[SCM] PostGIS branch master updated. 3.4.0rc1-1092-g260b2eeef
Mon Apr 22 08:53:51 PDT 2024
the project "PostGIS".
       via  260b2eeefc720995c5922efee6b535fee111a10a (commit)
      from  8c30a25acb166de09a7d647e1e02dc6d71eae9ea (commit)
revisions in full, below.
commit 260b2eeefc720995c5922efee6b535fee111a10a
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Apr 22 08:39:27 2024 -0700
    Remove WFS_locks and associated documentation, unused and unmaintained for many years
diff --git a/README.postgis b/README.postgis
index c6e303fa8..36e28a4c3 100644
--- a/README.postgis
+++ b/README.postgis
@@ -16,8 +16,8 @@ Directory structure::
   ./doc         PostGIS Documentation
   ./extensions  Support for the PostgreSQL Extensions framework
   ./extras      Various pieces that didn't belong to mainstream
-                (package management specfiles, WFS_locks
-                  , sample WKB parser, postgis_tiger_geocoder)
+                (package management specfiles, sample WKB parser,
+                postgis_tiger_geocoder)
   ./fuzzers     Google fuzz tests for liblwgeom
   ./liblwgeom   LWGEOM geometry library
   ./libpgcommon PostGIS library to bridge LWGEOM to PostgreSQL
diff --git a/doc/Makefile.in b/doc/Makefile.in
index 8dacae4af..3dac515be 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -193,7 +193,6 @@ XML_SOURCES = \
 	reference_sfcgal.xml \
 	reference_srs.xml \
 	reference_trajectory.xml \
-	reference_transaction.xml \
 	reference_transformation.xml \
 	reference_troubleshooting.xml \
 	reference_type.xml \
diff --git a/doc/postgis.xml b/doc/postgis.xml
index 75b529bc5..8e7912614 100644
--- a/doc/postgis.xml
+++ b/doc/postgis.xml
@@ -49,7 +49,6 @@
 <!ENTITY reference_lrs SYSTEM "reference_lrs.xml">
 <!ENTITY reference_srs SYSTEM "reference_srs.xml">
 <!ENTITY reference_trajectory SYSTEM "reference_trajectory.xml">
-<!ENTITY reference_transaction SYSTEM "reference_transaction.xml">
 <!ENTITY reference_transformation SYSTEM "reference_transformation.xml">
 <!ENTITY reference_misc SYSTEM "reference_misc.xml">
 <!ENTITY reference_troubleshooting SYSTEM "reference_troubleshooting.xml">
diff --git a/doc/reference.xml b/doc/reference.xml
index 3c2b0b380..af4e487ff 100644
--- a/doc/reference.xml
+++ b/doc/reference.xml
@@ -36,9 +36,8 @@
   &reference_bbox;
   &reference_lrs;
   &reference_trajectory;
-  &reference_transaction;
   &reference_version;
   &reference_guc;
   &reference_troubleshooting;
-</chapter>
\ No newline at end of file
+</chapter>
diff --git a/doc/reference_transaction.xml b/doc/reference_transaction.xml
deleted file mode 100644
index 91d5c0d57..000000000
--- a/doc/reference_transaction.xml
+++ /dev/null
@@ -1,349 +0,0 @@
-<!-- Converted by db4-upgrade version 1.1 -->
-<section xmlns:xlink="http://www.w3.org/1999/xlink" xmlns="http://docbook.org/ns/docbook" version="5.0" xml:id="Long_Transactions_Support">
-    <title>Long Transaction Support</title><info>
-    <abstract>
-	  <para>These functions implement a row locking mechanism to support long transactions.
