[SCM] PostGIS branch master updated. 3.4.0rc1-934-g53b48e51d
Sat Feb 17 00:54:39 PST 2024
the project "PostGIS".
       via  53b48e51df0991680fefd7af44a8faf33668306b (commit)
      from  d47bde26b885728ff281abe51c00701a4114d2c4 (commit)
revisions in full, below.
commit 53b48e51df0991680fefd7af44a8faf33668306b
Author: Sandro Santilli <strk at kbt.io>
Date:   Sat Feb 17 09:35:32 2024 +0100
    Avoid changing signature of TopoGeo_addLinestring
    Use an internal _TopoGeo_addLinestringNoFace function instead from
    the ST_CreateTopoGeo function.
    Closes #5670
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index cbf461f00..4e3d8b83a 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -5191,6 +5191,80 @@ Datum TopoGeo_AddLinestring(PG_FUNCTION_ARGS)
   SRF_RETURN_NEXT(funcctx, result);
+/*  _TopoGeo_AddLinestringNoFace(atopology, point, tolerance) */
+Datum TopoGeo_AddLinestringNoFace(PG_FUNCTION_ARGS);
+PG_FUNCTION_INFO_V1(TopoGeo_AddLinestringNoFace);
+  text* toponame_text;
+  char* toponame;
+  double tol;
+  int nelems;
+  GSERIALIZED *geom;
+  LWGEOM *lwgeom;
+  LWLINE *ln;
+  LWT_TOPOLOGY *topo;
+  toponame_text = PG_GETARG_TEXT_P(0);
+  toponame = text_to_cstring(toponame_text);
+  PG_FREE_IF_COPY(toponame_text, 0);
+  geom = PG_GETARG_GSERIALIZED_P(1);
+  lwgeom = lwgeom_from_gserialized(geom);
+  /* TODO: allow multilines too */
+  ln = lwgeom_as_lwline(lwgeom);
+  if ( ! ln )
+      char buf[32];
+      _lwtype_upper_name(lwgeom_get_type(lwgeom), buf, 32);
+      lwgeom_free(lwgeom);
+      PG_FREE_IF_COPY(geom, 1);
+      lwpgerror("Invalid geometry type (%s) passed to "
+                "TopoGeo_AddLinestringNoFace, expected LINESTRING", buf);
+      PG_RETURN_NULL();
+  tol = PG_GETARG_FLOAT8(2);
+  if ( tol < 0 )
+    lwpgerror("Tolerance must be >=0");
+    PG_RETURN_NULL();
+  if ( SPI_OK_CONNECT != SPI_connect() )
+    lwpgerror("Could not connect to SPI");
+    PG_RETURN_NULL();
+  topo = lwt_LoadTopology(be_iface, toponame);
+  pfree(toponame);
+  if ( ! topo )
+    /* should never reach this point, as lwerror would raise an exception */
+    SPI_finish();
+    PG_RETURN_NULL();
+  POSTGIS_DEBUG(1, "Calling lwt_AddLineNoFace");
+  /* return discarded as we assume lwerror would raise an exception earlier
+   * in case of error
+  lwt_AddLineNoFace(topo, ln, tol, &nelems);
+  POSTGIS_DEBUG(1, "lwt_AddLineNoFace returned");
+  lwt_FreeTopology(topo);
+  POSTGIS_DEBUG(1, "TopoGeo_AddLinestringNoFace calling SPI_finish");
+  SPI_finish();
+  PG_RETURN_VOID();
 /*  TopoGeo_AddPolygon(atopology, poly, tolerance) */
 Datum TopoGeo_AddPolygon(PG_FUNCTION_ARGS);
 PG_FUNCTION_INFO_V1(TopoGeo_AddPolygon);
diff --git a/topology/sql/populate.sql.in b/topology/sql/populate.sql.in
index 6788633c6..e7cd3531f 100644
--- a/topology/sql/populate.sql.in
+++ b/topology/sql/populate.sql.in
@@ -698,16 +698,12 @@ CREATE OR REPLACE FUNCTION topology.TopoGeo_AddPoint(atopology varchar, apoint g
 --} TopoGeo_AddPoint
--- TopoGeo_addLinestring(toponame, linegeom, tolerance=0, skipFaceSplitDetection=false)
+--  TopoGeo_addLinestring(toponame, linegeom, tolerance)
--- Add a LineString into a topology
--- Availability: 2.0.0
--- Changed: 3.5.0 - add skipFaceSplitDetection optional parameter
--- Replaces TopoGeo_addLinestring(varchar, geometry, float8) deprecated in 3.5.0
+--  Add a LineString into a topology
-CREATE OR REPLACE FUNCTION topology.TopoGeo_addLinestring(atopology varchar, aline geometry, tolerance float8 DEFAULT 0, skipFaceSplitDetection bool DEFAULT false)
+CREATE OR REPLACE FUNCTION topology.TopoGeo_addLinestring(atopology varchar, aline geometry, tolerance float8 DEFAULT 0)
 	RETURNS SETOF int AS
 	'MODULE_PATHNAME', 'TopoGeo_AddLinestring'
   LANGUAGE 'c' VOLATILE;
@@ -741,6 +737,12 @@ $$
 LANGUAGE 'plpgsql';
 --} TopoGeo_AddGeometry
+CREATE OR REPLACE FUNCTION topology._TopoGeo_addLinestringNoFace(atopology varchar, aline geometry, tolerance float8 DEFAULT 0)
+	RETURNS void AS
+	'MODULE_PATHNAME', 'TopoGeo_AddLinestringNoFace'
+  LANGUAGE 'c' VOLATILE STRICT;
 CREATE OR REPLACE FUNCTION topology._RegisterMissingFaces(atopology varchar)
 	RETURNS void AS
 	'MODULE_PATHNAME', 'RegisterMissingFaces'
diff --git a/topology/sql/sqlmm.sql.in b/topology/sql/sqlmm.sql.in
index 6b95da8da..17f28275a 100644
--- a/topology/sql/sqlmm.sql.in
+++ b/topology/sql/sqlmm.sql.in
@@ -539,10 +539,7 @@ BEGIN
   FOR rec IN
     WITH linework AS ( SELECT geom FROM ST_Dump(nodededges) )
-    SELECT topology.TopoGeo_addLinestring(
-      atopology, geom, 0,
-      skipFaceSplitDetection => true
+    SELECT topology._TopoGeo_addLinestringNoFace(atopology, geom)
     FROM linework
     ORDER BY geom
   LOOP
Summary of changes:
 topology/postgis_topology.c  | 74 ++++++++++++++++++++++++++++++++++++++++++++
 topology/sql/populate.sql.in | 16 +++++-----
 topology/sql/sqlmm.sql.in    |  5 +--
 3 files changed, 84 insertions(+), 11 deletions(-)
hooks/post-receive
