[SCM] PostGIS branch master updated. 3.4.0rc1-951-gea78085af
Wed Feb 28 07:30:09 PST 2024
the project "PostGIS".
       via  ea78085af40612926663e0a149bf1a776fa8412b (commit)
      from  5d7f02582a78549a0ca32f03190a7cd019411689 (commit)
revisions in full, below.
commit ea78085af40612926663e0a149bf1a776fa8412b
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Feb 28 16:30:48 2024 +0100
    Have TopologySummary signal pending computation of faces
    Based on presence of pivot faces (where face_id < 0)
diff --git a/topology/sql/manage/TopologySummary.sql.in b/topology/sql/manage/TopologySummary.sql.in
index ebca1f33e..cce626716 100644
--- a/topology/sql/manage/TopologySummary.sql.in
+++ b/topology/sql/manage/TopologySummary.sql.in
@@ -74,11 +74,22 @@ BEGIN
   END;
   BEGIN
-    EXECUTE 'SELECT count(*) FROM ' || quote_ident(atopology)
-      || '.face' INTO STRICT n;
-    ret = ret || greatest(n-1,0) || ' faces, '; -- -1 is face=0
+    EXECUTE format(
+    SELECT
+      count(*) FILTER (WHERE face_id > 0) p,
+      count(*) FILTER (WHERE face_id < 0) n
+    FROM %I.face
+      atopology)
+    INTO STRICT rec;
+    IF rec.n > 0 THEN
+      ret = ret || rec.p || '? faces (pending detection), ';
+    ELSE
+      ret = ret || rec.p || ' faces, ';
+    END IF;
   EXCEPTION
-    WHEN UNDEFINED_TABLE OR INVALID_SCHEMA_NAME THEN
+    WHEN UNDEFINED_TABLE OR UNDEFINED_COLUMN OR INVALID_SCHEMA_NAME THEN
       ret = ret || 'missing faces, ';
   END;
diff --git a/topology/test/regress/topologysummary.sql b/topology/test/regress/topologysummary.sql
index 0f57ff7c0..6454dff92 100644
--- a/topology/test/regress/topologysummary.sql
+++ b/topology/test/regress/topologysummary.sql
@@ -1,11 +1,12 @@
+SET client_min_messages TO WARNING;
 SELECT E'--missing--\n' || TopologySummary('test');
 CREATE SCHEMA test;
 SELECT E'--empty--\n' || TopologySummary('test');
-CREATE TABLE test.node(id int);
+CREATE TABLE test.node(node_id int);
 SELECT E'--node--\n' || TopologySummary('test');
-CREATE TABLE test.edge(id int);
+CREATE TABLE test.edge(edge_id int);
 SELECT E'--node+edge--\n' || TopologySummary('test');
-CREATE TABLE test.face(id int);
+CREATE TABLE test.face(face_id int);
 SELECT E'--node+edge+face--\n' || TopologySummary('test');
 CREATE TABLE test.relation(id int);
 SELECT E'--node+edge+face+corrupted_relation--\n' || TopologySummary('test');
@@ -29,13 +30,11 @@ UPDATE test.t SET c.layer_id = 1, c.topology_id = topology_id(c)+1 WHERE layer_i
 SELECT E'--registered_layer_missing_topogeom_in_proper_topo--\n' || TopologySummary('test');
 UPDATE test.t SET c.topology_id = topology_id(c)-1 WHERE layer_id(c) = 1;
 SELECT E'--registered_layer--\n' || TopologySummary('test');
--- TODO: test hierarchical
-DROP TABLE test.t;
-DROP TABLE test.node;
-DROP TABLE test.edge;
-DROP TABLE test.face;
-DROP TABLE test.relation;
-DROP SCHEMA test;
+INSERT INTO test.face(face_id) VALUES (-1);
+SELECT E'--pivot face--\n' || TopologySummary('test');
+DROP SCHEMA test CASCADE;
 SELECT E'--registered+missing--\n' || TopologySummary('test');
 DELETE FROM topology.layer WHERE topology_id = 1;
 DELETE FROM topology.topology WHERE id = 1;
+-- TODO: test hierarchical
diff --git a/topology/test/regress/topologysummary_expected b/topology/test/regress/topologysummary_expected
index 4cd90d36e..dba0f8e92 100644
--- a/topology/test/regress/topologysummary_expected
+++ b/topology/test/regress/topologysummary_expected
@@ -55,6 +55,11 @@ Layer 1, type Puntal (1), 1 topogeoms
 Topology test (id 1, SRID 10, precision 20)
 0 nodes, 0 edges, 0 faces, 1 topogeoms in 1 layers
+Layer 1, type Puntal (1), 1 topogeoms
+ Deploy: test.t.c
+--pivot face--
+Topology test (id 1, SRID 10, precision 20)
+0 nodes, 0 edges, 0? faces (pending detection), 1 topogeoms in 1 layers
  Deploy: test.t.c
Summary of changes:
 topology/sql/manage/TopologySummary.sql.in     | 19 +++++++++++++++----
 topology/test/regress/topologysummary.sql      | 19 +++++++++----------
 topology/test/regress/topologysummary_expected |  5 +++++
 3 files changed, 29 insertions(+), 14 deletions(-)
hooks/post-receive
