[SCM] PostGIS branch master updated. 3.4.0rc1-1091-g8c30a25ac
Tue Apr 16 17:05:10 PDT 2024
the project "PostGIS".
       via  8c30a25acb166de09a7d647e1e02dc6d71eae9ea (commit)
       via  1550e162bc79ac248aee74d81d2d7bc7ad7a0d28 (commit)
       via  464e60eb191f9bb9bf21614298cb78d26fe86ae7 (commit)
      from  1d12c312bdb2b7d900a01d0259b1f1259edf211d (commit)
revisions in full, below.
commit 8c30a25acb166de09a7d647e1e02dc6d71eae9ea
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Apr 16 16:49:40 2024 -0700
    Do not remove points when doubling back at zero tolerance, references #5654
diff --git a/liblwgeom/cunit/cu_algorithm.c b/liblwgeom/cunit/cu_algorithm.c
index a30a5e56e..41e6b1b60 100644
--- a/liblwgeom/cunit/cu_algorithm.c
+++ b/liblwgeom/cunit/cu_algorithm.c
@@ -1812,6 +1812,20 @@ static void test_trim_bits(void)
 	lwline_free(line);
+static void test_ptarray_simplify(void)
+	LWGEOM *geom1 = lwgeom_from_wkt("LINESTRING (2 2,3 2,4 1,3 2, 4 4)", LW_PARSER_CHECK_NONE);
+	LWGEOM *geom2 = lwgeom_from_wkt("LINESTRING (2 2,3 2,4 1,3 2, 4 4)", LW_PARSER_CHECK_NONE);
+	LWLINE *line1 = (LWLINE*)geom1;
+	double tolerance = 0.0;
+	int minpts = 2;
+	ptarray_simplify_in_place(line1->points, tolerance, minpts);
+	ASSERT_LWGEOM_EQUAL(geom1, geom2);
+	lwgeom_free(geom1);
+	lwgeom_free(geom2);
 ** Used by test harness to register the tests in this file.
@@ -1819,6 +1833,7 @@ void algorithms_suite_setup(void);
 	CU_pSuite suite = CU_add_suite("algorithm", init_cg_suite, clean_cg_suite);
+	PG_ADD_TEST(suite,test_ptarray_simplify);
 	PG_ADD_TEST(suite,test_lw_segment_side);
 	PG_ADD_TEST(suite,test_lw_segment_intersects);
 	PG_ADD_TEST(suite,test_lwline_crossing_short_lines);
diff --git a/liblwgeom/ptarray.c b/liblwgeom/ptarray.c
index 7d9c8c0cd..b331c9558 100644
--- a/liblwgeom/ptarray.c
+++ b/liblwgeom/ptarray.c
@@ -1685,7 +1685,11 @@ ptarray_simplify_in_place_tolerance0(POINTARRAY *pa)
 		double dot_ac_ab = ca_x * ba_x + ca_y * ba_y;
 		double s_numerator = ca_x * ba_y - ca_y * ba_x;
-		if (dot_ac_ab < 0.0 || dot_ac_ab > ab_length_sqr || s_numerator != 0)
+		if (p2d_same(kept_pt, next_pt) ||
+			dot_ac_ab < 0.0 ||
+			dot_ac_ab > ab_length_sqr ||
+			s_numerator != 0)
 			kept_it++;
 			kept_pt = curr_pt;
commit 1550e162bc79ac248aee74d81d2d7bc7ad7a0d28
Date:   Tue Apr 16 16:29:18 2024 -0700
    Support MacOS too
diff --git a/utils/check_tests_enabled.sh b/utils/check_tests_enabled.sh
index 687f73120..3b3d3e298 100755
--- a/utils/check_tests_enabled.sh
+++ b/utils/check_tests_enabled.sh
@@ -32,6 +32,7 @@ check_enabled() {
   #cat ${TMPDIR}/enabled_tests
   find ${bd} -name '*_expected' |
+    sed 's|//|/|' |
     sed 's|_expected$||' > ${TMPDIR}/available_tests
   #cat ${TMPDIR}/available_tests
commit 464e60eb191f9bb9bf21614298cb78d26fe86ae7
Date:   Tue Apr 16 13:23:05 2024 -0700
    Revert "Clean up recttree a little bit"
    This reverts commit 2c4abb3f268b1e806e59337bf737fbcc04d9b31e.
diff --git a/liblwgeom/lwtree.c b/liblwgeom/lwtree.c
index 19a6bd41c..481b329f6 100644
--- a/liblwgeom/lwtree.c
+++ b/liblwgeom/lwtree.c
@@ -82,7 +82,7 @@ rect_tree_free(RECT_NODE *node)
 static int
-rect_leaf_node_intersects(const RECT_NODE_LEAF *n1, const RECT_NODE_LEAF *n2)
+rect_leaf_node_intersects(RECT_NODE_LEAF *n1, RECT_NODE_LEAF *n2)
 	const POINT2D *p1, *p2, *p3, *q1, *q2, *q3;
 	DISTPTS dl;
@@ -196,7 +196,7 @@ rect_leaf_node_intersects(const RECT_NODE_LEAF *n1, const RECT_NODE_LEAF *n2)
 * Returns 1 if segment is to the right of point.
