[SCM] PostGIS branch master updated. 3.4.0rc1-1093-g9a746f869
Mon Apr 22 12:01:57 PDT 2024
the project "PostGIS".
       via  9a746f869c5486706b08bf60d35a0c61d923888d (commit)
      from  260b2eeefc720995c5922efee6b535fee111a10a (commit)
revisions in full, below.
commit 9a746f869c5486706b08bf60d35a0c61d923888d
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Apr 22 12:01:43 2024 -0700
    Remove long transaction functions, AddAuth, CheckAuth, DisableLongTransactions, EnableLongTransactions, LockRow, UnlockRows
diff --git a/NEWS b/NEWS
index 6a469da99..e31f0e48a 100644
--- a/NEWS
+++ b/NEWS
@@ -29,6 +29,7 @@ To take advantage of all SFCGAL featurs, SFCGAL 1.5.0+ is needed.
            rebuilding of materialized views that use them (Regina Obe)
   - #5659, ST_DFullyWithin behaviour has changed to
            be ST_Contains(ST_Buffer(A, R), B) (Paul Ramsey)
+  - Remove the WFS_locks extra package. (Paul Ramsey)
 * Deprecated signatures *
   - GH-761, ST_StraightSkeleton => CG_StraightSkeleton (Loïc Bartoletti)
diff --git a/postgis/Makefile.in b/postgis/Makefile.in
index c5b448b13..d9361ff1e 100644
--- a/postgis/Makefile.in
+++ b/postgis/Makefile.in
@@ -102,7 +102,6 @@ PG_OBJS= \
 	lwgeom_functions_temporal.o \
 	lwgeom_rectree.o \
 	lwgeom_itree.o \
-	long_xact.o \
 	lwgeom_sqlmm.o \
 	lwgeom_transform.o \
 	lwgeom_window.o \
@@ -255,7 +254,7 @@ postgis_upgrade.sql: common_before_upgrade.sql postgis_before_upgrade.sql postgi
 # SQL objects are also dependent on postgis_config.h for PostgreSQL version
 $(SQL_OBJS): ../postgis_config.h ../postgis_revision.h
-postgis.sql: sqldefines.h long_xact.sql.in geography.sql.in postgis_brin.sql.in postgis_spgist.sql.in postgis_letters.sql
+postgis.sql: sqldefines.h geography.sql.in postgis_brin.sql.in postgis_spgist.sql.in postgis_letters.sql
 uninstall_postgis.sql: postgis.sql ../utils/create_uninstall.pl
 	$(PERL) @top_srcdir@/utils/create_uninstall.pl $< $(POSTGIS_PGSQL_VERSION) > $@
diff --git a/postgis/long_xact.c b/postgis/long_xact.c
deleted file mode 100644
index 68e64796d..000000000
--- a/postgis/long_xact.c
+++ /dev/null
@@ -1,191 +0,0 @@
- * PostGIS - Spatial Types for PostgreSQL
- * http://postgis.net
- * PostGIS is free software: you can redistribute it and/or modify
- * it under the terms of the GNU General Public License as published by
- * the Free Software Foundation, either version 2 of the License, or
- * (at your option) any later version.
- * PostGIS is distributed in the hope that it will be useful,
- * but WITHOUT ANY WARRANTY; without even the implied warranty of
- * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
- * GNU General Public License for more details.
- * You should have received a copy of the GNU General Public License
- * along with PostGIS.  If not, see <http://www.gnu.org/licenses/>.
- * Copyright (C) 2006 Refractions Research Inc.
-#include "postgres.h"
-#include "access/xact.h"
-#include "executor/spi.h"       /* this is what you need to work with SPI */
-#include "commands/trigger.h"   /* ... and triggers */
-#include "utils/lsyscache.h"	/* for get_namespace_name() */
-#include "utils/rel.h"
-#include "../postgis_config.h"
-#include "lwgeom_pg.h"
-#define ABORT_ON_AUTH_FAILURE 1
-Datum check_authorization(PG_FUNCTION_ARGS);
-Datum getTransactionID(PG_FUNCTION_ARGS);
- * This trigger will check for authorization before
- * allowing UPDATE or DELETE of specific rows.
