[SCM] PostGIS branch master updated. 3.4.0rc1-883-gdd88d87cf
Wed Jan 17 13:08:56 PST 2024
the project "PostGIS".
       via  dd88d87cfc3b7b7b7f059171fb090ee4b2db8836 (commit)
      from  f66b215f0f3a04b83b6c47e004b264c2a5403269 (commit)
revisions in full, below.
commit dd88d87cfc3b7b7b7f059171fb090ee4b2db8836
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Jan 17 13:07:29 2024 -0800
    Replace the old cached point-in-polygon code with a new
    implementation of the same concept. More memory locality,
    and a more efficient search call stack, fewer unnecessary
    allocations. Tests out to 15% faster, at least on synthetic
    data. Removes some scruft and duplicate functionality that is
    now all in liblwgeom.
diff --git a/NEWS b/NEWS
index 68b4bfbbd..fa5958806 100644
--- a/NEWS
+++ b/NEWS
@@ -48,6 +48,7 @@ To take advantage of all SFCGAL featurs, SFCGAL 1.5.0+ is needed.
           in ST_AsGeoJson(record,..). (Jan Tojnar)
   - GH-744, Don't create docbook.css for the HTML manual,
             use style.css instead (Chris Mayo)
+  - Faster implementation of point-in-poly cached index (Paul Ramsey)
 PostGIS 3.4.0
diff --git a/liblwgeom/Makefile.in b/liblwgeom/Makefile.in
index 3094837af..68c173cc3 100644
--- a/liblwgeom/Makefile.in
+++ b/liblwgeom/Makefile.in
@@ -96,6 +96,7 @@ SA_OBJS = \
 	lwin_encoded_polyline.o \
 	lwutil.o \
 	lwhomogenize.o \
+	intervaltree.o \
 	lwalgorithm.o \
 	lwstroke.o \
 	lwlinearreferencing.o \
@@ -160,6 +161,7 @@ SA_HEADERS = \
 	lwgeom_log.h \
 	lwgeom_sfcgal.h \
 	lwinline.h \
+	intervaltree.h \
 	lwin_wkt.h \
 	lwin_wkt_parse.h \
 	lwout_twkb.h \
diff --git a/liblwgeom/cunit/cu_tree.c b/liblwgeom/cunit/cu_tree.c
index ce46c1c4f..0491ce223 100644
--- a/liblwgeom/cunit/cu_tree.c
+++ b/liblwgeom/cunit/cu_tree.c
@@ -18,6 +18,7 @@
 #include "liblwgeom_internal.h"
 #include "lwgeodetic.h"
 #include "lwgeodetic_tree.h"
+#include "intervaltree.h"
 #include "cu_tester.h"
@@ -419,6 +420,191 @@ static void test_tree_circ_distance_threshold(void)
+/***** Tests for IntervalTree *****/
+static void test_itree_once(
+	const char *polyWkt, double x, double y,
+	IntervalTreeResult iexp)
+	LWPOINT *pt = lwpoint_make2d(SRID_DEFAULT, x, y);
+	LWGEOM *poly = lwgeom_from_wkt(polyWkt, LW_PARSER_CHECK_NONE);
+	if(!poly)
+		CU_FAIL_FATAL("unable to parse WKT");
+	IntervalTree *itree = itree_from_lwgeom(poly);
+	IntervalTreeResult irslt = itree_point_in_multipolygon(itree, pt);
+	itree_free(itree);
+	lwgeom_free(poly);
+	lwpoint_free(pt);
+	CU_ASSERT_EQUAL(irslt, iexp);
+static void test_itree_square(void)
+	const char *wktPoly =
+		"MULTIPOLYGON(((-1 -1, 0 -1, 1 -1, 1 0, 1 1, -1 1, -1 -1)))";
+	/* inside square */
+	test_itree_once(wktPoly, 0.5, 0.5, ITREE_INSIDE);
+	/* inside square at vertex */
+	test_itree_once(wktPoly, 0.0, 0.0, ITREE_INSIDE);
+	/* left of square */
+	test_itree_once(wktPoly, -3.0, 0.0, ITREE_OUTSIDE);
+	/* right of square */
+	test_itree_once(wktPoly, 3.0, 0.0, ITREE_OUTSIDE);
+	/* above square */
+	test_itree_once(wktPoly, 0.0, 3.0, ITREE_OUTSIDE);
+	/* on horizontal boundary */
+	test_itree_once(wktPoly, 0.0, 1.0, ITREE_BOUNDARY);
+	/* on vertical boundary */
+	test_itree_once(wktPoly, -1.0, 0.0, ITREE_BOUNDARY);
+static void test_itree_hole(void)
+		"POLYGON("
+		"(-10 -10, 0 -10, 10 -10, 10 0, 10 10, 0 10, -10 10, -10 -10),"
+		"(-5 -5, -5 0, -5 5, 5 5, 5 0, 5 -5, -5 -5))";
+	/* inside hole */
+	test_itree_once(wktPoly, 1.0, 1.0, ITREE_OUTSIDE);
+	/* inside hole at vertical vertex */
+	test_itree_once(wktPoly, 0.0, 0.0, ITREE_OUTSIDE);
+	/* left of hole */
+	test_itree_once(wktPoly, -7.0, 0.0, ITREE_INSIDE);
+	/* right of hole */
+	test_itree_once(wktPoly, 7.0, 0.0, ITREE_INSIDE);
+	/* left of hole at top edge */
+	test_itree_once(wktPoly, -7.0, 5.0, ITREE_INSIDE);
+	/* right of hole at bottom edge */
+	test_itree_once(wktPoly, 7.0, -5.0, ITREE_INSIDE);
+	/* above hole */
+	test_itree_once(wktPoly, 0.0, 7.0, ITREE_INSIDE);
+	/* on hole boundary */
+	test_itree_once(wktPoly, 0.0, 5.0, ITREE_BOUNDARY);
+	/* on hole corner */
+	test_itree_once(wktPoly, 5.0, 5.0, ITREE_BOUNDARY);
+static void test_itree_hole_spike(void)
+		"POLYGON("
+		"(-10 -10, 6 -10, 7 -10, 7.5 2, 8 -10, 9 -10, 10 -10, 10 10, -10 10, -10 2, -10 2, -10 -10),"
+		"(-5 -5, -5 5, 5 5, 5 -5, -5 -5))";
+	/* inside hole */
+	test_itree_once(wktPoly, 2.0, 2.0, ITREE_OUTSIDE);
+	/* inside hole */
+	test_itree_once(wktPoly, -2.0, -2.0, ITREE_OUTSIDE);
+	/* left of spike */
+	test_itree_once(wktPoly, 6.0, -2.0, ITREE_INSIDE);
+	/* right of spike */
+	test_itree_once(wktPoly, 9.0, -2.0, ITREE_INSIDE);
+	/* left of tip of spike */
+	test_itree_once(wktPoly, 6.0, 2.0, ITREE_INSIDE);
+	/* right of tip of spike */
+	test_itree_once(wktPoly, 9.0, 2.0, ITREE_INSIDE);
+	/* on spike tip */
+	test_itree_once(wktPoly, 7.5, 2.0, ITREE_BOUNDARY);
+	/* left of dupe vertex */
+	test_itree_once(wktPoly, -11, 2.0, ITREE_OUTSIDE);
+	/* right of dupe vertex */
+	test_itree_once(wktPoly, 11, 2.0, ITREE_OUTSIDE);
+static void test_itree_multipoly_empty(void)
+	/* outside empty */
+	const char *wktPoly = "POLYGON EMPTY";
+	wktPoly = "MULTIPOLYGON EMPTY";
+	/* outside collection of empty */
+	wktPoly = "MULTIPOLYGON(EMPTY, EMPTY, EMPTY)";
+	/* mixed collection of empty and not */
+	wktPoly =
+		"MULTIPOLYGON(EMPTY,"
+		"((-10 -10, 6 -10, 7 -10, 7.5 2, 8 -10, 9 -10, 10 -10, 10 10, -10 10, -10 2, -10 2, -10 -10),"
+		"(-5 -5, -5 5, 5 5, 5 -5, -5 -5)))";
+	/* inside hole */
+	/* inside hole */
+	/* mixed collection of empty, empty in middle */
+	wktPoly =
+		"MULTIPOLYGON("
+		"(-5 -5, -5 5, 5 5, 5 -5, -5 -5)),"
+		"EMPTY, ((-1 -1, 1 -1, 1 1, -1 1, -1 -1)))";
+	/* inside poly in hole */
+	/* inside hole */
+	/* inside hole */
+static void test_itree_degenerate_poly(void)
+	/* collapsed polygon */
+	const char *wktPoly = "POLYGON((0 0, 0 0, 0 0, 0 0))";
+	/* zero area polygon */
+	wktPoly = "POLYGON((0 0, 0 1, 0 1, 0 0))";
+	test_itree_once(wktPoly, 0, 0.5, ITREE_BOUNDARY);
+	test_itree_once(wktPoly, 0, 1, ITREE_BOUNDARY);
+	wktPoly = "POLYGON((0 0, 0 1, 1 1, 2 2, 1 1, 0 1, 0 0))";
+	test_itree_once(wktPoly, 0.5, 0.5, ITREE_OUTSIDE);
+	test_itree_once(wktPoly, 1, 1, ITREE_BOUNDARY);
+	/* non finite coordinates */
+	wktPoly = "POLYGON((0 0, 0 NaN, 0 NaN, 0 0, 0 1, 0 0))";
+	test_itree_once(wktPoly, 0, 0, ITREE_BOUNDARY);
 ** Used by test harness to register the tests in this file.
@@ -426,6 +612,11 @@ void tree_suite_setup(void);
 	CU_pSuite suite = CU_add_suite("spatial_trees", NULL, NULL);
+	PG_ADD_TEST(suite, test_itree_square);
+	PG_ADD_TEST(suite, test_itree_hole);
+	PG_ADD_TEST(suite, test_itree_hole_spike);
+	PG_ADD_TEST(suite, test_itree_multipoly_empty);
+	PG_ADD_TEST(suite, test_itree_degenerate_poly);
 	PG_ADD_TEST(suite, test_tree_circ_create);
 	PG_ADD_TEST(suite, test_tree_circ_pip);
 	PG_ADD_TEST(suite, test_tree_circ_pip2);
diff --git a/liblwgeom/intervaltree.c b/liblwgeom/intervaltree.c
new file mode 100644
index 000000000..03bd52e50
--- /dev/null
+++ b/liblwgeom/intervaltree.c
@@ -0,0 +1,530 @@
+ * PostGIS - Spatial Types for PostgreSQL
+ * http://postgis.net
+ * PostGIS is free software: you can redistribute it and/or modify
+ * it under the terms of the GNU General Public License as published by
+ * the Free Software Foundation, either version 2 of the License, or
+ * (at your option) any later version.