-		They are provided primarily for implementors of the
-		<link xlink:href="http://www.opengeospatial.org/standards/wfs">Web Feature Service</link> specification.</para>
-    </abstract>
-    </info>
-	  <note>
-			<para>For the locking mechanism to operate correctly the <emphasis role="bold">serializable</emphasis>
-			<link xlink:href="http://www.postgresql.org/docs/current/static/transaction-iso.html">
-			transaction isolation level</link> must be used.</para>
-	  </note>
-	<refentry xml:id="AddAuth">
-	  <refnamediv>
-		<refname>AddAuth</refname>
-		<refpurpose>Adds an authorization token to be used in the current transaction.</refpurpose>
-	  </refnamediv>
-	  <refsynopsisdiv>
-		<funcsynopsis>
-		  <funcprototype>
-			<funcdef>boolean <function>AddAuth</function></funcdef>
-			<paramdef><type>text </type> <parameter>auth_token</parameter></paramdef>
-		  </funcprototype>
-		</funcsynopsis>
-	  </refsynopsisdiv>
-	  <refsection>
-		<title>Description</title>
-		<para>Adds an authorization token to be used in the current transaction.</para>
-		<para>Adds the current transaction identifier
-			and authorization token to a temporary table called <varname>temp_lock_have_table</varname>.</para>
-		<para role="availability" conformance="1.1.3">Availability: 1.1.3</para>
-	  </refsection>
-	  <refsection>
-		<title>Examples</title>
-		<programlisting>
-		SELECT LockRow('towns', '353', 'priscilla');
-		BEGIN TRANSACTION;
-			SELECT AddAuth('joey');
-			UPDATE towns SET geom = ST_Translate(geom,2,2) WHERE gid = 353;
-		COMMIT;
-		---Error--
-		ERROR:  UPDATE where "gid" = '353' requires authorization 'priscilla'
-		</programlisting>
-	  </refsection>
-	  <!-- Optionally add a "See Also" section -->
-	  <refsection>
-		<title>See Also</title>
-		<para><xref linkend="LockRow"/></para>
-	  </refsection>
-	</refentry>
-	  <refentry xml:id="CheckAuth">
-		  <refnamediv>
-			<refname>CheckAuth</refname>
-			<refpurpose>Creates a trigger on a table to prevent/allow updates and deletes of rows based on authorization token.</refpurpose>
-		  </refnamediv>
-		  <refsynopsisdiv>
-			<funcsynopsis>
-			  <funcprototype>
-				<funcdef>integer <function>CheckAuth</function></funcdef>
-				<paramdef><type>text </type> <parameter>a_schema_name</parameter></paramdef>
-				<paramdef><type>text </type> <parameter>a_table_name</parameter></paramdef>
-				<paramdef><type>text </type> <parameter>a_key_column_name</parameter></paramdef>
-			  </funcprototype>
-			  <funcprototype>
-			  </funcprototype>
-			</funcsynopsis>
-		  </refsynopsisdiv>
-		  <refsection>
-			<para>Creates trigger on a table to prevent/allow updates and deletes of rows based on an authorization token.
-			Identify rows using <rowid_col> column.</para>
-			<para>If a_schema_name is not passed in, then searches for table in current schema.</para>
-			<note><para>If an authorization trigger already exists on this table function errors.</para>
-				<para>If Transaction support is not enabled, function throws an exception.</para>
-			</note>
-		  </refsection>
-		  <refsection>
-			<programlisting>
-			SELECT CheckAuth('public', 'towns', 'gid');
-			result
-			0
-			</programlisting>
-		  </refsection>
-		  <refsection>
-			<para><xref linkend="EnableLongTransactions"/></para>
-		  </refsection>
-		</refentry>
-	  <refentry xml:id="DisableLongTransactions">
-		<refnamediv>
-		  <refname>DisableLongTransactions</refname>
-		  <refpurpose>Disables long transaction support.</refpurpose>
-		</refnamediv>
-		<refsynopsisdiv>
-		  <funcsynopsis>
-			<funcprototype>
-			  <funcdef>text <function>DisableLongTransactions</function></funcdef>
-			  <paramdef></paramdef>
-			</funcprototype>
-		  </funcsynopsis>
-		</refsynopsisdiv>
-		<refsection>
-			<para>Disables long transaction support. This function removes the
-			long transaction support metadata tables, and drops all triggers
-			attached to lock-checked tables.</para>
-			<para>Drops meta table called <varname>authorization_table</varname> and a view called <varname>authorized_tables</varname>
-				and all triggers called <varname>checkauthtrigger</varname></para>
-		</refsection>
-		<refsection>
-		  <programlisting>SELECT DisableLongTransactions();
---result--
-Long transactions support disabled
-		  </programlisting>
-		</refsection>
-		<refsection>
-		</refsection>
-	  </refentry>
-	  <refentry xml:id="EnableLongTransactions">
-		<refnamediv>
-		  <refname>EnableLongTransactions</refname>
-		  <refpurpose>Enables long transaction support.</refpurpose>
-		</refnamediv>
-		<refsynopsisdiv>
-		  <funcsynopsis>
-			<funcprototype>
-			  <funcdef>text <function>EnableLongTransactions</function></funcdef>
-			</funcprototype>
-		  </funcsynopsis>
-		</refsynopsisdiv>
-		<refsection>
-			<para>Enables long transaction support.
