rather "
-"than solid. To make them solid, you need to use <xref "
-"linkend=\"ST_MakeSolid\"/>. Areal geometries have no volume. Here is an "
-"example to demonstrate."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ", <xref linkend=\"ST_MakeSolid\"/>, <xref linkend=\"ST_IsSolid\"/>"
-msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Operators"
@@ -22833,186 +22437,6 @@ msgstr ""
 msgid ", <xref linkend=\"ST_VoronoiLines\"/>"
 msgstr ""
-#. Tag: title
-#, no-c-format
-msgid "Coverages"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"These functions operate on sets of polygonal geometry that form \"implicit "
-"coverages\". To form a valid coverage polygons must not overlap, and the "
-"vertices of adjacent edges must match exactly. Coverages are fast to "
-"process, and can be operated on with window functions, which retain the "
-"coverage topology inside the window partition while altering the edges."
-msgstr ""
-#. Tag: refpurpose
-#, no-c-format
-msgid ""
-"Window function that finds locations where polygons fail to form a valid "
-"coverage."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"A window function which checks if the polygons in the window partition form "
-"a valid polygonal coverage. It returns linear indicators showing the "
-"location of invalid edges (if any) in each polygon."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"A set of valid polygons is a valid coverage if the following conditions hold:"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<emphasis role=\"bold\">Non-overlapping</emphasis> - polygons do not overlap "
-"(their interiors do not intersect)"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<emphasis role=\"bold\">Edge-Matched</emphasis> - vertices along shared "
-"edges are identical"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"As a window function a value is returned for every input polygon. For "
-"polygons which violate one or more of the validity conditions the return "
-"value is a MULTILINESTRING containing the problematic edges. Coverage-valid "
-"polygons return the value NULL. Non-polygonal or empty geometries also "
-"produce NULL values."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"The conditions allow a valid coverage to contain holes (gaps between "
-"polygons), as long as the surrounding polygons are edge-matched. However, "
-"very narrow gaps are often undesirable. If the <parameter>tolerance</"
-"parameter> parameter is specified with a non-zero distance, edges forming "
-"narrower gaps will also be returned as invalid."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"The polygons being checked for coverage validity must also be valid "
-"geometries. This can be checked with <xref linkend=\"ST_IsValid\"/>."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Requires GEOS >= 3.12.0"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Invalid edges caused by overlap and non-matching vertices"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-", <xref linkend=\"ST_CoverageUnion\"/>, <xref "
-"linkend=\"ST_CoverageSimplify\"/>"
-msgstr ""
-#. Tag: refpurpose
-#, no-c-format
-msgid "Window function that simplifies the edges of a polygonal coverage."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"A window function which simplifies the edges of polygons in a polygonal "
-"coverage. The simplification preserves the coverage topology. This means the "
-"simplified output polygons are consisent along shared edges, and still form "
-"a valid coverage."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"The simplification uses a variant of the <link xlink:href=\"https://en."
-"wikipedia.org/wiki/Visvalingam%E2%80%93Whyatt_algorithm\">Visvalingam–Whyatt "
-"algorithm</link>. The <parameter>tolerance</parameter> parameter has units "
-"of distance, and is roughly equal to the square root of triangular areas to "
-"be simplified."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"To simplify only the \"internal\" edges of the coverage (those that are "
-"shared by two polygons) set the <parameter>simplifyBoundary</parameter> "
-"parameter to false."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"If the input is not a valid coverage there may be unexpected artifacts in "
-"the output (such as boundary intersections, or separated boundaries which "
-"appeared to be shared). Use <xref linkend=\"ST_CoverageInvalidEdges\"/> to "
-"determine if a coverage is valid."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Input coverage"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Simplified coverage"
-msgstr ""
-#. Tag: refpurpose
-#, no-c-format
-msgid ""
-"Computes the union of a set of polygons forming a coverage by removing "
-"shared edges."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"An aggregate function which unions a set of polygons forming a polygonal "
-"coverage. The result is a polygonal geometry covering the same area as the "
-"coverage. This function produces the same result as <xref "
-"linkend=\"ST_Union\"/>, but uses the coverage structure to compute the union "
-"much faster."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"the output (such as unmerged or overlapping polygons). Use <xref "
-"linkend=\"ST_CoverageInvalidEdges\"/> to determine if a coverage is valid."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Availability: 3.4.0 - requires GEOS >= 3.8.0"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Union result"
-msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Raster Reference"
@@ -24432,12 +23856,12 @@ msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "Pixel Width: Pixel size in the i direction"
+msgid "Pixel Height: Pixel size in the j direction"
 msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "Pixel Height: Pixel size in the j direction"
+msgid "Pixel Width: Pixel size in the i direction"
 msgstr ""
 #. Tag: refpurpose
@@ -31490,6 +30914,619 @@ msgstr ""
 msgid "Changed: 2.2.0 In prior versions this was called ST_Point_Inside_Circle"
 msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "SFCGAL Functions"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"SFCGAL is a C++ wrapper library around CGAL that provides advanced 2D and 3D "
+"spatial functions. For robustness, geometry coordinates have an exact "
+"rational number representation."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Installation instructions for the library can be found on the SFCGAL home "
+"page (<link xlink:href=\"http://www.sfcgal.org\">http://www.sfcgal.org</"
+"link>). To enable the functions use <code>create extension postgis_sfcgal</"
+"code>."
