[SCM] PostGIS branch master updated. 3.4.0rc1-892-gc72cdb44b
Mon Jan 22 13:58:10 PST 2024
the project "PostGIS".
       via  c72cdb44b4fae8c39a6fdad87da51f353da03371 (commit)
      from  b4e7b5736a799546b491213333d55a6841396234 (commit)
revisions in full, below.
commit c72cdb44b4fae8c39a6fdad87da51f353da03371
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Jan 22 13:57:59 2024 -0800
    Revert change to max distance, as it does not conform to original understanding of the function (max distance between points in the pairing), references #5639
diff --git a/liblwgeom/measures.c b/liblwgeom/measures.c
index 240b39bc6..b22b2cca1 100644
--- a/liblwgeom/measures.c
+++ b/liblwgeom/measures.c
@@ -238,17 +238,6 @@ lw_dist2d_comp(const LWGEOM *lw1, const LWGEOM *lw2, DISTPTS *dl)
 	return lw_dist2d_recursive(lw1, lw2, dl);
-static int
-lw_dist2d_zero(DISTPTS *dl, const POINT2D *pt1, const POINT2D *pt2)
-	dl->distance = 0.0;
-	if (pt1)
-		dl->p1 = *pt1;
-	if (pt2)
-		dl->p2 = *pt2;
-	return LW_TRUE;
 static int
 lw_dist2d_is_collection(const LWGEOM *g)
@@ -653,6 +642,10 @@ lw_dist2d_point_poly(LWPOINT *point, LWPOLY *poly, DISTPTS *dl)
 	const POINT2D *p = getPoint2d_cp(point->point, 0);
+	/* Max distance? Check only outer ring.*/
+	if (dl->mode == DIST_MAX)
+		return lw_dist2d_pt_ptarray(p, poly->rings[0], dl);
 	/* Return distance to outer ring if not inside it */
 	if (ptarray_contains_point(poly->rings[0], p) == LW_OUTSIDE)
@@ -668,7 +661,10 @@ lw_dist2d_point_poly(LWPOINT *point, LWPOLY *poly, DISTPTS *dl)
 			return lw_dist2d_pt_ptarray(p, poly->rings[i], dl);
 	/* Is inside the polygon */
-	return lw_dist2d_zero(dl, p, p);
+	dl->distance = 0.0;
+	dl->p1.x = dl->p2.x = p->x;
+	dl->p1.y = dl->p2.y = p->y;
+	return LW_TRUE;
 int
@@ -766,7 +762,12 @@ lw_dist2d_line_poly(LWLINE *line, LWPOLY *poly, DISTPTS *dl)
 	/* Not in hole, so inside polygon */
 	if (dl->mode == DIST_MIN)
+		dl->p1.x = dl->p2.x = pt->x;
+		dl->p1.y = dl->p2.y = pt->y;
+	return LW_TRUE;
 int
Summary of changes:
 liblwgeom/measures.c | 27 ++++++++++++++-------------
 1 file changed, 14 insertions(+), 13 deletions(-)
hooks/post-receive