- * Rows are identified by the provided column.
- * Authorization info is extracted by the
- * "authorization_table"
-PG_FUNCTION_INFO_V1(check_authorization);
-	TriggerData *trigdata = (TriggerData *) fcinfo->context;
-	char *colname;
-	HeapTuple rettuple_ok;
-	HeapTuple rettuple_fail;
-	TupleDesc tupdesc;
-	int SPIcode;
-	char query[1024];
-	const char *pk_id = NULL;
-	SPITupleTable *tuptable;
-	HeapTuple tuple;
-	char *lockcode;
-	char *authtable = "authorization_table";
-	const char *op;
-	char err_msg[256];
-	/* Make sure trigdata is pointing at what I expect */
-	if ( ! CALLED_AS_TRIGGER(fcinfo) )
-		elog(ERROR,"check_authorization: not fired by trigger manager");
-	if ( ! TRIGGER_FIRED_BEFORE(trigdata->tg_event) )
-		elog(ERROR,"check_authorization: not fired *before* event");
-	if ( TRIGGER_FIRED_BY_UPDATE(trigdata->tg_event) )
-		rettuple_ok = trigdata->tg_newtuple;
-		rettuple_fail = NULL;
-		op = "UPDATE";
-	else if ( TRIGGER_FIRED_BY_DELETE(trigdata->tg_event) )
-		rettuple_ok = trigdata->tg_trigtuple;
-		op = "DELETE";
-	else
-		elog(ERROR,"check_authorization: not fired by update or delete");
-		PG_RETURN_NULL();
-	tupdesc = trigdata->tg_relation->rd_att;
-	/* Connect to SPI manager */
-	SPIcode = SPI_connect();
-	if (SPIcode  != SPI_OK_CONNECT)
-		elog(ERROR,"check_authorization: could not connect to SPI");
-		PG_RETURN_NULL() ;
-	colname  = trigdata->tg_trigger->tgargs[0];
-	pk_id = SPI_getvalue(trigdata->tg_trigtuple, tupdesc,
-	                     SPI_fnumber(tupdesc, colname));
-	POSTGIS_DEBUG(3, "check_authorization called");
-	snprintf(query, sizeof(query), "SELECT authid FROM \"%s\" WHERE expires >= now() AND toid = '%d' AND rid = '%s'", authtable, trigdata->tg_relation->rd_id, pk_id);
-	POSTGIS_DEBUGF(3 ,"about to execute :%s", query);
-	SPIcode = SPI_exec(query,0);
-	if (SPIcode !=SPI_OK_SELECT )
-		elog(ERROR,"couldnt execute to test for lock :%s",query);
-	if (!SPI_processed )
-		POSTGIS_DEBUGF(3, "there is NO lock on row '%s'", pk_id);
-		SPI_finish();
-		return PointerGetDatum(rettuple_ok);
-	/* there is a lock - check to see if I have rights to it! */
-	tuptable = SPI_tuptable;
-	tupdesc = tuptable->tupdesc;
-	tuple = tuptable->vals[0];
-	lockcode = SPI_getvalue(tuple, tupdesc, 1);
-	POSTGIS_DEBUGF(3, "there is a lock on row '%s' (auth: '%s').", pk_id, lockcode);
-	 * check to see if temp_lock_have_table table exists
-	 * (it might not exist if they own no locks)
-	snprintf(query, sizeof(query), "SELECT * FROM pg_class WHERE relname = 'temp_lock_have_table'");
-	if (SPIcode != SPI_OK_SELECT )
-		elog(ERROR,"couldnt execute to test for lockkey temp table :%s",query);
-	if (SPI_processed==0)
-		goto fail;
-	snprintf(query, sizeof(query), "SELECT * FROM temp_lock_have_table WHERE xideq( transid, getTransactionID() ) AND lockcode ='%s'", lockcode);
-	POSTGIS_DEBUGF(3, "about to execute :%s", query);
-		elog(ERROR, "couldnt execute to test for lock acquire: %s", query);
-	if (SPI_processed >0)