+ * PostGIS is distributed in the hope that it will be useful,
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+ * GNU General Public License for more details.
+ * You should have received a copy of the GNU General Public License
+ * along with PostGIS.  If not, see <http://www.gnu.org/licenses/>.
+ * Copyright 2023 Paul Ramsey <pramsey at cleverelephant.ca>
+void
+itree_free(IntervalTree *itree)
+	if (itree->nodes) lwfree(itree->nodes);
+	if (itree->ringCounts) lwfree(itree->ringCounts);
+	if (itree->indexArrays)
+		for (uint32_t i = 0; i < itree->numIndexes; i++)
+			if (itree->indexArrays[i])
+				ptarray_free(itree->indexArrays[i]);
+	if (itree->indexes) lwfree(itree->indexes);
+	if (itree->indexArrays) lwfree(itree->indexArrays);
+	lwfree(itree);
+static uint32_t
+itree_num_nodes_pointarray(const POINTARRAY *pa)
+	uint32_t num_nodes = 0;
+	uint32_t level_nodes = 0;
+	/* not a closed polygon */
+	if (!pa || pa->npoints < 4) return 0;
+	/* one leaf node per edge */
+	level_nodes = pa->npoints - 1;
+	while(level_nodes > 1)
+		uint32_t next_level_nodes = level_nodes / ITREE_MAX_NODES;
+		next_level_nodes += ((level_nodes % ITREE_MAX_NODES) > 0);
+		num_nodes += level_nodes;
+		level_nodes = next_level_nodes;
+	/* and the root node */
+	return num_nodes + 1;
+static uint32_t
+itree_num_nodes_polygon(const LWPOLY *poly)
+	for (uint32_t i = 0; i < poly->nrings; i++)
+		const POINTARRAY *pa = poly->rings[i];
+		num_nodes += itree_num_nodes_pointarray(pa);
+	return num_nodes;
+static uint32_t
+itree_num_nodes_multipolygon(const LWMPOLY *mpoly)
+	for (uint32_t i = 0; i < mpoly->ngeoms; i++)
+		const LWPOLY *poly = mpoly->geoms[i];
+		num_nodes += itree_num_nodes_polygon(poly);
+	return num_nodes;
+static uint32_t
+itree_num_rings(const LWMPOLY *mpoly)
+	return lwgeom_count_rings((const LWGEOM*)mpoly);
+static IntervalTreeNode *
+itree_new_node(IntervalTree *itree)
+	IntervalTreeNode *node = NULL;
+	if (itree->numNodes >= itree->maxNodes)
+		lwerror("%s ran out of node space", __func__);
+	node = &(itree->nodes[itree->numNodes++]);
+	node->min = FLT_MAX;
+	node->max = FLT_MIN;
+	node->edgeIndex = UINT32_MAX;
+	node->numChildren = 0;
+	memset(node->children, 0, sizeof(node->children));
+	return node;
+static uint32_t // nodes_remaining for after latest merge, stop at 1
+itree_merge_nodes(IntervalTree *itree, uint32_t nodes_remaining)
+	 * store the starting state of the tree which gives
+	 * us the array of nodes we are going to have to merge
+	uint32_t end_node = itree->numNodes;
+	uint32_t start_node = end_node - nodes_remaining;
+	 * one parent for every ITREE_MAX_NODES children
+	 * plus one for the remainder
+	uint32_t num_parents = nodes_remaining / ITREE_MAX_NODES;
+	num_parents += ((nodes_remaining % ITREE_MAX_NODES) > 0);
+	 * each parent is composed by merging four adjacent children
+	 * this generates a useful index structure in O(n) time
+	 * because the edges are from a ring, and thus are
+	 * spatially autocorrelated, so the pre-sorting step of
+	 * building a packed index is already done for us before we even start
+	for (uint32_t i = 0; i < num_parents; i++)
+		uint32_t children_start = start_node + i * ITREE_MAX_NODES;
+		uint32_t children_end = start_node + (i+1) * ITREE_MAX_NODES;
+		children_end = children_end > end_node ? end_node : children_end;
+		 * put pointers to the children we are merging onto
+		 * the new parent node
+		IntervalTreeNode *parent_node = itree_new_node(itree);
+		for (uint32_t j = children_start; j < children_end; j++)
+			IntervalTreeNode *child_node = &(itree->nodes[j]);
+			parent_node->min = FP_MIN(child_node->min, parent_node->min);
+			parent_node->max = FP_MAX(child_node->max, parent_node->max);
+			parent_node->edgeIndex = FP_MIN(child_node->edgeIndex, parent_node->edgeIndex);
+			parent_node->children[parent_node->numChildren++] = child_node;
+	 * keep going until num_parents gets down to one and
+	 * we are at the root of the tree
+	return num_parents;
+static int
+itree_edge_invalid(const POINT2D *pt1, const POINT2D *pt2)
+	/* zero length */
+	if (pt1->x == pt2->x && pt1->y == pt2->y)
+		return 1;
+	/* nan/inf coordinates */
+	if (isfinite(pt1->x) &&
+	    isfinite(pt1->y) &&
+	    isfinite(pt2->x) &&
+	    isfinite(pt2->y))
+		return 0;
+	return 1;
+static void
+itree_add_pointarray(IntervalTree *itree, const POINTARRAY *pa)
+	uint32_t nodes_remaining = 0;
+	uint32_t leaf_nodes = 0;
+	IntervalTreeNode *root = NULL;
+	/* EMPTY/unusable ring */
+		lwerror("%s called with unusable ring", __func__);
+	/* fill in the leaf nodes */
+	for (uint32_t i = 0; i < pa->npoints-1; i++)
+		const POINT2D *pt1 = getPoint2d_cp(pa, i);
+		const POINT2D *pt2 = getPoint2d_cp(pa, i+1);
+		/* Do not add nodes for zero length segments */
+		if (itree_edge_invalid(pt1, pt2))
+			continue;
+		/* get a fresh node for each segment of the ring */
+		IntervalTreeNode *node = itree_new_node(itree);
+		node->min = FP_MIN(pt1->y, pt2->y);
+		node->max = FP_MAX(pt1->y, pt2->y);
+		node->edgeIndex = i;
+		leaf_nodes++;
+	/* merge leaf nodes up to parents */
+	nodes_remaining = leaf_nodes;
+	while (nodes_remaining > 1)
+		nodes_remaining = itree_merge_nodes(itree, nodes_remaining);
+	/* final parent is the root */
+	if (leaf_nodes > 0)
+		root = &(itree->nodes[itree->numNodes - 1]);
+	else
+		root = NULL;
+	 * take a copy of the point array we built this
+	 * tree on top of so we can reference it to get
+	 * segment information later
+	itree->indexes[itree->numIndexes] = root;
+	itree->indexArrays[itree->numIndexes] = ptarray_clone(pa);
+	itree->numIndexes += 1;
+	return;
+static void
+itree_add_polygon(IntervalTree *itree, const LWPOLY *poly)
+	if (poly->nrings == 0) return;
+	itree->maxNodes = itree_num_nodes_polygon(poly);
+	itree->nodes = lwalloc0(itree->maxNodes * sizeof(IntervalTreeNode));
+	itree->numNodes = 0;
+	itree->ringCounts = lwalloc0(sizeof(uint32_t));
+	itree->indexes = lwalloc0(poly->nrings * sizeof(IntervalTreeNode*));
+	itree->indexArrays = lwalloc0(poly->nrings * sizeof(POINTARRAY*));
+	for (uint32_t j = 0; j < poly->nrings; j++)
+		const POINTARRAY *pa = poly->rings[j];
+		/* skip empty/unclosed/invalid rings */
+			continue;
+		itree_add_pointarray(itree, pa);
+		itree->ringCounts[itree->numPolys] += 1;
+	itree->numPolys = 1;
+	return;
+static void
+itree_add_multipolygon(IntervalTree *itree, const LWMPOLY *mpoly)
+	if (mpoly->ngeoms == 0) return;
+	itree->maxNodes = itree_num_nodes_multipolygon(mpoly);
+	itree->ringCounts = lwalloc0(mpoly->ngeoms * sizeof(uint32_t));
+	itree->indexes = lwalloc0(itree_num_rings(mpoly) * sizeof(IntervalTreeNode*));
+	itree->indexArrays = lwalloc0(itree_num_rings(mpoly) * sizeof(POINTARRAY*));
+		/* skip empty polygons */
+		if (! poly || lwpoly_is_empty(poly))
+			continue;
+				continue;
+		itree->numPolys += 1;
+	return;
+IntervalTree *
+itree_from_lwgeom(const LWGEOM *geom)
+	if (!geom) lwerror("%s called with null geometry", __func__);
+	if (lwgeom_get_type(geom) == MULTIPOLYGONTYPE)
+		IntervalTree *itree = lwalloc0(sizeof(IntervalTree));
+		itree_add_multipolygon(itree, lwgeom_as_lwmpoly(geom));
+		return itree;
+	else if (lwgeom_get_type(geom) == POLYGONTYPE)
+		itree_add_polygon(itree, lwgeom_as_lwpoly(geom));
+		return itree;
+	else
+		lwerror("%s got asked to build index on non-polygon", __func__);
+		return NULL;
+ * The following is based on the "Fast Winding Number Inclusion of a Point
+ * in a Polygon" algorithm by Dan Sunday.
+ * http://softsurfer.com/Archive/algorithm_0103/algorithm_0103.htm#Winding%20Number
+ * returns: >0 for a point to the left of the segment,
+ *          <0 for a point to the right of the segment,
+ *          0 for a point on the segment
+static inline double
+itree_segment_side(const POINT2D *seg1, const POINT2D *seg2, const POINT2D *point)
+	return ((seg2->x - seg1->x) * (point->y - seg1->y) -
+		    (point->x - seg1->x) * (seg2->y - seg1->y));
+ * This function doesn't test that the point falls on the line defined by
+ * the two points.  It assumes that that has already been determined
+ * by having itree_segment_side return within the tolerance.  It simply checks
+ * that if the point is on the line, it is within the endpoints.
+ * returns: 1 if the point is inside the segment bounds
+ *          0 if the point is outside the segment bounds
+static int
+itree_point_on_segment(const POINT2D *seg1, const POINT2D *seg2, const POINT2D *point)
+	double maxX = FP_MAX(seg1->x, seg2->x);
+	double maxY = FP_MAX(seg1->y, seg2->y);
+	double minX = FP_MIN(seg1->x, seg2->x);
+	double minY = FP_MIN(seg1->y, seg2->y);
+	return point->x >= minX && point->x <= maxX &&
+	       point->y >= minY && point->y <= maxY;
+static IntervalTreeResult
+itree_point_in_ring_recursive(
+	const IntervalTreeNode *node,
+	const POINTARRAY *pa,
+	const POINT2D *pt,
+	int *winding_number)
+	if (!node) return ITREE_OUTSIDE;
+	 * If Y value is not within range of node, we can
+	 * learn nothing from this node or its children, so
+	 * we exit early.