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "<refpurpose>Returns the version of SFCGAL in use</refpurpose>"
+msgstr ""
+#. Tag: funcdef
+#, no-c-format
+msgid "text <function>postgis_sfcgal_version</function>"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "<para>Returns the version of SFCGAL in use</para>"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "&sfcgal_required;"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"<refpurpose>Returns the full version of SFCGAL in use including CGAL and "
+"Boost versions</refpurpose>"
+msgstr ""
+#. Tag: funcdef
+#, no-c-format
+msgid "text <function>postgis_sfcgal_full_version</function>"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<para>Returns the full version of SFCGAL in use including CGAL and Boost "
+"versions</para>"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Computes area of 3D surface geometries. Will return 0 for solids."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "&sqlmm_compliant; SQL-MM IEC 13249-3: 8.1, 10.5"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Note: By default a PolyhedralSurface built from WKT is a surface geometry, "
+"not solid. It therefore has surface area. Once converted to a solid, no area."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+", <xref linkend=\"ST_MakeSolid\"/>, <xref linkend=\"ST_IsSolid\"/>, <xref "
+"linkend=\"ST_Area\"/>"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Computes the 3D convex hull of a geometry."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Original geometry overlaid with 3D convex hull"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ", <xref linkend=\"ST_AsX3D\"/>"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Perform 3D intersection"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Return a geometry that is the shared portion between geom1 and geom2."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"3D images were generated using PostGIS <xref linkend=\"ST_AsX3D\"/> and "
+"rendering in HTML using <link xlink:href=\"http://www.x3dom.org\">X3Dom HTML "
+"Javascript rendering library</link>."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Original 3D geometries overlaid. geom2 is shown semi-transparent"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Intersection of geom1 and geom2"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "3D linestrings and polygons"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Cube (closed Polyhedral Surface) and Polygon Z"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Intersection of 2 solids that result in volumetric intersection is also a "
+"solid (ST_Dimension returns 3)"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Perform 3D difference"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Returns that part of geom1 that is not part of geom2."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Original 3D geometries overlaid. geom2 is the part that will be removed."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "What's left after removing geom2"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+", <xref linkend=\"ST_AsX3D\"/>, <xref linkend=\"ST_3DIntersection\"/> <xref "
+"linkend=\"ST_3DUnion\"/>"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Perform 3D union."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Availability: 3.3.0 aggregate variant was added"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<emphasis role=\"bold\">Aggregate variant:</emphasis> returns a geometry "
+"that is the 3D union of a rowset of geometries. The ST_3DUnion() function is "
+"an \"aggregate\" function in the terminology of PostgreSQL. That means that "
+"it operates on rows of data, in the same way the SUM() and AVG() functions "
+"do and like most aggregates, it also ignores NULL geometries."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Original 3D geometries overlaid. geom2 is the one with transparency."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Union of geom1 and geom2"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"linkend=\"ST_3DDifference\"/>"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Computes an Alpha-shape enclosing a geometry"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Computes the <link xlink:href=\"https://en.wikipedia.org/wiki/"
+"Alpha_shape\">Alpha-Shape</link> of the points in a geometry. An alpha-shape "
+"is a (usually) concave polygonal geometry which contains all the vertices of "
+"the input, and whose vertices are a subset of the input vertices. An alpha-"
+"shape provides a closer fit to the shape of the input than the shape "
+"produced by the <link linkend=\"ST_ConvexHull\">convex hull</link>."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The \"closeness of fit\" is controlled by the <varname>alpha</varname> "
+"parameter, which can have values from 0 to infinity. Smaller alpha values "
+"produce more concave results. Alpha values greater than some data-dependent "
+"value produce the convex hull of the input."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Following the CGAL implementation, the alpha value is the <emphasis>square</"
+"emphasis> of the radius of the disc used in the Alpha-Shape algorithm to "
+"\"erode\" the Delaunay Triangulation of the input points. See <link xlink:"
+"href=\"https://doc.cgal.org/latest/Alpha_shapes_2/index."