 static inline int
-rect_leaf_node_segment_side(const RECT_NODE_LEAF *node, const POINT2D *q, int *on_boundary)
+rect_leaf_node_segment_side(RECT_NODE_LEAF *node, const POINT2D *q, int *on_boundary)
 	const POINT2D *p1, *p2, *p3;
 	switch (node->seg_type)
@@ -311,7 +311,7 @@ rect_leaf_node_segment_side(const RECT_NODE_LEAF *node, const POINT2D *q, int *o
 * be on both sides, and will have a zero return sum.
 static int
-rect_tree_ring_contains_point(const RECT_NODE *node, const POINT2D *pt, int *on_boundary)
+rect_tree_ring_contains_point(RECT_NODE *node, const POINT2D *pt, int *on_boundary)
 	/* Only test nodes that straddle our stabline vertically */
 	/* and might be to the right horizontally */
@@ -341,7 +341,7 @@ rect_tree_ring_contains_point(const RECT_NODE *node, const POINT2D *pt, int *on_
 * (multiply contained by interior rings?)
 static int
-rect_tree_area_contains_point(const RECT_NODE *node, const POINT2D *pt)
+rect_tree_area_contains_point(RECT_NODE *node, const POINT2D *pt)
 	/* Can't do anything with a leaf node, makes no sense */
 	if (rect_node_is_leaf(node))
@@ -381,7 +381,7 @@ rect_tree_area_contains_point(const RECT_NODE *node, const POINT2D *pt)
 * Simple containment test for node/point inputs
 static int
-rect_node_bounds_point(const RECT_NODE *node, const POINT2D *pt)
+rect_node_bounds_point(RECT_NODE *node, const POINT2D *pt)
 	if (pt->y < node->ymin || pt->y > node->ymax ||
 		pt->x < node->xmin || pt->x > node->xmax)
@@ -395,7 +395,7 @@ rect_node_bounds_point(const RECT_NODE *node, const POINT2D *pt)
 * and false otherwise.
 int
-rect_tree_contains_point(const RECT_NODE *node, const POINT2D *pt)
+rect_tree_contains_point(RECT_NODE *node, const POINT2D *pt)
 	int i, c;
@@ -762,10 +762,6 @@ rect_tree_from_lwpoly(const LWGEOM *lwgeom)
 			nodes[j++] = node;
-	/* Put the top nodes in a z-order curve for a spatially coherent */
-	/* tree after node merge */
-	qsort(nodes, j, sizeof(RECT_NODE*), rect_node_cmp);
 	tree = rect_nodes_merge(nodes, j);
 	tree->geom_type = lwgeom->type;
 	lwfree(nodes);
@@ -852,9 +848,7 @@ rect_tree_from_lwcollection(const LWGEOM *lwgeom)
 	/* Note: CompoundCurve has edges already spatially organized, no */
 	/* sorting needed */
 	if (lwgeom->type != COMPOUNDTYPE)
@@ -939,7 +933,7 @@ rect_node_to_str(const RECT_NODE *n)
 * that intersect. Prune branches that do not intersect.
 static int
-rect_tree_intersects_tree_recursive(const RECT_NODE *n1, const RECT_NODE *n2)
+rect_tree_intersects_tree_recursive(RECT_NODE *n1, RECT_NODE *n2)
 	int i, j;
 #if POSTGIS_DEBUG_LEVEL >= 4
@@ -993,7 +987,7 @@ rect_tree_intersects_tree_recursive(const RECT_NODE *n1, const RECT_NODE *n2)
 int
-rect_tree_intersects_tree(const RECT_NODE *n1, const RECT_NODE *n2)
+rect_tree_intersects_tree(RECT_NODE *n1, RECT_NODE *n2)
 	* It is possible for an area to intersect another object
@@ -1020,12 +1014,24 @@ rect_tree_intersects_tree(const RECT_NODE *n1, const RECT_NODE *n2)
 	return rect_tree_intersects_tree_recursive(n1, n2);
+* For slightly more speed when doing distance comparisons,
+* where we only care if d1 < d2 and not what the actual value
+* of d1 or d2 is, we use the squared distance and avoid the
+* sqrt()
 static inline double
-distance(double x1, double y1, double x2, double y2)
+distance_sq(double x1, double y1, double x2, double y2)
 	double dx = x1-x2;
 	double dy = y1-y2;
-	return sqrt(dx*dx + dy*dy);
+	return dx*dx + dy*dy;
+static inline double
+distance(double x1, double y1, double x2, double y2)
+	return sqrt(distance_sq(x1, y1, x2, y2));
@@ -1216,8 +1222,72 @@ rect_leaf_node_distance(const RECT_NODE_LEAF *n1, const RECT_NODE_LEAF *n2, RECT
+static int
+rect_tree_node_sort_cmp(const void *a, const void *b)
+	RECT_NODE *n1 = *(RECT_NODE**)a;
+	RECT_NODE *n2 = *(RECT_NODE**)b;
+	if (n1->d < n2->d) return -1;
+	else if (n1->d > n2->d) return 1;
+	else return 0;
+/* Calculate the center of a node */
+static inline void
+rect_node_to_p2d(const RECT_NODE *n, POINT2D *pt)
+	pt->x = (n->xmin + n->xmax)/2;
+	pt->y = (n->ymin + n->ymax)/2;
+* (If necessary), sort the children of each node in
+* order of their distance from the enter of the other node.