+	uint8_t node_contains_value = FP_CONTAINS_INCL(node->min, pt->y, node->max) ? 1 : 0;
+	if (!node_contains_value)
+		return ITREE_OK;
+	/* This is a leaf node, so evaluate winding number */
+	if (node->numChildren == 0)
+		const POINT2D *seg1 = getPoint2d_cp(pa, node->edgeIndex);
+		const POINT2D *seg2 = getPoint2d_cp(pa, node->edgeIndex + 1);
+		double side = itree_segment_side(seg1, seg2, pt);
+		/* Zero length segments are ignored. */
+		// xxxx need a unit test, what about really really short segments?
+		// if (distance2d_sqr_pt_pt(seg1, seg2) < FP_EPS*FP_EPS)
+		// 	return ITREE_OK;
+		/* A point on the boundary of a ring is not contained. */
+		/* WAS: if (fabs(side) < 1e-12), see ticket #852 */
+		if (side == 0.0 && itree_point_on_segment(seg1, seg2, pt) == 1)
+			return ITREE_BOUNDARY;
+		 * If the point is to the left of the line, and it's rising,
+		 * then the line is to the right of the point and
+		 * circling counter-clockwise, so increment.
+		if ((seg1->y <= pt->y) && (pt->y < seg2->y) && (side > 0))
+			*winding_number = *winding_number + 1;
+		 * If the point is to the right of the line, and it's falling,
+		 * then the line is to the right of the point and circling
+		 * clockwise, so decrement.
+		else if ((seg2->y <= pt->y) && (pt->y < seg1->y) && (side < 0))
+			*winding_number = *winding_number - 1;
+		return ITREE_OK;
+	/* This is an interior node, so recurse downwards */
+	else
+		for (uint32_t i = 0; i < node->numChildren; i++)
+			IntervalTreeResult rslt = itree_point_in_ring_recursive(node->children[i], pa, pt, winding_number);
+			/* Short circuit and send back boundary result */
+			if (rslt == ITREE_BOUNDARY)
+				return rslt;
+	return ITREE_OK;
+itree_point_in_ring(const IntervalTree *itree, uint32_t ringNumber, const POINT2D *pt)
+	int winding_number = 0;
+	const IntervalTreeNode *node = itree->indexes[ringNumber];
+	const POINTARRAY *pa = itree->indexArrays[ringNumber];
+	IntervalTreeResult rslt = itree_point_in_ring_recursive(node, pa, pt, &winding_number);
+	/* Boundary case is separate from winding number */
+	if (rslt == ITREE_BOUNDARY) return rslt;
+	/* Not boundary, so evaluate winding number */
+	if (winding_number == 0)
+		return ITREE_OUTSIDE;
+	else
+		return ITREE_INSIDE;
+ * Test if the given point falls within the given multipolygon.
+ * Assume bbox short-circuit has already been attempted.
+ * First check if point is within any of the outer rings.
+ * If not, it is outside. If so, check if the point is
+ * within the relevant inner rings. If not, it is inside.
+IntervalTreeResult
+itree_point_in_multipolygon(const IntervalTree *itree, const LWPOINT *point)
+	uint32_t i = 0;
+	const POINT2D *pt;
+	IntervalTreeResult result = ITREE_OUTSIDE;
+	/* Empty is not within anything */
+	if (lwpoint_is_empty(point))
+	/* Non-finite point is within anything */
+	pt = getPoint2d_cp(point->point, 0);
+	if (!pt || !(isfinite(pt->x) && isfinite(pt->y)))
+	/* Is the point inside any of the exterior rings of the sub-polygons? */
+	for (uint32_t p = 0; p < itree->numPolys; p++)
+		uint32_t ringCount = itree->ringCounts[p];
+		/* Skip empty polygons */
+		if (ringCount == 0) continue;
+		/* Check result against exterior ring. */
+		result = itree_point_in_ring(itree, i, pt);
+		/* Boundary condition is a hard stop */
+		if (result == ITREE_BOUNDARY)
+		/* We are inside an exterior ring! Are we outside all the holes? */
+		if (result == ITREE_INSIDE)
+			for(uint32_t r = 1; r < itree->ringCounts[p]; r++)
+				result = itree_point_in_ring(itree, i+r, pt);
+				 * Inside a hole => Outside the polygon!
+				 * But there might be other polygons lurking
+				 * inside this hole so we have to continue
+				 * and check all the exterior rings.
+					goto holes_done;
+		holes_done:
+			/* Move to first ring of next polygon */
+			i += ringCount;
+	/* Not in any rings */
diff --git a/liblwgeom/intervaltree.h b/liblwgeom/intervaltree.h
index 000000000..e2b08337b
--- /dev/null
+++ b/liblwgeom/intervaltree.h
@@ -0,0 +1,76 @@
+#pragma once
+#include "liblwgeom_internal.h"
+#define ITREE_MAX_NODES 4
+typedef enum
+	ITREE_INSIDE = 1,
+	ITREE_BOUNDARY = 0, /* any boundary case stops calculations */
+	ITREE_OUTSIDE = -1,
+	ITREE_OK = 2        /* calculations may continue */
+} IntervalTreeResult;
+typedef struct IntervalTreeNode
+	double min;
+	double max;
+	struct IntervalTreeNode *children[ITREE_MAX_NODES];
+	uint32_t edgeIndex;
+	uint32_t numChildren;
+} IntervalTreeNode;
+ * A multi-polygon is converted into an interval tree for
+ * searching, with one indexed ring in the index for each
+ * (non-empty, non-degenerate) ring in the input.
+ * The indexes are arranged in order they are read off
+ * the multipolygon, so (P0R0, P0R1, P1R0, P1R1) etc.
+ * The ringCounts allow hopping to the exterior rings.
+	struct IntervalTreeNode *nodes;    /* store nodes here in flat array */
+	struct IntervalTreeNode **indexes; /* store pointers to index root nodes here */
+	POINTARRAY **indexArrays;          /* store original ring data here */
+	uint32_t numIndexes;               /* utilization of the indexes/indexArrays */
+	uint32_t *ringCounts;              /* number of rings in each polygon */
+	uint32_t numPolys;                 /* number of polygons */
+	uint32_t numNodes;                 /* utilization of the nodes array */
+	uint32_t maxNodes;                 /* capacity of the nodes array */
+} IntervalTree;
+ * Public prototypes
+IntervalTree *itree_from_lwgeom(const LWGEOM *geom);
+void itree_free(IntervalTree *itree);
+IntervalTreeResult itree_point_in_multipolygon(const IntervalTree *itree, const LWPOINT *point);
diff --git a/liblwgeom/liblwgeom_internal.h b/liblwgeom/liblwgeom_internal.h
index a0f76162f..178607155 100644
--- a/liblwgeom/liblwgeom_internal.h
+++ b/liblwgeom/liblwgeom_internal.h
@@ -489,5 +489,6 @@ int gbox_contains_point2d(const GBOX *g, const POINT2D *p);
 int lwpoly_contains_point(const LWPOLY *poly, const POINT2D *pt);
 POINT4D* lwmpoint_extract_points_4d(const LWMPOINT* g, uint32_t* npoints, int* input_empty);
 char* lwstrdup(const char* a);
+void* lwalloc0(size_t sz);
 #endif /* _LIBLWGEOM_INTERNAL_H */
diff --git a/liblwgeom/lwutil.c b/liblwgeom/lwutil.c
index 5f63acfa8..b14bb23f2 100644
--- a/liblwgeom/lwutil.c
+++ b/liblwgeom/lwutil.c
@@ -227,14 +227,20 @@ void *
 lwalloc(size_t size)
 	void *mem = lwalloc_var(size);
-	LWDEBUGF(5, "lwalloc: %d@%p", size, mem);
+	return mem;
+void *
+lwalloc0(size_t size)
+	void *mem = lwalloc_var(size);
+	memset(mem, 0, size);
 	return mem;
 void *
 lwrealloc(void *mem, size_t size)
-	LWDEBUGF(5, "lwrealloc: %d@%p", size, mem);
 	return lwrealloc_var(mem, size);
diff --git a/liblwgeom/ptarray.c b/liblwgeom/ptarray.c
index 2581a1f17..86454313c 100644
--- a/liblwgeom/ptarray.c
+++ b/liblwgeom/ptarray.c
@@ -746,8 +746,10 @@ ptarray_is_closed_z(const POINTARRAY *in)
-* Return 1 if the point is inside the POINTARRAY, -1 if it is outside,
-* and 0 if it is on the boundary.
+* Return LW_INSIDE if the point is inside the POINTARRAY,
+* LW_OUTSIDE if it is outside, and LW_BOUNDARY if it is on
+* the boundary.
