[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-649-g40502f87a
Fri Sep 29 01:04:23 PDT 2023
the project "PostGIS".
       via  40502f87ad24d593a88abf2095c76c5596743253 (commit)
       via  51430894851247f5a30a04c393504e3a25b23ec6 (commit)
       via  4c1509128edab81d7b39205fc17b9b118e2abe81 (commit)
      from  7a073e69b60a0c56573553c8c630d05a641bd2e9 (commit)
revisions in full, below.
commit 40502f87ad24d593a88abf2095c76c5596743253
Author: Chris Mayo <aklhfex at gmail.com>
Date:   Wed Sep 27 19:25:14 2023 +0100
    Publish the manual in HTML5
    This enables the single page manual to be encoded in UTF-8 instead of
    ISO-8859-1, and allows browsers to process the pages without resorting
    to quirks mode.
    Closes #5553
diff --git a/configure.ac b/configure.ac
index 189875c5f..ef3a18881 100644
--- a/configure.ac
+++ b/configure.ac
@@ -275,7 +275,7 @@ fi
 AC_SUBST(CAN_BUILD_EPUB)
 dnl
-dnl Allow the user to specify the location of the html/docbook.xsl stylesheet
+dnl Allow the user to specify the location of the xhtml5/docbook.xsl stylesheet
 dnl
 AC_ARG_WITH([xsldir],
@@ -286,7 +286,7 @@ XSLBASE_AUTO=""
 if test "x$XSLBASE" = "x"; then
 	dnl If the user did not specify a directory for the docbook
 	dnl stylesheet, choose the first uri that can resolve
-  dnl html/docbook.xsl or the first directory
+  dnl xhtml5/docbook.xsl or the first directory
 	dnl that matches from the following list
 	SEARCHPATH="
 		http://cdn.docbook.org/release/xsl/current
@@ -305,8 +305,8 @@ if test "x$XSLBASE" = "x"; then
 	for p in ${SEARCHPATH}; do
     case "${p}" in
-        AC_MSG_CHECKING([for html/docbook.xsl in directory $p...])
-        if test -r "${p}"/html/docbook.xsl; then
+        AC_MSG_CHECKING([for xhtml5/docbook.xsl in directory $p...])
+        if test -r "${p}"/xhtml5/docbook.xsl; then
           XSLBASE_AUTO="${p}"
           AC_MSG_RESULT([found])
           break
@@ -315,8 +315,8 @@ if test "x$XSLBASE" = "x"; then
         if test "x$XMLCATALOG" != "x"; then
-          AC_MSG_CHECKING([for html/docbook.xsl in URI $p...])
-          if $XMLCATALOG '' "${p}/html/docbook.xsl" >/dev/null; then
+          AC_MSG_CHECKING([for xhtml5/docbook.xsl in URI $p...])
