[postgis-tickets] [PostGIS] #5545: Postgis upgrade from 3.2.3 to 3.3.2 failing on create or update function st_orderingequals
PostGIS trac at osgeo.org
Mon Sep 25 06:53:15 PDT 2023
st_orderingequals
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  blocker                |  Milestone:  PostGIS 3.3.5
 Component:  build/upgrade/install  |    Version:  3.4.x
Resolution:                         |   Keywords:
Description changed by strk:
Old description:
> Putting in this ticket for Dan Worthman as he's having issues setting up
> an osgeo account.
> I'm having some issues with upgrading my postgis extension from 3.2.3 to
> 3.3.2. I'm on postgres engine 14.7 on AWS RDS Aurora, and my failure is
> coming from running SELECT postgis_extensions_upgrade();
> ERROR:  cannot change name of input parameter "geometrya"
> HINT:  Use DROP FUNCTION st_orderingequals(geometry,geometry) first.
> I was told this is fixed in unreleased 3.4.1
> https://trac.osgeo.org/postgis/changeset/e428b70577bd51d3924346d9f0124a6d37ef4ff8/git
> and I would like to request a backport to the 3.3 branch.
> I was also directed to try dropping the function:
> postgres=> DROP FUNCTION st_orderingequals(geometry,geometry);
> ERROR:  cannot drop function st_orderingequals(geometry,geometry) because
> extension postgis requires it
> HINT:  You can drop extension postgis instead.
> Strk told me to try `alter extension postgis drop function` but I am not
> permitted to do this in RDS Aurora (I opened a support ticket with AWS to
> try to solve the problem from this angle)
> postgres=> alter extension postgis drop function st_orderingequals;
> ERROR: must be owner of extension postgis
> They also told me that according to git log, commit 6082ff04f3 fixed the
> problem but since I am still facing the issue they recommended I open a
> ticket.
> Here is my search path:
> postgres=> show search_path;
>         search_path
> "$user", public, topology
> (1 row)
New description:
 an osgeo account.
 They also told me that according to git log, commit [6082ff04f3/git] fixed
 the problem but since I am still facing the issue they recommended I open
 a ticket.
         search_path
 (1 row)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5545#comment:5>