+* LW_INSIDE == 1, LW_BOUNDARY == 0, LW_OUTSIDE == -1
 int
 ptarray_contains_point(const POINTARRAY *pa, const POINT2D *pt)
@@ -755,6 +757,12 @@ ptarray_contains_point(const POINTARRAY *pa, const POINT2D *pt)
 	return ptarray_contains_point_partial(pa, pt, LW_TRUE, NULL);
 int
 ptarray_contains_point_partial(const POINTARRAY *pa, const POINT2D *pt, int check_closed, int *winding_number)
diff --git a/libpgcommon/lwgeom_cache.c b/libpgcommon/lwgeom_cache.c
index 7e013895d..95b591504 100644
--- a/libpgcommon/lwgeom_cache.c
+++ b/libpgcommon/lwgeom_cache.c
@@ -34,7 +34,7 @@
 * the following kinds of objects:
 *   geometries-with-trees
-*      PreparedGeometry, RTree, CIRC_TREE, RECT_TREE
+*      PreparedGeometry, IntervalTree, CIRC_TREE, RECT_TREE
 * Each GenericCache* has a type, and after that
 * some data. Similar to generic LWGEOM*. Test that
diff --git a/libpgcommon/lwgeom_cache.h b/libpgcommon/lwgeom_cache.h
index bbf3e7e18..a40512829 100644
--- a/libpgcommon/lwgeom_cache.h
+++ b/libpgcommon/lwgeom_cache.h
@@ -10,8 +10,7 @@
-#ifndef LWGEOM_CACHE_H_
-#define LWGEOM_CACHE_H_ 1
+#pragma once
 #include "postgres.h"
 #include "fmgr.h"
@@ -20,17 +19,19 @@
 #include "lwgeom_pg.h"
-#define TOAST_CACHE_ENTRY 0
-#define PREP_CACHE_ENTRY 1
-#define RTREE_CACHE_ENTRY 2
-#define CIRC_CACHE_ENTRY 3
-#define RECT_CACHE_ENTRY 4
-#define SRSDESC_CACHE_ENTRY 5
-#define SRID_CACHE_ENTRY 6
+enum CacheEntryEnum {
+	TOAST_CACHE_ENTRY   = 0,
+	PREP_CACHE_ENTRY    = 1,
+	ITREE_CACHE_ENTRY   = 2,
+	CIRC_CACHE_ENTRY    = 3,
+	RECT_CACHE_ENTRY    = 4,
+	SRSDESC_CACHE_ENTRY = 5,
+	SRID_CACHE_ENTRY    = 6
 #define NUM_CACHE_ENTRIES 7
 /* Returns the MemoryContext used to store the caches */
 MemoryContext PostgisCacheContext(FunctionCallInfo fcinfo);
@@ -61,7 +62,7 @@ typedef struct {
 * Other specific geometry cache types are the
-* RTreeGeomCache - lwgeom_rtree.h
+* IntervalTreeGeomCache - lwgeom_itree.h
 * PrepGeomCache - lwgeom_geos_prepared.h
@@ -135,4 +136,3 @@ typedef struct {
 int32_t GetSRIDCacheBySRS(FunctionCallInfo fcinfo, const char *srs);
-#endif /* LWGEOM_CACHE_H_ */
diff --git a/postgis/Makefile.in b/postgis/Makefile.in
index 0e972da7e..c5b448b13 100644
--- a/postgis/Makefile.in
+++ b/postgis/Makefile.in
@@ -44,9 +44,6 @@ SQL_OBJS = \
 	legacy.sql \
 	legacy_minimal.sql
-GEOM_BACKEND_OBJ = lwgeom_geos.o
-BACKEND_OBJ=$(GEOM_BACKEND_OBJ)
 DATA_built=$(SQL_built)
 ifeq (@HAVE_SPGIST@,yes)
@@ -80,12 +77,12 @@ PG_OBJS= \
 	lwgeom_spheroid.o \
 	lwgeom_ogc.o \
 	lwgeom_functions_analytic.o \
-	lwgeom_inout.o \
 	lwgeom_functions_basic.o \
+	lwgeom_inout.o \
 	lwgeom_btree.o \
 	lwgeom_box.o \
 	lwgeom_box3d.o \
-	$(BACKEND_OBJ) \
+	lwgeom_geos.o \
 	lwgeom_geos_prepared.o \
 	lwgeom_geos_clean.o \
 	lwgeom_geos_relatematch.o \
@@ -104,9 +101,9 @@ PG_OBJS= \
 	lwgeom_functions_lrs.o \
 	lwgeom_functions_temporal.o \
 	lwgeom_rectree.o \
+	lwgeom_itree.o \
 	long_xact.o \
 	lwgeom_sqlmm.o \
-	lwgeom_rtree.o \
 	lwgeom_transform.o \
 	lwgeom_window.o \
 	gserialized_typmod.o \
diff --git a/postgis/lwgeom_functions_analytic.c b/postgis/lwgeom_functions_analytic.c
index e1f94b6c9..abcc222c6 100644
--- a/postgis/lwgeom_functions_analytic.c
+++ b/postgis/lwgeom_functions_analytic.c
@@ -30,8 +30,7 @@
 #include "liblwgeom_internal.h"  /* For FP comparators. */
 #include "math.h"
-#include "lwgeom_rtree.h"
-#include "lwgeom_functions_analytic.h"
+#include "lwgeom_itree.h"
 #include "access/htup_details.h"
@@ -47,85 +46,6 @@ Datum ST_IsPolygonCCW(PG_FUNCTION_ARGS);
 Datum ST_IsPolygonCW(PG_FUNCTION_ARGS);
- * return -1 iff point is outside ring pts
- * return 1 iff point is inside ring pts
- * return 0 iff point is on ring pts
-static int point_in_ring(POINTARRAY *pts, const POINT2D *point)
-	int wn = 0;
-	uint32_t i;
-	double side;
-	const POINT2D* seg1;
-	const POINT2D* seg2;
-	POSTGIS_DEBUG(2, "point_in_ring called.");
-	seg2 = getPoint2d_cp(pts, 0);
-	for (i=0; i<pts->npoints-1; i++)
-		seg1 = seg2;
-		seg2 = getPoint2d_cp(pts, i+1);
-		side = determineSide(seg1, seg2, point);
-		POSTGIS_DEBUGF(3, "segment: (%.8f, %.8f),(%.8f, %.8f)", seg1->x, seg1->y, seg2->x, seg2->y);
-		POSTGIS_DEBUGF(3, "side result: %.8f", side);
-		POSTGIS_DEBUGF(3, "counterclockwise wrap %d, clockwise wrap %d", FP_CONTAINS_BOTTOM(seg1->y, point->y, seg2->y), FP_CONTAINS_BOTTOM(seg2->y, point->y, seg1->y));
-		/* zero length segments are ignored. */
-		if ((seg2->x == seg1->x) && (seg2->y == seg1->y))
-			POSTGIS_DEBUG(3, "segment is zero length... ignoring.");
-			continue;
-		/* a point on the boundary of a ring is not contained. */
-		/* WAS: if (fabs(side) < 1e-12), see #852 */
-		if (side == 0.0)
-			if (isOnSegment(seg1, seg2, point) == 1)
-				POSTGIS_DEBUGF(3, "point on ring boundary between points %d, %d", i, i+1);
-				return 0;
-		 * If the point is to the left of the line, and it's rising,
-		 * then the line is to the right of the point and
-		 * circling counter-clockwise, so increment.
-		if ((seg1->y <= point->y) && (point->y < seg2->y) && (side > 0))
-			POSTGIS_DEBUG(3, "incrementing winding number.");
-			++wn;
-		 * If the point is to the right of the line, and it's falling,
-		 * then the line is to the right of the point and circling
-		 * clockwise, so decrement.
-		else if ((seg2->y <= point->y) && (point->y < seg1->y) && (side < 0))
-			POSTGIS_DEBUG(3, "decrementing winding number.");
-			--wn;
-	POSTGIS_DEBUGF(3, "winding number %d", wn);
-	if (wn == 0)
-		return -1;
-	return 1;
  * Simple Douglas-Peucker line simplification.
  * No checks are done to avoid introduction of self-intersections.
@@ -731,191 +651,6 @@ Datum LWGEOM_line_substring(PG_FUNCTION_ARGS)
- * The following is based on the "Fast Winding Number Inclusion of a Point
- * in a Polygon" algorithm by Dan Sunday.
- * http://softsurfer.com/Archive/algorithm_0103/algorithm_0103.htm#Winding%20Number
- * returns: >0 for a point to the left of the segment,
- *          <0 for a point to the right of the segment,
- *          0 for a point on the segment
-double determineSide(const POINT2D *seg1, const POINT2D *seg2, const POINT2D *point)
-	return ((seg2->x-seg1->x)*(point->y-seg1->y)-(point->x-seg1->x)*(seg2->y-seg1->y));
- * This function doesn't test that the point falls on the line defined by
- * the two points.  It assumes that that has already been determined
- * by having determineSide return within the tolerance.  It simply checks
- * that if the point is on the line, it is within the endpoints.
- * returns: 1 if the point is not outside the bounds of the segment
- *          0 if it is
-int isOnSegment(const POINT2D *seg1, const POINT2D *seg2, const POINT2D *point)
-	double maxX;
-	double maxY;
-	double minX;
-	double minY;
-	if (seg1->x > seg2->x)
-		maxX = seg1->x;
-		minX = seg2->x;
-	else
-		maxX = seg2->x;
-		minX = seg1->x;
-	if (seg1->y > seg2->y)
-		maxY = seg1->y;
-		minY = seg2->y;
-	else
-		maxY = seg2->y;
-		minY = seg1->y;
-	POSTGIS_DEBUGF(3, "maxX minX/maxY minY: %.8f %.8f/%.8f %.8f", maxX, minX, maxY, minY);
-	if (maxX < point->x || minX > point->x)
-		POSTGIS_DEBUGF(3, "X value %.8f falls outside the range %.8f-%.8f", point->x, minX, maxX);
-		return 0;
-	else if (maxY < point->y || minY > point->y)
-		POSTGIS_DEBUGF(3, "Y value %.8f falls outside the range %.8f-%.8f", point->y, minY, maxY);
-		return 0;
-	return 1;
- * return -1 iff point outside polygon
- * return 0 iff point on boundary
- * return 1 iff point inside polygon
-int point_in_polygon(LWPOLY *polygon, LWPOINT *point)
-	uint32_t i;
-	int result, in_ring;
-	POINT2D pt;
-	POSTGIS_DEBUG(2, "point_in_polygon called.");
-	getPoint2d_p(point->point, 0, &pt);
-	/* assume bbox short-circuit has already been attempted */
-	/* everything is outside of an empty polygon */
-	if ( polygon->nrings == 0 ) return -1;
-	in_ring = point_in_ring(polygon->rings[0], &pt);
-	if ( in_ring == -1) /* outside the exterior ring */
-		POSTGIS_DEBUG(3, "point_in_polygon: outside exterior ring.");
-		return -1;
-	result = in_ring;
-	for (i=1; i<polygon->nrings; i++)
-		in_ring = point_in_ring(polygon->rings[i], &pt);
-		if (in_ring == 1) /* inside a hole => outside the polygon */
-			POSTGIS_DEBUGF(3, "point_in_polygon: within hole %d.", i);
-			return -1;
-		if (in_ring == 0) /* on the edge of a hole */
-			POSTGIS_DEBUGF(3, "point_in_polygon: on edge of hole %d.", i);
-			return 0;
-	return result; /* -1 = outside, 0 = boundary, 1 = inside */
- * return -1 iff point outside multipolygon
- * return 0 iff point on multipolygon boundary
- * return 1 iff point inside multipolygon
-int point_in_multipolygon(LWMPOLY *mpolygon, LWPOINT *point)
-	uint32_t i, j;
-	POINT2D pt;
-	/* empty is not within anything */
-	if (lwpoint_is_empty(point)) return -1;
-	result = -1;
-	for (j = 0; j < mpolygon->ngeoms; j++ )
-		LWPOLY *polygon = mpolygon->geoms[j];
-		if ( polygon->nrings == 0 ) continue;
-			continue;
-		if ( in_ring == 0 )
-			return 0;
-		result = in_ring;
-				result = -1;
-				break;
-				return 0;
-		if ( result != -1)
-			return result;
-	return result;
- * End of "Fast Winding Number Inclusion of a Point in a Polygon" derivative.