-		POSTGIS_DEBUG(3, "I own the lock - I can modify the row");
-		SPI_finish();
-fail:
-	snprintf(err_msg, sizeof(err_msg), "%s where \"%s\" = '%s' requires authorization '%s'",
-	         op, colname, pk_id, lockcode);
-	err_msg[sizeof(err_msg)-1] = '\0';
-#ifdef ABORT_ON_AUTH_FAILURE
-	elog(ERROR, "%s", err_msg);
-#else
-	elog(NOTICE, "%s", err_msg);
-#endif
-	SPI_finish();
-	return PointerGetDatum(rettuple_fail);
-PG_FUNCTION_INFO_V1(getTransactionID);
-	TransactionId xid = GetCurrentTransactionId();
-	PG_RETURN_DATUM( TransactionIdGetDatum(xid) );
diff --git a/postgis/long_xact.sql.in b/postgis/long_xact.sql.in
index cb7294ba2..000000000
--- a/postgis/long_xact.sql.in
+++ /dev/null
@@ -1,321 +0,0 @@
--- PostGIS - Spatial Types for PostgreSQL
--- http://postgis.net
--- Copyright 2001-2003 Refractions Research Inc.
--- This is free software; you can redistribute and/or modify it under
--- the terms of the GNU General Public Licence. See the COPYING file.
-#include "sqldefines.h"
--- LONG TERM LOCKING
--- UnlockRows(authid)
--- removes all locks held by the given auth
--- returns the number of locks released
-CREATE OR REPLACE FUNCTION UnlockRows(text)
-	RETURNS int
-	AS $$
-DECLARE
-	ret int;
-BEGIN
-	IF NOT LongTransactionsEnabled() THEN
-		RAISE EXCEPTION 'Long transaction support disabled, use EnableLongTransaction() to enable.';
-	END IF;
-	EXECUTE 'DELETE FROM authorization_table where authid = ' ||
-		quote_literal($1);
-	GET DIAGNOSTICS ret = ROW_COUNT;
-	RETURN ret;
-END;
-LANGUAGE 'plpgsql'  VOLATILE STRICT;
--- LockRow([schema], table, rowid, auth, [expires])
--- Returns 1 if successfully obtained the lock, 0 otherwise
-CREATE OR REPLACE FUNCTION LockRow(text, text, text, text, timestamp)
-	RETURNS int
-	AS $$
-DECLARE
-	myschema alias for $1;
-	mytable alias for $2;
-	myrid   alias for $3;
-	authid alias for $4;
-	expires alias for $5;
-	ret int;
-	mytoid oid;
-	myrec RECORD;
-BEGIN
-	END IF;
-	EXECUTE 'DELETE FROM authorization_table WHERE expires < now()';
-	SELECT c.oid INTO mytoid FROM pg_class c, pg_namespace n
-		WHERE c.relname = mytable
-		AND c.relnamespace = n.oid
-		AND n.nspname = myschema;
-	-- RAISE NOTICE 'toid: %', mytoid;
-	FOR myrec IN SELECT * FROM authorization_table WHERE
-		toid = mytoid AND rid = myrid
-	LOOP
-		IF myrec.authid != authid THEN
-			RETURN 0;
-		ELSE
-			RETURN 1;
-		END IF;
-	END LOOP;
-	EXECUTE 'INSERT INTO authorization_table VALUES ('||
-		quote_literal(mytoid::text)||','||quote_literal(myrid)||
-		','||quote_literal(expires::text)||
-		','||quote_literal(authid) ||')';
-	RETURN ret;
-END;
--- LockRow(schema, table, rid, authid);
-CREATE OR REPLACE FUNCTION LockRow(text, text, text, text)
-	RETURNS int
-	AS
-$$ SELECT LockRow($1, $2, $3, $4, now()::timestamp+'1:00'); $$
-	LANGUAGE 'sql'  VOLATILE STRICT;
--- LockRow(table, rid, authid);
-CREATE OR REPLACE FUNCTION LockRow(text, text, text)
-	RETURNS int
-	AS
-$$ SELECT LockRow(current_schema(), $1, $2, $3, now()::timestamp+'1:00'); $$
--- LockRow(schema, table, rid, expires);