+          if $XMLCATALOG '' "${p}/xhtml5/docbook.xsl" >/dev/null; then
             XSLBASE_AUTO="${p}"
             break
@@ -339,8 +339,8 @@ else
 		AC_MSG_ERROR([the docbook stylesheet directory specified using --with-xsldir does not exist])
 	fi
-	if test ! -f "$XSLBASE/html/docbook.xsl"; then
-		AC_MSG_ERROR([the docbook stylesheet directory specified using --with-xsldir does not contain the html/docbook.xsl file])
+	if test ! -f "$XSLBASE/xhtml5/docbook.xsl"; then
+		AC_MSG_ERROR([the docbook stylesheet directory specified using --with-xsldir does not contain the xhtml5/docbook.xsl file])
 	fi
 fi
diff --git a/doc/Makefile.in b/doc/Makefile.in
index cfaf68f55..ca8cd7509 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -107,6 +107,7 @@ XSLTPROC_COMMONOPTS= \
 	--param table.borders.with.css 1 \
 	--stringparam chunker.output.encoding UTF-8 \
 	--stringparam chunker.output.indent no \
+	--stringparam html.ext .html \
 	--stringparam saxon.character.representation decimal \
 	$(XSLTPROCFLAGS)
@@ -115,8 +116,8 @@ XSLTPROC_CHUNKED_HTML_OPTS = \
 	--stringparam img.src.path ../ \
 	--stringparam html.stylesheet ../style.css
-HTML_DOCBOOK_XSL=$(XSLBASE)/html/docbook.xsl
-CHUNK_HTML_DOCBOOK_XSL=$(XSLBASE)/html/chunk.xsl
+HTML_DOCBOOK_XSL=$(XSLBASE)/xhtml5/docbook.xsl
+CHUNK_HTML_DOCBOOK_XSL=$(XSLBASE)/xhtml5/chunk.xsl
 # DBLatex's dblatex script for PDF generation from DocBook
 DBLATEX=@DBLATEX@
diff --git a/doc/html/style.css b/doc/html/style.css
index 8f84002c4..4be89d30f 100644
--- a/doc/html/style.css
+++ b/doc/html/style.css
@@ -127,6 +127,12 @@ h5 {
 table, td {
     border-collapse: collapse;
+ul.toc {
+    padding-left: 0;
+ul.toc li {
+    list-style-type: none;
 /* 3. Block Formatted ----------------------------------------------------- */
commit 51430894851247f5a30a04c393504e3a25b23ec6
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Sep 29 10:03:48 2023 +0200
    Update pot (for new HasZ/HasM funx)
diff --git a/doc/po/templates/postgis-manual.pot b/doc/po/templates/postgis-manual.pot
index ac375afa5..e2b1484bb 100644
--- a/doc/po/templates/postgis-manual.pot
+++ b/doc/po/templates/postgis-manual.pot
@@ -10810,6 +10810,65 @@ msgstr ""
 msgid ", <xref linkend=\"ST_NDims\"/>, <xref linkend=\"ST_Dimension\"/>"
 msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Checks if a geometry has a Z dimension."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Checks if the input geometry has a Z dimension and returns a boolean value. "
+"If the geometry has a Z dimension, it returns true; otherwise, it returns "
+"false."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Geometry objects with a Z dimension typically represent three-dimensional "
+"(3D) geometries, while those without it are two-dimensional (2D) geometries."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"This function is useful for determining if a geometry has elevation or "
+"height information."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Availability: 3.5.0"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Checks if a geometry has an M (measure) dimension."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Checks if the input geometry has an M (measure) dimension and returns a "
+"boolean value. If the geometry has an M dimension, it returns true; "
+"otherwise, it returns false."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Geometry objects with an M dimension typically represent measurements or "
+"additional data associated with spatial features."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"This function is useful for determining if a geometry includes measure "
+"information."
+msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Bounding Box Functions"
commit 4c1509128edab81d7b39205fc17b9b118e2abe81
Date:   Fri Sep 29 10:02:28 2023 +0200
    Add NEWS item about ST_HasZ/ST_HasM
    See https://git.osgeo.org/gitea/postgis/postgis/pulls/155
diff --git a/NEWS b/NEWS
index 71ae58d26..f90510fe4 100644
--- a/NEWS
+++ b/NEWS
@@ -19,6 +19,7 @@ xxxx/xx/xx
   - #5055, add explicit <> geometry operator to prevent non-unique
            error with <> and != (Paul Ramsey)
+  - Add ST_HasZ/ST_HasM (Loïc Bartoletti)
 * Enhancements *
Summary of changes:
 NEWS                                |  1 +
 configure.ac                        | 16 +++++-----
 doc/Makefile.in                     |  5 ++--
 doc/html/style.css                  |  6 ++++
 doc/po/templates/postgis-manual.pot | 59 +++++++++++++++++++++++++++++++++++++
 5 files changed, 77 insertions(+), 10 deletions(-)
hooks/post-receive