diff --git a/postgis/lwgeom_geos.c b/postgis/lwgeom_geos.c
index 192d395a5..16ae6dd3d 100644
--- a/postgis/lwgeom_geos.c
+++ b/postgis/lwgeom_geos.c
@@ -37,11 +37,10 @@
 /* PostGIS */
-#include "lwgeom_functions_analytic.h" /* for point_in_polygon */
 #include "lwgeom_geos.h"
 #include "liblwgeom.h"
 #include "lwgeom_geos_prepared.h"
 #include "lwgeom_accum.h"
@@ -1784,7 +1783,7 @@ Datum overlaps(PG_FUNCTION_ARGS)
 	 * geom1 bounding box we can return FALSE.
 	if ( gserialized_get_gbox_p(geom1, &box1) &&
-	        gserialized_get_gbox_p(geom2, &box2) )
+	     gserialized_get_gbox_p(geom2, &box2) )
 		if ( ! gbox_overlaps_2d(&box1, &box2) )
@@ -1836,7 +1835,7 @@ Datum contains(PG_FUNCTION_ARGS)
 	if (gserialized_is_empty(geom1) || gserialized_is_empty(geom2))
 		PG_RETURN_BOOL(false);
-	POSTGIS_DEBUG(3, "contains called.");
+	POSTGIS_DEBUGF(3, "Contains: type1: %d, type2: %d", gserialized_get_type(geom1), gserialized_get_type(geom2));
 	** short-circuit 1: if geom2 bounding box is not completely inside
@@ -1855,64 +1854,12 @@ Datum contains(PG_FUNCTION_ARGS)
 	if (is_poly(geom1) && is_point(geom2))
-		SHARED_GSERIALIZED *shared_gpoly = is_poly(geom1) ? shared_geom1 : shared_geom2;
-		SHARED_GSERIALIZED *shared_gpoint = is_point(geom1) ? shared_geom1 : shared_geom2;
-		const GSERIALIZED *gpoly = shared_gserialized_get(shared_gpoly);
-		const GSERIALIZED *gpoint = shared_gserialized_get(shared_gpoint);
-		RTREE_POLY_CACHE *cache = GetRtreeCache(fcinfo, shared_gpoly);
-		int retval;
-		POSTGIS_DEBUG(3, "Point in Polygon test requested...short-circuiting.");
-		if (gserialized_get_type(gpoint) == POINTTYPE)
-			LWGEOM* point = lwgeom_from_gserialized(gpoint);
-			int pip_result = pip_short_circuit(cache, lwgeom_as_lwpoint(point), gpoly);
-			lwgeom_free(point);
-			retval = (pip_result == 1); /* completely inside */
-		else if (gserialized_get_type(gpoint) == MULTIPOINTTYPE)
-			LWMPOINT* mpoint = lwgeom_as_lwmpoint(lwgeom_from_gserialized(gpoint));
-			int found_completely_inside = LW_FALSE;
-			retval = LW_TRUE;
-			for (uint32_t i = 0; i < mpoint->ngeoms; i++)
-				int pip_result;
-				LWPOINT* pt = mpoint->geoms[i];
-				/* We need to find at least one point that's completely inside the
-				 * polygons (pip_result == 1).  As long as we have one point that's
-				 * completely inside, we can have as many as we want on the boundary
-				 * itself. (pip_result == 0)
-				if (lwpoint_is_empty(pt)) continue;
-				pip_result = pip_short_circuit(cache, pt, gpoly);
-				if (pip_result == 1)
-					found_completely_inside = LW_TRUE;
-				if (pip_result == -1) /* completely outside */
-					retval = LW_FALSE;
-					break;
-			retval = retval && found_completely_inside;
-			lwmpoint_free(mpoint);
-		else
-			/* Never get here */
-			elog(ERROR,"Type isn't point or multipoint!");
-			PG_RETURN_BOOL(false);
-		return retval > 0;
-	else
-		POSTGIS_DEBUGF(3, "Contains: type1: %d, type2: %d", gserialized_get_type(geom1), gserialized_get_type(geom2));
+		const GSERIALIZED *gpoint = shared_gserialized_get(shared_geom2);
+		LWGEOM *lwpt = lwgeom_from_gserialized(gpoint);
+		IntervalTree *itree = GetIntervalTree(fcinfo, shared_geom1);
+		bool result = itree_pip_contains(itree, lwpt);
+		lwgeom_free(lwpt);
+		PG_RETURN_BOOL(result);
 	initGEOS(lwpgnotice, lwgeom_geos_error);
@@ -1982,7 +1929,7 @@ Datum containsproperly(PG_FUNCTION_ARGS)
 		if ( ! gbox_contains_2d(&box1, &box2) )
@@ -2037,6 +1984,7 @@ Datum covers(PG_FUNCTION_ARGS)
 	GBOX box1, box2;
 	PrepGeomCache *prep_cache;
+	POSTGIS_DEBUGF(3, "Covers: type1: %d, type2: %d", gserialized_get_type(geom1), gserialized_get_type(geom2));
 	/* A.Covers(Empty) == FALSE */
 	if ( gserialized_is_empty(geom1) || gserialized_is_empty(geom2) )
@@ -2049,7 +1997,7 @@ Datum covers(PG_FUNCTION_ARGS)
@@ -2062,53 +2010,12 @@ Datum covers(PG_FUNCTION_ARGS)
-		int retval;
-			retval = (pip_result != -1); /* not outside */
-			uint32_t i;
-			retval = LW_TRUE;
-			for (i = 0; i < mpoint->ngeoms; i++)
-				LWPOINT *pt = mpoint->geoms[i];
-				if (pip_short_circuit(cache, pt, gpoly) == -1)
-					break;
-		else
-			PG_RETURN_NULL();
-		PG_RETURN_BOOL(retval);
-	else
-		POSTGIS_DEBUGF(3, "Covers: type1: %d, type2: %d", gserialized_get_type(geom1), gserialized_get_type(geom2));
+		bool result = itree_pip_covers(itree, lwpt);
@@ -2171,6 +2078,8 @@ Datum coveredby(PG_FUNCTION_ARGS)
 	gserialized_error_if_srid_mismatch(geom1, geom2, __func__);
+	POSTGIS_DEBUGF(3, "CoveredBy: type1: %d, type2: %d", gserialized_get_type(geom1), gserialized_get_type(geom2));
 	/* A.CoveredBy(Empty) == FALSE */
@@ -2180,7 +2089,7 @@ Datum coveredby(PG_FUNCTION_ARGS)
 	 * geom2 bounding box we can return FALSE.
 		if ( ! gbox_contains_2d(&box2, &box1) )
@@ -2195,53 +2104,12 @@ Datum coveredby(PG_FUNCTION_ARGS)
 	if (is_point(geom1) && is_poly(geom2))
-		int retval;
-			uint32_t i;
-			retval = LW_TRUE;
-					break;
-		else
-			PG_RETURN_NULL();
-	else
-		POSTGIS_DEBUGF(3, "CoveredBy: type1: %d, type2: %d", gserialized_get_type(geom1), gserialized_get_type(geom2));
+		const GSERIALIZED *gpoint = shared_gserialized_get(shared_geom1);
+		IntervalTree *itree = GetIntervalTree(fcinfo, shared_geom2);
@@ -2291,7 +2159,7 @@ Datum crosses(PG_FUNCTION_ARGS)
 		if ( gbox_overlaps_2d(&box1, &box2) == LW_FALSE )
@@ -2347,7 +2215,7 @@ Datum ST_Intersects(PG_FUNCTION_ARGS)
@@ -2355,51 +2223,19 @@ Datum ST_Intersects(PG_FUNCTION_ARGS)
 	 * short-circuit 2: if the geoms are a point and a polygon,
-	 * call the point_outside_polygon function.
+	 * call the itree_pip_intersects function.
-	if ((is_point(geom1) && is_poly(geom2)) || (is_poly(geom1) && is_point(geom2)))
+	if ((is_point(geom1) && is_poly(geom2)) ||
+	    (is_point(geom2) && is_poly(geom1)))
-		int retval;
-				if (pip_short_circuit(cache, pt, gpoly) != -1) /* not outside */
-					retval = LW_TRUE;
-					break;
-		else
-			PG_RETURN_NULL();
+		IntervalTree *itree = GetIntervalTree(fcinfo, shared_gpoly);
+		bool result = itree_pip_intersects(itree, lwpt);
@@ -2468,7 +2304,7 @@ Datum touches(PG_FUNCTION_ARGS)
@@ -2525,7 +2361,7 @@ Datum disjoint(PG_FUNCTION_ARGS)
 	 * geom1 bounding box we can return TRUE.
diff --git a/postgis/lwgeom_geos_prepared.h b/postgis/lwgeom_geos_prepared.h
index 5f3417bf2..e945d95c5 100644
--- a/postgis/lwgeom_geos_prepared.h
+++ b/postgis/lwgeom_geos_prepared.h
@@ -22,9 +22,7 @@
-#ifndef LWGEOM_GEOS_PREPARED_H_
-#define LWGEOM_GEOS_PREPARED_H_ 1
+#pragma once
 #include "fmgr.h"
@@ -39,20 +37,16 @@
 #include "lwgeom_cache.h"
-* Cache structure. We use GSERIALIZED as keys so no transformations
-* are needed before we memcmp them with other keys. We store the
-* size to avoid having to calculate the size every time.
-* The argnum gives the number of function arguments we are caching.
-* Intersects requires that both arguments be checked for cacheability,
-* while Contains only requires that the containing argument be checked.
-* Both the Geometry and the PreparedGeometry have to be cached,
-* because the PreparedGeometry contains a reference to the geometry.
-* Note that the first 6 entries are part of the common GeomCache
-* structure and have to remain in order to allow the overall caching
-* system to share code (the cache checking code is common between
-* prepared geometry, circtrees, recttrees, and rtrees).
+ * Cache structure. The common components used across all
+ * caches are in the GeomCache. That contains SHARED_GSERIALIZED
+ * and the argnum that indicates which argument we are caching
+ * prepared geometry for.
+ * The argnum gives the number of function arguments we are caching.
+ * Intersects requires that both arguments be checked for cacheability,
+ * while Contains only requires that the containing argument be checked.
+ * Both the Geometry and the PreparedGeometry have to be cached,
+ * because the PreparedGeometry contains a reference to the geometry.
 typedef struct {
 	GeomCache                   gcache;
 	MemoryContext               context_statement;
@@ -63,13 +57,12 @@ typedef struct {
-** Get the current cache, given the input geometries.
-** Function will create cache if none exists, and prepare geometries in
-** cache if necessary, or pull an existing cache if possible.
-** If you are only caching one argument (e.g., in contains) supply 0 as the
-** value for pg_geom2.
+ * Get the current cache, given the input geometries.
+ * Function will create cache if none exists, and prepare geometries in
+ * cache if necessary, or pull an existing cache if possible.
+ * If you are only caching one argument (e.g., in contains) supply 0 as the
+ * value for pg_geom2.
