[SCM] PostGIS branch stable-3.4 updated. 3.4.2-33-gbaf331904
Tue Apr 16 17:04:43 PDT 2024
the project "PostGIS".
The branch, stable-3.4 has been updated
       via  baf33190408969656a9abc5d07913ff1db191e4e (commit)
       via  2c68d13071458955c04ec2f28439914532bf9912 (commit)
      from  eb50b64d6c1271e8424b4e9ed338e23d1131e9e2 (commit)
revisions in full, below.
commit baf33190408969656a9abc5d07913ff1db191e4e
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Apr 16 17:04:34 2024 -0700
    NEWS entry for #5654
diff --git a/NEWS b/NEWS
index ae6a0d4da..87d6d8947 100644
--- a/NEWS
+++ b/NEWS
@@ -26,6 +26,8 @@ To take advantage of all SFCGAL featurs, SFCGAL 1.4.1+ is needed.
            Fix for PG17 security change (Regina Obe)
  - #5695, [address_standardizer_data_us] standardize_address
           incorrect handling of directionals (Regina Obe)
+ - #5653, Do not simplify away points when linestring doubles back on
+          itself (Paul Ramsey)
 PostGIS 3.4.2
 2024/02/08
commit 2c68d13071458955c04ec2f28439914532bf9912
Date:   Tue Apr 16 16:49:40 2024 -0700
    Do not remove points when doubling back at zero tolerance, references #5654
diff --git a/liblwgeom/cunit/cu_algorithm.c b/liblwgeom/cunit/cu_algorithm.c
index 44e2187d0..97cf1d8d0 100644
--- a/liblwgeom/cunit/cu_algorithm.c
+++ b/liblwgeom/cunit/cu_algorithm.c
@@ -1813,6 +1813,20 @@ static void test_trim_bits(void)
 	lwline_free(line);
+static void test_ptarray_simplify(void)
+	LWGEOM *geom1 = lwgeom_from_wkt("LINESTRING (2 2,3 2,4 1,3 2, 4 4)", LW_PARSER_CHECK_NONE);
+	LWGEOM *geom2 = lwgeom_from_wkt("LINESTRING (2 2,3 2,4 1,3 2, 4 4)", LW_PARSER_CHECK_NONE);
+	LWLINE *line1 = (LWLINE*)geom1;
+	double tolerance = 0.0;
+	int minpts = 2;
+	ptarray_simplify_in_place(line1->points, tolerance, minpts);
+	ASSERT_LWGEOM_EQUAL(geom1, geom2);
+	lwgeom_free(geom1);
+	lwgeom_free(geom2);
 ** Used by test harness to register the tests in this file.
@@ -1820,6 +1834,7 @@ void algorithms_suite_setup(void);
 	CU_pSuite suite = CU_add_suite("algorithm", init_cg_suite, clean_cg_suite);
+	PG_ADD_TEST(suite,test_ptarray_simplify);
 	PG_ADD_TEST(suite,test_lw_segment_side);
 	PG_ADD_TEST(suite,test_lw_segment_intersects);
 	PG_ADD_TEST(suite,test_lwline_crossing_short_lines);
diff --git a/liblwgeom/ptarray.c b/liblwgeom/ptarray.c
index 2581a1f17..c8fede189 100644
--- a/liblwgeom/ptarray.c
+++ b/liblwgeom/ptarray.c
@@ -1689,7 +1689,11 @@ ptarray_simplify_in_place_tolerance0(POINTARRAY *pa)
 		double dot_ac_ab = ca_x * ba_x + ca_y * ba_y;
 		double s_numerator = ca_x * ba_y - ca_y * ba_x;
-		if (dot_ac_ab < 0.0 || dot_ac_ab > ab_length_sqr || s_numerator != 0)
+		if (p2d_same(kept_pt, next_pt) ||
+			dot_ac_ab < 0.0 ||
+			dot_ac_ab > ab_length_sqr ||
+			s_numerator != 0)
 			kept_it++;
 			kept_pt = curr_pt;
Summary of changes:
 NEWS                           |  2 ++
 liblwgeom/cunit/cu_algorithm.c | 15 +++++++++++++++
 liblwgeom/ptarray.c            |  6 +++++-
 3 files changed, 22 insertions(+), 1 deletion(-)
hooks/post-receive
