[SCM] PostGIS branch master updated. 3.4.0rc1-933-gd47bde26b
Fri Feb 16 12:48:42 PST 2024
the project "PostGIS".
       via  d47bde26b885728ff281abe51c00701a4114d2c4 (commit)
       via  e73ac562025b9ee384cbc917aff34aeabdf164a7 (commit)
       via  d2c16dc4113c9ff0bb45c6c9f665cf2e0d04ff57 (commit)
      from  8779495f92373e7b88716186d75f59ff5106b6cb (commit)
revisions in full, below.
commit d47bde26b885728ff281abe51c00701a4114d2c4
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Aug 5 10:19:50 2020 +0200
    Rewrite ST_CreateTopoGeo to postpone face detection
    This was found to be faster for building the topology
    in current topology/test/perf/ST_CreateTopoGeo.sql
    (x2 improvement)
diff --git a/NEWS b/NEWS
index 4ab25172d..552949919 100644
--- a/NEWS
+++ b/NEWS
@@ -44,6 +44,7 @@ To take advantage of all SFCGAL featurs, SFCGAL 1.5.0+ is needed.
 * Enhancements *
+  - #5670, faster ST_CreateTopoGeo (Sandro Santilli)
   - #5531, documentation format upgraded to DocBook 5 (Sandro Santilli)
   - #5543, allow building without documentation (Sandro Santilli)
   - #5596, GH-749, Allow promoting column as an id
diff --git a/topology/sql/sqlmm.sql.in b/topology/sql/sqlmm.sql.in
index ec2d02c5e..6b95da8da 100644
--- a/topology/sql/sqlmm.sql.in
+++ b/topology/sql/sqlmm.sql.in
@@ -3,7 +3,7 @@
 -- PostGIS - Spatial Types for PostgreSQL
 -- http://postgis.net
--- Copyright (C) 2010-2015 Sandro Santilli <strk at kbt.io>
+-- Copyright (C) 2010-2024 Sandro Santilli <strk at kbt.io>
 -- Copyright (C) 2005 Refractions Research Inc.
 -- This is free software; you can redistribute and/or modify it under
@@ -401,14 +401,9 @@ RETURNS text
 AS
 DECLARE
-  typ char(4);
   rec RECORD;
-  ret int;
-  nodededges GEOMETRY;
   points GEOMETRY;
-  snode_id int;
-  enode_id int;
-  tolerance FLOAT8;
+  nodededges GEOMETRY;
   topoinfo RECORD;
 BEGIN
@@ -476,10 +471,10 @@ BEGIN
   WITH components AS ( SELECT geom FROM ST_Dump(acollection) )
   SELECT ST_UnaryUnion(ST_Collect(geom)) FROM (
     SELECT geom FROM components
-      WHERE ST_Dimension(geom) = 1
-    UNION ALL
+    WHERE ST_Dimension(geom) = 1
+      UNION ALL
     SELECT ST_Boundary(geom) FROM components
-      WHERE ST_Dimension(geom) = 2
+    WHERE ST_Dimension(geom) = 2
   ) as linework INTO STRICT nodededges;
 #ifdef POSTGIS_TOPOLOGY_DEBUG
@@ -524,44 +519,56 @@ BEGIN
 #endif
   END IF; -- points is not null
-  -- Collect all nodes (from points and noded linework endpoints)
-  WITH edges AS ( SELECT geom FROM ST_Dump(nodededges) )
-  SELECT ST_Union( -- TODO: ST_UnaryUnion ?
-          COALESCE(ST_UnaryUnion(ST_Collect(geom)),
-            ST_SetSRID('POINT EMPTY'::geometry, topoinfo.SRID)),
-          COALESCE(points,
-  FROM (
-    SELECT ST_StartPoint(geom) as geom FROM edges
-      UNION ALL
-    SELECT ST_EndPoint(geom) FROM edges
-  ) as endpoints INTO points;
-#ifdef POSTGIS_TOPOLOGY_DEBUG
-  RAISE DEBUG 'Total nodes count: %', ST_NumGeometries(points);
-#endif
-  -- Add all nodes as isolated so that
-  -- later calls to AddEdgeModFace will tweak their being
-  -- isolated or not...