 PrepGeomCache *GetPrepGeomCache(FunctionCallInfo fcinfo, SHARED_GSERIALIZED *pg_geom1, SHARED_GSERIALIZED *pg_geom2);
-#endif /* LWGEOM_GEOS_PREPARED_H_ */
diff --git a/postgis/lwgeom_itree.c b/postgis/lwgeom_itree.c
index 000000000..046f61fee
--- /dev/null
+++ b/postgis/lwgeom_itree.c
@@ -0,0 +1,292 @@
+ * Copyright (C) 2024 Paul Ramsey <pramsey at cleverelephant.ca>
+/* PostgreSQL */
+#include "postgres.h"
+#include "funcapi.h"
+#include "fmgr.h"
+/* Liblwgeom */
+#include "liblwgeom.h"
+#include "liblwgeom_internal.h"  /* For FP comparators. */
+/* PostGIS */
+#include "lwgeom_pg.h"
+#include "lwgeom_cache.h"
+/* Prototypes */
+Datum ST_IntersectsIntervalTree(PG_FUNCTION_ARGS);
+* IntervalTree Caching support
+ * Specific cache types include all the generic GeomCache slots and
+ * their own slots for their index trees. .
+typedef struct {
+	GeomCache           gcache;
+	IntervalTree        *itree;
+} IntervalTreeGeomCache;
+* Builder, freeer and public accessor for cached IntervalTrees
+static int
+IntervalTreeBuilder(const LWGEOM *lwgeom, GeomCache *geomcache)
+	IntervalTreeGeomCache *cache = (IntervalTreeGeomCache*)geomcache;
+	IntervalTree *itree = itree_from_lwgeom(lwgeom);
+	if (cache->itree)
+		itree_free(cache->itree);
+		cache->itree = 0;
+	if (!itree)
+		return LW_FAILURE;
+	cache->itree = itree;
+	return LW_SUCCESS;
+static int
+IntervalTreeFreer(GeomCache *geomcache)
+	if (cache->itree)
+		cache->itree = 0;
+		cache->gcache.argnum = 0;
+static GeomCache *
+IntervalTreeAllocator(void)
+	IntervalTreeGeomCache *cache = palloc(sizeof(IntervalTreeGeomCache));
+	memset(cache, 0, sizeof(IntervalTreeGeomCache));
+	return (GeomCache*)cache;
+static GeomCacheMethods IntervalTreeCacheMethods =
+	ITREE_CACHE_ENTRY,
+	IntervalTreeBuilder,
+	IntervalTreeFreer,
+	IntervalTreeAllocator
+ * Always return an IntervalTree, even if we don't have one
+ * cached already so that the caller can use it to do a
+ * index assisted p-i-p every time.
+IntervalTree *
+GetIntervalTree(FunctionCallInfo fcinfo, SHARED_GSERIALIZED *g1)
+	const GSERIALIZED *poly1;
+	LWGEOM *lwpoly1;
+	IntervalTree *itree = NULL;
+	IntervalTreeGeomCache *cache = (IntervalTreeGeomCache*)GetGeomCache(fcinfo, &IntervalTreeCacheMethods, g1, NULL);
+	/* Found a cached tree */
+	if (cache && cache->itree)
+		return cache->itree;
+	/* Build one on the fly */
+	poly1 = shared_gserialized_get(g1);
+	lwpoly1 = lwgeom_from_gserialized(poly1);
+	itree = itree_from_lwgeom(lwpoly1);
+	lwgeom_free(lwpoly1);
+	return itree;
+ * A point must be fully inside (not on boundary) of
+ * a polygon to be contained. A multipoint must have
+ * at least one fully contained member and no members
+ * outside the polygon to be contained.
+bool itree_pip_contains(const IntervalTree *itree, const LWGEOM *lwpoints)
+	if (lwgeom_get_type(lwpoints) == POINTTYPE)
+		return itree_point_in_multipolygon(itree, lwgeom_as_lwpoint(lwpoints)) == ITREE_INSIDE;
+	else if (lwgeom_get_type(lwpoints) == MULTIPOINTTYPE)
+		bool found_completely_inside = false;
+		LWMPOINT *mpoint = lwgeom_as_lwmpoint(lwpoints);
+		for (uint32_t i = 0; i < mpoint->ngeoms; i++)
+			IntervalTreeResult pip_result;
+			const LWPOINT* pt = mpoint->geoms[i];
+			if (lwpoint_is_empty(pt))
+				continue;
+			 * We need to find at least one point that's completely inside the
+			 * polygons (pip_result == 1).  As long as we have one point that's
+			 * completely inside, we can have as many as we want on the boundary
+			 * itself. (pip_result == 0)
+			pip_result = itree_point_in_multipolygon(itree, pt);
+			if (pip_result == ITREE_INSIDE)
+				found_completely_inside = true;
+			if (pip_result == ITREE_OUTSIDE)
+				return false;
+		return found_completely_inside;
+	else
+		elog(ERROR, "%s got a non-point input", __func__);
+		return false;
+ * If any point in the point/multipoint is outside
+ * the polygon, then the polygon does not cover the point/multipoint.
+bool itree_pip_covers(const IntervalTree *itree, const LWGEOM *lwpoints)
+		return itree_point_in_multipolygon(itree, lwgeom_as_lwpoint(lwpoints)) != ITREE_OUTSIDE;
+		LWMPOINT* mpoint = lwgeom_as_lwmpoint(lwpoints);
+			const LWPOINT *pt = mpoint->geoms[i];
+				continue;
+			if (itree_point_in_multipolygon(itree, pt) == ITREE_OUTSIDE)
+				return false;
+		return true;
+	else
+		return false;
+ * A.intersects(B) implies if any member of the point/multipoint
+ * is not outside, then they intersect.
+bool itree_pip_intersects(const IntervalTree *itree, const LWGEOM *lwpoints)
+				continue;
+			if (itree_point_in_multipolygon(itree, pt) != ITREE_OUTSIDE)
+				return true;
+		return false;
+	else
+		return false;
+* ST_IntersectsIntervalTree
+PG_FUNCTION_INFO_V1(ST_IntersectsIntervalTree);
+	GSERIALIZED *g1 = PG_GETARG_GSERIALIZED_P(0);
+	GSERIALIZED *g2 = PG_GETARG_GSERIALIZED_P(1);
+	LWGEOM *lwg1, *lwg2;
+	LWPOINT *lwpt;
+	bool isPoly1, isPoly2, isPt1, isPt2;
+	/* Return false on empty arguments. */
+	if (gserialized_is_empty(g1) || gserialized_is_empty(g2))
+		PG_FREE_IF_COPY(g1, 0);
+		PG_FREE_IF_COPY(g2, 1);
+		PG_RETURN_BOOL(false);
+	lwg1 = lwgeom_from_gserialized(g1);
+	lwg2 = lwgeom_from_gserialized(g2);
+	isPoly1 = lwg1->type == POLYGONTYPE || lwg1->type == MULTIPOLYGONTYPE;
+	isPoly2 = lwg2->type == POLYGONTYPE || lwg2->type == MULTIPOLYGONTYPE;
+	isPt1 = lwg1->type == POINTTYPE;
+	isPt2 = lwg2->type == POINTTYPE;
+	/* Two points? Get outa here... */
+	if (isPoly1 && isPt2)
+		itree = itree_from_lwgeom(lwg1);
+		lwpt = lwgeom_as_lwpoint(lwg2);
+	else if (isPoly2 && isPt1)
+		itree = itree_from_lwgeom(lwg2);
+		lwpt = lwgeom_as_lwpoint(lwg1);
+	if (!itree)
+		elog(ERROR, "arguments to %s must a point and a polygon", __func__);
+	PG_RETURN_BOOL(itree_point_in_multipolygon(itree, lwpt) != ITREE_OUTSIDE);
diff --git a/postgis/lwgeom_functions_analytic.h b/postgis/lwgeom_itree.h
similarity index 59%
rename from postgis/lwgeom_functions_analytic.h
rename to postgis/lwgeom_itree.h
index 79d05ec79..e46f95315 100644
--- a/postgis/lwgeom_functions_analytic.h
+++ b/postgis/lwgeom_itree.h
@@ -18,19 +18,25 @@
- * Copyright 2001-2011 Refractions Research Inc.
+ * Copyright 2024 Paul Ramsey <pramsey at cleverelephant.ca>
+#pragma once
-** Public prototypes for analytic functions.
+* Checks for a cache hit against the provided geometry and returns
+* a pre-built index structure (RTREE_POLY_CACHE) if one exists. Otherwise
+* builds a new one and returns that.
+IntervalTree * GetIntervalTree(FunctionCallInfo fcinfo, SHARED_GSERIALIZED *g1);
+bool itree_pip_intersects(const IntervalTree *itree, const LWGEOM *lwpoints);
+bool itree_pip_contains(const IntervalTree *itree, const LWGEOM *lwpoints);
+bool itree_pip_covers(const IntervalTree *itree, const LWGEOM *lwpoints);
-int point_in_polygon(LWPOLY *polygon, LWPOINT *point);
-int point_in_multipolygon(LWMPOLY *mpolygon, LWPOINT *pont);
-double determineSide(const POINT2D *seg1, const POINT2D *seg2, const POINT2D *point);
-int isOnSegment(const POINT2D *seg1, const POINT2D *seg2, const POINT2D *point);
diff --git a/postgis/lwgeom_rectree.c b/postgis/lwgeom_rectree.c
index 4927750ee..2fce4407a 100644
--- a/postgis/lwgeom_rectree.c
+++ b/postgis/lwgeom_rectree.c
@@ -174,7 +174,7 @@ Datum ST_DistanceRectTreeCached(PG_FUNCTION_ARGS)
 	if (tree_cache && tree_cache->gcache.argnum)
 		RECT_NODE *n;
-		RECT_NODE *n_cached = tree_cache->index;;
+		RECT_NODE *n_cached = tree_cache->index;
 		if (tree_cache->gcache.argnum == 1)
 			LWGEOM *lwg2 = lwgeom_from_gserialized(g2);
diff --git a/postgis/lwgeom_rtree.c b/postgis/lwgeom_rtree.c
deleted file mode 100644
index 59cc77395..000000000
--- a/postgis/lwgeom_rtree.c
+++ /dev/null
@@ -1,681 +0,0 @@
- * PostGIS - Spatial Types for PostgreSQL
- * http://postgis.net
- * PostGIS is free software: you can redistribute it and/or modify
- * it under the terms of the GNU General Public License as published by
- * the Free Software Foundation, either version 2 of the License, or
- * (at your option) any later version.
- * PostGIS is distributed in the hope that it will be useful,
- * but WITHOUT ANY WARRANTY; without even the implied warranty of
- * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
- * GNU General Public License for more details.
- * You should have received a copy of the GNU General Public License
- * along with PostGIS.  If not, see <http://www.gnu.org/licenses/>.