-			This function creates the
-			required metadata tables. It must be called once before using the
-			other functions in this section. Calling it twice is
-			harmless.</para>
-			<para>Creates a meta table called <varname>authorization_table</varname> and a view called <varname>authorized_tables</varname></para>
-		</refsection>
-		<refsection>
-		  <programlisting>SELECT EnableLongTransactions();
---result--
-Long transactions support enabled
-		  </programlisting>
-		</refsection>
-		<refsection>
-		  <para><xref linkend="DisableLongTransactions"/></para>
-		</refsection>
-	  </refentry>
-	<refentry xml:id="LockRow">
-	  <refnamediv>
-		<refname>LockRow</refname>
-		<refpurpose>Sets lock/authorization for a row in a table.</refpurpose>
-	  </refnamediv>
-	  <refsynopsisdiv>
-		<funcsynopsis>
-		  <funcprototype>
-			<funcdef>integer <function>LockRow</function></funcdef>
-			<paramdef><type>text </type> <parameter>a_row_key</parameter></paramdef>
-			<paramdef><type>text</type> <parameter>an_auth_token</parameter></paramdef>
-			<paramdef><type>timestamp</type> <parameter>expire_dt</parameter></paramdef>
-		  </funcprototype>
-		  <funcprototype>
-		  </funcprototype>
-		  <funcprototype>
-		  </funcprototype>
-		</funcsynopsis>
-	  </refsynopsisdiv>
-	  <refsection>
-		<para>Sets lock/authorization for a specific row in a table.
-		<varname>an_auth_token</varname> is a text value.
-		<varname>expire_dt</varname> is a timestamp
-		which defaults to <emphasis>now() + 1 hour</emphasis>.
-		Returns 1 if lock has been assigned, 0
-		otherwise (i.e. row is already locked by another auth.)</para>
-	  </refsection>
-	  <refsection>
-		<programlisting>SELECT LockRow('public', 'towns', '2', 'joey');
-LockRow
-1
---Joey has already locked the record and Priscilla is out of luck
-SELECT LockRow('public', 'towns', '2', 'priscilla');
-LockRow
-0
-		</programlisting>
-	  </refsection>
-	  <refsection>
-		<para><xref linkend="UnlockRows"/></para>
-	  </refsection>
-	</refentry>
-	<refentry xml:id="UnlockRows">
-	  <refnamediv>
-		<refname>UnlockRows</refname>
-		<refpurpose>Removes all locks held by an authorization token.
-		</refpurpose>
-	  </refnamediv>
-	  <refsynopsisdiv>
-		<funcsynopsis>
-		  <funcprototype>
-			<funcdef>integer <function>UnlockRows</function></funcdef>
-		  </funcprototype>
-		</funcsynopsis>
-	  </refsynopsisdiv>
-	  <refsection>
-		<para>Removes all locks held by specified authorization token.
-		Returns the number of locks released.</para>
-	  </refsection>
-	  <refsection>
-		<programlisting>
-		SELECT LockRow('towns', '2', 'priscilla');
-		SELECT UnLockRows('priscilla');
-		UnLockRows
-		2
-		</programlisting>
-	  </refsection>
-	  <refsection>
-	  </refsection>
-	</refentry>
-  </section>
diff --git a/extras/WFS_locks/Makefile b/extras/WFS_locks/Makefile
index b27c26a62..000000000
--- a/extras/WFS_locks/Makefile
+++ /dev/null
@@ -1,33 +0,0 @@
-CFLAGS += -g -Wall -O2 -pedantic -Wno-long-long -I$(shell pg_config --includedir-server)
-CC = gcc
-MODULE_FILENAME = $(PWD)/libWFS_locks.so
-ifneq ($(findstring 7.1,$(shell pg_config --version)),)
-	USE_VERSION=71
-else
-	ifneq ($(findstring 7.2,$(VERSION)),)
-		USE_VERSION=72
-	else
-		ifneq ($(findstring 7.3,$(VERSION)),)
-			USE_VERSION=73
-		else
-			ifneq ($(findstring 7.4,$(VERSION)),)
-				USE_VERSION=74
-			else
-				USE_VERSION=80
-			endif
-		endif
-	endif
-endif
-all: libWFS_locks.so WFS_locks.sql
-libWFS_locks.so: WFS_locks.c
-	$(CC) $(CFLAGS) $(LDFLAGS) -shared -o $@ $<
-WFS_locks.sql: WFS_locks.sql.in
-	cpp -P -traditional-cpp -DUSE_VERSION=$(USE_VERSION) $< | sed -e 's:@MODULE_FILENAME@:$(MODULE_FILENAME):g' | grep -v '^#' > $@
-clean:
-	rm -f libWFS_locks.so WFS_locks.sql
diff --git a/extras/WFS_locks/README b/extras/WFS_locks/README
index 5641d1c8b..000000000
--- a/extras/WFS_locks/README
+++ /dev/null
@@ -1,46 +0,0 @@
-Thu Mar 24 17:25:48 CET 2005
-This module and associated pl/pgsql functions have been implemented
-to provide long locking support required by Web Feature Service
-specification (https://portal.opengeospatial.org/files/?artifact_id=7176)
-It is based on original work by David Blasby <dblasby at openplans.org>
-and has been modified and packaged by Sandro Santilli <strk at refractions.net>.