+  -- Add pivot face (-1 id)
-  FOR rec IN SELECT geom FROM ST_Dump(points)
+  EXECUTE format('INSERT INTO %I.face(face_id) VALUES (-1)', atopology);
+  -- Collect possibly isolated points, to add later
+  WITH components AS ( SELECT geom FROM ST_Dump(acollection) )
+  SELECT ST_Union(geom) FROM components
+  WHERE ST_Dimension(geom) = 0
+  INTO STRICT points;
+  -- Add all linework
+  -- NOTE: we do this in an ordered way to be predictable
+  FOR rec IN
+    WITH linework AS ( SELECT geom FROM ST_Dump(nodededges) )
+    SELECT topology.TopoGeo_addLinestring(
+      atopology, geom, 0,
+      skipFaceSplitDetection => true
+    FROM linework
+    ORDER BY geom
   LOOP
-    PERFORM topology.ST_AddIsoNode(atopology, 0, rec.geom);
   END LOOP;
-  FOR rec IN SELECT geom FROM ST_Dump(nodededges)
+  -- Register all faces
+  PERFORM topology._RegisterMissingFaces(atopology);
+  -- Delete pivot face (-1 id)
+  EXECUTE format('DELETE FROM %I.face WHERE face_id = -1', atopology);
+  -- Add collected points so isolated ones get correctly
+  -- marked as being in their face
+  FOR rec IN SELECT geom FROM
+    ( SELECT * FROM ST_Dump(points) ) foo
+    ORDER BY geom
   LOOP
-    SELECT topology.GetNodeByPoint(atopology, st_startpoint(rec.geom), 0)
-      INTO STRICT snode_id;
-    SELECT topology.GetNodeByPoint(atopology, st_endpoint(rec.geom), 0)
-      INTO STRICT enode_id;
-    PERFORM topology.ST_AddEdgeModFace(atopology, snode_id, enode_id, rec.geom);
+    PERFORM topology.TopoGeo_addPoint(atopology, rec.geom);
   END LOOP;
   RETURN 'Topology ' || atopology || ' populated';
diff --git a/topology/test/regress/st_createtopogeo_expected b/topology/test/regress/st_createtopogeo_expected
index da3243ee1..c7ac08e75 100644
--- a/topology/test/regress/st_createtopogeo_expected
+++ b/topology/test/regress/st_createtopogeo_expected
@@ -33,7 +33,7 @@ T13|1 isolated nodes in face 0
 T13|1 isolated nodes in face 5
 T14|GEOMETRYCOLLECTION(LINESTRING(8 30,16 30,16 38,3 38,3 30,8 30),POINT(4 31),LINESTRING(4 31,7 31,7 34,4 34,4 31),POINT(8 30),POINT(9 6),LINESTRING(9 6,9 14),LINESTRING(9 6,21 6),POLYGON((9 14,21 14,21 6,9 6,9 14)),POINT(9 14),LINESTRING(9 14,9 22),LINESTRING(9 14,21 14),POLYGON((9 22,21 22,21 14,9 14,9 22)),POINT(9 22),LINESTRING(9 22,21 22),POINT(9 35),LINESTRING(9 35,13 35),POINT(13 35),POLYGON((25 30,17 30,17 40,31 40,31 30,25 30)),POINT(20 37),POINT(21 6),LINESTRING(21 6,21 14),LINESTRING(21 6,35 6),POLYGON((21 14,35 14,35 6,21 6,21 14)),POINT(21 14),LINESTRING(21 14,21 22),LINESTRING(35 14,21 14),POLYGON((21 22,35 22,35 14,21 14,21 22)),POINT(21 22),LINESTRING(21 22,35 22),POINT(25 30),LINESTRING(25 30,25 35),POINT(25 35),POINT(35 6),LINESTRING(35 6,35 14),LINESTRING(35 6,47 6),POLYGON((35 14,47 14,47 6,35 6,35 14)),POINT(35 14),LINESTRING(35 14,35 22),LINESTRING(35 14,47 14),POLYGON((35 22,47 22,47 14,35 14,35 22)),POINT(35 22),LINESTRING(35 22,47 22),LINESTRING(36 38,38 35