+"html#Chapter_2D_Alpha_Shapes\">CGAL Alpha-Shapes</link> for more "
+"information. This is different from the original definition of alpha-shapes, "
+"which defines alpha as the radius of the eroding disc."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The computed shape does not contain holes unless the optional "
+"<varname>allow_holes</varname> argument is specified as true."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"This function effectively computes a concave hull of a geometry in a similar "
+"way to <xref linkend=\"ST_ConcaveHull\"/>, but uses CGAL and a different "
+"algorithm."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Availability: 3.3.0 - requires SFCGAL >= 1.4.1."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Alpha-shape of a MultiPoint (same example As <xref "
+"linkend=\"ST_OptimalAlphaShape\"/>)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Alpha-shape of a MultiPoint, allowing holes (same example as <xref "
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"linkend=\"ST_ConcaveHull\"/>)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ", <xref linkend=\"ST_OptimalAlphaShape\"/>"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Compute the approximate medial axis of an areal geometry."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Return an approximate medial axis for the areal input based on its straight "
+"skeleton. Uses an SFCGAL specific API when built against a capable version "
+"(1.2.0+). Otherwise the function is just a wrapper around "
+"ST_StraightSkeleton (slower case)."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "A polygon and its approximate medial axis"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"Return a constrained Delaunay triangulation around the given input geometry."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Return a <link xlink:href=\"https://en.wikipedia.org/wiki/"
+"Constrained_Delaunay_triangulation\">Constrained Delaunay triangulation</"
+"link> around the vertices of the input geometry. Output is a TIN."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "ST_ConstrainedDelaunayTriangles of 2 polygons"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "of 2 polygons. Triangle edges cross polygon boundaries."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+", <xref linkend=\"ST_TriangulatePolygon\"/>, <xref linkend=\"ST_Tesselate\"/"
+">, <xref linkend=\"ST_ConcaveHull\"/>, <xref linkend=\"ST_Dump\"/>"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Extrude a surface to a related volume"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Original octagon formed from buffering point"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Hexagon extruded 30 units along Z produces a PolyhedralSurfaceZ"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Original linestring"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "LineString Extruded along Z produces a PolyhedralSurfaceZ"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Force LHR orientation"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Check if a surface is or not planar"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Availability: 2.2.0: This was documented in 2.1.0 but got accidentally left "
+"out in 2.1 release."
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Test if the geometry is a solid. No validity check is performed."
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"Cast the geometry into a solid. No check is performed. To obtain a valid "
+"solid, the input geometry must be a closed Polyhedral Surface or a closed "
+"TIN."
