[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-631-g2d8bd64b6
Mon Sep 25 09:23:45 PDT 2023
the project "PostGIS".
       via  2d8bd64b63981ff6acc241e0432f781522fcbbcf (commit)
       via  573244c6a9deda8f8dc6ebf3f548d8b5416948da (commit)
      from  829ceeeb25d133a03a776887b8bbd282f9fe3a67 (commit)
revisions in full, below.
commit 2d8bd64b63981ff6acc241e0432f781522fcbbcf
Author: Anonymous <noreply at weblate.org>
Date:   Mon Sep 25 14:21:15 2023 +0000
    Translated PostGIS Manual using Weblate (Russian)
    Currently translated at 0.5% (32 of 5596 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ru/
diff --git a/doc/po/ru/postgis-manual.po b/doc/po/ru/postgis-manual.po
index 4e03a657a..076ef662a 100644
--- a/doc/po/ru/postgis-manual.po
+++ b/doc/po/ru/postgis-manual.po
@@ -6,15 +6,17 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2023-09-25 14:15+0000\n"
-"PO-Revision-Date: 2023-09-14 17:40+0000\n"
-"Last-Translator: Automatically generated\n"
-"Language-Team: none\n"
+"PO-Revision-Date: 2023-09-25 16:23+0000\n"
+"Last-Translator: Anonymous <noreply at weblate.org>\n"
+"Language-Team: Russian <https://weblate.osgeo.org/projects/postgis/"
+"postgis-manual/ru/>\n"
 "Language: ru\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
-"Plural-Forms: nplurals=3; plural=(n%10==1 && n%100!=11 ? 0 : n%10>=2 && n"
-"%10<=4 && (n%100<10 || n%100>=20) ? 1 : 2);\n"
+"Plural-Forms: nplurals=3; plural=n%10==1 && n%100!=11 ? 0 : n%10>=2 && "
+"n%10<=4 && (n%100<10 || n%100>=20) ? 1 : 2;\n"
+"X-Generator: Weblate 5.0\n"
 #. Tag: chapter
 #, no-c-format
@@ -617,9 +619,9 @@ msgid "These settings are configured in <code>postgresql.conf</code>:"
 msgstr ""
 #. Tag: link
-#, no-c-format
+#, fuzzy, no-c-format
 msgid "constraint_exclusion"
-msgstr ""
+msgstr "constraint_exclusion"
 #. Tag: para
 #, no-c-format
@@ -3629,9 +3631,9 @@ msgid ""
 msgstr ""
 #. Tag: entry
-#, no-c-format
 msgid "Error"
-msgstr ""
+msgstr "Ошибка"
 #. Tag: entry
 #, no-c-format
@@ -6232,9 +6234,9 @@ msgid "PostGIS has the following requirements for building and usage:"
 msgstr ""
 #. Tag: emphasis
-#, no-c-format
 msgid "Required"
-msgstr ""
+msgstr "Обязательная"
 #. Tag: para
 #, no-c-format
@@ -6325,9 +6327,9 @@ msgid ""
 msgstr ""
 #. Tag: emphasis
-#, no-c-format
 msgid "Optional"
-msgstr ""
+msgstr "Необязательная"
 #. Tag: para
 #, no-c-format
@@ -17486,9 +17488,9 @@ msgid ""
 msgstr ""
 #. Tag: title
-#, no-c-format
 msgid "Operators"
-msgstr ""
+msgstr "Операторы"
 #. Tag: title
 #, no-c-format
@@ -18706,9 +18708,9 @@ msgid ""
 msgstr ""
 #. Tag: para
-#, no-c-format
 msgid "Basic"
-msgstr ""
+msgstr "Базовый (только чтение)"
 #. Tag: para
 #, no-c-format
@@ -25216,9 +25218,9 @@ msgid "NearestNeighbor (english or american spelling)"
 msgstr ""
 #. Tag: para
-#, no-c-format
 msgid "Bilinear"
-msgstr ""
+msgstr "Билинейная"
 #. Tag: para
 #, no-c-format
@@ -34014,9 +34016,9 @@ msgid ""
 msgstr ""
 #. Tag: title
-#, no-c-format
 msgid "Point"
-msgstr ""
+msgstr "Точка"
 #. Tag: para
 #, no-c-format
@@ -34026,9 +34028,9 @@ msgid ""
 msgstr ""
 #. Tag: title
-#, no-c-format
 msgid "LineString"
-msgstr ""
+msgstr "Строки линии"
 #. Tag: para
 #, no-c-format
@@ -34056,9 +34058,9 @@ msgid ""
 msgstr ""
 #. Tag: title
-#, no-c-format
 msgid "Polygon"
-msgstr ""
+msgstr "Полигон"
 #. Tag: para
 #, no-c-format
commit 573244c6a9deda8f8dc6ebf3f548d8b5416948da
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Sep 25 14:26:16 2023 +0000
    Translated PostGIS Manual using Weblate (Italian)
    Currently translated at 25.7% (1442 of 5596 strings)
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/it/
diff --git a/doc/po/it_IT/postgis-manual.po b/doc/po/it_IT/postgis-manual.po
index 70b49a318..3e1d07f39 100644
--- a/doc/po/it_IT/postgis-manual.po
+++ b/doc/po/it_IT/postgis-manual.po
@@ -6,10 +6,10 @@ msgstr ""
-"PO-Revision-Date: 2023-09-22 13:23+0000\n"
 "Last-Translator: Sandro Santilli <strk at kbt.io>\n"
-"Language-Team: Italian <https://weblate.osgeo.org/projects/postgis/postgis-"
-"manual/it/>\n"
+"Language-Team: Italian <https://weblate.osgeo.org/projects/postgis/"
+"postgis-manual/it/>\n"
 "Language: it_IT\n"
@@ -1727,6 +1727,10 @@ msgid ""
 "html#--r-typ--\">http://www.pagcgeo.org/docs/html/pagc-12.html#--r-typ--</"
 "link>."
 msgstr ""
+"<emphasis role=\"bold\">Gettoni di uscita <varname>MACRO_C</varname></"
+"emphasis> (estratto da <link xlink:href=\"http://www.pagcgeo.org/docs/html/"
+"pagc-12.html#--r-typ--\">http://www.pagcgeo.org/docs/html/pagc-12."
+"html#--r-typ--</link>."
 #. Tag: para
 #, no-c-format
@@ -1774,6 +1778,10 @@ msgid ""
 "link>."
 msgstr ""
+"<emphasis role=\"bold\">Gettoni di uscita <varname>MICRO_C</varname></"
 #. Tag: para
 #, no-c-format
@@ -1806,6 +1814,10 @@ msgid ""
 "link>."
 msgstr ""
+"<emphasis role=\"bold\">Gettoni di uscita <varname>EXTRA_C</varname></"
 #. Tag: para
 #, no-c-format
Summary of changes:
 doc/po/it_IT/postgis-manual.po | 18 ++++++++++++---
 doc/po/ru/postgis-manual.po    | 52 ++++++++++++++++++++++--------------------
 2 files changed, 42 insertions(+), 28 deletions(-)
hooks/post-receive