 ,41 34,42 33,45 32,47 28,50 28,52 32,57 33),POINT(36 38),LINESTRING(41 40,45 40,47 42,62 41,61 38,59 39,57 36,57 33),POINT(41 40),POINT(47 6),LINESTRING(47 6,47 14),POINT(47 14),LINESTRING(47 14,47 22),POINT(47 22),POINT(57 33))
 T14|22 nodes|24 edges|9 faces
-T14|1 isolated nodes in face 3
+T14|1 isolated nodes in face 7
 T15|GEOMETRYCOLLECTION(LINESTRING(-5 -2,0 0),LINESTRING(0 0,10 10),LINESTRING(0 0,5 2,10 10),LINESTRING(10 10,12 10))
 T15|4 nodes|4 edges|1 faces
 T16|GEOMETRYCOLLECTION(LINESTRING(0 0,10 0),LINESTRING(0 3,20 4),LINESTRING(10 0,20 4))
commit e73ac562025b9ee384cbc917aff34aeabdf164a7
Date:   Fri Jun 25 12:42:24 2021 +0200
    Add internal _RegisterMissingFaces SQL function
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index 0d4872d48..cbf461f00 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -5509,3 +5509,44 @@ Datum GetFaceContainingPoint(PG_FUNCTION_ARGS)
   SPI_finish();
   PG_RETURN_INT32(face_id);
+/*  RegisterMissingFaces(atopology) */
+Datum RegisterMissingFaces(PG_FUNCTION_ARGS);
+PG_FUNCTION_INFO_V1(RegisterMissingFaces);
+  text* toponame_text;
+  char* toponame;
+  LWT_TOPOLOGY *topo;
+  toponame_text = PG_GETARG_TEXT_P(0);
+  toponame = text_to_cstring(toponame_text);
+  PG_FREE_IF_COPY(toponame_text, 0);
+  if ( SPI_OK_CONNECT != SPI_connect() ) {
+    lwpgerror("Could not connect to SPI");
+    PG_RETURN_NULL();
+    int pre = be_data.topoLoadFailMessageFlavor;
+    be_data.topoLoadFailMessageFlavor = 1;
+    topo = lwt_LoadTopology(be_iface, toponame);
+    be_data.topoLoadFailMessageFlavor = pre;
+  pfree(toponame);
+  if ( ! topo ) {
+    /* should never reach this point, as lwerror would raise an exception */
+    SPI_finish();
+    PG_RETURN_NULL();
+  POSTGIS_DEBUG(1, "Calling lwt_Polygonize");
+  lwt_Polygonize(topo);
+  POSTGIS_DEBUG(1, "lwt_Polygonize returned");
+  lwt_FreeTopology(topo);
+  SPI_finish();
+  PG_RETURN_NULL();
diff --git a/topology/sql/populate.sql.in b/topology/sql/populate.sql.in
index e024a9809..6788633c6 100644
--- a/topology/sql/populate.sql.in
+++ b/topology/sql/populate.sql.in
@@ -740,3 +740,8 @@ END
 LANGUAGE 'plpgsql';
 --} TopoGeo_AddGeometry
+CREATE OR REPLACE FUNCTION topology._RegisterMissingFaces(atopology varchar)
+	RETURNS void AS
+	'MODULE_PATHNAME', 'RegisterMissingFaces'
+  LANGUAGE 'c' VOLATILE;
commit d2c16dc4113c9ff0bb45c6c9f665cf2e0d04ff57
Date:   Fri Jun 25 12:37:01 2021 +0200
    Add optional skipFaceSplitDetection to TopoGeo_addLinestring SQL function
    Defaults to false, can be set to true to skip computing face splits
    to perform batch topology loading. Requires presence of a record
    with face_id = -1 in the face table as a pivot value.