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Performs Minkowski sum"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"This function performs a 2D minkowski sum of a point, line or polygon with a "
+"polygon."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"A minkowski sum of two geometries A and B is the set of all points that are "
+"the sum of any point in A and B. Minkowski sums are often used in motion "
+"planning and computer-aided design. More details on <link xlink:"
+"href=\"https://en.wikipedia.org/wiki/Minkowski_addition\">Wikipedia "
+"Minkowski addition</link>."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The first parameter can be any 2D geometry (point, linestring, polygon). If "
+"a 3D geometry is passed, it will be converted to 2D by forcing Z to 0, "
+"leading to possible cases of invalidity. The second parameter must be a 2D "
+"polygon."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Implementation utilizes <link xlink:href=\"http://doc.cgal.org/latest/"
+"Minkowski_sum_2/\">CGAL 2D Minkowskisum</link>."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Minkowski Sum of Linestring and circle polygon where Linestring cuts thru "
+"the circle"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Before Summing"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "After summing"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Minkowski Sum of a polygon and multipoint"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"After summing: polygon is duplicated and translated to position of points"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"Computes an Alpha-shape enclosing a geometry using an \"optimal\" alpha "
+"value."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Computes the \"optimal\" alpha-shape of the points in a geometry. The alpha-"
+"shape is computed using a value of α chosen so that:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"the number of polygon elements is equal to or smaller than "
+"<varname>nb_components</varname> (which defaults to 1)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "all input points are contained in the shape"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The result will not contain holes unless the optional <varname>allow_holes</"
+"varname> argument is specified as true."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Optimal alpha-shape of a MultiPoint (same example as <xref "
+"linkend=\"ST_AlphaShape\"/>)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Optimal alpha-shape of a MultiPoint, allowing holes (same example as <xref "
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ", <xref linkend=\"ST_AlphaShape\"/>"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Determine surface orientation"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The function only applies to polygons. It returns -1 if the polygon is "
+"counterclockwise oriented and 1 if the polygon is clockwise oriented."
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Compute a straight skeleton from a geometry"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Original polygon"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Straight Skeleton of polygon"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"Perform surface Tesselation of a polygon or polyhedralsurface and returns as "
+"a TIN or collection of TINS"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Takes as input a surface such a MULTI(POLYGON) or POLYHEDRALSURFACE and "
+"returns a TIN representation via the process of tessellation using triangles."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Original Cube"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "ST_AsText output:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Tesselated Cube with triangles colored"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "ST_AsText output"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Tesselated Polygon"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ", <xref linkend=\"ST_DelaunayTriangles\"/>"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"Computes the volume of a 3D solid. If applied to surface (even closed) "
+"geometries will return 0."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "&sqlmm_compliant; SQL-MM IEC 13249-3: 9.1 (same as ST_3DVolume)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"When closed surfaces are created with WKT, they are treated as areal rather "
+"than solid. To make them solid, you need to use <xref "
+"linkend=\"ST_MakeSolid\"/>. Areal geometries have no volume. Here is an "
+"example to demonstrate."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ", <xref linkend=\"ST_MakeSolid\"/>, <xref linkend=\"ST_IsSolid\"/>"
+msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Spatial Reference System Functions"
@@ -33384,44 +33421,6 @@ msgid ""
 ">, <xref linkend=\"PostGIS_PROJ_Version\"/>"
 msgstr ""
-#. Tag: title
-#, no-c-format
-msgid "PostGIS Reference"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"The functions given below are the ones which a user of PostGIS is likely to "
-"need. There are other functions which are required support functions to the "
-"PostGIS objects which are not of use to a general user."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"PostGIS has begun a transition from the existing naming convention to an SQL-"
-"MM-centric convention. As a result, most of the functions that you know and "
-"love have been renamed using the standard spatial type (ST) prefix. Previous "
-"functions are still available, though are not listed in this document where "
-"updated functions are equivalent. The non ST_ functions not listed in this "
-"documentation are deprecated and will be removed in a future release so STOP "
-"USING THEM."
-msgstr ""
-#. Tag: chapter
-#, no-c-format
-msgid ""
-"&reference_type; &reference_management; &reference_constructor; "
-"&reference_accessor; &reference_editor; &reference_validation; "
-"&reference_srs; &reference_input; &reference_output; &reference_operator; "
-"&reference_relationship; &reference_measure; &reference_overlay; "
-"&reference_processing; &reference_coverage; &reference_transformation; "
-"&reference_cluster; &reference_bbox; &reference_lrs; &reference_trajectory; "
-"&reference_sfcgal; &reference_transaction; &reference_version; "
-"&reference_guc; &reference_troubleshooting;"
-msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Appendix"
Summary of changes:
 doc/Makefile.in                     |    14 +-
 doc/po/templates/postgis-manual.pot | 18543 +++++++++++++++++-----------------
 2 files changed, 9278 insertions(+), 9279 deletions(-)
hooks/post-receive