-  Usage:
-	-- Enable long transaction support
-	SELECT EnableLongTransactions();
-	-- Disable long transaction support
-	SELECT DisableLongTransactions();
-	-- Check updates and deletes of rows in
-	-- given table for being authorized.
-	-- Identify rows using <column> value.
-	SELECT CheckAuth([<schema>], <table>, <column>)
-	-- Set lock/authorization for specific row in table
-	-- <authid> is a text value, <expires> is a timestamp
-	-- defaulting to now()+1hour.
-	-- Returns 1 if lock has been assigned, 0 otherwise
-	-- (already locked by other auth)
-	SELECT LockRow([<schema>], <table>, <rowid>, <authid>, [<expires>])
-	-- Remove all locks held by specified authorization id.
-	-- Returns the number of locks released.
-	SELECT UnlockRows(<authid>)
-	-- Add an authorization token to be used in current
-	-- transaction.
-	SELECT AddAuth(<authid>)
-  WARNING! users must use serializable transaction level
-  (see http://www.postgresql.org/docs/7.4/static/transaction-iso.html)
-  otherwise locking mechanism would break
-	--strk;
diff --git a/extras/WFS_locks/WFS_locks.c b/extras/WFS_locks/WFS_locks.c
index 6655ac191..000000000
--- a/extras/WFS_locks/WFS_locks.c
+++ /dev/null
@@ -1,173 +0,0 @@
-#include "postgres.h"
-#include "executor/spi.h"       /* this is what you need to work with SPI */
-#include "commands/trigger.h"   /* ... and triggers */
-#include "utils/lsyscache.h"	/* for get_namespace_name() */
-/*#define PGIS_DEBUG 1*/
-#define ABORT_ON_AUTH_FAILURE 1
-Datum check_authorization(PG_FUNCTION_ARGS);
- * This trigger will check for authorization before
- * allowing UPDATE or DELETE of specific rows.
- * Rows are identified by the provided column.
- * Authorization info is extracted by the
- * "authorization_table"
-PG_FUNCTION_INFO_V1(check_authorization);
-	TriggerData *trigdata = (TriggerData *) fcinfo->context;
-	char *colname;
-	HeapTuple rettuple_ok;
-	HeapTuple rettuple_fail;
-	TupleDesc tupdesc;
-	int SPIcode;
-	char query[1024];
-	const char *pk_id = NULL;
-	SPITupleTable *tuptable;
-	HeapTuple tuple;
-	char *lockcode;
-	char *authtable = "authorization_table";
-	const char *op;
-	char errmsg[256];
-	/* Make sure trigdata is pointing at what I expect */
-	if ( ! CALLED_AS_TRIGGER(fcinfo) )
-		elog(ERROR,"check_authorization: not fired by trigger manager");
-	if ( ! TRIGGER_FIRED_BEFORE(trigdata->tg_event) )
-		elog(ERROR,"check_authorization: not fired *before* event");
-	if ( TRIGGER_FIRED_BY_UPDATE(trigdata->tg_event) )
-		rettuple_ok = trigdata->tg_newtuple;
-		rettuple_fail = NULL;
-		op = "UPDATE";
-	else if ( TRIGGER_FIRED_BY_DELETE(trigdata->tg_event) )
-		rettuple_ok = trigdata->tg_trigtuple;
-		op = "DELETE";
-	else
-		elog(ERROR,"check_authorization: not fired by update or delete");
-		PG_RETURN_NULL();
-	tupdesc = trigdata->tg_relation->rd_att;
-	/* Connect to SPI manager */
