[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-646-g7a073e69b
Fri Sep 29 01:00:20 PDT 2023
the project "PostGIS".
       via  7a073e69b60a0c56573553c8c630d05a641bd2e9 (commit)
       via  458f51b31a0749ac2b6472d9152d4e335547da40 (commit)
       via  c920fedd640e15244d047cc0afc46d8af0d34bf1 (commit)
       via  ba61460327d693dc734d74da5774f390e905a39a (commit)
      from  4ad7b3117c4354c6127fd6b5626c723e26d2e9b1 (commit)
revisions in full, below.
commit 7a073e69b60a0c56573553c8c630d05a641bd2e9
Merge: 4ad7b3117 458f51b31
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Sep 29 01:00:18 2023 -0700
    Merge pull request '[Feature] Add ST_HasZ/ST_HasM' (!155) from lbartoletti/postgis:add_hasz_hasm into master
    Reviewed-on: https://git.osgeo.org/gitea/postgis/postgis/pulls/155
commit 458f51b31a0749ac2b6472d9152d4e335547da40
Author: Loïc Bartoletti <loic.bartoletti at oslandia.com>
Date:   Fri Sep 29 08:23:10 2023 +0200
    Add paragraph about availability version and z/m support
diff --git a/doc/reference_accessor.xml b/doc/reference_accessor.xml
index 08165efe3..06d8309c5 100644
--- a/doc/reference_accessor.xml
+++ b/doc/reference_accessor.xml
@@ -3152,6 +3152,10 @@ SELECT ST_Zmflag(ST_GeomFromEWKT('POINT(1 2 3 4)'));
     <para>Geometry objects with a Z dimension typically represent three-dimensional (3D) geometries, while those without it are two-dimensional (2D) geometries.</para>
     <para>This function is useful for determining if a geometry has elevation or height information.</para>
+    <para role="availability" conformance="3.5.0">Availability: 3.5.0</para>
+    <para>&Z_support;</para>
+    <para>&M_support;</para>
   </refsection>
   <refsection>
@@ -3197,6 +3201,10 @@ SELECT ST_Zmflag(ST_GeomFromEWKT('POINT(1 2 3 4)'));
     <para>Geometry objects with an M dimension typically represent measurements or additional data associated with spatial features.</para>
     <para>This function is useful for determining if a geometry includes measure information.</para>
   </refsection>
   <refsection>
commit c920fedd640e15244d047cc0afc46d8af0d34bf1
Date:   Fri Sep 29 08:22:41 2023 +0200
    fix availabity version
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 49880dd33..2840dfb55 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -1660,14 +1660,14 @@ CREATE OR REPLACE FUNCTION ST_NDims(geometry)
 	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
 	_COST_DEFAULT;
--- Availability: 3.6.0
+-- Availability: 3.5.0
 CREATE OR REPLACE FUNCTION ST_HasZ(geometry)
 	RETURNS boolean
 	AS 'MODULE_PATHNAME', 'LWGEOM_hasz'
 	_COST_DEFAULT;
 CREATE OR REPLACE FUNCTION ST_HasM(geometry)
 	RETURNS boolean
 	AS 'MODULE_PATHNAME', 'LWGEOM_hasm'
commit ba61460327d693dc734d74da5774f390e905a39a
Date:   Thu Sep 28 15:23:07 2023 +0200
    These functions have been available for a long time with ST_ZMFlags and in lwgeom
    but were not exposed in SQL.
    However, we have had a deprecation note for ST_ZMFlags for several versions now.