- * Copyright (C) 2001-2005 Refractions Research Inc.
-#include <assert.h>
-#include "../postgis_config.h"
-#include "lwgeom_pg.h"
-#include "liblwgeom.h"
-#include "liblwgeom_internal.h" /* For FP comparators. */
-#include "lwgeom_cache.h"
-/* Prototypes */
-static void RTreeFree(RTREE_NODE* root);
-* Allocate a fresh clean RTREE_POLY_CACHE
-static RTREE_POLY_CACHE*
-RTreeCacheCreate()
-	RTREE_POLY_CACHE* result;
-	result = lwalloc(sizeof(RTREE_POLY_CACHE));
-	memset(result, 0, sizeof(RTREE_POLY_CACHE));
-	return result;
-* Recursively frees the child nodes, the interval and the line before
-* freeing the root node.
-static void
-RTreeFree(RTREE_NODE* root)
-	POSTGIS_DEBUGF(2, "RTreeFree called for %p", root);
-	if (root->leftNode)
-		RTreeFree(root->leftNode);
-	if (root->rightNode)
-		RTreeFree(root->rightNode);
-	if (root->segment)
-		lwline_free(root->segment);
-	lwfree(root);
-* Free the cache object and all the sub-objects properly.
-static void
-RTreeCacheClear(RTREE_POLY_CACHE* cache)
-	int g, r, i;
-	POSTGIS_DEBUGF(2, "RTreeCacheClear called for %p", cache);
-	i = 0;
-	for (g = 0; g < cache->polyCount; g++)
-		for (r = 0; r < cache->ringCounts[g]; r++)
-			RTreeFree(cache->ringIndices[i]);
-			i++;
-	lwfree(cache->ringIndices);
-	lwfree(cache->ringCounts);
-	cache->ringIndices = 0;
-	cache->ringCounts = 0;
-	cache->polyCount = 0;
- * Returns 1 if min < value <= max, 0 otherwise.
-static uint32
-IntervalIsContained(const RTREE_INTERVAL* interval, double value)
-	return FP_CONTAINS_INCL(interval->min, value, interval->max) ? 1 : 0;
-* Creates an interval with the total extents of the two given intervals.
-static void
-RTreeMergeIntervals(
-	const RTREE_INTERVAL *inter1,
-	const RTREE_INTERVAL *inter2,
-	RTREE_INTERVAL *result)
-	result->max = FP_MAX(inter1->max, inter2->max);
-	result->min = FP_MIN(inter1->min, inter2->min);
-	return;
-* Creates an interior node given the children.
-static RTREE_NODE*
-RTreeCreateInteriorNode(RTREE_NODE* left, RTREE_NODE* right)
-	RTREE_NODE *parent;
-	POSTGIS_DEBUGF(2, "RTreeCreateInteriorNode called for children %p, %p", left, right);
-	parent = lwalloc(sizeof(RTREE_NODE));
-	parent->leftNode = left;
-	parent->rightNode = right;
-	parent->segment = NULL;
-	RTreeMergeIntervals(
-		&(left->interval), &(right->interval),
-		&(parent->interval));
-	POSTGIS_DEBUGF(3, "RTreeCreateInteriorNode returning %p", parent);
-	return parent;
-* Creates a leaf node given the pointer to the start point of the segment.
-static RTREE_NODE*
-RTreeCreateLeafNode(POINTARRAY* pa, uint32_t startPoint)
-	LWLINE *line;
-	double value1;
-	double value2;
-	POINT4D tmp;
-	POINTARRAY *npa;
-	POSTGIS_DEBUGF(2, "RTreeCreateLeafNode called for point %d of %p", startPoint, pa);
-	if (pa->npoints < startPoint + 2)
-		lwpgerror("RTreeCreateLeafNode: npoints = %d, startPoint = %d", pa->npoints, startPoint);
-	 * The given point array will be part of a geometry that will be freed
-	 * independently of the index.	Since we may want to cache the index,
-	 * we must create independent arrays.
-	npa = ptarray_construct_empty(0,0,2);
-	getPoint4d_p(pa, startPoint, &tmp);
-	value1 = tmp.y;
-	ptarray_append_point(npa,&tmp,LW_TRUE);
-	getPoint4d_p(pa, startPoint+1, &tmp);
-	value2 = tmp.y;
-	line = lwline_construct(SRID_UNKNOWN, NULL, npa);
-	parent->interval.min = FP_MIN(value1, value2);
-	parent->interval.max = FP_MAX(value1, value2);
-	parent->segment = line;
-	parent->leftNode = NULL;
-	parent->rightNode = NULL;
-	POSTGIS_DEBUGF(3, "RTreeCreateLeafNode returning %p", parent);
-	return parent;
-* Creates an rtree given a pointer to the point array.
-* Must copy the point array.
-static RTREE_NODE*
-RTreeCreate(POINTARRAY* pointArray)
-	RTREE_NODE* root;
-	RTREE_NODE** nodes = lwalloc(pointArray->npoints * sizeof(RTREE_NODE*));
-	uint32_t i, nodeCount;
-	uint32_t childNodes, parentNodes;
-	POSTGIS_DEBUGF(2, "RTreeCreate called with pointarray %p", pointArray);
-	nodeCount = pointArray->npoints - 1;
-	POSTGIS_DEBUGF(3, "Total leaf nodes: %d", nodeCount);
-	 * Create a leaf node for every line segment.
-	for (i = 0; i < nodeCount; i++)
-		nodes[i] = RTreeCreateLeafNode(pointArray, i);
-	 * Next we group nodes by pairs.  If there's an odd number of nodes,
-	 * we bring the last node up a level as is.	 Continue until we have
-	 * a single top node.
-	childNodes = nodeCount;
-	parentNodes = nodeCount / 2;
-	while (parentNodes > 0)
-		POSTGIS_DEBUGF(3, "Merging %d children into %d parents.", childNodes, parentNodes);
-		i = 0;
-		while (i < parentNodes)
-			nodes[i] = RTreeCreateInteriorNode(nodes[i*2], nodes[i*2+1]);
-			i++;
-		 * Check for an odd numbered final node.
-		if (parentNodes * 2 < childNodes)
-			POSTGIS_DEBUGF(3, "Shuffling child %d to parent %d", childNodes - 1, i);
-			nodes[i] = nodes[childNodes - 1];
-			parentNodes++;
-		childNodes = parentNodes;
-		parentNodes = parentNodes / 2;
-	root = nodes[0];
-	lwfree(nodes);
-	POSTGIS_DEBUGF(3, "RTreeCreate returning %p", root);
-	return root;
-* Merges two multilinestrings into a single multilinestring.
-static LWMLINE*
-RTreeMergeMultiLines(LWMLINE *line1, LWMLINE *line2)
-	LWGEOM **geoms;
-	LWCOLLECTION *col;
-	uint32_t i, j, ngeoms;
-	POSTGIS_DEBUGF(2, "RTreeMergeMultiLines called on %p, %d, %d; %p, %d, %d", line1, line1->ngeoms, line1->type, line2, line2->ngeoms, line2->type);
-	ngeoms = line1->ngeoms + line2->ngeoms;
-	geoms = lwalloc(sizeof(LWGEOM *) * ngeoms);
-	j = 0;
-	for (i = 0; i < line1->ngeoms; i++, j++)
-		geoms[j] = lwgeom_clone((LWGEOM *)line1->geoms[i]);
-	for (i = 0; i < line2->ngeoms; i++, j++)
-		geoms[j] = lwgeom_clone((LWGEOM *)line2->geoms[i]);
-	col = lwcollection_construct(MULTILINETYPE, SRID_UNKNOWN, NULL, ngeoms, geoms);
-	POSTGIS_DEBUGF(3, "RTreeMergeMultiLines returning %p, %d, %d", col, col->ngeoms, col->type);
-	return (LWMLINE *)col;
-* Callback function sent into the GetGeomCache generic caching system. Given a
-* LWGEOM* this function builds and stores an RTREE_POLY_CACHE into the provided
-* GeomCache object.
-static int
-RTreeBuilder(const LWGEOM* lwgeom, GeomCache* cache)
-	uint32_t i, p, r;
-	LWMPOLY *mpoly;
-	LWPOLY *poly;
-	int nrings;
-	RTreeGeomCache* rtree_cache = (RTreeGeomCache*)cache;
-	RTREE_POLY_CACHE* currentCache;
-	if ( ! cache )
-		return LW_FAILURE;
-	if ( rtree_cache->index )
-		lwpgerror("RTreeBuilder asked to build index where one already exists.");
-	if (lwgeom->type == MULTIPOLYGONTYPE)
-		POSTGIS_DEBUG(2, "RTreeBuilder MULTIPOLYGON");
-		mpoly = (LWMPOLY *)lwgeom;
-		nrings = 0;
-		** Count the total number of rings.
-		currentCache = RTreeCacheCreate();
-		currentCache->polyCount = mpoly->ngeoms;
-		currentCache->ringCounts = lwalloc(sizeof(int) * mpoly->ngeoms);
-		for ( i = 0; i < mpoly->ngeoms; i++ )
-			currentCache->ringCounts[i] = mpoly->geoms[i]->nrings;
-			nrings += mpoly->geoms[i]->nrings;
-		currentCache->ringIndices = lwalloc(sizeof(RTREE_NODE *) * nrings);
-		** Load the array in geometry order, each outer ring followed by the inner rings
-		** associated with that outer ring
-		i = 0;
-		for ( p = 0; p < mpoly->ngeoms; p++ )
-			for ( r = 0; r < mpoly->geoms[p]->nrings; r++ )
-				currentCache->ringIndices[i] = RTreeCreate(mpoly->geoms[p]->rings[r]);
-				i++;
-		rtree_cache->index = currentCache;
-	else if ( lwgeom->type == POLYGONTYPE )
-		POSTGIS_DEBUG(2, "RTreeBuilder POLYGON");
-		poly = (LWPOLY *)lwgeom;
-		currentCache->polyCount = 1;
-		currentCache->ringCounts = lwalloc(sizeof(int));
-		currentCache->ringCounts[0] = poly->nrings;
-		** Just load the rings on in order
-		currentCache->ringIndices = lwalloc(sizeof(RTREE_NODE *) * poly->nrings);
-		for ( i = 0; i < poly->nrings; i++ )
-			currentCache->ringIndices[i] = RTreeCreate(poly->rings[i]);
-	else
-		/* Uh oh, shouldn't be here. */
-		lwpgerror("RTreeBuilder got asked to build index on non-polygon");
-	return LW_SUCCESS;
-* Callback function sent into the GetGeomCache generic caching system. On a
-* cache miss, this function clears the cached index object.