-CREATE OR REPLACE FUNCTION LockRow(text, text, text, timestamp)
-	RETURNS int
-	AS
-$$ SELECT LockRow(current_schema(), $1, $2, $3, $4); $$
-CREATE OR REPLACE FUNCTION AddAuth(text)
-	RETURNS BOOLEAN
-	AS $$
-DECLARE
-	lockid alias for $1;
-	okay boolean;
-	myrec record;
-BEGIN
-	-- check to see if table exists
-	--  if not, CREATE TEMP TABLE mylock (transid xid, lockcode text)
-	okay := 'f';
-	FOR myrec IN SELECT * FROM pg_class WHERE relname = 'temp_lock_have_table' LOOP
-		okay := 't';
-	END LOOP;
-	IF (okay <> 't') THEN
-		CREATE TEMP TABLE temp_lock_have_table (transid xid, lockcode text);
-			-- this will only work from pgsql7.4 up
-			-- ON COMMIT DELETE ROWS;
-	END IF;
-	--  INSERT INTO mylock VALUES ( $1)
---	EXECUTE 'INSERT INTO temp_lock_have_table VALUES ( '||
---		quote_literal(getTransactionID()) || ',' ||
---		quote_literal(lockid) ||')';
-	INSERT INTO temp_lock_have_table VALUES (getTransactionID(), lockid);
-	RETURN true::boolean;
-END;
-LANGUAGE PLPGSQL;
--- CheckAuth( <schema>, <table>, <ridcolumn> )
--- Returns 0
-CREATE OR REPLACE FUNCTION CheckAuth(text, text, text)
-	RETURNS INT
-	AS $$
-DECLARE
-	schema text;
-BEGIN
-	END IF;
-	if ( $1 != '' ) THEN
-		schema = $1;
-	ELSE
-		SELECT current_schema() into schema;
-	END IF;
-	-- TODO: check for an already existing trigger ?
-	EXECUTE 'CREATE TRIGGER check_auth BEFORE UPDATE OR DELETE ON '
-		|| quote_ident(schema) || '.' || quote_ident($2)
-		||' FOR EACH ROW EXECUTE PROCEDURE CheckAuthTrigger('
-		|| quote_literal($3) || ')';
-	RETURN 0;
-END;
-LANGUAGE 'plpgsql';
--- CheckAuth(<table>, <ridcolumn>)
-CREATE OR REPLACE FUNCTION CheckAuth(text, text)
-	RETURNS INT
-	AS
-	$$ SELECT CheckAuth('', $1, $2) $$
-	LANGUAGE 'sql';
-CREATE OR REPLACE FUNCTION CheckAuthTrigger()
-	RETURNS trigger AS
-	'MODULE_PATHNAME', 'check_authorization'
-	LANGUAGE C;
-CREATE OR REPLACE FUNCTION GetTransactionID()
-	RETURNS xid AS
-	'MODULE_PATHNAME', 'getTransactionID'
-	LANGUAGE C;
--- Enable Long transactions support
---  Creates the authorization_table if not already existing
-CREATE OR REPLACE FUNCTION EnableLongTransactions()
-	RETURNS TEXT
-	AS $$
-DECLARE
-	"query" text;
-	exists bool;
-	rec RECORD;
-BEGIN
-	exists = 'f';
-	FOR rec IN SELECT * FROM pg_class WHERE relname = 'authorization_table'
-	LOOP
-		exists = 't';
-	END LOOP;
-	IF NOT exists
-	THEN
-		"query" = 'CREATE TABLE authorization_table (
-			toid oid, -- table oid
-			rid text, -- row id
-			expires timestamp,
-			authid text
-		EXECUTE "query";
-	END IF;
-	exists = 'f';
-	FOR rec IN SELECT * FROM pg_class WHERE relname = 'authorized_tables'
-	LOOP
-		exists = 't';
-	END LOOP;
-	IF NOT exists THEN
-		"query" = 'CREATE VIEW authorized_tables AS ' ||
-			'SELECT ' ||
-			'n.nspname as schema, ' ||
-			'c.relname as table, trim(' ||
-			quote_literal(chr(92) || '000') ||
-			' from t.tgargs) as id_column ' ||
-			'FROM pg_trigger t, pg_class c, pg_proc p ' ||
-			', pg_namespace n ' ||
-			'WHERE p.proname = ' || quote_literal('checkauthtrigger') ||