-	SPIcode = SPI_connect();
-	if (SPIcode  != SPI_OK_CONNECT)
-		elog(ERROR,"check_authorization: could not connect to SPI");
-		PG_RETURN_NULL() ;
-	colname  = trigdata->tg_trigger->tgargs[0];
-	pk_id = SPI_getvalue(trigdata->tg_trigtuple, tupdesc,
-	                     SPI_fnumber(tupdesc, colname));
-#if PGIS_DEBUG
-	elog(NOTICE,"check_authorization called");
-#endif
-	snprintf(query, sizeof(query), "SELECT authid FROM \"%s\" WHERE expires >= now() AND toid = '%d' AND rid = '%s'", authtable, trigdata->tg_relation->rd_id, pk_id);
-#if PGIS_DEBUG > 1
-	elog(NOTICE,"about to execute :%s", query);
-#endif
-	SPIcode = SPI_exec(query,0);
-	if (SPIcode !=SPI_OK_SELECT )
-		elog(ERROR,"couldnt execute to test for lock :%s",query);
-	if (!SPI_processed )
-#if PGIS_DEBUG
-		elog(NOTICE,"there is NO lock on row '%s'", pk_id);
-#endif
-		SPI_finish();
-		return PointerGetDatum(rettuple_ok);
-	/* there is a lock - check to see if I have rights to it! */
-	tuptable = SPI_tuptable;
-	tupdesc = tuptable->tupdesc;
-	tuple = tuptable->vals[0];
-	lockcode = SPI_getvalue(tuple, tupdesc, 1);
-#if PGIS_DEBUG
-	elog(NOTICE, "there is a lock on row '%s' (auth: '%s').", pk_id, lockcode);
-#endif
-	 * check to see if temp_lock_have_table table exists
-	 * (it might not exist if they own no locks)
-	snprintf(query, sizeof(query), "SELECT * FROM pg_class WHERE relname = 'temp_lock_have_table'");
-	if (SPIcode != SPI_OK_SELECT )
-		elog(ERROR,"couldnt execute to test for lockkey temp table :%s",query);
-	if (SPI_processed==0)
-		goto fail;
-	snprintf(query, sizeof(query), "SELECT * FROM temp_lock_have_table WHERE xideq( transid, getTransactionID() ) AND lockcode ='%s'", lockcode);
-#if PGIS_DEBUG
-#endif
-		elog(ERROR, "couldnt execute to test for lock acquire: %s", query);
-	if (SPI_processed >0)
-#if PGIS_DEBUG
-		elog(NOTICE,"I own the lock - I can modify the row");
-#endif
-		SPI_finish();
-fail:
-	snprintf(errmsg, sizeof(errmsg), "%s where \"%s\" = '%s' requires authorization '%s'",
-	         op, colname, pk_id, lockcode);
-	errmsg[ERRMSGLEN-1] = '\0';
-#ifdef ABORT_ON_AUTH_FAILURE
-	elog(ERROR, "%s", errmsg);
-#else
-	elog(NOTICE, "%s", errmsg);
-#endif
-	SPI_finish();
-	return PointerGetDatum(rettuple_fail);
-PG_FUNCTION_INFO_V1(getTransactionID);
-Datum getTransactionID(PG_FUNCTION_ARGS)
-	TransactionId xid = GetCurrentTransactionId();
-	PG_RETURN_DATUM( TransactionIdGetDatum(xid) );
diff --git a/extras/WFS_locks/WFS_locks.sql.in b/extras/WFS_locks/WFS_locks.sql.in
index 7f2346c8b..000000000
--- a/extras/WFS_locks/WFS_locks.sql.in
+++ /dev/null
@@ -1,371 +0,0 @@
--- PostGIS - Spatial Types for PostgreSQL
--- http://postgis.net
--- Copyright 2001-2003 Refractions Research Inc.
--- This is free software; you can redistribute and/or modify it under
--- the terms of the GNU General Public Licence. See the COPYING file.