    This MR proposes to simply expose these methods with their ISO names.
index bd92d89ea..08165efe3 100644
@@ -3129,4 +3129,95 @@ SELECT ST_Zmflag(ST_GeomFromEWKT('POINT(1 2 3 4)'));
 	  </refsection>
 	</refentry>
+    <refentry xml:id="ST_HasZ">
+  <refnamediv>
+    <refname>ST_HasZ</refname>
+    <refpurpose>Checks if a geometry has a Z dimension.</refpurpose>
+  </refnamediv>
+  <refsynopsisdiv>
+    <funcsynopsis>
+      <funcprototype>
+        <funcdef>boolean <function>ST_HasZ</function></funcdef>
+        <paramdef><type>geometry</type> <parameter>geom</parameter></paramdef>
+      </funcprototype>
+    </funcsynopsis>
+  </refsynopsisdiv>
+  <refsection>
+    <title>Description</title>
+    <para>Checks if the input geometry has a Z dimension and returns a boolean value. If the geometry has a Z dimension, it returns true; otherwise, it returns false.</para>
+    <para>Geometry objects with a Z dimension typically represent three-dimensional (3D) geometries, while those without it are two-dimensional (2D) geometries.</para>
+    <para>This function is useful for determining if a geometry has elevation or height information.</para>
+  </refsection>
+  <refsection>
+    <title>Examples</title>
+    <programlisting>SELECT ST_HasZ(ST_GeomFromText('POINT(1 2 3)'));
+ --result
+ true
+</programlisting>
+    <programlisting>SELECT ST_HasZ(ST_GeomFromText('LINESTRING(0 0, 1 1)'));
+ --result
+ false
+</programlisting>
+  </refsection>
+  <refsection>
+    <title>See Also</title>
+    <para><xref linkend="ST_Zmflag"/></para>
+    <para><xref linkend="ST_HasM"/></para>
+  </refsection>
+</refentry>
+<refentry xml:id="ST_HasM">
+  <refnamediv>
+    <refname>ST_HasM</refname>
+    <refpurpose>Checks if a geometry has an M (measure) dimension.</refpurpose>
+  </refnamediv>
+  <refsynopsisdiv>
+    <funcsynopsis>
+      <funcprototype>
+        <funcdef>boolean <function>ST_HasM</function></funcdef>
+      </funcprototype>
+    </funcsynopsis>
+  </refsynopsisdiv>
+  <refsection>
+    <para>Checks if the input geometry has an M (measure) dimension and returns a boolean value. If the geometry has an M dimension, it returns true; otherwise, it returns false.</para>
+    <para>Geometry objects with an M dimension typically represent measurements or additional data associated with spatial features.</para>
+    <para>This function is useful for determining if a geometry includes measure information.</para>
+  </refsection>
+  <refsection>
+    <programlisting>SELECT ST_HasM(ST_GeomFromText('POINTM(1 2 3)'));
+ --result
+ true
+</programlisting>
+    <programlisting>SELECT ST_HasM(ST_GeomFromText('LINESTRING(0 0, 1 1)'));
+ --result
+ false
+</programlisting>
+  </refsection>
+  <refsection>
+    <para><xref linkend="ST_HasZ"/></para>
+  </refsection>
+</refentry>
   </section>
index e962965e7..49880dd33 100644
@@ -1660,6 +1660,20 @@ CREATE OR REPLACE FUNCTION ST_NDims(geometry)
 	_COST_DEFAULT;
+-- Availability: 3.6.0
+CREATE OR REPLACE FUNCTION ST_HasZ(geometry)
+	RETURNS boolean
+	AS 'MODULE_PATHNAME', 'LWGEOM_hasz'
+	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
+	_COST_DEFAULT;
+CREATE OR REPLACE FUNCTION ST_HasM(geometry)
+	RETURNS boolean
+	AS 'MODULE_PATHNAME', 'LWGEOM_hasm'
+	_COST_DEFAULT;
 -- Availability: 1.2.2
 CREATE OR REPLACE FUNCTION ST_AsEWKT(geometry)
 	RETURNS TEXT
Summary of changes:
 doc/reference_accessor.xml | 99 ++++++++++++++++++++++++++++++++++++++++++++++
 postgis/postgis.sql.in     | 14 +++++++
 2 files changed, 113 insertions(+)
hooks/post-receive
