[postgis-tickets] [PostGIS] #5545: Postgis upgrade from 3.2.3 to 3.3.2 failing on create or update function st_orderingequals
PostGIS trac at osgeo.org
Mon Sep 25 15:52:12 PDT 2023
st_orderingequals
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  blocker                |  Milestone:  PostGIS 3.3.5
 Component:  build/upgrade/install  |    Version:  3.4.x
Resolution:                         |   Keywords:
Comment (by wodan):
 Hi there, thank you for the attention on this!
 select pg_get_function_identity_arguments('st_orderingequals'::regproc);
  geometrya geometry, geometryb geometry
 (1 row)
 I was able to run `ALTER FUNCTION st_orderingequals(geometry, geometry)
 RENAME TO st_orderingequals_old;` but ran into further ownership issues:
 postgres=> ALTER FUNCTION st_orderingequals(geometry, geometry) RENAME TO
 ALTER FUNCTION
 postgres=> SELECT postgis_extensions_upgrade();
 NOTICE:  Updating extension postgis from 3.2.3 to 3.3.2
 NOTICE:  Packaging extension postgis_raster
 ERROR:  Trying to add VIEW raster_columns to postgis_raster, got must be
 owner of extension postgis_raster (42501)
 CONTEXT:  PL/pgSQL function _postgis_package_object(text,text) line 28 at
 RAISE
 SQL statement "CREATE EXTENSION postgis_raster SCHEMA
 ecosystem_observation_app VERSION unpackaged;ALTER EXTENSION
 postgis_raster UPDATE TO "3.3.2""
 PL/pgSQL function postgis_extensions_upgrade() line 71 at EXECUTE
 I opened a support ticket with AWS who told me that there are remaining
 raster functions that are no longer supported
 unsupported raster functions exist on the instance that are causing the
 upgrade to fail:
 > SELECT postgis_full_version();
          RASTER (raster procs from "2.5.1 r0" need upgrade)
 I plan to follow https://postgis.net/documentation/tips/tip-removing-
 raster-from-2-3/, please let me know if that sounds right to you.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5545#comment:6>