-			' AND c.relnamespace = n.oid' ||
-			' AND t.tgfoid = p.oid and t.tgrelid = c.oid';
-		EXECUTE "query";
-	END IF;
-	RETURN 'Long transactions support enabled';
-END;
--- Check if Long transactions support is enabled
-CREATE OR REPLACE FUNCTION LongTransactionsEnabled()
-	RETURNS bool
-AS $$
-DECLARE
-	rec RECORD;
-BEGIN
-	FOR rec IN SELECT oid FROM pg_class WHERE relname = 'authorized_tables'
-	LOOP
-		return 't';
-	END LOOP;
-	return 'f';
-END;
--- Disable Long transactions support
---  (1) Drop any long_xact trigger
---  (2) Drop the authorization_table
---  (3) KEEP the authorized_tables view
-CREATE OR REPLACE FUNCTION DisableLongTransactions()
-	RETURNS TEXT
-	AS $$
-DECLARE
-	rec RECORD;
-BEGIN
-	-- Drop all triggers applied by CheckAuth()
-	FOR rec IN
-		SELECT c.relname, t.tgname, t.tgargs FROM pg_trigger t, pg_class c, pg_proc p
-		WHERE p.proname = 'checkauthtrigger' and t.tgfoid = p.oid and t.tgrelid = c.oid
-	LOOP
-		EXECUTE 'DROP TRIGGER ' || quote_ident(rec.tgname) ||
-			' ON ' || quote_ident(rec.relname);
-	END LOOP;
-	-- Drop the authorization_table table
-	FOR rec IN SELECT * FROM pg_class WHERE relname = 'authorization_table' LOOP
-		DROP TABLE authorization_table;
-	END LOOP;
-	-- Drop the authorized_tables view
-	FOR rec IN SELECT * FROM pg_class WHERE relname = 'authorized_tables' LOOP
-		DROP VIEW authorized_tables;
-	END LOOP;
-	RETURN 'Long transactions support disabled';
-END;
--- END
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 2c3941a6c..9677eeccc 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -6215,7 +6215,6 @@ $$
 LANGUAGE 'plpgsql' IMMUTABLE STRICT PARALLEL SAFE;
 /* Should we include the .sql directly here ? */
-#include "long_xact.sql.in"
 #include "geography.sql.in"
 -- Availability: 2.2.0
diff --git a/postgis/uninstall_long_xact.sql.in b/postgis/uninstall_long_xact.sql.in
index cda20e785..000000000
--- a/postgis/uninstall_long_xact.sql.in
+++ /dev/null
@@ -1,30 +0,0 @@
-DROP FUNCTION UnlockRows(text);
-DROP FUNCTION LockRow(text, text, text, text, timestamp);
-DROP FUNCTION LockRow(text, text, text, text);
-DROP FUNCTION LockRow(text, text, text);
-DROP FUNCTION LockRow(text, text, text, timestamp);
-DROP FUNCTION AddAuth(text);
-DROP FUNCTION CheckAuth(text, text, text);
-DROP FUNCTION CheckAuth(text, text);
-DROP FUNCTION CheckAuthTrigger();
-DROP FUNCTION GetTransactionID();
-DROP FUNCTION EnableLongTransactions();
-DROP FUNCTION LongTransactionsEnabled();
-DROP FUNCTION DisableLongTransactions();
diff --git a/regress/core/long_xact.sql b/regress/core/long_xact.sql
index 19e16e749..000000000
--- a/regress/core/long_xact.sql
+++ /dev/null
@@ -1,60 +0,0 @@
-SELECT EnableLongTransactions();
-CREATE TABLE test_locks (id numeric, state varchar);
-INSERT INTO test_locks(id) VALUES (1);
-INSERT INTO test_locks(id) VALUES (2);
-INSERT INTO test_locks(id) VALUES (3);
--- Enable locks checking on the table
-SELECT CheckAuth('test_locks', 'id');
--- this has no lock
-UPDATE test_locks SET state = 'nolocks';
