[PostGIS] #5567: Mark PostGIS extensions as trusted ( PG13+ )
PostGIS trac at osgeo.org
Fri Jan 19 17:03:57 PST 2024
  Reporter:  strk         |      Owner:  strk
      Type:  enhancement  |     Status:  new
  Priority:  medium       |  Milestone:  PostGIS 3.5.0
 Component:  postgis      |    Version:  master
Resolution:               |   Keywords:
Comment (by rouault):
 https://www.postgresql.org/docs/13/extend-extensions.html mentions
 "Generally, this should not be set true for extensions that could allow
 access to otherwise-superuser-only abilities, such as file system access."
 So obviously you don't want postgis_raster to be trusted (at least when
 out_db support is enabled). But even regular postgis can access files like
 using ST_Transform() with a PROJ.4 string using +nadgrids=/some/path .
 ST_TransformPipeline() can also use various PROJ operations that load
 grids or JSON files.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5567#comment:6>