-static int
-RTreeFreer(GeomCache* cache)
-	if ( ! cache )
-		RTreeCacheClear(rtree_cache->index);
-		lwfree(rtree_cache->index);
-		rtree_cache->index = 0;
-		rtree_cache->gcache.argnum = 0;
-static GeomCache*
-RTreeAllocator(void)
-	RTreeGeomCache* cache = palloc(sizeof(RTreeGeomCache));
-	memset(cache, 0, sizeof(RTreeGeomCache));
-	return (GeomCache*)cache;
-static GeomCacheMethods RTreeCacheMethods =
-	RTREE_CACHE_ENTRY,
-	RTreeBuilder,
-	RTreeFreer,
-	RTreeAllocator
-RTREE_POLY_CACHE *
-GetRtreeCache(FunctionCallInfo fcinfo, SHARED_GSERIALIZED *g1)
-	RTreeGeomCache* cache = (RTreeGeomCache*)GetGeomCache(fcinfo, &RTreeCacheMethods, g1, NULL);
-	RTREE_POLY_CACHE* index = NULL;
-	if ( cache )
-		index = cache->index;
-	return index;
-* Retrieves a collection of line segments given the root and crossing value.
-* The collection is a multilinestring consisting of two point lines
-* representing the segments of the ring that may be crossed by the
-* horizontal projection line at the given y value.
-LWMLINE *RTreeFindLineSegments(RTREE_NODE *root, double value)
-	LWMLINE *tmp, *result;
-	LWGEOM **lwgeoms;
-	POSTGIS_DEBUGF(2, "RTreeFindLineSegments called for tree %p and value %8.3f", root, value);
-	result = NULL;
-	if (!IntervalIsContained(&(root->interval), value))
-		POSTGIS_DEBUGF(3, "RTreeFindLineSegments %p: not contained.", root);
-		return NULL;
-	/* If there is a segment defined for this node, include it. */
-		POSTGIS_DEBUGF(3, "RTreeFindLineSegments %p: adding segment %p %d.", root, root->segment, root->segment->type);
-		lwgeoms = lwalloc(sizeof(LWGEOM *));
-		lwgeoms[0] = (LWGEOM *)root->segment;
-		POSTGIS_DEBUGF(3, "Found geom %p, type %d, dim %d", root->segment, root->segment->type, lwgeom_ndims((LWGEOM *)(root->segment)));
-		result = (LWMLINE *)lwcollection_construct(MULTILINETYPE, SRID_UNKNOWN, NULL, 1, lwgeoms);
-	/* If there is a left child node, recursively include its results. */
-		POSTGIS_DEBUGF(3, "RTreeFindLineSegments %p: recursing left.", root);
-		tmp = RTreeFindLineSegments(root->leftNode, value);
-		if (tmp)
-			POSTGIS_DEBUGF(3, "Found geom %p, type %d, dim %d", tmp, tmp->type, lwgeom_ndims((LWGEOM *)tmp));
-			if (result)
-				result = RTreeMergeMultiLines(result, tmp);
-			else
-				result = tmp;
-	/* Same for any right child. */
-		POSTGIS_DEBUGF(3, "RTreeFindLineSegments %p: recursing right.", root);
-		tmp = RTreeFindLineSegments(root->rightNode, value);
-		if (tmp)
-			if (result)
-			else
-				result = tmp;
-	return result;
-static int point_in_ring_rtree(RTREE_NODE *root, const POINT2D *point)
-	int wn = 0;
-	uint32_t i;
-	double side;
-	const POINT2D *seg1;
-	const POINT2D *seg2;
-	LWMLINE *lines;
-	lines = RTreeFindLineSegments(root, point->y);
-	if (!lines)
-		return -1;
-	for (i=0; i<lines->ngeoms; i++)
-		seg1 = getPoint2d_cp(lines->geoms[i]->points, 0);
-		seg2 = getPoint2d_cp(lines->geoms[i]->points, 1);
-		if (((seg2->x - seg1->x)*(seg2->x - seg1->x) + (seg2->y - seg1->y)*(seg2->y - seg1->y)) < 1e-12*1e-12)
-			continue;
-		if (side == 0.0)
-				return 0;
-			++wn;
-			--wn;
-	if (wn == 0)
-		return -1;
-	return 1;
- * return -1 if point outside polygon
- * return 0 if point on boundary
- * return 1 if point inside polygon
- * Expected **root order is each exterior ring followed by its holes, eg. EIIEIIEI
-static int
-point_in_multipolygon_rtree(RTREE_NODE **root, int polyCount, int *ringCounts, LWPOINT *point)
-	int i, p, r, in_ring;
-	const POINT2D *pt;
-	int result = -1;
-	POSTGIS_DEBUGF(2, "point_in_multipolygon_rtree called for %p %d %p.", root, polyCount, point);
-	pt = getPoint2d_cp(point->point, 0);
-	i = 0; /* the current index into the root array */
-	/* is the point inside any of the sub-polygons? */
-	for ( p = 0; p < polyCount; p++ )
-		/* Skip empty polygons */
-		if( ringCounts[p] == 0 ) continue;
-		in_ring = point_in_ring_rtree(root[i], pt);
-		POSTGIS_DEBUGF(4, "point_in_multipolygon_rtree: exterior ring (%d), point_in_ring returned %d", p, in_ring);
-		if ( in_ring == -1 ) /* outside the exterior ring */
-			POSTGIS_DEBUG(3, "point_in_multipolygon_rtree: outside exterior ring.");
-		else if ( in_ring == 0 ) /* on the boundary */
-			POSTGIS_DEBUGF(3, "point_in_multipolygon_rtree: on edge of exterior ring %d", p);
-			return 0;
-		else
-			result = in_ring;
-			for(r = 1; r < ringCounts[p]; r++)
-				in_ring = point_in_ring_rtree(root[i+r], pt);
-				POSTGIS_DEBUGF(4, "point_in_multipolygon_rtree: interior ring (%d), point_in_ring returned %d", r, in_ring);
-					POSTGIS_DEBUGF(3, "point_in_multipolygon_rtree: within hole %d of exterior ring %d", r, p);
-					result = -1;
-					break;
-					POSTGIS_DEBUGF(3, "point_in_multipolygon_rtree: on edge of hole %d of exterior ring %d", r, p);
-					return 0;
-			/* if we have a positive result, we can short-circuit and return it */
-			if (result != -1)
-				return result;
-		/* increment the index by the total number of rings in the sub-poly */
-		/* we do this here in case we short-cutted out of the poly before looking at all the rings */
-		i += ringCounts[p];
-/* Utility function that checks a LWPOINT and a GSERIALIZED poly against a cache.
- * Serialized poly may be a multipart.
-int
-pip_short_circuit(RTREE_POLY_CACHE *poly_cache, LWPOINT *point, const GSERIALIZED *gpoly)
-	int result;
-	if (poly_cache && poly_cache->ringIndices)
-		result = point_in_multipolygon_rtree(poly_cache->ringIndices, poly_cache->polyCount, poly_cache->ringCounts, point);
-	else
-		LWGEOM* poly = lwgeom_from_gserialized(gpoly);
-		if (lwgeom_get_type(poly) == POLYGONTYPE)
-			result = point_in_polygon(lwgeom_as_lwpoly(poly), point);
-		else
-			result = point_in_multipolygon(lwgeom_as_lwmpoly(poly), point);
-		lwgeom_free(poly);
-	return result;
diff --git a/postgis/lwgeom_rtree.h b/postgis/lwgeom_rtree.h
index 41db74aae..000000000
--- a/postgis/lwgeom_rtree.h
+++ /dev/null
@@ -1,87 +0,0 @@
- * ^copyright^
-#ifndef _LWGEOM_RTREE_H
-#define _LWGEOM_RTREE_H 1
-* Representation for the y-axis interval spanned by an edge.
-typedef struct
-	double min;
-	double max;
-RTREE_INTERVAL;
-* The following struct and methods are used for a 1D RTree implementation,
-* described at:
-*  http://lin-ear-th-inking.blogspot.com/2007/06/packed-1-dimensional-r-tree.html
-typedef struct rtree_node
-	RTREE_INTERVAL interval;
-	struct rtree_node *leftNode;
-	struct rtree_node *rightNode;
-	LWLINE *segment;
-RTREE_NODE;
-* The tree structure used for fast P-i-P tests by point_in_multipolygon_rtree()
-typedef struct
-	RTREE_NODE **ringIndices;
-	int* ringCounts;
-	int polyCount;
-} RTREE_POLY_CACHE;
-typedef struct
-	GeomCache             gcache;
-	RTREE_POLY_CACHE      *index;
-} RTreeGeomCache;
-LWMLINE *RTreeFindLineSegments(RTREE_NODE *root, double value);
-* Checks for a cache hit against the provided geometry and returns
-* a pre-built index structure (RTREE_POLY_CACHE) if one exists. Otherwise
-* builds a new one and returns that.
-RTREE_POLY_CACHE *GetRtreeCache(FunctionCallInfo fcinfo, SHARED_GSERIALIZED *g1);
-int pip_short_circuit(RTREE_POLY_CACHE *poly_cache, LWPOINT *point, const GSERIALIZED *gpoly);
-#endif /* !defined _LWGEOM_RTREE_H */
Summary of changes:
 NEWS                                               |   1 +
 liblwgeom/Makefile.in                              |   2 +
 liblwgeom/cunit/cu_tree.c                          | 191 ++++++
 liblwgeom/intervaltree.c                           | 530 ++++++++++++++++
 liblwgeom/intervaltree.h                           |  76 +++
 liblwgeom/liblwgeom_internal.h                     |   1 +
 liblwgeom/lwutil.c                                 |  10 +-
 liblwgeom/ptarray.c                                |  12 +-
 libpgcommon/lwgeom_cache.c                         |   2 +-
 libpgcommon/lwgeom_cache.h                         |  24 +-
 postgis/Makefile.in                                |   9 +-
 postgis/lwgeom_functions_analytic.c                | 267 +-------
 postgis/lwgeom_geos.c                              | 242 ++------
 postgis/lwgeom_geos_prepared.h                     |  43 +-
 postgis/lwgeom_itree.c                             | 292 +++++++++
 ...{lwgeom_functions_analytic.h => lwgeom_itree.h} |  22 +-
 postgis/lwgeom_rectree.c                           |   2 +-
 postgis/lwgeom_rtree.c                             | 681 ---------------------
 postgis/lwgeom_rtree.h                             |  87 ---
 19 files changed, 1200 insertions(+), 1294 deletions(-)
 create mode 100644 liblwgeom/intervaltree.c
 create mode 100644 liblwgeom/intervaltree.h
 create mode 100644 postgis/lwgeom_itree.c
 rename postgis/{lwgeom_functions_analytic.h => lwgeom_itree.h} (59%)
 delete mode 100644 postgis/lwgeom_rtree.c
 delete mode 100644 postgis/lwgeom_rtree.h
hooks/post-receive
