[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-606-gcb91c5193
Wed Sep 20 01:20:45 PDT 2023
the project "PostGIS".
       via  cb91c5193eccff425f7a0a56d0b35bc5fb7d0dd4 (commit)
       via  64d0633229af59c2fac0123f08f6dee4b4444efc (commit)
      from  d06a349651886cb4789f1480389857a636f58504 (commit)
revisions in full, below.
commit cb91c5193eccff425f7a0a56d0b35bc5fb7d0dd4
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Sep 20 10:07:48 2023 +0200
    Rewrite caption of ST_PointOnSurface examples
diff --git a/doc/po/templates/postgis-manual.pot b/doc/po/templates/postgis-manual.pot
index 39cb649ea..4b37f02c2 100644
--- a/doc/po/templates/postgis-manual.pot
+++ b/doc/po/templates/postgis-manual.pot
@@ -21869,22 +21869,22 @@ msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "PointOnSurface of a <varname>MULTIPOINT</varname>"
+msgid "Point on surface of a <varname>MULTIPOINT</varname>"
 msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "PointOnSurface of a <varname>LINESTRING</varname>"
+msgid "Point on surface of a <varname>LINESTRING</varname>"
 msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "PointOnSurface of a <varname>POLYGON</varname>"
+msgid "Point on surface of a <varname>POLYGON</varname>"
 msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "PointOnSurface of a <varname>GEOMETRYCOLLECTION</varname>"
+msgid "Point on surface of a <varname>GEOMETRYCOLLECTION</varname>"
 msgstr ""
 #. Tag: para
diff --git a/doc/reference_processing.xml b/doc/reference_processing.xml
index 5a0a6b385..4254b3aae 100644
--- a/doc/reference_processing.xml
+++ b/doc/reference_processing.xml
@@ -2213,7 +2213,7 @@ MULTILINESTRING((164 1,11.7867965644036 1,1 11.7867965644036,1 195),
                       <imagedata fileref="images/st_pointonsurface01.png"/>
                     </imageobject>
-                    <caption><para>PointOnSurface of a
+                    <caption><para>Point on surface of a
                     <varname>MULTIPOINT</varname></para></caption>
                   </mediaobject>
                 </informalfigure></para></entry>
@@ -2224,7 +2224,7 @@ MULTILINESTRING((164 1,11.7867965644036 1,1 11.7867965644036,1 195),
                       <imagedata fileref="images/st_pointonsurface02.png"/>
                     </imageobject>
                     <varname>LINESTRING</varname></para></caption>
                   </mediaobject>
@@ -2237,7 +2237,7 @@ MULTILINESTRING((164 1,11.7867965644036 1,1 11.7867965644036,1 195),
                       <imagedata fileref="images/st_pointonsurface03.png"/>
                     </imageobject>
                     <varname>POLYGON</varname></para></caption>
                   </mediaobject>
@@ -2248,7 +2248,7 @@ MULTILINESTRING((164 1,11.7867965644036 1,1 11.7867965644036,1 195),
                       <imagedata fileref="images/st_pointonsurface04.png"/>
                     </imageobject>
                     <varname>GEOMETRYCOLLECTION</varname></para></caption>
                   </mediaobject>
commit 64d0633229af59c2fac0123f08f6dee4b4444efc
Date:   Wed Sep 20 10:18:34 2023 +0200
    Revert the msgmerge hack aimed at avoiding linewrap war on .pot file
    The hack was not functions.
    References #5544
diff --git a/doc/Makefile.in b/doc/Makefile.in
index 7c5496c3f..cfaf68f55 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -286,7 +286,6 @@ endif
 ifeq ($(MSGMERGE),)
 $(PO_FILES): requirements_not_met_msgmerge
-$(XML_UNIFIED_POT): requirements_not_met_msgmerge
 endif
 ifeq ($(MSGATTRIB),)
@@ -328,14 +327,14 @@ $(XML_UNIFIED_POT): $(XML_SOURCE_POTS)
 	@$(MSGCAT) --sort-by-file --use-first --no-location -o $@.tmp $(XML_SOURCE_POTS)
 	@if test -f $@; then \
     if test -n "$$($(MSGCOMM) --unique $@.tmp $@ | tail -1)"; then \
-      $(MSGMERGE) -U $@ $@.tmp || exit 1; \
       echo "$@ updated"; \
     else \
       echo "$@ unchanged"; \
+      rm -f $@.tmp; \
     fi; \
-    rm -f $@.tmp; \
-  else \
-		mv $@.tmp $@; \
+  fi; \
+  if test -f $@.tmp; then \
+    mv $@.tmp $@; \
   fi;
 # Creates or updates translation files
Summary of changes:
 doc/Makefile.in                     | 9 ++++-----
 doc/po/templates/postgis-manual.pot | 8 ++++----
 doc/reference_processing.xml        | 8 ++++----
 3 files changed, 12 insertions(+), 13 deletions(-)
hooks/post-receive
