[SCM] PostGIS branch master updated. 3.4.0rc1-882-gf66b215f0
Tue Jan 16 16:32:08 PST 2024
the project "PostGIS".
       via  f66b215f0f3a04b83b6c47e004b264c2a5403269 (commit)
      from  8619e4da76e068c94327613a3196c73911f82b0c (commit)
revisions in full, below.
commit f66b215f0f3a04b83b6c47e004b264c2a5403269
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Jan 16 16:32:01 2024 -0800
    Fix huge mistake in generate points update
diff --git a/liblwgeom/lwgeom_geos.c b/liblwgeom/lwgeom_geos.c
index d7aa1cedb..1c662d6e6 100644
--- a/liblwgeom/lwgeom_geos.c
+++ b/liblwgeom/lwgeom_geos.c
@@ -1513,8 +1513,8 @@ lwpoly_to_points(const LWPOLY* lwpoly, uint32_t npoints, int32_t seed)
 		for (j = 0; j < sample_height; j++)
 			int intersects = 0;
-			double xmin = i * sample_cell_size;
-			double ymin = j * sample_cell_size;
+			double xmin = bbox.xmin + i * sample_cell_size;
+			double ymin = bbox.ymin + j * sample_cell_size;
 			GEOSGeometry *gcell = lwpoly_to_points_makepoly(xmin, ymin, sample_cell_size);
 			intersects = GEOSPreparedIntersects(gprep, gcell);
 			if (intersects == 2)
diff --git a/regress/core/generate_points.sql b/regress/core/generate_points.sql
new file mode 100644
index 000000000..ddb80741b
--- /dev/null
+++ b/regress/core/generate_points.sql
@@ -0,0 +1,12 @@
+-- Check containment and count of generated points
+WITH circle AS (
+	SELECT ST_Point(5000,5000) AS pt,
+	       ST_Buffer(ST_Point(5000,5000),10) AS geom
+pts AS (
+	SELECT (ST_Dump(ST_GeneratePoints(geom, 50))).geom AS geom
+	FROM circle
+SELECT 'generate_points_1', bool_and(ST_Distance(circle.pt, pts.geom) < 10), count(pts.geom)
+FROM circle, pts
diff --git a/regress/core/generate_points_expected b/regress/core/generate_points_expected
index 000000000..4d584a78e
--- /dev/null
+++ b/regress/core/generate_points_expected
@@ -0,0 +1 @@
+generate_points_1|t|50
diff --git a/regress/core/tests.mk.in b/regress/core/tests.mk.in
index 2e872af78..dca602a6a 100644
--- a/regress/core/tests.mk.in
+++ b/regress/core/tests.mk.in
@@ -44,9 +44,10 @@ TESTS += \
 	$(top_srcdir)/regress/core/forcecurve \
 	$(top_srcdir)/regress/core/flatgeobuf \
 	$(top_srcdir)/regress/core/frechet \
+	$(top_srcdir)/regress/core/generate_points \
 	$(top_srcdir)/regress/core/geography \
 	$(top_srcdir)/regress/core/geometric_median \
-  $(top_srcdir)/regress/core/geos_noop \
+	$(top_srcdir)/regress/core/geos_noop \
 	$(top_srcdir)/regress/core/geos38 \
 	$(top_srcdir)/regress/core/hausdorff \
 	$(top_srcdir)/regress/core/in_flatgeobuf \
Summary of changes:
 liblwgeom/lwgeom_geos.c               |  4 ++--
 regress/core/generate_points.sql      | 12 ++++++++++++
 regress/core/generate_points_expected |  1 +
 regress/core/tests.mk.in              |  3 ++-
 4 files changed, 17 insertions(+), 3 deletions(-)
 create mode 100644 regress/core/generate_points.sql
 create mode 100644 regress/core/generate_points_expected
hooks/post-receive