index c47d9e4f6..0d4872d48 100644
@@ -3,7 +3,7 @@
  * PostGIS - Spatial Types for PostgreSQL
  * http://postgis.net
- * Copyright (C) 2015-2021 Sandro Santilli <strk at kbt.io>
+ * Copyright (C) 2015-2024 Sandro Santilli <strk at kbt.io>
  * This is free software; you can redistribute and/or modify it under
  * the terms of the GNU General Public Licence. See the COPYING file.
@@ -5069,6 +5069,7 @@ Datum TopoGeo_AddLinestring(PG_FUNCTION_ARGS)
   FACEEDGESSTATE *state;
   Datum result;
   LWT_ELEMID id;
+  bool skipFace = false;
   if (SRF_IS_FIRSTCALL())
@@ -5131,9 +5132,18 @@ Datum TopoGeo_AddLinestring(PG_FUNCTION_ARGS)
       PG_RETURN_NULL();
-    POSTGIS_DEBUG(1, "Calling lwt_AddLine");
-    elems = lwt_AddLine(topo, ln, tol, &nelems);
-    POSTGIS_DEBUG(1, "lwt_AddLine returned");
+    if ( PG_NARGS() > 3 ) {
+      skipFace = PG_GETARG_BOOL(3);
+    if ( skipFace ) {
+      POSTGIS_DEBUG(1, "Calling lwt_AddLineNoFace");
+      elems = lwt_AddLineNoFace(topo, ln, tol, &nelems);
+    } else {
+      POSTGIS_DEBUG(1, "Calling lwt_AddLine");
+      elems = lwt_AddLine(topo, ln, tol, &nelems);
+    POSTGIS_DEBUG(1, "lwt_AddLine* returned");
     lwgeom_free(lwgeom);
     PG_FREE_IF_COPY(geom, 1);
index 361f13a71..e024a9809 100644
@@ -3,7 +3,7 @@
--- Copyright (C) 2010-2012 Sandro Santilli <strk at kbt.io>
 -- the terms of the GNU General Public Licence. See the COPYING file.
@@ -698,12 +698,16 @@ CREATE OR REPLACE FUNCTION topology.TopoGeo_AddPoint(atopology varchar, apoint g
 --} TopoGeo_AddPoint
---  TopoGeo_addLinestring(toponame, linegeom, tolerance)
+-- TopoGeo_addLinestring(toponame, linegeom, tolerance=0, skipFaceSplitDetection=false)
---  Add a LineString into a topology
+-- Add a LineString into a topology
+-- Availability: 2.0.0
+-- Changed: 3.5.0 - add skipFaceSplitDetection optional parameter
+-- Replaces TopoGeo_addLinestring(varchar, geometry, float8) deprecated in 3.5.0
-CREATE OR REPLACE FUNCTION topology.TopoGeo_addLinestring(atopology varchar, aline geometry, tolerance float8 DEFAULT 0)
+CREATE OR REPLACE FUNCTION topology.TopoGeo_addLinestring(atopology varchar, aline geometry, tolerance float8 DEFAULT 0, skipFaceSplitDetection bool DEFAULT false)
 	RETURNS SETOF int AS
 	'MODULE_PATHNAME', 'TopoGeo_AddLinestring'
Summary of changes:
 NEWS                                            |  1 +
 topology/postgis_topology.c                     | 59 ++++++++++++++++--
 topology/sql/populate.sql.in                    | 17 +++--
 topology/sql/sqlmm.sql.in                       | 83 ++++++++++++++-----------
 topology/test/regress/st_createtopogeo_expected |  2 +-
 5 files changed, 115 insertions(+), 47 deletions(-)
hooks/post-receive