--- place the lock
-SELECT LockRow('test_locks', '1', 'auth1', now()::timestamp+'00:01');
-SELECT LockRow('test_locks', '2', 'auth2', now()::timestamp+'00:01');
--- this should fail due to missing auth
-UPDATE test_locks SET state = 'unauthorized' where id = 1;
-BEGIN;
-	-- Add authorization for row 1
-	SELECT AddAuth('auth1');
-	-- we're authorized for row 1
-	UPDATE test_locks SET state = 'authorized' where id = 1;
-END;
--- Out of transaction we're no more authorized for row 1
-BEGIN;
-	-- Add authorization for row 2
-	SELECT AddAuth('auth2');
-	-- we're authorized for row 2
-	UPDATE test_locks SET state = 'authorized' where id = 2;
-END;
-BEGIN;
-	-- we're *not* authorized for row 1
-	UPDATE test_locks SET state = 'unauthorized' where id = 1;
-END;
-UPDATE test_locks SET state = 'unauthorized' where id = 2;
-SELECT * from test_locks;
-DROP TABLE test_locks;
-SELECT DisableLongTransactions();
diff --git a/regress/core/long_xact_expected b/regress/core/long_xact_expected
index 5acec95a5..000000000
--- a/regress/core/long_xact_expected
+++ /dev/null
@@ -1,16 +0,0 @@
-Long transactions support enabled
-0
-1
-1
-ERROR:  UPDATE where "id" = '1' requires authorization 'auth1'
-t
-t
-t
-ERROR:  UPDATE where "id" = '2' requires authorization 'auth2'
-3|nolocks
-1|authorized
-2|authorized
-Long transactions support disabled
diff --git a/regress/core/tests.mk.in b/regress/core/tests.mk.in
index 7e783d7b5..6d8b4ed22 100644
--- a/regress/core/tests.mk.in
+++ b/regress/core/tests.mk.in
@@ -62,7 +62,6 @@ TESTS += \
 	$(top_srcdir)/regress/core/iscollection \
 	$(top_srcdir)/regress/core/legacy \
 	$(top_srcdir)/regress/core/letters \
-	$(top_srcdir)/regress/core/long_xact \
 	$(top_srcdir)/regress/core/lwgeom_regress \
 	$(top_srcdir)/regress/core/measures \
 	$(top_srcdir)/regress/core/minimum_bounding_circle \
diff --git a/utils/read_scripts_version.pl b/utils/read_scripts_version.pl
index e402aed51..7a38dbf2c 100755
--- a/utils/read_scripts_version.pl
+++ b/utils/read_scripts_version.pl
@@ -5,7 +5,6 @@ my $debug = 0;
 my @files = (
 	"postgis.sql.in.c",
 	"geography.sql.in.c",
-	"long_xact.sql.in.c"
 my $rev = 0;
Summary of changes:
 NEWS                               |   1 +
 postgis/Makefile.in                |   3 +-
 postgis/long_xact.c                | 191 ----------------------
 postgis/long_xact.sql.in           | 321 -------------------------------------
 postgis/postgis.sql.in             |   1 -
 postgis/uninstall_long_xact.sql.in |  30 ----
 regress/core/long_xact.sql         |  60 -------
 regress/core/long_xact_expected    |  16 --
 regress/core/tests.mk.in           |   1 -
 utils/read_scripts_version.pl      |   1 -
 10 files changed, 2 insertions(+), 623 deletions(-)
 delete mode 100644 postgis/long_xact.c
 delete mode 100644 postgis/long_xact.sql.in
 delete mode 100644 postgis/uninstall_long_xact.sql.in
 delete mode 100644 regress/core/long_xact.sql
 delete mode 100644 regress/core/long_xact_expected
hooks/post-receive