+static void
+rect_tree_node_sort(RECT_NODE *n1, RECT_NODE *n2)
+	int i;
+	RECT_NODE *n;
+	POINT2D c1, c2, c;
+	if (!rect_node_is_leaf(n1) && ! n1->i.sorted)
+		rect_node_to_p2d(n2, &c2);
+		/* Distance of each child from center of other node */
+		for (i = 0; i < n1->i.num_nodes; i++)
+			n = n1->i.nodes[i];
+			rect_node_to_p2d(n, &c);
+			n->d = distance2d_sqr_pt_pt(&c2, &c);
+		/* Sort the children by distance */
+		n1->i.sorted = 1;
+		qsort(n1->i.nodes,
+		         n1->i.num_nodes,
+		         sizeof(RECT_NODE*),
+		         rect_tree_node_sort_cmp);
+	if (!rect_node_is_leaf(n2) && ! n2->i.sorted)
+		rect_node_to_p2d(n1, &c1);
+		for (i = 0; i < n2->i.num_nodes; i++)
+			n = n2->i.nodes[i];
+			n->d = distance2d_sqr_pt_pt(&c1, &c);
+		n2->i.sorted = 1;
+		qsort(n2->i.nodes,
+		         n2->i.num_nodes,
 static double
-rect_tree_distance_tree_recursive(const RECT_NODE *n1, const RECT_NODE *n2, RECT_TREE_DISTANCE_STATE *state)
+rect_tree_distance_tree_recursive(RECT_NODE *n1, RECT_NODE *n2, RECT_TREE_DISTANCE_STATE *state)
 	double min, max;
@@ -1249,6 +1319,7 @@ rect_tree_distance_tree_recursive(const RECT_NODE *n1, const RECT_NODE *n2, RECT
 		int i, j;
 		double d_min = FLT_MAX;
+		rect_tree_node_sort(n1, n2);
 		if (rect_node_is_leaf(n1) && !rect_node_is_leaf(n2))
@@ -1280,7 +1351,7 @@ rect_tree_distance_tree_recursive(const RECT_NODE *n1, const RECT_NODE *n2, RECT
-double rect_tree_distance_tree(const RECT_NODE *n1, const RECT_NODE *n2, double threshold)
+double rect_tree_distance_tree(RECT_NODE *n1, RECT_NODE *n2, double threshold)
 	double distance;
 	RECT_TREE_DISTANCE_STATE state;
diff --git a/liblwgeom/lwtree.h b/liblwgeom/lwtree.h
index 1167e3c2c..0aa4cf31d 100644
--- a/liblwgeom/lwtree.h
+++ b/liblwgeom/lwtree.h
@@ -95,19 +95,19 @@ RECT_NODE * rect_tree_from_lwgeom(const LWGEOM *geom);
 * Test if two RECT_NODE trees intersect one another.
-int rect_tree_intersects_tree(const RECT_NODE *tree1, const RECT_NODE *tree2);
+int rect_tree_intersects_tree(RECT_NODE *tree1, RECT_NODE *tree2);
 * Return the distance between two RECT_NODE trees.
-double rect_tree_distance_tree(const RECT_NODE *n1, const RECT_NODE *n2, double threshold);
+double rect_tree_distance_tree(RECT_NODE *n1, RECT_NODE *n2, double threshold);
 * Free the rect-tree memory
 void rect_tree_free(RECT_NODE *node);
-int rect_tree_contains_point(const RECT_NODE *tree, const POINT2D *pt);
+int rect_tree_contains_point(RECT_NODE *tree, const POINT2D *pt);
 RECT_NODE * rect_tree_from_ptarray(const POINTARRAY *pa, int geom_type);
 LWGEOM * rect_tree_to_lwgeom(const RECT_NODE *tree);
 char * rect_tree_to_wkt(const RECT_NODE *node);
Summary of changes:
 liblwgeom/cunit/cu_algorithm.c |  15 ++++++
 liblwgeom/lwtree.c             | 107 ++++++++++++++++++++++++++++++++++-------
 liblwgeom/lwtree.h             |   6 +--
 liblwgeom/ptarray.c            |   6 ++-
 utils/check_tests_enabled.sh   |   1 +
 5 files changed, 113 insertions(+), 22 deletions(-)
hooks/post-receive