-#define CREATEFUNCTION CREATE OR REPLACE FUNCTION
-#if USE_VERSION > 72
-# define _IMMUTABLE_STRICT IMMUTABLE STRICT
-# define _IMMUTABLE IMMUTABLE
-# define _STABLE_STRICT STABLE STRICT
-# define _STABLE STABLE
-# define _VOLATILE_STRICT VOLATILE STRICT
-# define _VOLATILE VOLATILE
-# define _STRICT STRICT
-#else
-# define _IMMUTABLE_STRICT  with(iscachable,isstrict)
-# define _IMMUTABLE with(iscachable)
-# define _STABLE_STRICT with(isstrict)
-# define _STABLE
-# define _VOLATILE_STRICT with(isstrict)
-# define _VOLATILE
-# define _STRICT with(isstrict)
-#endif
-#if USE_VERSION >= 73
-# define HAS_SCHEMAS 1
-#endif
--- LONG TERM LOCKING
--- UnlockRows(authid)
--- removes all locks held by the given auth
--- returns the number of locks released
-CREATEFUNCTION UnlockRows(text)
-	RETURNS int
-	AS '
-DECLARE
-	ret int;
-BEGIN
-	IF NOT LongTransactionsEnabled() THEN
-		RAISE EXCEPTION ''Long transaction support disabled, use EnableLongTransaction() to enable.'';
-	END IF;
-	EXECUTE ''DELETE FROM authorization_table where authid = '' ||
-		quote_literal($1);
-	GET DIAGNOSTICS ret = ROW_COUNT;
-	RETURN ret;
-END;
-LANGUAGE 'plpgsql' _VOLATILE_STRICT;
--- LockRow([schema], table, rowid, auth, [expires])
--- Returns 1 if successfully obtained the lock, 0 otherwise
-CREATEFUNCTION LockRow(text, text, text, text, timestamp)
-	RETURNS int
-	AS '
-DECLARE
-	myschema alias for $1;
-	mytable alias for $2;
-	myrid   alias for $3;
-	authid alias for $4;
-	expires alias for $5;
-	ret int;
-	mytoid oid;
-	myrec RECORD;
-BEGIN
-	END IF;
-	EXECUTE ''DELETE FROM authorization_table WHERE expires < now()'';
-#ifdef HAS_SCHEMAS
-	SELECT c.oid INTO mytoid FROM pg_class c, pg_namespace n
-		WHERE c.relname = mytable
-		AND c.relnamespace = n.oid
-		AND n.nspname = myschema;
-#else
-		WHERE c.relname = mytable;
-#endif
-	-- RAISE NOTICE ''toid: %'', mytoid;
-	FOR myrec IN SELECT * FROM authorization_table WHERE
-		toid = mytoid AND rid = myrid
-	LOOP
-		IF myrec.authid != authid THEN
-			RETURN 0;
-		ELSE
-			RETURN 1;
-		END IF;
-	END LOOP;
-	EXECUTE ''INSERT INTO authorization_table VALUES (''||
-		quote_literal(mytoid)||'',''||quote_literal(myrid)||
-		'',''||quote_literal(expires)||
-		'',''||quote_literal(authid) ||'')'';
-	RETURN ret;
-END;'
--- LockRow(schema, table, rid, authid);
-CREATEFUNCTION LockRow(text, text, text, text)
-	RETURNS int
-	AS
-'SELECT LockRow($1, $2, $3, $4, now()::timestamp+''1:00'');'
-	LANGUAGE 'sql' _VOLATILE_STRICT;
--- LockRow(table, rid, authid);
-CREATEFUNCTION LockRow(text, text, text)
-	RETURNS int
-	AS
-#ifdef HAS_SCHEMAS
-'SELECT LockRow(current_schema(), $1, $2, $3, now()::timestamp+''1:00'');'
-#else
-'SELECT LockRow('''', $1, $2, $3, now()::timestamp+''1:00'');'
-#endif
--- LockRow(schema, table, rid, expires);
-CREATEFUNCTION LockRow(text, text, text, timestamp)
-	RETURNS int
-	AS
-#ifdef HAS_SCHEMAS
-'SELECT LockRow(current_schema(), $1, $2, $3, $4);'
-#else
-'SELECT LockRow('''', $1, $2, $3, $4);'
-#endif
-CREATEFUNCTION AddAuth(text)
-	RETURNS BOOLEAN
-	AS '
-DECLARE
-	lockid alias for $1;
-	okay boolean;
-	myrec record;
-BEGIN
-	-- check to see if table exists
-	--  if not, CREATE TEMP TABLE mylock (transid xid, lockcode text)
-	okay := ''f'';
