[SCM] PostGIS branch master updated. 3.4.0rc1-950-g5d7f02582
Wed Feb 28 06:26:24 PST 2024
the project "PostGIS".
       via  5d7f02582a78549a0ca32f03190a7cd019411689 (commit)
      from  f64b082efca3986205253ffee3fd0f1b421ee0db (commit)
revisions in full, below.
commit 5d7f02582a78549a0ca32f03190a7cd019411689
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Feb 28 15:27:07 2024 +0100
    Move populate_topology_layer function in its own file
    Ready for future enhancements
diff --git a/topology/Makefile.in b/topology/Makefile.in
index be2afd862..ef8de4bb9 100644
--- a/topology/Makefile.in
+++ b/topology/Makefile.in
@@ -142,6 +142,7 @@ topology.sql: \
 	sql/manage/FindLayer.sql.in \
 	sql/manage/FindTopology.sql.in \
 	sql/manage/ManageHelper.sql.in \
+	sql/manage/populate_topology_layer.sql.in \
 	sql/manage/RenameTopology.sql.in \
 	sql/manage/TopologySummary.sql.in \
 	sql/manage/ValidateTopologyRelation.sql.in \
diff --git a/topology/sql/manage/populate_topology_layer.sql.in b/topology/sql/manage/populate_topology_layer.sql.in
new file mode 100644
index 000000000..0378897f7
--- /dev/null
+++ b/topology/sql/manage/populate_topology_layer.sql.in
@@ -0,0 +1,47 @@
+-- populate_topology_layer
+-- Register missing layers into topology.topology, looking at
+-- their constraints.
+-- The function doesn't attempt to determine if a layer is
+-- hierarchical or primitive, but always assumes primitive.
+CREATE OR REPLACE FUNCTION topology.populate_topology_layer()
+	RETURNS TABLE(schema_name text, table_name text, feature_column text)
+AS
+  INSERT INTO topology.layer
+  WITH checks AS (
+  SELECT
+    n.nspname sch, r.relname tab,
+    replace(c.conname, 'check_topogeom_', '') col,
+    --c.consrc src,
+    regexp_matches(c.consrc,
+      E'\\.topology_id = (\\d+).*\\.layer_id = (\\d+).*\\.type = (\\d+)') inf
+  FROM (SELECT conname, connamespace, conrelid, conkey, pg_get_constraintdef(oid) As consrc
+		    FROM pg_constraint) AS c, pg_class r, pg_namespace n
+  WHERE c.conname LIKE 'check_topogeom_%'
+    AND r.oid = c.conrelid
+    AND n.oid = r.relnamespace
+  ), newrows AS (
+    SELECT inf[1]::int as topology_id,
+           inf[2]::int as layer_id,
+          sch, tab, col, inf[3]::int as feature_type --, src
+    FROM checks c
+    WHERE NOT EXISTS (
+      SELECT * FROM topology.layer l
+      WHERE l.schema_name = c.sch
+        AND l.table_name = c.tab
+        AND l.feature_column = c.col
+  SELECT topology_id, layer_id, sch,
+         tab, col, feature_type,
+         0, NULL
+  FROM newrows RETURNING schema_name,table_name,feature_column;
+LANGUAGE 'sql' VOLATILE;
diff --git a/topology/topology.sql.in b/topology/topology.sql.in
index 5746794c5..afe5b576d 100644
--- a/topology/topology.sql.in
+++ b/topology/topology.sql.in
@@ -648,53 +648,6 @@ LANGUAGE 'plpgsql' VOLATILE;
 --} DropTopoGeometryColumn
--- populate_topology_layer
--- Register missing layers into topology.topology, looking at
--- their constraints.
--- The function doesn't attempt to determine if a layer is
--- hierarchical or primitive, but always assumes primitive.
-CREATE OR REPLACE FUNCTION topology.populate_topology_layer()
-	RETURNS TABLE(schema_name text, table_name text, feature_column text)
-AS
-  INSERT INTO topology.layer
-  WITH checks AS (
-  SELECT
-    n.nspname sch, r.relname tab,
-    replace(c.conname, 'check_topogeom_', '') col,
-    --c.consrc src,
-    regexp_matches(c.consrc,
-      E'\\.topology_id = (\\d+).*\\.layer_id = (\\d+).*\\.type = (\\d+)') inf
-  FROM (SELECT conname, connamespace, conrelid, conkey, pg_get_constraintdef(oid) As consrc
-		    FROM pg_constraint) AS c, pg_class r, pg_namespace n
-  WHERE c.conname LIKE 'check_topogeom_%'
-    AND r.oid = c.conrelid
-    AND n.oid = r.relnamespace
-  ), newrows AS (
-    SELECT inf[1]::int as topology_id,
-           inf[2]::int as layer_id,
-          sch, tab, col, inf[3]::int as feature_type --, src
-    FROM checks c
-    WHERE NOT EXISTS (
-      SELECT * FROM topology.layer l
-      WHERE l.schema_name = c.sch
-        AND l.table_name = c.tab
-        AND l.feature_column = c.col
-  SELECT topology_id, layer_id, sch,
-         tab, col, feature_type,
-         0, NULL
-  FROM newrows RETURNING schema_name,table_name,feature_column;
-LANGUAGE 'sql' VOLATILE;
 -- CreateTopoGeom(topology_name, topogeom_type, layer_id, elements)
@@ -1444,6 +1397,7 @@ LANGUAGE 'plpgsql' VOLATILE STRICT;
 #include "sql/manage/CopyTopology.sql.in"
 #include "sql/manage/FindTopology.sql.in"
 #include "sql/manage/FindLayer.sql.in"
+#include "sql/manage/populate_topology_layer.sql.in"
 #include "sql/manage/RenameTopology.sql.in"
 #include "sql/manage/ValidateTopology.sql.in"
 #include "sql/manage/ValidateTopologyRelation.sql.in"
Summary of changes:
 topology/Makefile.in                               |  1 +
 topology/sql/manage/populate_topology_layer.sql.in | 47 +++++++++++++++++++++
 topology/topology.sql.in                           | 48 +---------------------
 3 files changed, 49 insertions(+), 47 deletions(-)
 create mode 100644 topology/sql/manage/populate_topology_layer.sql.in
hooks/post-receive
