[SCM] PostGIS branch master updated. 3.4.0rc1-935-g8ed84517a
Sat Feb 17 01:01:07 PST 2024
the project "PostGIS".
       via  8ed84517a9b86c86724504d1b6a0f0c1ccd86cf6 (commit)
      from  53b48e51df0991680fefd7af44a8faf33668306b (commit)
revisions in full, below.
commit 8ed84517a9b86c86724504d1b6a0f0c1ccd86cf6
Author: Sandro Santilli <strk at kbt.io>
Date:   Sat Feb 17 10:00:54 2024 +0100
    Comments and cleanups
diff --git a/topology/sql/populate.sql.in b/topology/sql/populate.sql.in
index e7cd3531f..96909066e 100644
--- a/topology/sql/populate.sql.in
+++ b/topology/sql/populate.sql.in
@@ -703,7 +703,7 @@ CREATE OR REPLACE FUNCTION topology.TopoGeo_AddPoint(atopology varchar, apoint g
 --  Add a LineString into a topology
-CREATE OR REPLACE FUNCTION topology.TopoGeo_addLinestring(atopology varchar, aline geometry, tolerance float8 DEFAULT 0)
+CREATE OR REPLACE FUNCTION topology.TopoGeo_AddLinestring(atopology varchar, aline geometry, tolerance float8 DEFAULT 0)
 	RETURNS SETOF int AS
 	'MODULE_PATHNAME', 'TopoGeo_AddLinestring'
   LANGUAGE 'c' VOLATILE;
@@ -738,11 +738,13 @@ LANGUAGE 'plpgsql';
 --} TopoGeo_AddGeometry
-CREATE OR REPLACE FUNCTION topology._TopoGeo_addLinestringNoFace(atopology varchar, aline geometry, tolerance float8 DEFAULT 0)
+-- Internal function used by ST_CreateTopoGeo
+CREATE OR REPLACE FUNCTION topology._TopoGeo_AddLinestringNoFace(atopology varchar, aline geometry, tolerance float8 DEFAULT 0)
 	RETURNS void AS
 	'MODULE_PATHNAME', 'TopoGeo_AddLinestringNoFace'
   LANGUAGE 'c' VOLATILE STRICT;
 CREATE OR REPLACE FUNCTION topology._RegisterMissingFaces(atopology varchar)
 	RETURNS void AS
 	'MODULE_PATHNAME', 'RegisterMissingFaces'
Summary of changes:
 topology/sql/populate.sql.in | 6 ++++--
 1 file changed, 4 insertions(+), 2 deletions(-)
hooks/post-receive