-	FOR myrec IN SELECT * FROM pg_class WHERE relname = ''temp_lock_have_table'' LOOP
-		okay := ''t'';
-	END LOOP;
-	IF (okay <> ''t'') THEN
-		CREATE TEMP TABLE temp_lock_have_table (transid xid, lockcode text);
-			-- this will only work from pgsql7.4 up
-			-- ON COMMIT DELETE ROWS;
-	END IF;
-	--  INSERT INTO mylock VALUES ( $1)
---	EXECUTE ''INSERT INTO temp_lock_have_table VALUES ( ''||
---		quote_literal(getTransactionID()) || '','' ||
---		quote_literal(lockid) ||'')'';
-	INSERT INTO temp_lock_have_table VALUES (getTransactionID(), lockid);
-	RETURN true::boolean;
-END;
-LANGUAGE PLPGSQL;
--- CheckAuth( <schema>, <table>, <ridcolumn> )
--- Returns 0
-CREATEFUNCTION CheckAuth(text, text, text)
-	RETURNS INT
-	AS '
-DECLARE
-#ifdef HAS_SCHEMAS
-	schema text;
-#endif
-BEGIN
-	END IF;
-#ifdef HAS_SCHEMAS
-	if ( $1 != '''' ) THEN
-		schema = $1;
-	ELSE
-		SELECT current_schema() into schema;
-	END IF;
-#endif
-	-- TODO: check for an already existing trigger ?
-	EXECUTE ''CREATE TRIGGER check_auth BEFORE UPDATE OR DELETE ON ''
-#ifdef HAS_SCHEMAS
-		|| quote_ident(schema) || ''.'' || quote_ident($2)
-#else
-		|| quote_ident($2)
-#endif
-		||'' FOR EACH ROW EXECUTE PROCEDURE CheckAuthTrigger(''
-		|| quote_literal($3) || '')'';
-	RETURN 0;
-END;
-LANGUAGE 'plpgsql';
--- CheckAuth(<table>, <ridcolumn>)
-CREATEFUNCTION CheckAuth(text, text)
-	RETURNS INT
-	AS
-	'SELECT CheckAuth('''', $1, $2)'
-	LANGUAGE 'SQL';
-CREATEFUNCTION CheckAuthTrigger()
-	RETURNS trigger AS
-	'@MODULE_FILENAME@', 'check_authorization'
-	LANGUAGE C;
-CREATEFUNCTION GetTransactionID()
-	RETURNS xid AS
-	'@MODULE_FILENAME@', 'getTransactionID'
-	LANGUAGE C;
--- Enable Long transactions support
---  Creates the authorization_table if not already existing
-CREATEFUNCTION EnableLongTransactions()
-	RETURNS TEXT
-	AS '
-DECLARE
-	query text;
-	exists bool;
-	rec RECORD;
-BEGIN
-	exists = ''f'';
-	FOR rec IN SELECT * FROM pg_class WHERE relname = ''authorization_table''
-	LOOP
-		exists = ''t'';
-	END LOOP;
-	IF NOT exists
-	THEN
-		query = ''CREATE TABLE authorization_table (
-			toid oid, -- table oid
-			rid text, -- row id
-			expires timestamp,
-			authid text
-		EXECUTE query;
-	END IF;
-	exists = ''f'';
-	FOR rec IN SELECT * FROM pg_class WHERE relname = ''authorized_tables''
-	LOOP
-		exists = ''t'';
-	END LOOP;
-	IF NOT exists THEN
-		query = ''CREATE VIEW authorized_tables AS '' ||
-			''SELECT '' ||
-#ifdef HAS_SCHEMAS
-			''n.nspname as schema, '' ||
-#endif
-			''c.relname as table, trim('' ||
-			quote_literal(''\\\\000'') ||
-			'' from t.tgargs) as id_column '' ||
-			''FROM pg_trigger t, pg_class c, pg_proc p '' ||
-#ifdef HAS_SCHEMAS
-			'', pg_namespace n '' ||
-#endif
-			''WHERE p.proname = '' || quote_literal(''checkauthtrigger'') ||
-#ifdef HAS_SCHEMAS
-			'' AND c.relnamespace = n.oid'' ||
-#endif
-			'' AND t.tgfoid = p.oid and t.tgrelid = c.oid'';
-		EXECUTE query;
-	END IF;
-	RETURN ''Long transactions support enabled'';
-END;
--- Check if Long transactions support is enabled
-CREATEFUNCTION LongTransactionsEnabled()
-	RETURNS bool
-AS '
-DECLARE
-	rec RECORD;
-BEGIN
-	FOR rec IN SELECT oid FROM pg_class WHERE relname = ''authorized_tables''
-	LOOP
-		return ''t'';
-	END LOOP;
-	return ''f'';
-END;
--- Disable Long transactions support
---  (1) Drop any long_xact trigger
---  (2) Drop the authorization_table
---  (3) KEEP the authorized_tables view
-CREATEFUNCTION DisableLongTransactions()
-	RETURNS TEXT
-	AS '
-DECLARE
-	query text;
-	exists bool;
-	rec RECORD;
-BEGIN
-	-- Drop all triggers applied by CheckAuth()
-	FOR rec IN
-		SELECT c.relname, t.tgname, t.tgargs FROM pg_trigger t, pg_class c, pg_proc p
-		WHERE p.proname = ''checkauthtrigger'' and t.tgfoid = p.oid and t.tgrelid = c.oid
-	LOOP
-		EXECUTE ''DROP TRIGGER '' || quote_ident(rec.tgname) ||
-			'' ON '' || quote_ident(rec.relname);
-	END LOOP;
-	-- Drop the authorization_table table
-	FOR rec IN SELECT * FROM pg_class WHERE relname = ''authorization_table'' LOOP
-		DROP TABLE authorization_table;
-	END LOOP;
-	-- Drop the authorized_tables view
-	FOR rec IN SELECT * FROM pg_class WHERE relname = ''authorized_tables'' LOOP
-		DROP VIEW authorized_tables;
-	END LOOP;
-	RETURN ''Long transactions support disabled'';
-END;
--- END
diff --git a/extras/WFS_locks/test.sql b/extras/WFS_locks/test.sql
index 5da5a7656..000000000
--- a/extras/WFS_locks/test.sql
+++ /dev/null
@@ -1,58 +0,0 @@
-CREATE TABLE test_locks (id serial, b char(16), c char(16) );
-INSERT INTO test_locks(b) VALUES ('one');
-INSERT INTO test_locks(b) VALUES ('two');
-INSERT INTO test_locks(b) VALUES ('three');
--- Enable locks checking on the table
-SELECT CheckAuth('test_locks', 'id');
--- this has no lock
-UPDATE test_locks SET c = 'nolocks';
--- place the lock
-SELECT LockRow('test_locks', '1', 'auth1', now()::timestamp+'00:01');
-SELECT LockRow('test_locks', '2', 'auth2', now()::timestamp+'00:01');
--- this should fail due to missing auth
-UPDATE test_locks SET c = 'unauthorized' where id = 1;
-BEGIN;
-	-- Add authorization for row 1
-	SELECT AddAuth('auth1');
-	-- we're authorized for row 1
-	UPDATE test_locks SET c = 'authorized' where id = 1;
-END;
--- Out of transaction we're no more authorized for row 1
-BEGIN;
-	-- Add authorization for row 2
-	SELECT AddAuth('auth2');
-	-- we're authorized for row 2
-	UPDATE test_locks SET c = 'authorized' where id = 2;
-END;
-BEGIN;
-	-- we're *not* authorized for row 1
-	UPDATE test_locks SET c = 'unauthorized' where id = 1;
-END;
-UPDATE test_locks SET c = 'unauthorized' where id = 2;
-SELECT * from test_locks;
-DROP TABLE test_locks;
Summary of changes:
 README.postgis                    |   4 +-
 doc/Makefile.in                   |   1 -
 doc/postgis.xml                   |   1 -
 doc/reference.xml                 |   3 +-
 doc/reference_transaction.xml     | 349 -----------------------------------
 extras/WFS_locks/Makefile         |  33 ----
 extras/WFS_locks/README           |  46 -----
 extras/WFS_locks/WFS_locks.c      | 173 ------------------
 extras/WFS_locks/WFS_locks.sql.in | 371 --------------------------------------
 extras/WFS_locks/test.sql         |  58 ------
 10 files changed, 3 insertions(+), 1036 deletions(-)
 delete mode 100644 doc/reference_transaction.xml
 delete mode 100644 extras/WFS_locks/Makefile
 delete mode 100644 extras/WFS_locks/README
 delete mode 100644 extras/WFS_locks/WFS_locks.c
 delete mode 100644 extras/WFS_locks/WFS_locks.sql.in
 delete mode 100644 extras/WFS_locks/test.sql
hooks/post-receive
